[MOAB-dev] commit/MOAB: danwu: Updated NC reader/writer with some minor changes to existing error handling code.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Fri Jun 27 14:06:44 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/b77f786ac429/
Changeset:   b77f786ac429
Branch:      master
User:        danwu
Date:        2014-06-27 21:06:26
Summary:     Updated NC reader/writer with some minor changes to existing error handling code.
Affected #:  12 files
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 8a1b91e..92cad43 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -215,7 +215,7 @@ ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
   // <PARTITION_METHOD>
   Tag part_tag = scdi->part_method_tag();
   if (!part_tag)
-    ERRORR(MB_FAILURE, "Trouble getting partition method tag.");
+    ERRORR(MB_FAILURE, "Trouble getting PARTITION_METHOD tag.");
   rval = mbImpl->tag_set_data(part_tag, &_fileSet, 1, &partMethod);
   ERRORR(rval, "Trouble setting data for PARTITION_METHOD tag.");
   if (MB_SUCCESS == rval)
@@ -229,7 +229,7 @@ ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
   std::string gattVal;
   std::vector<int> gattLen;
   rval = create_attrib_string(globalAtts, gattVal, gattLen);
-  ERRORR(rval, "Trouble creating attribute strings.");
+  ERRORR(rval, "Trouble creating global attribute string.");
   const void* gattptr = gattVal.c_str();
   int globalAttSz = gattVal.size();
   rval = mbImpl->tag_set_by_ptr(globalAttTag, &_fileSet, 1, &gattptr, &globalAttSz);
@@ -424,7 +424,7 @@ ErrorCode NCHelper::read_variables_setup(std::vector<std::string>& var_names, st
           vdatas.push_back(vd);
       else {
-        ERRORR(MB_FAILURE, "Couldn't find variable.");
+        ERRORR(MB_FAILURE, "Couldn't find specified variable.");
@@ -470,7 +470,7 @@ ErrorCode NCHelper::read_variables_to_set(std::vector<ReadNC::VarData>& vdatas,
   DebugOutput& dbgOut = _readNC->dbgOut;
   ErrorCode rval = read_variables_to_set_allocate(vdatas, tstep_nums);
-  ERRORR(rval, "Trouble allocating read variables to set.");
+  ERRORR(rval, "Trouble allocating space to read set variables.");
   // Finally, read into that space
   int success;
@@ -505,12 +505,9 @@ ErrorCode NCHelper::read_variables_to_set(std::vector<ReadNC::VarData>& vdatas,
           ERRORS(success, "Failed to read double data.");
           break;
         default:
-          success = 1;
+          ERRORR(MB_FAILURE, "Unexpected variable data type.");
-      if (success)
-        ERRORR(MB_FAILURE, "Trouble reading variable.");
       dbgOut.tprintf(2, "Setting data for variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t]);
       rval = mbImpl->tag_set_by_ptr(vdatas[i].varTags[t], &_fileSet, 1, &data, &vdatas[i].sz);
       ERRORR(rval, "Failed to set data for variable.");
@@ -562,7 +559,7 @@ ErrorCode NCHelper::read_coordinate(const char* var_name, int lmin, int lmax, st
   NCDF_SIZE tstart = lmin;
   NCDF_SIZE tcount = lmax - lmin + 1;
   NCDF_DIFF dum_stride = 1;
-  int fail;
+  int success;
   // Check size
   if ((std::size_t)tcount != cvals.size())
@@ -570,19 +567,17 @@ ErrorCode NCHelper::read_coordinate(const char* var_name, int lmin, int lmax, st
   // Check to make sure it's a float or double
   if (NC_DOUBLE == (*vmit).second.varDataType) {
-    fail = NCFUNCAG(_vars_double)(_fileId, (*vmit).second.varId, &tstart, &tcount, &dum_stride, &cvals[0]);
-    if (fail)
-      ERRORS(MB_FAILURE, "Failed to get coordinate values.");
+    success = NCFUNCAG(_vars_double)(_fileId, (*vmit).second.varId, &tstart, &tcount, &dum_stride, &cvals[0]);
+    ERRORS(success, "Failed to get coordinate values.");
   else if (NC_FLOAT == (*vmit).second.varDataType) {
     std::vector<float> tcvals(tcount);
-    fail = NCFUNCAG(_vars_float)(_fileId, (*vmit).second.varId, &tstart, &tcount, &dum_stride, &tcvals[0]);
-    if (fail)
+    success = NCFUNCAG(_vars_float)(_fileId, (*vmit).second.varId, &tstart, &tcount, &dum_stride, &tcvals[0]);
     std::copy(tcvals.begin(), tcvals.end(), cvals.begin());
   else {
-    ERRORR(MB_FAILURE, "Wrong data type for coordinate variable.");
+    ERRORR(MB_FAILURE, "Unexpected coordinate variable data type.");
   return MB_SUCCESS;
@@ -619,8 +614,7 @@ ErrorCode NCHelper::get_tag_to_set(ReadNC::VarData& var_data, int tstep_num, Tag
       rval = mbImpl->tag_get_handle(tag_name.str().c_str(), 0, MB_TYPE_DOUBLE, tagh, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
       break;
     default:
-      std::cerr << "Unrecognized data type for tag " << tag_name << std::endl;
-      rval = MB_FAILURE;
@@ -657,8 +651,7 @@ ErrorCode NCHelper::get_tag_to_nonset(ReadNC::VarData& var_data, int tstep_num,
       rval = mbImpl->tag_get_handle(tag_name.str().c_str(), num_lev, MB_TYPE_DOUBLE, tagh, MB_TAG_DENSE | MB_TAG_CREAT);
       break;
     default:
-      std::cerr << "Unrecognized data type for tag " << tag_name.str() << std::endl;
@@ -715,7 +708,7 @@ ErrorCode NCHelper::create_attrib_string(const std::map<std::string, ReadNC::Att
         ssAtt << "double;";
         break;
       default:
-        success = 1;
+        ERRORR(MB_FAILURE, "Unexpected attribute data type.");
     char* tmpc = (char *) attData;
     for (unsigned int counter = 0; counter != sz; ++counter)
@@ -846,8 +839,7 @@ ErrorCode NCHelper::read_variables_to_set_allocate(std::vector<ReadNC::VarData>&
           vdatas[i].varDatas[t] = new double[vdatas[i].sz];
           break;
         default:
-          std::cerr << "Unrecognized data type for set variable tag values" << std::endl;
       // Loop continues only for set variables with timesteps, e.g. xtime(Time) or xtime(Time, StrLen)
@@ -949,7 +941,7 @@ ErrorCode ScdNCHelper::create_mesh(Range& faces)
   int djl = lDims[4] - lDims[1] + 1;
   assert(dil == (int)ilVals.size() && djl == (int)jlVals.size() &&
       (-1 == lDims[2] || lDims[5] - lDims[2] + 1 == (int)levVals.size()));
-//#define INDEX(i, j, k) ()
   for (kl = lDims[2]; kl <= lDims[5]; kl++) {
     k = kl - lDims[2];
     for (jl = lDims[1]; jl <= lDims[4]; jl++) {
@@ -963,7 +955,6 @@ ErrorCode ScdNCHelper::create_mesh(Range& faces)
-//#undef INDEX
 #ifndef NDEBUG
   int num_verts = (lDims[3] - lDims[0] + 1) * (lDims[4] - lDims[1] + 1) * (-1 == lDims[2] ? 1 : lDims[5] - lDims[2] + 1);
@@ -1033,21 +1024,21 @@ ErrorCode ScdNCHelper::read_scd_variables_to_nonset_allocate(std::vector<ReadNC:
   Range* range = NULL;
-  // Get vertices in set
+  // Get vertices
   Range verts;
   rval = mbImpl->get_entities_by_dimension(_fileSet, 0, verts);
-  ERRORR(rval, "Trouble getting vertices in set.");
+  ERRORR(rval, "Trouble getting vertices in current file set.");
   assert("Should only have a single vertex subrange, since they were read in one shot" &&
       verts.psize() == 1);
   Range edges;
   rval = mbImpl->get_entities_by_dimension(_fileSet, 1, edges);
-  ERRORR(rval, "Trouble getting edges in set.");
+  ERRORR(rval, "Trouble getting edges in current file set.");
-  // Get faces in set
+  // Get faces
   Range faces;
   rval = mbImpl->get_entities_by_dimension(_fileSet, 2, faces);
-  ERRORR(rval, "Trouble getting faces in set.");
+  ERRORR(rval, "Trouble getting faces in current file set.");
   assert("Should only have a single face subrange, since they were read in one shot" &&
       faces.psize() == 1);
@@ -1057,7 +1048,7 @@ ErrorCode ScdNCHelper::read_scd_variables_to_nonset_allocate(std::vector<ReadNC:
   if (isParallel) {
     ParallelComm*& myPcomm = _readNC->myPcomm;
     rval = myPcomm->filter_pstatus(faces, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &faces_owned);
-    ERRORR(rval, "Trouble getting owned faces in set.");
+    ERRORR(rval, "Trouble getting owned faces in current file set.");
   else
     faces_owned = faces; // Not running in parallel, but still with MPI
@@ -1093,10 +1084,9 @@ ErrorCode ScdNCHelper::read_scd_variables_to_nonset_allocate(std::vector<ReadNC:
         range = &verts;
         break;
       case ReadNC::ENTLOCNSEDGE:
-        ERRORR(MB_FAILURE, "Reading edge data not implemented yet.");
-        break;
       case ReadNC::ENTLOCEWEDGE:
+      case ReadNC::ENTLOCEDGE:
+        ERRORR(MB_NOT_IMPLEMENTED, "Reading edge data not implemented yet.");
         break;
       case ReadNC::ENTLOCFACE:
         // Faces
@@ -1110,12 +1100,8 @@ ErrorCode ScdNCHelper::read_scd_variables_to_nonset_allocate(std::vector<ReadNC:
         range = &faces;
 #endif
         break;
-      case ReadNC::ENTLOCSET:
-        // Set
-        break;
       default:
-        ERRORR(MB_FAILURE, "Unrecognized entity location type.");
-        break;
+        ERRORR(MB_FAILURE, "Unexpected entity location type.");
     for (unsigned int t = 0; t < tstep_nums.size(); t++) {
@@ -1154,7 +1140,7 @@ ErrorCode ScdNCHelper::read_scd_variables_to_nonset(std::vector<ReadNC::VarData>
   ErrorCode rval = read_scd_variables_to_nonset_allocate(vdatas, tstep_nums);
-  ERRORR(rval, "Trouble allocating read variables.");
+  ERRORR(rval, "Trouble allocating space to read non-set variables.");
   int success;
@@ -1221,11 +1207,8 @@ ErrorCode ScdNCHelper::read_scd_variables_to_nonset(std::vector<ReadNC::VarData>
           break;
         default:
-          success = 1;
-      if (success)
diff --git a/src/io/NCHelper.hpp b/src/io/NCHelper.hpp
index 44d93b7..36f40f1 100644
--- a/src/io/NCHelper.hpp
+++ b/src/io/NCHelper.hpp
@@ -206,7 +206,7 @@ private:
 protected:
   //! This version takes as input the moab range, from which we actually need just the
   //! size of each sequence, for a proper transpose of the data
-  template <typename T> ErrorCode kji_to_jik_stride(size_t , size_t nj, size_t nk, void* dest, T* source, Range& localGid)
+  template <typename T> void kji_to_jik_stride(size_t , size_t nj, size_t nk, void* dest, T* source, Range& localGid)
     std::size_t idxInSource = 0; // Position of the start of the stride
     // For each subrange, we will transpose a matrix of size
@@ -222,7 +222,6 @@ protected:
             tmp_data[idxInSource + j*nik + i*nk + k] = source[idxInSource + k*nij + j*size_range + i];
       idxInSource += (size_range*nj*nk);
-    return MB_SUCCESS;
   //! Dimensions of global grid in file
diff --git a/src/io/NCHelperEuler.cpp b/src/io/NCHelperEuler.cpp
index 1f1e7a3..b2aa378 100644
--- a/src/io/NCHelperEuler.cpp
+++ b/src/io/NCHelperEuler.cpp
@@ -383,7 +383,7 @@ ErrorCode NCHelperEuler::init_mesh_vals()
     case NC_DOUBLE:
       break;
     default:
-      ERRORR(MB_FAILURE, "Unexpected data type for coordinate variable 'lon'");
+      ERRORR(MB_FAILURE, "Unexpected variable data type for 'lon'");
   for (unsigned int i = 0; i != ijdimNames.size(); i++) {
diff --git a/src/io/NCHelperFV.cpp b/src/io/NCHelperFV.cpp
index a26ebe6..5f847e2 100644
--- a/src/io/NCHelperFV.cpp
+++ b/src/io/NCHelperFV.cpp
@@ -384,7 +384,7 @@ ErrorCode NCHelperFV::init_mesh_vals()
     case NC_DOUBLE:
       break;
     default:
diff --git a/src/io/NCHelperGCRM.cpp b/src/io/NCHelperGCRM.cpp
index d0bd7e3..f790736 100644
--- a/src/io/NCHelperGCRM.cpp
+++ b/src/io/NCHelperGCRM.cpp
@@ -179,19 +179,17 @@ ErrorCode NCHelperGCRM::check_existing_mesh()
     ErrorCode rval;
     if (localGidVerts.empty()) {
-      // Get all vertices from tmp_set (it is the input set in no_mesh scenario)
+      // Get all vertices from current file set (it is the input set in no_mesh scenario)
       Range local_verts;
       rval = mbImpl->get_entities_by_dimension(_fileSet, 0, local_verts);
-      if (MB_FAILURE == rval)
-        return rval;
+      ERRORR(rval, "Trouble getting local vertices in current file set.");
       if (!local_verts.empty()) {
         std::vector<int> gids(local_verts.size());
         // !IMPORTANT : this has to be the GLOBAL_ID tag
         rval = mbImpl->tag_get_data(mGlobalIdTag, local_verts, &gids[0]);
-          return rval;
+        ERRORR(rval, "Trouble getting local gid values of vertices.");
         // Restore localGidVerts
         std::copy(gids.rbegin(), gids.rend(), range_inserter(localGidVerts));
@@ -200,19 +198,17 @@ ErrorCode NCHelperGCRM::check_existing_mesh()
     if (localGidEdges.empty()) {
-      // Get all edges from _fileSet (it is the input set in no_mesh scenario)
+      // Get all edges from current file set (it is the input set in no_mesh scenario)
       Range local_edges;
       rval = mbImpl->get_entities_by_dimension(_fileSet, 1, local_edges);
-        return rval;
+      ERRORR(rval, "Trouble getting local edges in current file set.");
       if (!local_edges.empty()) {
         std::vector<int> gids(local_edges.size());
         rval = mbImpl->tag_get_data(mGlobalIdTag, local_edges, &gids[0]);
-          return rval;
+        ERRORR(rval, "Trouble getting local gid values of edges.");
         // Restore localGidEdges
         std::copy(gids.rbegin(), gids.rend(), range_inserter(localGidEdges));
@@ -221,19 +217,17 @@ ErrorCode NCHelperGCRM::check_existing_mesh()
     if (localGidCells.empty()) {
-      // Get all cells from tmp_set (it is the input set in no_mesh scenario)
+      // Get all cells from current file set (it is the input set in no_mesh scenario)
       Range local_cells;
       rval = mbImpl->get_entities_by_dimension(_fileSet, 2, local_cells);
-        return rval;
+      ERRORR(rval, "Trouble getting local cells in current file set.");
       if (!local_cells.empty()) {
         std::vector<int> gids(local_cells.size());
         rval = mbImpl->tag_get_data(mGlobalIdTag, local_cells, &gids[0]);
-          return rval;
+        ERRORR(rval, "Trouble getting local gid values of cells.");
         // Restore localGidCells
         std::copy(gids.rbegin(), gids.rend(), range_inserter(localGidCells));
@@ -333,7 +327,7 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
     success = NCFUNCAG(_vara_int)(_fileId, verticesOnCellVarId, read_starts, read_counts,
                                       &(vertices_on_local_cells[indexInArray]));
 #endif
-    ERRORS(success, "Failed to read cell_corners data in a loop");
+    ERRORS(success, "Failed to read cell_corners data in a loop.");
     // Increment the index for next subrange
     indexInArray += (endh - starth + 1) * EDGES_PER_CELL;
@@ -414,22 +408,22 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC
+  // Get vertices
   Range verts;
-  // Get edges in set
+  // Get edges
   Range edges;
+  // Get faces
   Range faces;
   // Note, for GCRM faces.psize() can be more than 1
 #ifdef USE_MPI
@@ -437,7 +431,7 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC
   if (isParallel) {
     rval = myPcomm->filter_pstatus(faces, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &facesOwned);
   else
     facesOwned = faces; // not running in parallel, but still with MPI
@@ -492,8 +486,7 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC
         range = &edges;
         break;
       default:
-        ERRORR(MB_FAILURE, "Unexpected entity location type for GCRM non-set variable.");
-        break;
     // Finally: layers or other optional levels, it is possible that there is no
@@ -542,7 +535,7 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
   ErrorCode rval = read_ucd_variables_to_nonset_allocate(vdatas, tstep_nums);
   int success;
@@ -564,8 +557,7 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
         pLocalGid = &localGidEdges;
         break;
       default:
-        break;
     std::size_t sz = vdatas[i].sz;
@@ -581,16 +573,6 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
       vdatas[i].readStarts[0] = tstep_nums[t];
       switch (vdatas[i].varDataType) {
-        case NC_BYTE:
-        case NC_CHAR: {
-          ERRORR(MB_FAILURE, "not implemented");
-          break;
-        case NC_SHORT:
-        case NC_INT: {
-          break;
         case NC_FLOAT:
         case NC_DOUBLE: {
           // Read float as double
@@ -616,7 +598,7 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
             success = NCFUNCREQG(_vara_double)(_fileId, vdatas[i].varId,
                 &(vdatas[i].readStarts[0]), &(vdatas[i].readCounts[0]),
                             &(tmpdoubledata[indexInDoubleArray]), &requests[idxReq++]);
-            ERRORS(success, "Failed to read double data in loop");
+            ERRORS(success, "Failed to read double data in a loop.");
             // We need to increment the index in double array for the
             // next subrange
             indexInDoubleArray += (endh - starth + 1) * 1 * vdatas[i].numLev;
@@ -633,11 +615,8 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
           break;
         default:
-          success = 1;
-      if (success)
@@ -658,7 +637,7 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
   int success;
@@ -680,8 +659,7 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
         break;
       default:
-        break;
@@ -691,16 +669,6 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
-        case NC_BYTE:
-        case NC_CHAR: {
-          break;
-        case NC_SHORT:
-        case NC_INT: {
-          break;
         case NC_FLOAT:
         case NC_DOUBLE: {
@@ -724,7 +692,7 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
             success = NCFUNCAG(_vara_double)(_fileId, vdatas[i].varId,
                             &(tmpdoubledata[indexInDoubleArray]));
             // next subrange
@@ -738,11 +706,8 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
           break;
         default:
-          success = 1;
-      if (success)
@@ -844,10 +809,10 @@ ErrorCode NCHelperGCRM::create_local_vertices(const std::vector<int>& vertices_o
                                                           (createGatherSet ? nLocalVertices + nVertices : nLocalVertices));
   ERRORR(rval, "Failed to create local vertices.");
-  // Add local vertices to the file set
+  // Add local vertices to current file set
   Range local_verts_range(start_vertex, start_vertex + nLocalVertices - 1);
   rval = _readNC->mbImpl->add_entities(_fileSet, local_verts_range);
-  ERRORR(rval, "Failed to add local vertices to the file set.");
+  ERRORR(rval, "Failed to add local vertices to current file set.");
   // Get ptr to GID memory for local vertices
   int count = 0;
@@ -918,7 +883,7 @@ ErrorCode NCHelperGCRM::create_local_vertices(const std::vector<int>& vertices_o
     success = NCFUNCAG(_vara_double)(_fileId, xVertexVarId, &read_start, &read_count,
                                       &(xptr[indexInArray]));
 #endif
-    ERRORS(success, "Failed to read grid_corner_lon data in a loop");
+    ERRORS(success, "Failed to read grid_corner_lon data in a loop.");
     indexInArray += (endh - starth + 1);
@@ -955,7 +920,7 @@ ErrorCode NCHelperGCRM::create_local_vertices(const std::vector<int>& vertices_o
     success = NCFUNCAG(_vara_double)(_fileId, yVertexVarId, &read_start, &read_count,
                                       &(yptr[indexInArray]));
 #endif
-    ERRORS(success, "Failed to read grid_corner_lat data in a loop");
+    ERRORS(success, "Failed to read grid_corner_lat data in a loop.");
@@ -1022,7 +987,7 @@ ErrorCode NCHelperGCRM::create_local_edges(EntityHandle start_vertex)
     success = NCFUNCAG(_vara_int)(_fileId, edgesOnCellVarId, read_starts, read_counts,
                                       &(edges_on_local_cells[indexInArray]));
 #endif
-    ERRORS(success, "Failed to read cell_edges data in a loop");
+    ERRORS(success, "Failed to read cell_edges data in a loop.");
@@ -1052,12 +1017,12 @@ ErrorCode NCHelperGCRM::create_local_edges(EntityHandle start_vertex)
   ErrorCode rval = _readNC->readMeshIface->get_element_connect(nLocalEdges, 2, MBEDGE, 0, start_edge, conn_arr_edges,
                                                     // Might have to create gather mesh later
                                                     (createGatherSet ? nLocalEdges + nEdges : nLocalEdges));
-  ERRORR(rval, "Failed to create edges.");
+  ERRORR(rval, "Failed to create local edges.");
-  // Add local edges to the file set
+  // Add local edges to current file set
   Range local_edges_range(start_edge, start_edge + nLocalEdges - 1);
   rval = _readNC->mbImpl->add_entities(_fileSet, local_edges_range);
-  ERRORR(rval, "Failed to add local edges to the file set.");
+  ERRORR(rval, "Failed to add local edges to current file set.");
   // Get ptr to GID memory for edges
   int count = 0;
@@ -1098,7 +1063,7 @@ ErrorCode NCHelperGCRM::create_local_edges(EntityHandle start_vertex)
     success = NCFUNCAG(_vara_int)(_fileId, verticesOnEdgeVarId, read_starts, read_counts,
                                     &(vertices_on_local_edges[indexInArray]));
 #endif
-    ERRORS(success, "Failed to read edge_corners data in a loop");
+    ERRORS(success, "Failed to read edge_corners data in a loop.");
     indexInArray += (endh - starth + 1) * 2;
@@ -1136,13 +1101,13 @@ ErrorCode NCHelperGCRM::create_padded_local_cells(const std::vector<int>& vertic
   ErrorCode rval = _readNC->readMeshIface->get_element_connect(nLocalCells, EDGES_PER_CELL, MBPOLYGON, 0, start_element, conn_arr_local_cells,
                                                     (createGatherSet ? nLocalCells + nCells : nLocalCells));
-  ERRORR(rval, "Failed to create cells.");
+  ERRORR(rval, "Failed to create local cells.");
   faces.insert(start_element, start_element + nLocalCells - 1);
-  // Add local cells to the file set
+  // Add local cells to current file set
   Range local_cells_range(start_element, start_element + nLocalCells - 1);
   rval = _readNC->mbImpl->add_entities(_fileSet, local_cells_range);
-  ERRORR(rval, "Failed to add local cells to the file set.");
+  ERRORR(rval, "Failed to add local cells to current file set.");
   // Get ptr to GID memory for local cells
   int count = 0;
@@ -1179,7 +1144,7 @@ ErrorCode NCHelperGCRM::create_gather_set_vertices(EntityHandle gather_set, Enti
   std::vector<double*> arrays;
   // Don't need to specify allocation number here, because we know enough vertices were created before
   ErrorCode rval = _readNC->readMeshIface->get_node_coords(3, nVertices, 0, gather_set_start_vertex, arrays);
-  ERRORR(rval, "Failed to create vertices.");
+  ERRORR(rval, "Failed to create gather set vertices.");
   // Add vertices to the gather set
   Range gather_set_verts_range(gather_set_start_vertex, gather_set_start_vertex + nVertices - 1);
@@ -1269,7 +1234,7 @@ ErrorCode NCHelperGCRM::create_gather_set_edges(EntityHandle gather_set, EntityH
   EntityHandle* conn_arr_gather_set_edges = NULL;
   // Don't need to specify allocation number here, because we know enough edges were created before
   ErrorCode rval = _readNC->readMeshIface->get_element_connect(nEdges, 2, MBEDGE, 0, start_edge, conn_arr_gather_set_edges);
+  ERRORR(rval, "Failed to create gather set edges.");
   // Add edges to the gather set
   Range gather_set_edges_range(start_edge, start_edge + nEdges - 1);
@@ -1319,7 +1284,7 @@ ErrorCode NCHelperGCRM::create_padded_gather_set_cells(EntityHandle gather_set,
   EntityHandle* conn_arr_gather_set_cells = NULL;
   // Don't need to specify allocation number here, because we know enough cells were created before
   ErrorCode rval = _readNC->readMeshIface->get_element_connect(nCells, EDGES_PER_CELL, MBPOLYGON, 0, start_element, conn_arr_gather_set_cells);
+  ERRORR(rval, "Failed to create gather set cells.");
   // Add cells to the gather set
   Range gather_set_cells_range(start_element, start_element + nCells - 1);
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index 73f09c8..cef0771 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -179,7 +179,7 @@ ErrorCode NCHelperHOMME::init_mesh_vals()
       ERRORR(rval, "Trouble reading 't' variable.");
     else {
-      // If expected time variable is not available, set dummy time coordinate values to tVals
+      // If expected time variable does not exist, set dummy values to tVals
       for (int t = 0; t < nTimeSteps; t++)
         tVals.push_back((double)t);
@@ -219,26 +219,22 @@ ErrorCode NCHelperHOMME::check_existing_mesh()
   bool& noMesh = _readNC->noMesh;
   if (noMesh && localGidVerts.empty()) {
-    // We need to populate localGidVerts range with the gids of vertices from the tmp_set
+    // We need to populate localGidVerts range with the gids of vertices from current file set
     // localGidVerts is important in reading the variable data into the nodes
-    // also, for our purposes, localGidVerts is truly the GLOBAL_ID tag data, not other
+    // Also, for our purposes, localGidVerts is truly the GLOBAL_ID tag data, not other
     // file_id tags that could get passed around in other scenarios for parallel reading
-    // for nodal_partition, this local gid is easier, should be initialized with only
-    // the owned nodes
-    // We need to get all vertices from tmp_set (it is the input set in no_mesh scenario)
     Range local_verts;
     ErrorCode rval = mbImpl->get_entities_by_dimension(_fileSet, 0, local_verts);
-      return rval;
-        return rval;
@@ -396,7 +392,7 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
                                               MBQUAD, 0, start_quad, conn_arr,
                                               (create_gathers ? num_coarse_quads + num_quads : num_coarse_quads));
-    ERRORR(rval, "Failed to create quads.");
+    ERRORR(rval, "Failed to create local quads.");
     tmp_range.insert(start_quad, start_quad + num_coarse_quads - 1);
     std::copy(&tmp_conn[start_idx], &tmp_conn[start_idx + 4 * num_fine_quads], conn_arr);
     std::copy(conn_arr, conn_arr + 4 * num_fine_quads, range_inserter(localGidVerts));
@@ -418,7 +414,7 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
   rval = _readNC->readMeshIface->get_node_coords(3, nLocalVertices, 0, start_vertex, arrays,
                                         (create_gathers ? nLocalVertices + nVertices : nLocalVertices));
-  ERRORR(rval, "Couldn't create vertices in HOMME mesh.");
+  ERRORR(rval, "Failed to create local vertices.");
   // Set vertex coordinates
   Range::iterator rit;
@@ -450,7 +446,7 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
   void* data;
   int count;
   rval = mbImpl->tag_iterate(mGlobalIdTag, vert_range.begin(), vert_range.end(), count, data);
-  ERRORR(rval, "Failed to get tag iterator.");
+  ERRORR(rval, "Failed to iterate global id tag on local vertices.");
   assert(count == nLocalVertices);
   int* gid_data = (int*) data;
   std::copy(localGidVerts.begin(), localGidVerts.end(), gid_data);
@@ -458,7 +454,7 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
   // Duplicate global id data, which will be used to resolve sharing
   if (mpFileIdTag) {
     rval = mbImpl->tag_iterate(*mpFileIdTag, vert_range.begin(), vert_range.end(), count, data);
-    ERRORR(rval, "Failed to get tag iterator on file id tag.");
+    ERRORR(rval, "Failed to iterate file id tag on local vertices.");
@@ -482,29 +478,29 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
-  // Add new vertices and elements to the set
+  // Add new vertices and quads to current file set
   faces.merge(tmp_range);
   tmp_range.insert(start_vertex, start_vertex + nLocalVertices - 1);
   rval = mbImpl->add_entities(_fileSet, tmp_range);
-  ERRORR(rval, "Couldn't add new vertices and quads to file set.");
+  ERRORR(rval, "Failed to add new vertices and quads to current file set.");
   // Mark the set with the spectral order
   Tag sporder;
   rval = mbImpl->tag_get_handle("SPECTRAL_ORDER", 1, MB_TYPE_INTEGER, sporder, MB_TAG_CREAT | MB_TAG_SPARSE);
-  ERRORR(rval, "Couldn't create spectral order tag.");
+  ERRORR(rval, "Failed to get SPECTRAL_ORDER tag.");
   rval = mbImpl->tag_set_data(sporder, &_fileSet, 1, &_spectralOrder);
-  ERRORR(rval, "Couldn't set value for spectral order tag.");
+  ERRORR(rval, "Failed to set data for SPECTRAL_ORDER tag.");
   if (create_gathers) {
     EntityHandle gather_set;
     rval = _readNC->readMeshIface->create_gather_set(gather_set);
-    ERRORR(rval, "Trouble creating gather set.");
+    ERRORR(rval, "Failed to create gather set.");
     // Create vertices
     arrays.clear();
     // Don't need to specify allocation number here, because we know enough verts were created before
     rval = _readNC->readMeshIface->get_node_coords(3, nVertices, 0, start_vertex, arrays);
-    ERRORR(rval, "Couldn't create vertices in HOMME mesh for gather set.");
     xptr = arrays[0];
     yptr = arrays[1];
@@ -520,38 +516,38 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
     // Get ptr to gid memory for vertices
-    Range gather_verts(start_vertex, start_vertex + nVertices - 1);
-    rval = mbImpl->tag_iterate(mGlobalIdTag, gather_verts.begin(), gather_verts.end(), count, data);
+    Range gather_set_verts_range(start_vertex, start_vertex + nVertices - 1);
+    rval = mbImpl->tag_iterate(mGlobalIdTag, gather_set_verts_range.begin(), gather_set_verts_range.end(), count, data);
+    ERRORR(rval, "Failed to iterate global id tag on gather set vertices.");
     assert(count == nVertices);
     for (int j = 1; j <= nVertices; j++)
       gid_data[j - 1] = j;
     // Set the file id tag too, it should be bigger something not interfering with global id
     if (mpFileIdTag) {
-      rval = mbImpl->tag_iterate(*mpFileIdTag, gather_verts.begin(), gather_verts.end(), count, data);
-      ERRORR(rval, "Failed to get tag iterator in file id tag.");
+      rval = mbImpl->tag_iterate(*mpFileIdTag, gather_set_verts_range.begin(), gather_set_verts_range.end(), count, data);
+      ERRORR(rval, "Failed to iterate file id tag on gather set vertices.");
         gid_data[j - 1] = nVertices + j; // bigger than global id tag
-    rval = mbImpl->add_entities(gather_set, gather_verts);
-    ERRORR(rval, "Couldn't add vertices to gather set.");
+    rval = mbImpl->add_entities(gather_set, gather_set_verts_range);
+    ERRORR(rval, "Failed to add vertices to the gather set.");
     // Create quads
-    Range gather_quads;
+    Range gather_set_quads_range;
     // Don't need to specify allocation number here, because we know enough quads were created before
     rval = _readNC->readMeshIface->get_element_connect(num_quads, 4,
                                               MBQUAD, 0, start_quad, conn_arr);
-    gather_quads.insert(start_quad, start_quad + num_quads - 1);
+    ERRORR(rval, "Failed to create gather set quads.");
+    gather_set_quads_range.insert(start_quad, start_quad + num_quads - 1);
     std::copy(&tmp_conn[0], &tmp_conn[4 * num_quads], conn_arr);
     for (i = 0; i != 4 * num_quads; i++)
       conn_arr[i] += start_vertex - 1; // Connectivity array is shifted by where the gather verts start
-    rval = mbImpl->add_entities(gather_set, gather_quads);
-    ERRORR(rval, "Couldn't add quads to gather set.");
+    rval = mbImpl->add_entities(gather_set, gather_set_quads_range);
+    ERRORR(rval, "Failed to add quads to the gather set.");
   return MB_SUCCESS;
@@ -567,10 +563,10 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_allocate(std::vector<ReadN
+  // Get vertices
   Range verts;
@@ -604,8 +600,7 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_allocate(std::vector<ReadN
         range = &verts;
         break;
       default:
-        ERRORR(MB_FAILURE, "Unexpected entity location type for HOMME non-set variable.");
-        break;
     // Get variable size
@@ -645,7 +640,7 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_async(std::vector<ReadNC::
   int success;
@@ -673,16 +668,6 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_async(std::vector<ReadNC::
-        case NC_BYTE:
-        case NC_CHAR: {
-          break;
-        case NC_SHORT:
-        case NC_INT: {
-          break;
         case NC_FLOAT:
         case NC_DOUBLE: {
@@ -708,7 +693,7 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_async(std::vector<ReadNC::
             // next subrange
@@ -718,22 +703,19 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_async(std::vector<ReadNC::
           success = ncmpi_wait_all(_fileId, requests.size(), &requests[0], &statuss[0]);
           ERRORS(success, "Failed on wait_all.");
-          if (vdatas[i].numLev != 1)
+          if (vdatas[i].numLev > 1)
             // Transpose (lev, ncol) to (ncol, lev)
-            success = kji_to_jik_stride(ni, nj, nk, data, &tmpdoubledata[0], localGidVerts);
+            kji_to_jik_stride(ni, nj, nk, data, &tmpdoubledata[0], localGidVerts);
           else {
             for (std::size_t idx = 0; idx != tmpdoubledata.size(); idx++)
               ((double*) data)[idx] = tmpdoubledata[idx];
-          ERRORS(success, "Failed to read double data.");
           break;
         default:
-          success = 1;
-      if (success)
@@ -753,7 +735,7 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset(std::vector<ReadNC::VarDat
   int success;
@@ -774,16 +756,6 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset(std::vector<ReadNC::VarDat
-        case NC_BYTE:
-        case NC_CHAR: {
-          break;
-        case NC_SHORT:
-        case NC_INT: {
-          break;
         case NC_FLOAT:
         case NC_DOUBLE: {
@@ -807,29 +779,26 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset(std::vector<ReadNC::VarDat
-            ERRORS(success, "Failed to read float data in loop");
             // next subrange
           assert(ic == localGidVerts.psize());
           else {
           break;
         default:
-          success = 1;
-      if (success)
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 0e51a89..398184d 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -221,19 +221,17 @@ ErrorCode NCHelperMPAS::check_existing_mesh()
       Range local_verts;
-        return rval;
-          return rval;
@@ -242,19 +240,17 @@ ErrorCode NCHelperMPAS::check_existing_mesh()
       Range local_edges;
-        return rval;
-          return rval;
@@ -263,19 +259,17 @@ ErrorCode NCHelperMPAS::check_existing_mesh()
       Range local_cells;
-        return rval;
-          return rval;
@@ -377,7 +371,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
     success = NCFUNCAG(_vara_int)(_fileId, nEdgesOnCellVarId, &read_start, &read_count,
                                       &(num_edges_on_local_cells[indexInArray]));
 #endif
-    ERRORS(success, "Failed to read nEdgesOnCell data in a loop");
+    ERRORS(success, "Failed to read nEdgesOnCell data in a loop.");
@@ -434,7 +428,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
 #endif
-    ERRORS(success, "Failed to read verticesOnCell data in a loop");
+    ERRORS(success, "Failed to read verticesOnCell data in a loop.");
     indexInArray += (endh - starth + 1) * maxEdgesPerCell;
@@ -526,22 +520,22 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC
+  // Get vertices
   Range verts;
+  // Get edges
   Range edges;
+  // Get faces
   Range faces;
   // Note, for MPAS faces.psize() can be more than 1
 #ifdef USE_MPI
@@ -549,7 +543,7 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC
   if (isParallel) {
   else
@@ -604,8 +598,7 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC
         range = &edges;
         break;
       default:
-        ERRORR(MB_FAILURE, "Unexpected entity location type for MPAS non-set variable.");
-        break;
     // Finally: nVertLevels or other optional levels, it is possible that there is no
@@ -661,7 +654,7 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
   int success;
@@ -683,8 +676,7 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
         break;
       default:
-        break;
@@ -700,16 +692,6 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
-        case NC_BYTE:
-        case NC_CHAR: {
-          break;
-        case NC_SHORT:
-        case NC_INT: {
-          break;
         case NC_FLOAT:
         case NC_DOUBLE: {
@@ -735,7 +717,7 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
             // next subrange
@@ -775,11 +757,8 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
           break;
         default:
-          success = 1;
-      if (success)
@@ -801,7 +780,7 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
   int success;
@@ -823,8 +802,7 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
         break;
       default:
-        break;
@@ -834,16 +812,6 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
-        case NC_BYTE:
-        case NC_CHAR: {
-          break;
-        case NC_SHORT:
-        case NC_INT: {
-          break;
         case NC_FLOAT:
         case NC_DOUBLE: {
@@ -867,7 +835,7 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
             // next subrange
@@ -904,11 +872,8 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
           break;
         default:
-          success = 1;
-      if (success)
@@ -1003,10 +968,10 @@ ErrorCode NCHelperMPAS::create_local_vertices(const std::vector<int>& vertices_o
   int count = 0;
@@ -1055,7 +1020,7 @@ ErrorCode NCHelperMPAS::create_local_vertices(const std::vector<int>& vertices_o
 #endif
-    ERRORS(success, "Failed to read xVertex data in a loop");
+    ERRORS(success, "Failed to read xVertex data in a loop.");
@@ -1092,7 +1057,7 @@ ErrorCode NCHelperMPAS::create_local_vertices(const std::vector<int>& vertices_o
 #endif
-    ERRORS(success, "Failed to read yVertex data in a loop");
+    ERRORS(success, "Failed to read yVertex data in a loop.");
@@ -1129,7 +1094,7 @@ ErrorCode NCHelperMPAS::create_local_vertices(const std::vector<int>& vertices_o
     success = NCFUNCAG(_vara_double)(_fileId, zVertexVarId, &read_start, &read_count,
                                       &(zptr[indexInArray]));
 #endif
-    ERRORS(success, "Failed to read zVertex data in a loop");
+    ERRORS(success, "Failed to read zVertex data in a loop.");
@@ -1181,7 +1146,7 @@ ErrorCode NCHelperMPAS::create_local_edges(EntityHandle start_vertex, const std:
 #endif
-    ERRORS(success, "Failed to read edgesOnCell data in a loop");
+    ERRORS(success, "Failed to read edgesOnCell data in a loop.");
@@ -1219,10 +1184,10 @@ ErrorCode NCHelperMPAS::create_local_edges(EntityHandle start_vertex, const std:
   int count = 0;
@@ -1263,7 +1228,7 @@ ErrorCode NCHelperMPAS::create_local_edges(EntityHandle start_vertex, const std:
 #endif
-    ERRORS(success, "Failed to read verticesOnEdge data in a loop");
+    ERRORS(success, "Failed to read verticesOnEdge data in a loop.");
@@ -1319,13 +1284,13 @@ ErrorCode NCHelperMPAS::create_local_cells(const std::vector<int>& vertices_on_l
     EntityHandle start_element;
     ErrorCode rval = _readNC->readMeshIface->get_element_connect(num_group_cells, num_edges_per_cell, MBPOLYGON, 0, start_element,
                                                        conn_arr_local_cells_with_n_edges[num_edges_per_cell], num_group_cells);
-    ERRORR(rval, "Failed to create cells");
+    ERRORR(rval, "Failed to create local cells");
     faces.insert(start_element, start_element + num_group_cells - 1);
     Range local_cells_range(start_element, start_element + num_group_cells - 1);
     // Get ptr to gid memory for local cells
     int count = 0;
@@ -1375,13 +1340,13 @@ ErrorCode NCHelperMPAS::create_padded_local_cells(const std::vector<int>& vertic
   ErrorCode rval = _readNC->readMeshIface->get_element_connect(nLocalCells, maxEdgesPerCell, MBPOLYGON, 0, start_element, conn_arr_local_cells,
   int count = 0;
@@ -1417,7 +1382,7 @@ ErrorCode NCHelperMPAS::create_gather_set_vertices(EntityHandle gather_set, Enti
@@ -1512,7 +1477,7 @@ ErrorCode NCHelperMPAS::create_gather_set_edges(EntityHandle gather_set, EntityH
@@ -1613,7 +1578,7 @@ ErrorCode NCHelperMPAS::create_gather_set_cells(EntityHandle gather_set, EntityH
                                                          conn_arr_gather_set_cells_with_n_edges[num_edges_per_cell], num_group_cells);
       Range gather_set_cells_range(start_element, start_element + num_group_cells - 1);
@@ -1668,7 +1633,7 @@ ErrorCode NCHelperMPAS::create_padded_gather_set_cells(EntityHandle gather_set,
   ErrorCode rval = _readNC->readMeshIface->get_element_connect(nCells, maxEdgesPerCell, MBPOLYGON, 0, start_element, conn_arr_gather_set_cells);
diff --git a/src/io/NCWriteGCRM.cpp b/src/io/NCWriteGCRM.cpp
index b80d90a..16e4872 100644
--- a/src/io/NCWriteGCRM.cpp
+++ b/src/io/NCWriteGCRM.cpp
@@ -75,7 +75,7 @@ ErrorCode NCWriteGCRM::collect_mesh_info()
       unsigned int num_local_verts = localVertsOwned.size();
 #endif
       rval = myPcomm->filter_pstatus(localVertsOwned, PSTATUS_NOT_OWNED, PSTATUS_NOT);
-      ERRORR(rval, "Trouble getting owned vertices in set.");
+      ERRORR(rval, "Trouble getting owned vertices in current file set.");
       // Assume that PARALLEL_RESOLVE_SHARED_ENTS option is set
       // Verify that not all local vertices are owned by the last processor
@@ -84,11 +84,11 @@ ErrorCode NCWriteGCRM::collect_mesh_info()
       if (!localEdgesOwned.empty()) {
         rval = myPcomm->filter_pstatus(localEdgesOwned, PSTATUS_NOT_OWNED, PSTATUS_NOT);
-        ERRORR(rval, "Trouble getting owned edges in set.");
+        ERRORR(rval, "Trouble getting owned edges in current file set.");
       rval = myPcomm->filter_pstatus(localCellsOwned, PSTATUS_NOT_OWNED, PSTATUS_NOT);
-      ERRORR(rval, "Trouble getting owned cells in set.");
+      ERRORR(rval, "Trouble getting owned cells in current file set.");
 #endif
@@ -217,7 +217,7 @@ ErrorCode NCWriteGCRM::collect_variable_data(std::vector<std::string>& var_names
         currentVarData.writeCounts[dim_idx] = localGidEdgesOwned.size();
         break;
       default:
     dim_idx++;
@@ -283,7 +283,7 @@ ErrorCode NCWriteGCRM::write_nonset_variables(std::vector<WriteNC::VarData>& vda
         pLocalGidEntsOwned = &localGidCellsOwned;
         break;
       default:
     unsigned int num_timesteps;
@@ -356,7 +356,7 @@ ErrorCode NCWriteGCRM::write_nonset_variables(std::vector<WriteNC::VarData>& vda
                 &(variableData.writeStarts[0]), &(variableData.writeCounts[0]),
                            &(tag_data[indexInDoubleArray]));
 #endif
             // next subrange
             indexInDoubleArray += (endh - starth + 1) * num_lev;
diff --git a/src/io/NCWriteHOMME.cpp b/src/io/NCWriteHOMME.cpp
index 3dd61c1..2a4291b 100644
--- a/src/io/NCWriteHOMME.cpp
+++ b/src/io/NCWriteHOMME.cpp
@@ -63,7 +63,7 @@ ErrorCode NCWriteHOMME::collect_mesh_info()
 #endif
+      ERRORR(rval, "Trouble getting owned vertices in current set.");
@@ -158,7 +158,7 @@ ErrorCode NCWriteHOMME::collect_variable_data(std::vector<std::string>& var_name
         currentVarData.writeCounts[dim_idx] = localGidVertsOwned.size();
         break;
       default:
     dim_idx++;
@@ -188,7 +188,7 @@ ErrorCode NCWriteHOMME::write_nonset_variables(std::vector<WriteNC::VarData>& vd
         // Vertices
         break;
       default:
@@ -272,7 +272,7 @@ ErrorCode NCWriteHOMME::write_nonset_variables(std::vector<WriteNC::VarData>& vd
 #endif
             // next subrange
diff --git a/src/io/NCWriteHelper.cpp b/src/io/NCWriteHelper.cpp
index ee6e7aa..3111a72 100644
--- a/src/io/NCWriteHelper.cpp
+++ b/src/io/NCWriteHelper.cpp
@@ -632,7 +632,7 @@ ErrorCode ScdNCWriteHelper::collect_mesh_info()
     int procs = myPcomm->proc_config().proc_size();
     if (procs > 1) {
 #endif
@@ -715,7 +715,7 @@ ErrorCode ScdNCWriteHelper::collect_variable_data(std::vector<std::string>& var_
         currentVarData.writeCounts[dim_idx + 1] = lCDims[3] - lCDims[0] + 1;
         break;
       default:
-        ERRORR(MB_FAILURE, "Unexpected entity location type for structured mesh non-set variable.");
     dim_idx += 2;
@@ -747,7 +747,7 @@ ErrorCode ScdNCWriteHelper::write_nonset_variables(std::vector<WriteNC::VarData>
         // Faces
         break;
       default:
diff --git a/src/io/NCWriteMPAS.cpp b/src/io/NCWriteMPAS.cpp
index 512c1d5..45f0cec 100644
--- a/src/io/NCWriteMPAS.cpp
+++ b/src/io/NCWriteMPAS.cpp
@@ -75,7 +75,7 @@ ErrorCode NCWriteMPAS::collect_mesh_info()
 #endif
@@ -84,11 +84,11 @@ ErrorCode NCWriteMPAS::collect_mesh_info()
 #endif
@@ -229,7 +229,7 @@ ErrorCode NCWriteMPAS::collect_variable_data(std::vector<std::string>& var_names
         break;
       default:
     dim_idx++;
@@ -295,7 +295,7 @@ ErrorCode NCWriteMPAS::write_nonset_variables(std::vector<WriteNC::VarData>& vda
         break;
       default:
@@ -368,7 +368,7 @@ ErrorCode NCWriteMPAS::write_nonset_variables(std::vector<WriteNC::VarData>& vda
 #endif
             // next subrange
diff --git a/src/io/ReadNC.cpp b/src/io/ReadNC.cpp
index 4543b64..64d67ab 100644
--- a/src/io/ReadNC.cpp
+++ b/src/io/ReadNC.cpp
@@ -84,7 +84,7 @@ ErrorCode ReadNC::load_file(const char* file_name, const EntityHandle* file_set,
   // Make sure there's a file set to put things in
   EntityHandle tmp_set;
   if (noMesh && !file_set) {
-    ERRORR(MB_FAILURE, "NOMESH option requires non-NULL file set on input.\n");
+    ERRORR(MB_FAILURE, "NOMESH option requires non-NULL file set on input.");
   else if (!file_set || (file_set && *file_set == 0)) {
     rval = mbImpl->create_meshset(MESHSET_SET, tmp_set);
@@ -115,7 +115,7 @@ ErrorCode ReadNC::load_file(const char* file_name, const EntityHandle* file_set,
   // Check existing mesh from last read
   if (noMesh && !noVars) {
     rval = myHelper->check_existing_mesh();
-    ERRORR(rval, "Trouble checking mesh from last read.\n");
+    ERRORR(rval, "Trouble checking mesh from last read.");
   // Create some conventional tags, e.g. __NUM_DIMS
@@ -194,7 +194,7 @@ ErrorCode ReadNC::load_file(const char* file_name, const EntityHandle* file_set,
     Range verts;
     rval = mbImpl->get_connectivity(faces, verts);
-    ERRORR(rval, "Couldn't get verts of faces");
+    ERRORR(rval, "Couldn't get verts of faces.");
     rval = mbImpl->add_entities(partn_set, verts);
     ERRORR(rval, "Couldn't add new verts to partition set.");
@@ -296,7 +296,7 @@ ErrorCode ReadNC::parse_options(const FileOptions& opts, std::vector<std::string
 #ifdef USE_MPI
-  isParallel = (opts.match_option("PARALLEL","READ_PART") != MB_ENTITY_NOT_FOUND);
+  isParallel = (opts.match_option("PARALLEL", "READ_PART") != MB_ENTITY_NOT_FOUND);
   if (!isParallel)
   // Return success here, since rval still has _NOT_FOUND from not finding option
@@ -306,7 +306,7 @@ ErrorCode ReadNC::parse_options(const FileOptions& opts, std::vector<std::string
   int pcomm_no = 0;
   rval = opts.get_int_option("PARALLEL_COMM", pcomm_no);
-  if (rval == MB_TYPE_OUT_OF_RANGE) {
+  if (MB_TYPE_OUT_OF_RANGE == rval) {
     readMeshIface->report_error("Invalid value for PARALLEL_COMM option");
     return rval;
@@ -319,11 +319,11 @@ ErrorCode ReadNC::parse_options(const FileOptions& opts, std::vector<std::string
   int dum;
   rval = opts.match_option("PARTITION_METHOD", ScdParData::PartitionMethodNames, dum);
-  if (rval == MB_FAILURE) {
-    readMeshIface->report_error("Unknown partition method specified.");
-    partMethod = ScdParData::ALLJORKORI;
+  if (MB_FAILURE == rval) {
+    readMeshIface->report_error("Unknown partition method specified");
+    return rval;
-  else if (rval == MB_ENTITY_NOT_FOUND)
+  else if (MB_ENTITY_NOT_FOUND == rval)
   else
     partMethod = dum;
@@ -344,17 +344,17 @@ ErrorCode ReadNC::read_header()
   // Read attributes into globalAtts
   ErrorCode result = get_attributes(NC_GLOBAL, numgatts, globalAtts);
-  ERRORR(result, "Getting attributes.");
+  ERRORR(result, "Trouble getting attributes.");
   dbgOut.tprintf(1, "Read %u attributes\n", (unsigned int) globalAtts.size());
   // Read in dimensions into dimNames and dimLens
   result = get_dimensions(fileId, dimNames, dimLens);
-  ERRORR(result, "Getting dimensions.");
+  ERRORR(result, "Trouble getting dimensions.");
   dbgOut.tprintf(1, "Read %u dimensions\n", (unsigned int) dimNames.size());
   // Read in variables into varInfo
   result = get_variables();
-  ERRORR(result, "Getting variables.");
+  ERRORR(result, "Trouble getting variables.");
   dbgOut.tprintf(1, "Read %u variables\n", (unsigned int) varInfo.size());
   return MB_SUCCESS;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
