[MOAB-dev] MOAB w/ BGQ
    Mohsen Behzad-Jazi
    m.behzad.jazi at mail.utoronto.ca
    Sat Jun 14 20:24:46 CDT 2014
Hello all,
I encountered a problem when I wanted to build moab on our (SciNet) BGQ cluster.
Seemingly, there isn't any problem with configure script. However, when I run make check, it fails to build with a couple of warning messages. I attached the log files for configure and make check.
I wondered if anyone can shed some light on the issue.
Mohsen
Desc: config.log
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140615/7269c163/attachment-0002.obj>
Desc: make_check.log
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140615/7269c163/attachment-0003.obj>
