[MOAB-dev] commit/MOAB: danwu: For HOMME and MPAS, we can read float type data as double type (we have already done so for GRCM), since netcdf/pnetcdf is able to do the conversion automatically when reading. Then there is no need to call convert_variable() for float to double type conversion.
    commits-noreply at bitbucket.org
    Fri Jun 13 14:16:11 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/1402bef9bdfd/
Changeset:   1402bef9bdfd
Branch:      master
User:        danwu
Date:        2014-06-13 21:15:19
Summary:     For HOMME and MPAS, we can read float type data as double type (we have already done so for GRCM), since netcdf/pnetcdf is able to do the conversion automatically when reading. Then there is no need to call convert_variable() for float to double type conversion.
Affected #:  2 files
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index 4aade2f..73f09c8 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -678,8 +678,14 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_async(std::vector<ReadNC::
           ERRORR(MB_FAILURE, "not implemented");
           break;
+        case NC_SHORT:
+        case NC_INT: {
+          ERRORR(MB_FAILURE, "not implemented");
+          break;
+        case NC_FLOAT:
         case NC_DOUBLE: {
-          // Copied from float case
+          // Read float as double
           std::vector<double> tmpdoubledata(sz);
           // In the case of ucd mesh, and on multiple proc,
@@ -691,14 +697,14 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_async(std::vector<ReadNC::
           size_t ic = 0;
           for (Range::pair_iterator pair_iter = localGidVerts.pair_begin();
               pair_iter != localGidVerts.pair_end();
-              pair_iter++, ic++) {
+              ++pair_iter, ic++) {
             EntityHandle starth = pair_iter->first;
-            EntityHandle endh = pair_iter->second; // inclusive
+            EntityHandle endh = pair_iter->second; // Inclusive
             vdatas[i].readStarts[2] = (NCDF_SIZE) (starth - 1);
             vdatas[i].readCounts[2] = (NCDF_SIZE) (endh - starth + 1);
             // Do a partial read, in each subrange
-            // wait outside this loop
+            // Wait outside this loop
             success = NCFUNCREQG(_vara_double)(_fileId, vdatas[i].varId,
                             &(vdatas[i].readStarts[0]), &(vdatas[i].readCounts[0]),
                             &(tmpdoubledata[indexInDoubleArray]), &requests[idxReq++]);
@@ -722,57 +728,6 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_async(std::vector<ReadNC::
           ERRORS(success, "Failed to read double data.");
           break;
-        case NC_FLOAT: {
-          std::vector<float> tmpfloatdata(sz);
-          // In the case of ucd mesh, and on multiple proc,
-          // we need to read as many times as subranges we have in the
-          // localGidVerts range;
-          // basically, we have to give a different point
-          // for data to start, for every subrange :(
-          size_t indexInFloatArray = 0;
-          size_t ic = 0;
-          for (Range::pair_iterator pair_iter = localGidVerts.pair_begin();
-              pair_iter != localGidVerts.pair_end();
-            EntityHandle starth = pair_iter->first;
-            vdatas[i].readStarts[2] = (NCDF_SIZE) (starth - 1);
-            vdatas[i].readCounts[2] = (NCDF_SIZE) (endh - starth + 1);
-            // Do a partial read, in each subrange
-            success = NCFUNCREQG(_vara_float)(_fileId, vdatas[i].varId,
-                            &(vdatas[i].readStarts[0]), &(vdatas[i].readCounts[0]),
-                            &(tmpfloatdata[indexInFloatArray]), &requests[idxReq++]);
-            ERRORS(success, "Failed to read float data in loop");
-            // We need to increment the index in float array for the
-            // next subrange
-            indexInFloatArray += (endh - starth + 1) * 1 * vdatas[i].numLev;
-          assert(ic == localGidVerts.psize());
-          success = ncmpi_wait_all(_fileId, requests.size(), &requests[0], &statuss[0]);
-          ERRORS(success, "Failed on wait_all.");
-          if (vdatas[i].numLev != 1)
-            // Transpose (lev, ncol) to (ncol, lev)
-            success = kji_to_jik_stride(ni, nj, nk, data, &tmpfloatdata[0], localGidVerts);
-          else {
-            for (std::size_t idx = 0; idx != tmpfloatdata.size(); idx++)
-              ((float*) data)[idx] = tmpfloatdata[idx];
-          ERRORS(success, "Failed to read float data.");
-          break;
-        case NC_INT: {
-          ERRORR(MB_FAILURE, "not implemented");
-          break;
-        case NC_SHORT: {
-          break;
         default:
           success = 1;
@@ -782,15 +737,6 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_async(std::vector<ReadNC::
-  for (unsigned int i = 0; i < vdatas.size(); i++) {
-    for (unsigned int t = 0; t < tstep_nums.size(); t++) {
-      dbgOut.tprintf(2, "Converting variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t]);
-      ErrorCode tmp_rval = convert_variable(vdatas[i], t);
-      if (MB_SUCCESS != tmp_rval)
-        rval = tmp_rval;
   // Debug output, if requested
   if (1 == dbgOut.get_verbosity()) {
     dbgOut.printf(1, "Read variables: %s", vdatas.begin()->varName.c_str());
@@ -833,8 +779,14 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset(std::vector<ReadNC::VarDat
           break;
+        case NC_SHORT:
+        case NC_INT: {
+          break;
+        case NC_FLOAT:
         case NC_DOUBLE: {
@@ -846,7 +798,7 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset(std::vector<ReadNC::VarDat
           size_t ic = 0;
@@ -872,52 +824,6 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset(std::vector<ReadNC::VarDat
           break;
-        case NC_FLOAT: {
-          size_t ic = 0;
-            EntityHandle endh = pair_iter->second; // Inclusive
-            success = NCFUNCAG(_vara_float)(_fileId, vdatas[i].varId,
-                            &(tmpfloatdata[indexInFloatArray]));
-            // next subrange
-          else {
-          break;
-        case NC_INT: {
-          break;
-        case NC_SHORT: {
-          break;
         default:
           success = 1;
@@ -927,14 +833,6 @@ ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset(std::vector<ReadNC::VarDat
-        rval = tmp_rval;
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index ace33a2..0e51a89 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -705,7 +705,14 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
           break;
+        case NC_SHORT:
+        case NC_INT: {
+          break;
+        case NC_FLOAT:
         case NC_DOUBLE: {
@@ -713,19 +720,18 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
           // localGid range;
           size_t indexInDoubleArray = 0;
           size_t ic = 0;
           for (Range::pair_iterator pair_iter = pLocalGid->pair_begin();
               pair_iter != pLocalGid->pair_end();
             vdatas[i].readStarts[1] = (NCDF_SIZE) (starth - 1);
             vdatas[i].readCounts[1] = (NCDF_SIZE) (endh - starth + 1);
@@ -768,18 +774,6 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
           break;
-        case NC_FLOAT: {
-          break;
-        case NC_INT: {
-          break;
-        case NC_SHORT: {
-          break;
         default:
           success = 1;
@@ -789,17 +783,6 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
-    if (noEdges && vdatas[i].entLoc == ReadNC::ENTLOCEDGE)
-      continue;
-        rval = tmp_rval;
@@ -856,7 +839,14 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
           break;
+        case NC_SHORT:
+        case NC_INT: {
+          break;
+        case NC_FLOAT:
         case NC_DOUBLE: {
@@ -868,7 +858,7 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
           size_t ic = 0;
@@ -913,18 +903,6 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
           break;
-        case NC_FLOAT: {
-          break;
-        case NC_INT: {
-          break;
-        case NC_SHORT: {
-          break;
         default:
           success = 1;
@@ -934,18 +912,6 @@ ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
-      continue;
-        rval = tmp_rval;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
