[MOAB-dev] commit/MOAB: danwu: Renamed a few member functions of NCHelper classes (e.g. read_variable_setup => read_variables_setup).
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Thu Jun 12 15:55:08 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/849eec7915e8/
Changeset:   849eec7915e8
Branch:      master
User:        danwu
Date:        2014-06-12 22:53:37
Summary:     Renamed a few member functions of NCHelper classes (e.g. read_variable_setup => read_variables_setup).
Affected #:  8 files
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 950d20c..9e982f3 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -380,7 +380,7 @@ ErrorCode NCHelper::update_time_tag_vals()
   return MB_SUCCESS;
-ErrorCode NCHelper::read_variable_setup(std::vector<std::string>& var_names, std::vector<int>& tstep_nums,
+ErrorCode NCHelper::read_variables_setup(std::vector<std::string>& var_names, std::vector<int>& tstep_nums,
                                         std::vector<ReadNC::VarData>& vdatas, std::vector<ReadNC::VarData>& vsetdatas)
   std::map<std::string, ReadNC::VarData>& varInfo = _readNC->varInfo;
@@ -464,12 +464,12 @@ ErrorCode NCHelper::read_variable_setup(std::vector<std::string>& var_names, std
   return MB_SUCCESS;
-ErrorCode NCHelper::read_variable_to_set(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelper::read_variables_to_set(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
   Interface*& mbImpl = _readNC->mbImpl;
   DebugOutput& dbgOut = _readNC->dbgOut;
-  ErrorCode rval = read_variable_to_set_allocate(vdatas, tstep_nums);
+  ErrorCode rval = read_variables_to_set_allocate(vdatas, tstep_nums);
   ERRORR(rval, "Trouble allocating read variables to set.");
   // Finally, read into that space
@@ -874,7 +874,7 @@ ErrorCode NCHelper::create_dummy_variables()
   return MB_SUCCESS;
-ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelper::read_variables_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
   std::vector<int>& dimLens = _readNC->dimLens;
@@ -1102,23 +1102,23 @@ ErrorCode ScdNCHelper::read_variables(std::vector<std::string>& var_names, std::
   std::vector<ReadNC::VarData> vdatas;
   std::vector<ReadNC::VarData> vsetdatas;
-  ErrorCode rval = read_variable_setup(var_names, tstep_nums, vdatas, vsetdatas);
+  ErrorCode rval = read_variables_setup(var_names, tstep_nums, vdatas, vsetdatas);
   ERRORR(rval, "Trouble setting up read variable.");
   if (!vsetdatas.empty()) {
-    rval = read_variable_to_set(vsetdatas, tstep_nums);
+    rval = read_variables_to_set(vsetdatas, tstep_nums);
     ERRORR(rval, "Trouble read variables to set.");
   if (!vdatas.empty()) {
-    rval = read_scd_variable_to_nonset(vdatas, tstep_nums);
+    rval = read_scd_variables_to_nonset(vdatas, tstep_nums);
     ERRORR(rval, "Trouble read variables to entities verts/edges/faces.");
   return MB_SUCCESS;
-ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode ScdNCHelper::read_scd_variables_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -1244,11 +1244,11 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(std::vector<ReadNC::
   return rval;
-ErrorCode ScdNCHelper::read_scd_variable_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode ScdNCHelper::read_scd_variables_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
-  ErrorCode rval = read_scd_variable_to_nonset_allocate(vdatas, tstep_nums);
+  ErrorCode rval = read_scd_variables_to_nonset_allocate(vdatas, tstep_nums);
   ERRORR(rval, "Trouble allocating read variables.");
@@ -1434,21 +1434,21 @@ ErrorCode UcdNCHelper::read_variables(std::vector<std::string>& var_names, std::
 #ifdef PNETCDF_FILE
     // With pnetcdf support, we will use async read
-    rval = read_ucd_variable_to_nonset_async(vdatas, tstep_nums);
+    rval = read_ucd_variables_to_nonset_async(vdatas, tstep_nums);
 #else
     // Without pnetcdf support, we will use old read
-    rval = read_ucd_variable_to_nonset(vdatas, tstep_nums);
+    rval = read_ucd_variables_to_nonset(vdatas, tstep_nums);
 #endif
diff --git a/src/io/NCHelper.hpp b/src/io/NCHelper.hpp
index d134249..5b3b93c 100644
--- a/src/io/NCHelper.hpp
+++ b/src/io/NCHelper.hpp
@@ -40,13 +40,13 @@ public:
 protected:
   //! Separate set and non-set variables (common to scd mesh and ucd mesh)
-  ErrorCode read_variable_setup(std::vector<std::string>& var_names,
+  ErrorCode read_variables_setup(std::vector<std::string>& var_names,
                                             std::vector<ReadNC::VarData>& vsetdatas);
   //! Read set variables (common to scd mesh and ucd mesh)
-  ErrorCode read_variable_to_set(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums);
+  ErrorCode read_variables_to_set(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums);
   //! Convert variables in place
   ErrorCode convert_variable(ReadNC::VarData& var_data, int tstep_num);
@@ -72,8 +72,8 @@ protected:
   ErrorCode create_dummy_variables();
 private:
-  //! Used by read_variable_to_set()
-  ErrorCode read_variable_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums);
+  //! Used by read_variables_to_set()
+  ErrorCode read_variables_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums);
 protected:
   //! Allow NCHelper to directly access members of ReadNC
@@ -129,9 +129,9 @@ private:
   virtual ErrorCode read_variables(std::vector<std::string>& var_names, std::vector<int>& tstep_nums);
   //! Read non-set variables for scd mesh
-  ErrorCode read_scd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas,
+  ErrorCode read_scd_variables_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas,
-  ErrorCode read_scd_variable_to_nonset(std::vector<ReadNC::VarData>& vdatas,
+  ErrorCode read_scd_variables_to_nonset(std::vector<ReadNC::VarData>& vdatas,
   //! Create COORDS tag for quads coordinate
@@ -197,13 +197,13 @@ private:
                                    std::vector<int> &tstep_nums);
   //! Read non-set variables for ucd mesh (implemented differently in child classes)
-  virtual ErrorCode read_ucd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas,
+  virtual ErrorCode read_ucd_variables_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas,
                                                          std::vector<int>& tstep_nums) = 0;
 #ifdef PNETCDF_FILE
-  virtual ErrorCode read_ucd_variable_to_nonset_async(std::vector<ReadNC::VarData>& vdatas,
+  virtual ErrorCode read_ucd_variables_to_nonset_async(std::vector<ReadNC::VarData>& vdatas,
 #else
-  virtual ErrorCode read_ucd_variable_to_nonset(std::vector<ReadNC::VarData>& vdatas,
+  virtual ErrorCode read_ucd_variables_to_nonset(std::vector<ReadNC::VarData>& vdatas,
 #endif
diff --git a/src/io/NCHelperGCRM.cpp b/src/io/NCHelperGCRM.cpp
index 13103a8..25ed53c 100644
--- a/src/io/NCHelperGCRM.cpp
+++ b/src/io/NCHelperGCRM.cpp
@@ -403,7 +403,7 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
   return MB_SUCCESS;
-ErrorCode NCHelperGCRM::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -536,12 +536,12 @@ ErrorCode NCHelperGCRM::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC:
 #ifdef PNETCDF_FILE
-ErrorCode NCHelperGCRM::read_ucd_variable_to_nonset_async(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_async(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
   bool& noEdges = _readNC->noEdges;
-  ErrorCode rval = read_ucd_variable_to_nonset_allocate(vdatas, tstep_nums);
+  ErrorCode rval = read_ucd_variables_to_nonset_allocate(vdatas, tstep_nums);
@@ -656,13 +656,13 @@ ErrorCode NCHelperGCRM::read_ucd_variable_to_nonset_async(std::vector<ReadNC::Va
   return rval;
 #else
-ErrorCode NCHelperGCRM::read_ucd_variable_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
diff --git a/src/io/NCHelperGCRM.hpp b/src/io/NCHelperGCRM.hpp
index 160e538..2887e86 100644
--- a/src/io/NCHelperGCRM.hpp
+++ b/src/io/NCHelperGCRM.hpp
@@ -30,16 +30,16 @@ private:
   //! Implementation of NCHelper::get_mesh_type_name()
   virtual std::string get_mesh_type_name() { return "GCRM"; }
-  //! Implementation of UcdNCHelper::read_ucd_variable_to_nonset_allocate()
+  //! Implementation of UcdNCHelper::read_ucd_variables_to_nonset_allocate()
 #ifdef PNETCDF_FILE
-  //! Implementation of UcdNCHelper::read_ucd_variable_to_nonset_async()
+  //! Implementation of UcdNCHelper::read_ucd_variables_to_nonset_async()
 #else
-  //! Implementation of UcdNCHelper::read_ucd_variable_to_nonset()
+  //! Implementation of UcdNCHelper::read_ucd_variables_to_nonset()
 #endif
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index a296314..4aade2f 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -557,7 +557,7 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
   return MB_SUCCESS;
-ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -640,11 +640,11 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC
 #ifdef PNETCDF_FILE
-ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_async(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_async(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -802,11 +802,11 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_async(std::vector<ReadNC::V
   return rval;
 #else
-ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
diff --git a/src/io/NCHelperHOMME.hpp b/src/io/NCHelperHOMME.hpp
index a6d50f0..4c383bb 100644
--- a/src/io/NCHelperHOMME.hpp
+++ b/src/io/NCHelperHOMME.hpp
   virtual std::string get_mesh_type_name() { return "CAM_SE"; }
 #ifdef PNETCDF_FILE
 #else
 #endif
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index b453b82..ace33a2 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -515,7 +515,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   return MB_SUCCESS;
-ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -654,13 +654,13 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC:
 #ifdef PNETCDF_FILE
-ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_async(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_async(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -811,13 +811,13 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_async(std::vector<ReadNC::Va
   return rval;
 #else
-ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
diff --git a/src/io/NCHelperMPAS.hpp b/src/io/NCHelperMPAS.hpp
index 6c6dc99..9db8d4a 100644
--- a/src/io/NCHelperMPAS.hpp
+++ b/src/io/NCHelperMPAS.hpp
@@ -30,15 +30,15 @@ private:
   virtual std::string get_mesh_type_name() { return "MPAS"; }
 #ifdef PNETCDF_FILE
 #else
 #endif
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
