[MOAB-dev] pytaps: can't import iBase and iMesh
Anthony Scopatz scopatz at gmail.com
Mon Jun 9 10:11:58 CDT 2014
Hello Huayi,
This means that you have not linked iMesh.so to MOAB.  This is also what "U
imesh_getentities_" means (the U stands for undefined). There probably was
an error thrown in the setup.py.  Can you please report the full output of
a clean build?  Thanks!
Be Well
Anthony
On Mon, Jun 9, 2014 at 8:50 AM, Huayi Wei <huayiwei1984 at gmail.com> wrote:
>  Hi, there
> I installed pytaps on my computer with os Ubuntu 14.04 64 bit. And I met
> such an error when I import iBase and iMesh in Python:
> >>> from itaps import iBase, iMesh
> Traceback (most recent call last):
>   File "<stdin>", line 1, in <module>
> ImportError: /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg/itaps/iMesh.so: undefined symbol: imesh_getentities_
> And using the command nm -D nm -D
> /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg/itaps/iMesh.so,
> I can find imesh_getentities_ in iMesh.so`.
> By the way, when I compile cgm/moab/lasso, I use the option --with-pic
> following the suggestion on PyTAPS
> <http://pythonhosted.org/PyTAPS/install.html>. So what’s the problem?
> Please give me some suggestions about it. Thanks very much.
> Best
> Huayi
> 0000000000213c68 B __bss_start
>                  w __cxa_finalize
> 0000000000213c68 D _edata
> 0000000000213d10 B _end
> 000000000000b9e8 T _fini
>                  U free
>                  w __gmon_start__
>                  U imesh_addentarrtoset_
>                  U imesh_addentset_
>                  U imesh_addenttoset_
>                  U imesh_addprntchld_
>                  U imesh_createent_
>                  U imesh_createentarr_
>                  U imesh_createentset_
>                  U imesh_createtag_
>                  U imesh_createvtx_
>                  U imesh_createvtxarr_
>                  U imesh_deleteent_
>                  U imesh_deleteentarr_
>                  U imesh_destroyentset_
>                  U imesh_destroytag_
>                  U imesh_dtor_
>                  U imesh_endentarriter_
>                  U imesh_endentiter_
>                  U imesh_getadjentindices_
>                  U imesh_getadjtable_
>                  U imesh_getallentsettags_
>                  U imesh_getalltags_
>                  U imesh_getarrdata_
>                  U imesh_getchldn_
>                  U imesh_getdata_
>                  U imesh_getdescription_
>                  U imesh_getdfltstorage_
>                  U imesh_getent2ndadj_
>                  U imesh_getentadj_
>                  U imesh_getentarr2ndadj_
>                  U imesh_getentarradj_
>                  U imesh_getentarrtopo_
>                  U imesh_getentarrtype_
>                  U imesh_getentities_
>                  U imesh_getentsetdata_
>                  U imesh_getentsets_
>                  U imesh_getenttopo_
>                  U imesh_getenttype_
>                  U imesh_getgeometricdimension_
>                  U imesh_getnextentarriter_
>                  U imesh_getnextentiter_
>                  U imesh_getnumchld_
>                  U imesh_getnumentsets_
>                  U imesh_getnumoftopo_
>                  U imesh_getnumoftype_
>                  U imesh_getnumprnt_
>                  U imesh_getprnts_
>                  U imesh_getrootset_
>                  U imesh_gettaghandle_
>                  U imesh_gettagname_
>                  U imesh_gettagsizebytes_
>                  U imesh_gettagsizevalues_
>                  U imesh_gettagtype_
>                  U imesh_getvtxarrcoords_
>                  U imesh_getvtxcoord_
>                  U imesh_initentarriter_
>                  U imesh_initentiter_
>                  U imesh_intersect_
>                  U imesh_ischildof_
>                  U imesh_isentarrcontained_
>                  U imesh_isentcontained_
>                  U imesh_isentsetcontained_
>                  U imesh_islist_
>                  U imesh_load_
>                  U imesh_newmesh_
>                  U imesh_optimize_
>                  U imesh_resetentarriter_
>                  U imesh_resetentiter_
>                  U imesh_rmvarrtag_
>                  U imesh_rmventarrfromset_
>                  U imesh_rmventfromset_
>                  U imesh_rmventset_
>                  U imesh_rmventsettag_
>                  U imesh_rmvprntchld_
>                  U imesh_rmvtag_
>                  U imesh_save_
>                  U imesh_setadjtable_
>                  U imesh_setarrdata_
>                  U imesh_setdata_
>                  U imesh_setentsetdata_
>                  U imesh_setgeometricdimension_
>                  U imesh_setvtxarrcoords_
>                  U imesh_setvtxcoord_
>                  U imesh_subtract_
>                  U imesh_unite_
> 00000000000046e8 T _init
> 000000000000af60 T initiMesh
>                  w _ITM_deregisterTMCloneTable
>                  w _ITM_registerTMCloneTable
>                  w _Jv_RegisterClasses
>                  U malloc
>                  U PyArg_ParseTuple
>                  U PyArg_ParseTupleAndKeywords
>                  U PyBool_FromLong
>                  U PyBool_Type
>                  U Py_BuildValue
>                  U PyCObject_AsVoidPtr
>                  U PyCObject_FromVoidPtr
>                  U PyCObject_Type
>                  U PyDict_SetItemString
>                  U PyErr_BadArgument
>                  U PyErr_Clear
>                  U PyErr_Format
>                  U PyErr_Occurred
>                  U PyErr_Print
>                  U PyErr_SetNone
>                  U PyErr_SetString
>                  U PyErr_WarnEx
>                  U PyExc_AttributeError
>                  U PyExc_DeprecationWarning
>                  U PyExc_ImportError
>                  U PyExc_RuntimeError
>                  U PyExc_TypeError
>                  U PyExc_ValueError
>                  U PyImport_ImportModule
>                  U Py_InitModule4_64
>                  U PyInt_AsLong
>                  U PyInt_FromLong
>                  U PyModule_AddObject
>                  U _Py_NoneStruct
>                  U _Py_NotImplementedStruct
>                  U PyNumber_Add
>                  U PyObject_Call
>                  U PyObject_CallFunction
>                  U PyObject_CallObject
>                  U PyObject_GenericGetAttr
>                  U PyObject_GetAttr
>                  U PyObject_GetAttrString
>                  U PyObject_SelfIter
>                  U PyString_FromFormat
>                  U PyString_FromString
>                  U _Py_TrueStruct
>                  U PyTuple_Pack
>                  U PyTuple_Type
>                  U PyType_GenericNew
>                  U PyType_IsSubtype
>                  U PyType_Ready
>                  U Py_VaBuildValue
>                  U __stack_chk_fail
>                  U strlen
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140609/747ec3e7/attachment-0001.html>
