[MOAB-dev] commit/MOAB: danwu: Updated unit test read_gcrm_nc for GCRM reader (most test cases are now enabled).
commits-noreply at bitbucket.org
Wed May 21 17:23:43 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/2685565c68a1/
Changeset: 2685565c68a1
Branch: master
User: danwu
Date: 2014-05-22 00:23:13
Summary: Updated unit test read_gcrm_nc for GCRM reader (most test cases are now enabled).
Affected #: 1 file
diff --git a/test/io/read_gcrm_nc.cpp b/test/io/read_gcrm_nc.cpp
index d38ca2c..1304495 100644
--- a/test/io/read_gcrm_nc.cpp
+++ b/test/io/read_gcrm_nc.cpp
@@ -21,13 +21,13 @@ void test_read_onevar();
void test_read_onetimestep();
void test_read_nomesh();
void test_read_novars();
-void test_read_no_mixed_elements(); // Test read option NO_MIXED_ELEMENTS
void test_read_no_edges(); // Test read option NO_EDGES
void test_gather_onevar(); // Test gather set with one variable
void get_options(std::string& opts);
-const double eps = 1e-20;
+const double eps = 1e-6;
+const int layers = 256;
int main(int argc, char* argv[])
@@ -42,12 +42,11 @@ int main(int argc, char* argv[])
#endif
result += RUN_TEST(test_read_all);
- //result += RUN_TEST(test_read_onevar);
- //result += RUN_TEST(test_read_onetimestep);
- //result += RUN_TEST(test_read_nomesh);
- //result += RUN_TEST(test_read_novars);
- //result += RUN_TEST(test_read_no_mixed_elements);
- //result += RUN_TEST(test_read_no_edges);
+ result += RUN_TEST(test_read_onevar);
+ result += RUN_TEST(test_read_onetimestep);
+ result += RUN_TEST(test_read_nomesh);
+ result += RUN_TEST(test_read_novars);
+ result += RUN_TEST(test_read_no_edges);
//result += RUN_TEST(test_gather_onevar);
#ifdef USE_MPI
@@ -66,14 +65,13 @@ void test_read_all()
std::string opts;
get_options(opts);
- opts+=";DEBUG_IO=2";
// Read mesh and read all variables at all timesteps
ErrorCode rval = mb.load_file(example, 0, opts.c_str());
CHECK_ERR(rval);
mb.write_file("gcrm.h5m");
-#if 0
int procs = 1;
#ifdef USE_MPI
ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
@@ -82,14 +80,15 @@ void test_read_all()
// Make check runs this test on one processor
if (1 == procs) {
- // For each tag, check two values
- double val[2];
+ // For each tag, check values on two entities
+ // There are 256 layers, only check on first two
+ double val[2 * layers];
- // Check tags for vertex variable vorticity
- Tag vorticity_tag0, vorticity_tag1;
- rval = mb.tag_get_handle("vorticity0", 1, MB_TYPE_DOUBLE, vorticity_tag0);
+ // Check tags for vertex variable u
+ Tag u_tag0, u_tag1;
+ rval = mb.tag_get_handle("u0", layers, MB_TYPE_DOUBLE, u_tag0);
CHECK_ERR(rval);
- rval = mb.tag_get_handle("vorticity1", 1, MB_TYPE_DOUBLE, vorticity_tag1);
+ rval = mb.tag_get_handle("u1", layers, MB_TYPE_DOUBLE, u_tag1);
CHECK_ERR(rval);
// Get vertices (1280 edges)
@@ -99,22 +98,34 @@ void test_read_all()
CHECK_EQUAL((size_t)1280, verts.size());
CHECK_EQUAL((size_t)1, verts.psize());
- // Check vorticity tag values on first two vertices
- EntityHandle vert_ents[] = {verts[0], verts[1]};
- rval = mb.tag_get_data(vorticity_tag0, vert_ents, 2, val);
+ // Check u tag values on first and last vertices
+ EntityHandle vert_ents[] = {verts[0], verts[1279]};
+ // Timestep 0
+ rval = mb.tag_get_data(u_tag0, vert_ents, 2, val);
CHECK_ERR(rval);
- CHECK_REAL_EQUAL(1.1, val[0], eps);
- CHECK_REAL_EQUAL(1.2, val[1], eps);
- rval = mb.tag_get_data(vorticity_tag1, vert_ents, 2, val);
+ // Layer 0
+ CHECK_REAL_EQUAL(-4.839992, val[0 * layers], eps);
+ CHECK_REAL_EQUAL(-3.699257, val[1 * layers], eps);
+ // Layer 1
+ CHECK_REAL_EQUAL(-4.839925, val[0 * layers + 1], eps);
+ CHECK_REAL_EQUAL(-3.699206, val[1 * layers + 1], eps);
+ // Timestep 1
+ rval = mb.tag_get_data(u_tag1, vert_ents, 2, val);
CHECK_ERR(rval);
- CHECK_REAL_EQUAL(2.1, val[0], eps);
- CHECK_REAL_EQUAL(2.2, val[1], eps);
- // Check tags for edge variable u
- Tag u_tag0, u_tag1;
- rval = mb.tag_get_handle("u0", 1, MB_TYPE_DOUBLE, u_tag0);
+ // Layer 0
+ CHECK_REAL_EQUAL(-4.712473, val[0 * layers], eps);
+ CHECK_REAL_EQUAL(-3.601793, val[1 * layers], eps);
+ // Layer 1
+ CHECK_REAL_EQUAL(-4.712409, val[0 * layers + 1], eps);
+ CHECK_REAL_EQUAL(-3.601743, val[1 * layers + 1], eps);
+ // Check tags for edge variable wind
+ Tag wind_tag0, wind_tag1;
+ rval = mb.tag_get_handle("wind0", layers, MB_TYPE_DOUBLE, wind_tag0);
CHECK_ERR(rval);
- rval = mb.tag_get_handle("u1", 1, MB_TYPE_DOUBLE, u_tag1);
+ rval = mb.tag_get_handle("wind1", layers, MB_TYPE_DOUBLE, wind_tag1);
CHECK_ERR(rval);
// Get edges (1920 edges)
@@ -124,22 +135,34 @@ void test_read_all()
CHECK_EQUAL((size_t)1920, edges.size());
CHECK_EQUAL((size_t)1, edges.psize());
- // Check u tag values on two specified edges
- EntityHandle edge_ents[] = {edges[5], edges[6]};
- rval = mb.tag_get_data(u_tag0, edge_ents, 2, val);
+ // Check wind tag values on first and last edges
+ EntityHandle edge_ents[] = {edges[0], edges[1919]};
+ // Timestep 0
+ rval = mb.tag_get_data(wind_tag0, edge_ents, 2, val);
CHECK_ERR(rval);
- CHECK_REAL_EQUAL(1.113138721544778, val[0], eps);
- CHECK_REAL_EQUAL(-1.113138721930009, val[1], eps);
- rval = mb.tag_get_data(u_tag1, edge_ents, 2, val);
+ // Layer 0
+ CHECK_REAL_EQUAL(-5.081991, val[0 * layers], eps);
+ CHECK_REAL_EQUAL(-6.420274, val[1 * layers], eps);
+ // Layer 1
+ CHECK_REAL_EQUAL(-5.081781, val[0 * layers + 1], eps);
+ CHECK_REAL_EQUAL(-6.419831, val[1 * layers + 1], eps);
+ // Timestep 1
+ rval = mb.tag_get_data(wind_tag1, edge_ents, 2, val);
CHECK_ERR(rval);
- CHECK_REAL_EQUAL(2.113138721544778, val[0], eps);
- CHECK_REAL_EQUAL(-2.113138721930009, val[1], eps);
- // Check tags for cell variable ke
- Tag ke_tag0, ke_tag1;
- rval = mb.tag_get_handle("ke0", 1, MB_TYPE_DOUBLE, ke_tag0);
+ // Layer 0
+ CHECK_REAL_EQUAL(-4.948097, val[0 * layers], eps);
+ CHECK_REAL_EQUAL(-6.251121, val[1 * layers], eps);
+ // Layer 1
+ CHECK_REAL_EQUAL(-4.947892, val[0 * layers + 1], eps);
+ CHECK_REAL_EQUAL(-6.250690, val[1 * layers + 1], eps);
+ // Check tags for cell variable vorticity
+ Tag vorticity_tag0, vorticity_tag1;
+ rval = mb.tag_get_handle("vorticity0", layers, MB_TYPE_DOUBLE, vorticity_tag0);
CHECK_ERR(rval);
- rval = mb.tag_get_handle("ke1", 1, MB_TYPE_DOUBLE, ke_tag1);
+ rval = mb.tag_get_handle("vorticity1", layers, MB_TYPE_DOUBLE, vorticity_tag1);
CHECK_ERR(rval);
// Get cells (12 pentagons and 630 hexagons)
@@ -147,27 +170,33 @@ void test_read_all()
rval = mb.get_entities_by_type(0, MBPOLYGON, cells);
CHECK_ERR(rval);
CHECK_EQUAL((size_t)642, cells.size());
-#ifdef USE_MPI
- // If MOAB is compiled parallel, sequence size requested are increased
- // by a factor of 1.5, to allow for ghosts. This will introduce a gap
- // between the two face sequences.
- CHECK_EQUAL((size_t)2, cells.psize());
-#else
+ // GCRM pentagons are always padded to hexagons
CHECK_EQUAL((size_t)1, cells.psize());
-#endif
- // Check ke tag values on first pentagon and first hexagon
- EntityHandle cell_ents[] = {cells[0], cells[12]};
- rval = mb.tag_get_data(ke_tag0, cell_ents, 2, val);
+ // Check vorticity tag values on first and last cells
+ EntityHandle cell_ents[] = {cells[0], cells[641]};
+ // Timestep 0
+ rval = mb.tag_get_data(vorticity_tag0, cell_ents, 2, val);
CHECK_ERR(rval);
- CHECK_REAL_EQUAL(15.001, val[0], eps);
- CHECK_REAL_EQUAL(16.013, val[1], eps);
- rval = mb.tag_get_data(ke_tag1, cell_ents, 2, val);
+ // Layer 0
+ CHECK_REAL_EQUAL(3.629994, val[0 * layers], eps);
+ CHECK_REAL_EQUAL(-0.554888, val[1 * layers], eps);
+ // Layer 1
+ CHECK_REAL_EQUAL(3.629944, val[0 * layers + 1], eps);
+ CHECK_REAL_EQUAL(-0.554881, val[1 * layers + 1], eps);
+ // Timestep 1
+ rval = mb.tag_get_data(vorticity_tag1, cell_ents, 2, val);
CHECK_ERR(rval);
- CHECK_REAL_EQUAL(25.001, val[0], eps);
- CHECK_REAL_EQUAL(26.013, val[1], eps);
+ // Layer 0
+ CHECK_REAL_EQUAL(3.534355, val[0 * layers], eps);
+ CHECK_REAL_EQUAL(-0.540269, val[1 * layers], eps);
+ // Layer 1
+ CHECK_REAL_EQUAL(3.534306, val[0 * layers + 1], eps);
+ CHECK_REAL_EQUAL(-0.540262, val[1 * layers + 1], eps);
-#endif
@@ -178,8 +207,8 @@ void test_read_onevar()
std::string opts;
get_options(opts);
- // Read mesh and read cell variable ke at all timesteps
- opts += ";VARIABLE=ke";
+ // Read mesh and read cell variable vorticity at all timesteps
+ opts += ";VARIABLE=vorticity";
ErrorCode rval = mb.load_file(example, NULL, opts.c_str());
CHECK_ERR(rval);
@@ -191,11 +220,11 @@ void test_read_onevar()
if (1 == procs) {
- // Check ke tags
+ // Check vorticity tags
CHECK_ERR(rval);
CHECK_ERR(rval);
@@ -204,32 +233,41 @@ void test_read_onevar()
CHECK_ERR(rval);
-#ifdef USE_MPI
-#else
-#endif
- // Check ke tag values on 4 cells: first pentagon, last pentagon,
- // first hexagon, and last hexagon
- EntityHandle cell_ents[] = {cells[0], cells[11], cells[12], cells[641]};
- double ke0_val[4];
- rval = mb.tag_get_data(ke_tag0, cell_ents, 4, ke0_val);
+ // Check vorticity tag values on 4 cells: first cell, two median cells, and last cell
+ EntityHandle cell_ents[] = {cells[0], cells[320], cells[321], cells[641]};
+ double vorticity_val[4 * layers];
+ // Timestep 0
+ rval = mb.tag_get_data(vorticity_tag0, cell_ents, 4, vorticity_val);
CHECK_ERR(rval);
- CHECK_REAL_EQUAL(15.001, ke0_val[0], eps);
- CHECK_REAL_EQUAL(15.012, ke0_val[1], eps);
- CHECK_REAL_EQUAL(16.013, ke0_val[2], eps);
- CHECK_REAL_EQUAL(16.642, ke0_val[3], eps);
- double ke1_val[4];
- rval = mb.tag_get_data(ke_tag1, cell_ents, 4, ke1_val);
+ // Layer 0
+ CHECK_REAL_EQUAL(3.629994, vorticity_val[0 * layers], eps);
+ CHECK_REAL_EQUAL(0.131688, vorticity_val[1 * layers], eps);
+ CHECK_REAL_EQUAL(-0.554888, vorticity_val[2 * layers], eps);
+ CHECK_REAL_EQUAL(-0.554888, vorticity_val[3 * layers], eps);
+ // Layer 1
+ CHECK_REAL_EQUAL(3.629944, vorticity_val[0 * layers + 1], eps);
+ CHECK_REAL_EQUAL(0.131686, vorticity_val[1 * layers + 1], eps);
+ CHECK_REAL_EQUAL(-0.554881, vorticity_val[2 * layers + 1], eps);
+ CHECK_REAL_EQUAL(-0.554881, vorticity_val[3 * layers + 1], eps);
+ // Timestep 1
+ rval = mb.tag_get_data(vorticity_tag1, cell_ents, 4, vorticity_val);
CHECK_ERR(rval);
- CHECK_REAL_EQUAL(25.001, ke1_val[0], eps);
- CHECK_REAL_EQUAL(25.012, ke1_val[1], eps);
- CHECK_REAL_EQUAL(26.013, ke1_val[2], eps);
- CHECK_REAL_EQUAL(26.642, ke1_val[3], eps);
+ // Layer 0
+ CHECK_REAL_EQUAL(3.534355, vorticity_val[0 * layers], eps);
+ CHECK_REAL_EQUAL(0.128218, vorticity_val[1 * layers], eps);
+ CHECK_REAL_EQUAL(-0.540269, vorticity_val[2 * layers], eps);
+ CHECK_REAL_EQUAL(-0.540269, vorticity_val[3 * layers], eps);
+ // Layer 1
+ CHECK_REAL_EQUAL(3.534306, vorticity_val[0 * layers + 1], eps);
+ CHECK_REAL_EQUAL(0.128216, vorticity_val[1 * layers + 1], eps);
+ CHECK_REAL_EQUAL(-0.540262, vorticity_val[2 * layers + 1], eps);
+ CHECK_REAL_EQUAL(-0.540262, vorticity_val[3 * layers + 1], eps);
@@ -248,10 +286,10 @@ void test_read_onetimestep()
// Tag vorticity0 should not exist
CHECK_EQUAL(rval, MB_TAG_NOT_FOUND);
CHECK_ERR(rval);
@@ -275,10 +313,10 @@ void test_read_nomesh()
// Check u tags
Tag u_tag0, u_tag1;
CHECK_ERR(rval);
// Tag u1 should not exist
// Read all variables at 2nd timestep 0, no need to read mesh
@@ -287,7 +325,7 @@ void test_read_nomesh()
CHECK_ERR(rval);
// Check tag u1 again
// Tag u1 should exist at this time
CHECK_ERR(rval);
@@ -312,42 +350,40 @@ void test_read_novars()
CHECK_ERR(rval);
// Read mesh, but still no variables
- opts = orig + ";VARIABLE=;TIMESTEP=0;DEBUG_IO=2";
+ opts = orig + ";VARIABLE=";
rval = mb.load_file(example, &file_set, opts.c_str());
CHECK_ERR(rval);
- rval = mb.write_file("gcrm.vtk");
-#if 0
- // Check ke tags
- // Tag ke0 should not exist
+ // Tag vorticity0 should not exist
- // Tag ke1 should not exist
+ // Tag vorticity1 should not exist
- // Read ke at 1st timestep, no need to read mesh
- opts = orig + ";VARIABLE=ke;TIMESTEP=0;NOMESH";
+ // Read vorticity at 1st timestep, no need to read mesh
+ opts = orig + ";VARIABLE=vorticity;TIMESTEP=0;NOMESH";
CHECK_ERR(rval);
- // Check ke tags again
- // Tag ke0 should exist at this time
+ // Check vorticity tags again
+ // Tag vorticity0 should exist at this time
CHECK_ERR(rval);
- // Tag ke1 should still not exist
+ // Tag vorticity1 should still not exist
- // Read ke at 2nd timestep, no need to read mesh
- opts = orig + ";VARIABLE=ke;TIMESTEP=1;NOMESH";
+ // Read vorticity at 2nd timestep, no need to read mesh
+ opts = orig + ";VARIABLE=vorticity;TIMESTEP=1;NOMESH";
CHECK_ERR(rval);
- // Check tag ke1 again
- // Tag ke1 should exist at this time
+ // Check tag vorticity1 again
+ // Tag vorticity1 should exist at this time
CHECK_ERR(rval);
int procs = 1;
@@ -364,90 +400,41 @@ void test_read_novars()
CHECK_ERR(rval);
-#ifdef USE_MPI
-#else
-#endif
- CHECK_ERR(rval);
- CHECK_ERR(rval);
-#endif
- Core moab;
- Interface& mb = moab;
- std::string opts;
- get_options(opts);
- // Read mesh with no mixed elements and read all variables at all timesteps
- opts += ";NO_MIXED_ELEMENTS";
- ErrorCode rval = mb.load_file(example, NULL, opts.c_str());
- CHECK_ERR(rval);
- int procs = 1;
-#ifdef USE_MPI
- ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
- procs = pcomm->proc_config().proc_size();
-#endif
- // Make check runs this test on one processor
- if (1 == procs) {
- // Check ke tags
- CHECK_ERR(rval);
- CHECK_ERR(rval);
- // Get cells (12 pentagons and 630 hexagons)
- Range cells;
- rval = mb.get_entities_by_type(0, MBPOLYGON, cells);
+ // Timestep 0
CHECK_ERR(rval);
- CHECK_EQUAL((size_t)642, cells.size());
- // Only one group of cells (pentagons are padded to hexagons,
- // e.g. connectivity [1 2 3 4 5] => [1 2 3 4 5 5])
- CHECK_EQUAL((size_t)1, cells.psize());
+ // Layer 0
+ // Layer 1
+ // Timestep 1
CHECK_ERR(rval);
- CHECK_ERR(rval);
+ // Layer 0
+ // Layer 1
@@ -472,73 +459,7 @@ void test_read_no_edges()
- Core moab;
- EntityHandle file_set;
- ErrorCode rval = mb.create_meshset(MESHSET_SET, file_set);
- CHECK_ERR(rval);
- std::string opts;
- // Read cell variable ke and create gather set on processor 0
- opts += ";VARIABLE=ke;GATHER_SET=0";
- rval = mb.load_file(example, &file_set, opts.c_str());
- CHECK_ERR(rval);
-#ifdef USE_MPI
- int rank = pcomm->proc_config().proc_rank();
- Range cells, cells_owned;
- rval = mb.get_entities_by_type(file_set, MBPOLYGON, cells);
- CHECK_ERR(rval);
- // Get local owned cells
- rval = pcomm->filter_pstatus(cells, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &cells_owned);
- CHECK_ERR(rval);
- EntityHandle gather_set = 0;
- if (0 == rank) {
- // Get gather set
- ReadUtilIface* readUtilIface;
- mb.query_interface(readUtilIface);
- rval = readUtilIface->get_gather_set(gather_set);
- CHECK_ERR(rval);
- assert(gather_set != 0);
- Tag ke_tag0, gid_tag;
- rval = mb.tag_get_handle("ke0", 1, MB_TYPE_DOUBLE, ke_tag0, MB_TAG_DENSE);
- CHECK_ERR(rval);
- rval = mb.tag_get_handle(GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, gid_tag, MB_TAG_DENSE);
- CHECK_ERR(rval);
- pcomm->gather_data(cells_owned, ke_tag0, gid_tag, gather_set, 0);
- if (0 == rank) {
- // Get gather set cells
- Range gather_set_cells;
- rval = mb.get_entities_by_type(gather_set, MBPOLYGON, gather_set_cells);
- CHECK_ERR(rval);
- CHECK_EQUAL((size_t)642, gather_set_cells.size());
- CHECK_EQUAL((size_t)2, gather_set_cells.psize());
- // Check ke0 tag values on 4 gather set cells: first pentagon, last pentagon,
- EntityHandle cell_ents[] = {gather_set_cells[0], gather_set_cells[11],
- gather_set_cells[12], gather_set_cells[641]};
- CHECK_ERR(rval);
-#endif
+ // TBD
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
