[MOAB-dev] commit/MOAB: danwu: Removed a warning (from buildbot output of builder moab-32bit) for Tqdcfr.cpp. This -Wsign-compare warning is only reproducible in a 32-bit moab build.
commits-noreply at bitbucket.org
Tue May 20 15:09:32 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/fa13025fa861/
Changeset: fa13025fa861
Branch: master
User: danwu
Date: 2014-05-20 22:09:19
Summary: Removed a warning (from buildbot output of builder moab-32bit) for Tqdcfr.cpp. This -Wsign-compare warning is only reproducible in a 32-bit moab build.
Affected #: 1 file
diff --git a/src/io/Tqdcfr.cpp b/src/io/Tqdcfr.cpp
index 7416164..522bc55 100644
--- a/src/io/Tqdcfr.cpp
+++ b/src/io/Tqdcfr.cpp
@@ -2329,7 +2329,7 @@ ErrorCode Tqdcfr::read_acis_records( const char* sat_filename )
// get next occurrence of '#' (record terminator)
ret = strchr(&(char_buf[buf_pos]), '#');
- while (ret && ret+1-&char_buf[0] < bytes_left && *(ret+1) != '\n')
+ while (ret && (unsigned int)(ret+1-&char_buf[0]) < bytes_left && *(ret+1) != '\n')
ret = strchr(ret+1, '#');
if (NULL != ret) {
// grab the string (inclusive of the record terminator and the line feed) and complete the record
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
