[MOAB-dev] commit/MOAB: danwu: Removed some warnings (-Wunused-parameter and -Wunused-variable) for ReadCGM.cpp.
commits-noreply at bitbucket.org
Tue May 20 09:51:46 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/e3e1bcfcdb74/
Changeset: e3e1bcfcdb74
Branch: master
User: danwu
Date: 2014-05-20 16:51:34
Summary: Removed some warnings (-Wunused-parameter and -Wunused-variable) for ReadCGM.cpp.
Affected #: 1 file
diff --git a/src/io/ReadCGM.cpp b/src/io/ReadCGM.cpp
index 19217e1..c4db384 100644
--- a/src/io/ReadCGM.cpp
+++ b/src/io/ReadCGM.cpp
@@ -421,7 +421,7 @@ ErrorCode ReadCGM::create_group_entsets( Interface* moab, std::map<RefEntity*,En
return MB_SUCCESS;
-ErrorCode ReadCGM::store_group_content( Interface* moab, std::map<RefEntity*,EntityHandle>* entitymap )
+ErrorCode ReadCGM::store_group_content( Interface* /* moab */, std::map<RefEntity*,EntityHandle>* entitymap )
ErrorCode rval;
@@ -532,8 +532,8 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
// CGM data
std::map<RefEntity*,EntityHandle>::iterator ci;
- const char geom_categories[][CATEGORY_TAG_SIZE] =
- {"Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0"};
+ //const char geom_categories[][CATEGORY_TAG_SIZE] =
+ //{"Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0"};
DLIList<ModelEntity*> me_list;
@@ -560,7 +560,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
// create entity sets for all geometric entities
DLIList<RefEntity*> entlist;
std::map<RefEntity*,EntityHandle> entmap[5]; // one for each dim, and one for groups
- std::map<RefEntity*,EntityHandle>* entmap_ptr = entmap;
+ //std::map<RefEntity*,EntityHandle>* entmap_ptr = entmap;
rval = create_entity_sets( mdbImpl, entmap );
if (rval!=MB_SUCCESS) return rval;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
