[MOAB-dev] commit/MOAB: 91 new changesets
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Tue May 20 01:01:55 CDT 2014
91 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/26dbacbd995f/
Changeset:   26dbacbd995f
Branch:      None
User:        pshriwise
Date:        2014-02-14 00:56:36
Summary:     Created a new file for basic tests on ReadCGM using a simple geometry. Old ReadCGM test filed renamed to reduce confusion.
Affected #:  1 file
diff --git a/test/io/read_cgm_load_test.cpp b/test/io/read_cgm_load_test.cpp
index 5377220..9704ee7 100644
--- a/test/io/read_cgm_load_test.cpp
+++ b/test/io/read_cgm_load_test.cpp
@@ -43,7 +43,8 @@ void read_multiple_test()
 int main(int /* argc */, char** /* argv */)
-  int result = RUN_TEST( read_multiple_test );
+  int result = RUN_TEST( read_multiple_test ) ;
   return result;
https://bitbucket.org/fathomteam/moab/commits/e1b9d54d39a3/
Changeset:   e1b9d54d39a3
Branch:      None
User:        pshriwise
Date:        2014-02-14 00:56:37
Summary:     Removed unused tag_get_handle call in read_cgm testing
Affected #:  1 file
diff --git a/test/io/read_cgm_basic_test.cpp b/test/io/read_cgm_basic_test.cpp
index 7a2d07d..14e03fd 100644
--- a/test/io/read_cgm_basic_test.cpp
+++ b/test/io/read_cgm_basic_test.cpp
@@ -37,10 +37,6 @@ void read_cube_test()
   ErrorCode rval = mb.load_file(input_cube); CHECK_ERR(rval);
-  Tag geom_tag;
-  rval = mb.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER,
-                                  geom_tag, MB_TAG_SPARSE|MB_TAG_CREAT);
   CHECK_ERR(rval);
   int number_of_tris;
https://bitbucket.org/fathomteam/moab/commits/ee59212f9cb7/
Changeset:   ee59212f9cb7
Branch:      None
User:        pshriwise
Date:        2014-02-14 01:02:37
Summary:     Attempt at fixing the problem with loading a file multiple times in clean MOAB instances.
Affected #:  1 file
index 14e03fd..40d75be 100644
@@ -31,22 +31,32 @@ static const char input_cube[] = "cube.sat";
 #endif
 #endif
-void read_cube_test()
-  Core mb;
-  ErrorCode rval = mb.load_file(input_cube); CHECK_ERR(rval);
+void read_file( Interface* moab, const char* input_file );
+void read_cube_test();
+  ErrorCode rval = moab->load_file( input_file );
   CHECK_ERR(rval);
+  ErrorCode rval;
+  Core moab;
+  Interface* mb = &moab;
+  mb->delete_mesh();
+  read_file( mb, input_cube );
   int number_of_tris;
-  rval = mb.get_number_entities_by_type(0, MBTRI , number_of_tris);
+  rval = mb->get_number_entities_by_type(0, MBTRI , number_of_tris);
   std::cout << "Number of Triangles = " << number_of_tris << std::endl;
   CHECK_ERR(rval);
   int number_of_vertices;
-  rval = mb.get_number_entities_by_type(0, MBVERTEX, number_of_vertices);
+  rval = mb->get_number_entities_by_type(0, MBVERTEX, number_of_vertices);
   CHECK_ERR(rval);
@@ -54,13 +64,14 @@ void read_cube_test()
   if( number_of_vertices !=8) rval = MB_FAILURE; CHECK_ERR(rval);
   int result = 0;
   result += RUN_TEST( read_cube_test );
   return result;
https://bitbucket.org/fathomteam/moab/commits/7eb2f8c1296f/
Changeset:   7eb2f8c1296f
Branch:      None
User:        pshriwise
Date:        2014-02-14 01:04:11
Summary:     More changes to decypher how to create new moab instances.
Affected #:  1 file
index 40d75be..3be49d2 100644
@@ -46,7 +46,6 @@ void read_cube_test()
   ErrorCode rval;
   Core moab;
-  mb->delete_mesh();
   int number_of_tris;
@@ -66,12 +65,59 @@ void read_cube_test()
+void delete_mesh_test()
+ Core moab;
+ ErrorCode rval;
+ Tag geom_tag;
+ rval = mb->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1,
+				MB_TYPE_INTEGER, geom_tag, moab::MB_TAG_DENSE|moab::MB_TAG_CREAT );
+ CHECK_ERR(rval);
+ Range geom_sets[4];
+ for(unsigned dim=0; dim<4; dim++)
+	void *val[] = {&dim};
+	rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag,
+	  					    val, 1, geom_sets[dim] );
+        CHECK_ERR(rval);
+        if( geom_sets[dim].size() == 0 ) std::cout << "Warning: No geom sets to begin with" << std::endl;
+ Range geom_sets_after[4];
+	void *val_after[] = {&dim};
+	  					    val_after, 1, geom_sets_after[dim] );
+        CHECK_ERR(rval);
+        if( 0 != geom_sets_after[dim].size() ) rval = MB_FAILURE;
+        CHECK_ERR(rval);
   int result = 0;
-  result += RUN_TEST( read_cube_test );
+  result += RUN_TEST( read_cube_test );
+  result += RUN_TEST( delete_mesh_test );
   return result;
https://bitbucket.org/fathomteam/moab/commits/1b0dcfa41a99/
Changeset:   1b0dcfa41a99
Branch:      None
User:        pshriwise
Date:        2014-02-14 01:07:51
Summary:     Separated test for cube verts and test for cube triangles. Updated method of value comparison.
Affected #:  1 file
index 3be49d2..cdce4fd 100644
@@ -41,7 +41,22 @@ void read_file( Interface* moab, const char* input_file )
   CHECK_ERR(rval);
+void read_cube_verts_test()
+  ErrorCode rval;
+  Core moab;
+  int number_of_vertices;
+  CHECK_ERR(rval);
+  CHECK_EQUAL( 8, number_of_vertices);
+void read_cube_tris_test()
   ErrorCode rval;
   Core moab;
@@ -54,18 +69,20 @@ void read_cube_test()
   CHECK_ERR(rval);
-  int number_of_vertices;
-  rval = mb->get_number_entities_by_type(0, MBVERTEX, number_of_vertices);
-  CHECK_ERR(rval);
+  CHECK_EQUAL( 12, number_of_tris);
-  if( number_of_tris != 12) rval = MB_FAILURE; CHECK_ERR(rval);
-  if( number_of_vertices !=8) rval = MB_FAILURE; CHECK_ERR(rval);
+int main(int /* argc */, char** /* argv */)
+  int result = 0;
+  result += RUN_TEST( read_cube_tris_test );
+  return result;
  Core moab;
@@ -109,15 +126,4 @@ void delete_mesh_test()
-int main(int /* argc */, char** /* argv */)
-  int result = 0;
-  result += RUN_TEST( delete_mesh_test );
-  return result;
https://bitbucket.org/fathomteam/moab/commits/c6c383b22a79/
Changeset:   c6c383b22a79
Branch:      None
User:        pshriwise
Summary:     Added multiple new tests for the correct number of geometric entities in read_cgm_basic_test.cpp
Affected #:  1 file
index cdce4fd..4977497 100644
@@ -32,7 +32,6 @@ static const char input_cube[] = "cube.sat";
 #endif
-void read_cube_test();
@@ -72,12 +71,90 @@ void read_cube_tris_test()
+void read_cube_curves_test()
+  ErrorCode rval;
+  Core moab;
+  Tag geom_tag;
+  CHECK_ERR(rval);
+  Range curves;
+  int dim = 1;
+  int number_of_curves;
+  rval = mb->get_number_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag,
+	  					    val, 1, number_of_curves );
+  CHECK_ERR(rval);
+  CHECK_EQUAL( 12, number_of_curves);
+void read_cube_surfs_test()
+  ErrorCode rval;
+  Core moab;
+  Tag geom_tag;
+  CHECK_ERR(rval);
+  Range curves;
+  int dim = 2;
+  int number_of_surfs;
+	  					    val, 1, number_of_surfs );
+  CHECK_ERR(rval);
+  CHECK_EQUAL( 6, number_of_surfs);
+void read_cube_vols_test()
+  ErrorCode rval;
+  Core moab;
+  Tag geom_tag;
+  CHECK_ERR(rval);
+  Range curves;
+  int dim = 3;
+  int number_of_vols;
+	  					    val, 1, number_of_vols );
+  CHECK_ERR(rval);
+  CHECK_EQUAL( 1, number_of_vols);
   int result = 0;
-  result += RUN_TEST( read_cube_tris_test );
+  result += RUN_TEST( read_cube_vols_test );
   return result;
https://bitbucket.org/fathomteam/moab/commits/e8d47e3c83a9/
Changeset:   e8d47e3c83a9
Branch:      None
User:        pshriwise
Summary:     Added a function to verify that mesh vertices are in the correct locations.
Affected #:  1 file
index 4977497..4eafe96 100644
@@ -150,11 +150,81 @@ void read_cube_vols_test()
+void read_cube_vertex_pos_test()
+  ErrorCode rval;
+  Core moab;
+  //First check that the correct number of vertices are present
+  int number_of_verts;
+  rval = mb->get_number_entities_by_type( 0 , MBVERTEX , number_of_verts);
+  CHECK_ERR(rval);
+  CHECK_EQUAL(8, number_of_verts);
+  //Retrieve all vertex handles from the mesh
+  Range verts;
+  rval = mb->get_entities_by_type( 0, MBVERTEX, verts);
+  CHECK_ERR(rval);
+  //Get the vertex coordinates
+  double x[verts.size()];
+  double y[verts.size()];
+  double z[verts.size()];
+  rval = mb-> get_coords( verts, &x[0], &y[0], &z[0]);
+  CHECK_ERR(rval);
+  //Check against known locations of the vertices
+  // Vertex 1
+  CHECK_EQUAL( x[0], 5);
+  CHECK_EQUAL( y[0], -5);
+  CHECK_EQUAL( z[0], 5);
+  // Vertex 2
+  CHECK_EQUAL( x[1], 5);
+  CHECK_EQUAL( y[1], 5);
+  CHECK_EQUAL( z[1], 5);
+  // Vertex 3
+  CHECK_EQUAL( x[2], -5);
+  CHECK_EQUAL( y[2], 5);
+  CHECK_EQUAL( z[2], 5);
+  // Vertex 4
+  CHECK_EQUAL( x[3], -5);
+  CHECK_EQUAL( y[3], -5);
+  CHECK_EQUAL( z[3], 5);
+  // Vertex 5
+  CHECK_EQUAL( x[4], 5);
+  CHECK_EQUAL( y[4], 5);
+  CHECK_EQUAL( z[4], -5);
+  // Vertex 6
+  CHECK_EQUAL( x[5], 5);
+  CHECK_EQUAL( y[5], -5);
+  CHECK_EQUAL( z[5], -5);
+  // Vertex 7
+  CHECK_EQUAL( x[6], -5);
+  CHECK_EQUAL( y[6], -5);
+  CHECK_EQUAL( z[6], -5);
+  // Vertex 8
+  CHECK_EQUAL( x[7], -5);
+  CHECK_EQUAL( y[7], 5);
+  CHECK_EQUAL( z[7], -5);
   int result = 0;
-  result += RUN_TEST( read_cube_vols_test );
+  result += RUN_TEST( read_cube_vertex_pos_test );
   return result;
https://bitbucket.org/fathomteam/moab/commits/57579949cf8e/
Changeset:   57579949cf8e
Branch:      None
User:        pshriwise
Summary:     Added some comments to read_cgm_basic_test.cpp for clarity.
Affected #:  1 file
index 4eafe96..d225837 100644
@@ -43,6 +43,7 @@ void read_file( Interface* moab, const char* input_file )
   ErrorCode rval;
+  //Open the test file
   Core moab;
@@ -58,6 +59,7 @@ void read_cube_verts_test()
   ErrorCode rval;
   Core moab;
@@ -75,6 +77,7 @@ void read_cube_tris_test()
   ErrorCode rval;
   Core moab;
@@ -92,7 +95,6 @@ void read_cube_curves_test()
   CHECK_ERR(rval);
@@ -101,6 +103,7 @@ void read_cube_curves_test()
   ErrorCode rval;
   Core moab;
@@ -127,12 +130,12 @@ void read_cube_surfs_test()
   ErrorCode rval;
   Core moab;
   Tag geom_tag;
   CHECK_ERR(rval);
@@ -152,7 +155,9 @@ void read_cube_vols_test()
   ErrorCode rval;
   Core moab;
https://bitbucket.org/fathomteam/moab/commits/0fad33850f9b/
Changeset:   0fad33850f9b
Branch:      None
User:        pshriwise
Summary:     Restructured the read_cgm_basic_test file. Added comments for clarity.
Affected #:  1 file
index d225837..13f7bac 100644
@@ -31,8 +31,29 @@ static const char input_cube[] = "cube.sat";
 #endif
 #endif
+// Function used to load the test file
+// List of tests in this file
+void read_cube_verts_test();
+void read_cube_curves_test();
+void read_cube_surfs_test();
+void read_cube_vols_test();
+void read_cube_vertes_pos_test();
+void read_cube_curve_senses_test();
+void delete_mesh_test();
+  int result = 0;
+  result += RUN_TEST( read_cube_curve_senses_test );
+  return result;
@@ -225,16 +246,6 @@ void read_cube_vertex_pos_test()
-  int result = 0;
-  result += RUN_TEST( read_cube_vertex_pos_test );
-  return result;
  Core moab;
https://bitbucket.org/fathomteam/moab/commits/b61782a8128a/
Changeset:   b61782a8128a
Branch:      None
User:        pshriwise
Summary:     Created a new file for testing the loading of sense data with READ_CGM.
This was done for a simple cube geometry. Cleanup of the code is needed.
Affected #:  2 files
diff --git a/test/io/Makefile.am b/test/io/Makefile.am
index 6cf835a..31049a1 100644
--- a/test/io/Makefile.am
+++ b/test/io/Makefile.am
@@ -25,7 +25,7 @@ else
 endif
 if HAVE_CGM
-  CGM_TEST = read_cgm_load_test read_cgm_basic_test
+  CGM_TEST = read_cgm_load_test read_cgm_basic_test read_cgm_senses_test
 else
   CGM_TEST =
 endif
diff --git a/test/io/read_cgm_senses_test.cpp b/test/io/read_cgm_senses_test.cpp
new file mode 100644
index 0000000..f42abed
--- /dev/null
+++ b/test/io/read_cgm_senses_test.cpp
@@ -0,0 +1,233 @@
+#include <iostream>
+#include "moab/Interface.hpp"
+#ifndef IS_BUILDING_MB
+#define IS_BUILDING_MB
+#endif
+#include "TestUtil.hpp"
+#include "Internals.hpp"
+#include "moab/Core.hpp"
+#include "MBTagConventions.hpp"
+#include "moab/GeomTopoTool.hpp"
+using namespace moab;
+#define CHKERR(A) do { if (MB_SUCCESS != (A)) { \
+  std::cerr << "Failure (error code " << (A) << ") at " __FILE__ ":" \
+            << __LINE__ << std::endl; \
+  return A; } } while(false)
+#ifdef MESHDIR
+static const char input_cube[] = STRINGIFY(MESHDIR) "/io/cube.sat";
+#else
+static const char input_cube[] = "/io/cube.sat";
+#endif
+// Functions containing known sense data
+void load_curve_sense_data( Interface* moab, EntityHandle curve,  std::vector<int>& surf_ids_out, std::vector<int>& senses_out );
+// Functions used to compare sense information found in
+// the model to reference information
+void check_curve_sense_data( Interface* moab, std::vector<EntityHandle> wrt_ents, std::vector<int> senses,
+                             std::vector<int> known_wrt_ids, std::vector<int> known_senses);
+//Function used to get id's from entity handles
+int geom_id_by_handle( Interface* moab, const EntityHandle set );
+  int result = 0;
+  return result;
+  CHECK_ERR(rval);
+  ErrorCode rval;
+  Core moab;
+  //Get all curve handles
+  Tag geom_tag;
+  CHECK_ERR(rval);
+  // Check that the proper number of curves exist
+  int dim = 1;
+  CHECK_ERR(rval);
+  CHECK_EQUAL(12 , number_of_curves);
+  // Get curve handles
+  Range curves;
+	  					    val, 1, curves );
+  CHECK_ERR(rval);
+  // Establish GeomTopoTool instance needed to get curve data
+  moab::GeomTopoTool gt(mb, false);
+  std::vector<EntityHandle> surfs;
+  std::vector<int> senses;
+  std::vector<int> known_surf_ids;
+  std::vector<int> known_senses;
+for(unsigned int i = 0; i < curves.size() ; i++)
+  surfs.clear();
+  senses.clear();
+  //Curve 1
+  gt.get_senses( curves[i], surfs, senses);
+  CHECK_ERR(rval);
+  //Load known curve-sense data
+   known_surf_ids.clear();
+   known_senses.clear();
+   load_curve_sense_data( mb, curves[i], known_surf_ids, known_senses );
+   check_curve_sense_data( mb, surfs, senses, known_surf_ids, known_senses);
+int geom_id_by_handle( Interface* moab, const EntityHandle set ) {
+ErrorCode rval;
+    Tag id_tag;
+    rval = moab->tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, id_tag, moab::MB_TAG_DENSE);
+    assert(MB_SUCCESS==result || MB_ALREADY_ALLOCATED==result);
+    int id;
+    rval = moab->tag_get_data( id_tag, &set, 1, &id );
+    assert(MB_SUCCESS == result);
+    return id;
+  std::vector<int> wrt_ent_ids;
+  for( unsigned int i=0 ; i<wrt_ents.size() ; i++)
+      wrt_ent_ids.push_back(geom_id_by_handle(moab, wrt_ents[i]));
+  for (unsigned int i=0; i< wrt_ent_ids.size() ; i++)
+     for(unsigned int j=0; j< known_wrt_ids.size(); j++)
+       if(wrt_ent_ids[i] == known_wrt_ids [j])
+          CHECK_EQUAL(senses[i],known_senses[j]);
+          known_wrt_ids.erase(known_wrt_ids.begin()+j);
+          known_senses.erase(known_senses.begin()+j);
+  int leftovers = known_wrt_ids.size();
+  CHECK_EQUAL(leftovers, 0 );
+void load_curve_sense_data( Interface* moab, EntityHandle curve, std::vector<int>& surf_ids_out, std::vector<int>& senses_out ){
+  int curve_id = geom_id_by_handle( moab, curve);
+  std::cout << curve_id << std::endl;
+  switch(curve_id)
+    case 1:
+          surf_ids_out.push_back(1); surf_ids_out.push_back(6);
+          senses_out.push_back(1); senses_out.push_back(-1);
+    break;
+    case 2:
+          surf_ids_out.push_back(1); surf_ids_out.push_back(5);
+    break;
+    case 3:
+          surf_ids_out.push_back(1); surf_ids_out.push_back(4);
+    break;
+    case 4:
+          surf_ids_out.push_back(1); surf_ids_out.push_back(3);
+    break;
+    case 5:
+          surf_ids_out.push_back(2); surf_ids_out.push_back(6);
+    break;
+    case 6:
+          surf_ids_out.push_back(2); surf_ids_out.push_back(3);
+    break;
+    case 7:
+          surf_ids_out.push_back(2); surf_ids_out.push_back(4);
+    break;
+    case 8:
+          surf_ids_out.push_back(2); surf_ids_out.push_back(5);
+    break;
+    case 9:
+          surf_ids_out.push_back(3); surf_ids_out.push_back(4);
+    break;
+    case 10:
+          surf_ids_out.push_back(3); surf_ids_out.push_back(6);
+          senses_out.push_back(-1); senses_out.push_back(1);
+    break;
+    case 11:
+          surf_ids_out.push_back(4); surf_ids_out.push_back(5);
+    break;
+    case 12:
+          surf_ids_out.push_back(5); surf_ids_out.push_back(6);
+    break;
https://bitbucket.org/fathomteam/moab/commits/53113cb2d2c0/
Changeset:   53113cb2d2c0
Branch:      None
User:        pshriwise
Summary:     Removed curve sense test from read_cgm_basic_test.
This was still there from before the creation of the new file read_cgm_senses_test where this function now lives.
Affected #:  1 file
index 13f7bac..c43b365 100644
@@ -40,7 +40,6 @@ void read_cube_curves_test();
-void read_cube_curve_senses_test();
@@ -48,7 +47,7 @@ int main(int /* argc */, char** /* argv */)
   int result = 0;
-  result += RUN_TEST( read_cube_curve_senses_test );
+  result += RUN_TEST( read_cube_verts_test );
   return result;
https://bitbucket.org/fathomteam/moab/commits/b8d03b7fd655/
Changeset:   b8d03b7fd655
Branch:      None
User:        pshriwise
Summary:     Added a new test to check the sense loading of a simple cube geometry using READ_CGM.
Again, this new function read_cgm_surf_senses_test along with read_cgm_curve_senses_test needs some cleanup.
Affected #:  1 file
index f42abed..fcc2281 100644
--- a/test/io/read_cgm_senses_test.cpp
@@ -28,11 +28,11 @@ void read_file( Interface* moab, const char* input_file );
+void load_vol_sense_data( Interface* moab, EntityHandle surf, std::vector<int>& vol_ids_out, std::vector<int>& senses_out );
-void check_curve_sense_data( Interface* moab, std::vector<EntityHandle> wrt_ents, std::vector<int> senses,
+void check_sense_data( Interface* moab, std::vector<EntityHandle> wrt_ents, std::vector<int> senses,
@@ -40,6 +40,7 @@ int geom_id_by_handle( Interface* moab, const EntityHandle set );
+void read_cube_surf_senses_test();
@@ -47,7 +48,7 @@ int main(int /* argc */, char** /* argv */)
   int result = 0;
+  result += RUN_TEST( read_cube_surf_senses_test );
   return result;
@@ -112,7 +113,7 @@ for(unsigned int i = 0; i < curves.size() ; i++)
-   check_curve_sense_data( mb, surfs, senses, known_surf_ids, known_senses);
+   check_sense_data( mb, surfs, senses, known_surf_ids, known_senses);
@@ -130,7 +131,7 @@ ErrorCode rval;
     return id;
@@ -158,6 +159,7 @@ void check_curve_sense_data( Interface* moab, std::vector<EntityHandle> wrt_ents
@@ -231,3 +233,113 @@ void load_curve_sense_data( Interface* moab, EntityHandle curve, std::vector<int
+///SURFACE SENSE CHECKING
+  ErrorCode rval;
+  Core moab;
+  Tag geom_tag;
+  CHECK_ERR(rval);
+  int dim = 2;
+  CHECK_ERR(rval);
+  CHECK_EQUAL(6 , number_of_curves);
+  Range surfs;
+	  					    val, 1, surfs );
+  CHECK_ERR(rval);
+  std::vector<EntityHandle> vols;
+  std::vector<int> known_vol_ids;
+for(unsigned int i = 0; i < surfs.size() ; i++)
+  vols.clear();
+  senses.clear();
+  //Curve 1
+  gt.get_senses( surfs[i], vols, senses);
+  CHECK_ERR(rval);
+   known_vol_ids.clear();
+   load_vol_sense_data( mb, surfs[i], known_vol_ids, known_senses );
+   check_sense_data( mb, vols, senses, known_vol_ids, known_senses);
+void load_vol_sense_data( Interface* moab, EntityHandle surf, std::vector<int>& vol_ids_out, std::vector<int>& senses_out ){
+  int surf_id = geom_id_by_handle( moab, surf);
+  switch(surf_id)
+    case 1:
+          vol_ids_out.push_back(1);
+    break;
+    case 2:
+    break;
+    case 3:
+    break;
+    case 4:
+    break;
+    case 5:
+    break;
+    case 6:
+    break;
https://bitbucket.org/fathomteam/moab/commits/616f53a60bed/
Changeset:   616f53a60bed
Branch:      None
User:        pshriwise
Summary:     Cleaned up read_cgm_basic_tests.cpp.
Affected #:  1 file
index c43b365..23b2c72 100644
@@ -127,11 +127,11 @@ void read_cube_surfs_test()
   Core moab;
+  //Get geometry tag for pulling curve data from the mesh
   Tag geom_tag;
-  rval = mb->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1,
-				MB_TYPE_INTEGER, geom_tag, moab::MB_TAG_DENSE|moab::MB_TAG_CREAT );
+  rval = mb->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER,
+                             geom_tag, moab::MB_TAG_DENSE|moab::MB_TAG_CREAT );
   CHECK_ERR(rval);
   Range curves;
@@ -140,10 +140,10 @@ void read_cube_surfs_test()
-  CHECK_ERR(rval);
+  CHECK_ERR( rval );
-  CHECK_EQUAL( 6, number_of_surfs);
+  CHECK_EQUAL( 6, number_of_surfs );
@@ -154,11 +154,12 @@ void read_cube_vols_test()
   Core moab;
   Tag geom_tag;
-  CHECK_ERR(rval);
   Range curves;
   int dim = 3;
@@ -166,10 +167,10 @@ void read_cube_vols_test()
   int number_of_vols;
-  CHECK_ERR(rval);
-  CHECK_EQUAL( 1, number_of_vols);
+  CHECK_EQUAL( 1, number_of_vols );
@@ -184,64 +185,64 @@ void read_cube_vertex_pos_test()
-  rval = mb->get_number_entities_by_type( 0 , MBVERTEX , number_of_verts);
-  CHECK_ERR(rval);
+  rval = mb->get_number_entities_by_type( 0, MBVERTEX, number_of_verts );
-  CHECK_EQUAL(8, number_of_verts);
+  CHECK_EQUAL( 8, number_of_verts );
   Range verts;
-  rval = mb->get_entities_by_type( 0, MBVERTEX, verts);
-  CHECK_ERR(rval);
+  rval = mb->get_entities_by_type( 0, MBVERTEX, verts );
-  rval = mb-> get_coords( verts, &x[0], &y[0], &z[0]);
-  CHECK_ERR(rval);
+  rval = mb-> get_coords( verts, &x[0], &y[0], &z[0] );
   // Vertex 1
-  CHECK_EQUAL( x[0], 5);
-  CHECK_EQUAL( y[0], -5);
-  CHECK_EQUAL( z[0], 5);
+  CHECK_EQUAL( x[0], 5  );
+  CHECK_EQUAL( y[0], -5 );
+  CHECK_EQUAL( z[0], 5  );
   // Vertex 2
-  CHECK_EQUAL( x[1], 5);
-  CHECK_EQUAL( y[1], 5);
-  CHECK_EQUAL( z[1], 5);
+  CHECK_EQUAL( x[1], 5  );
+  CHECK_EQUAL( y[1], 5  );
+  CHECK_EQUAL( z[1], 5  );
   // Vertex 3
-  CHECK_EQUAL( x[2], -5);
-  CHECK_EQUAL( y[2], 5);
-  CHECK_EQUAL( z[2], 5);
+  CHECK_EQUAL( x[2], -5 );
+  CHECK_EQUAL( y[2], 5  );
+  CHECK_EQUAL( z[2], 5  );
   // Vertex 4
-  CHECK_EQUAL( x[3], -5);
-  CHECK_EQUAL( y[3], -5);
-  CHECK_EQUAL( z[3], 5);
+  CHECK_EQUAL( x[3], -5 );
+  CHECK_EQUAL( y[3], -5 );
+  CHECK_EQUAL( z[3], 5  );
   // Vertex 5
-  CHECK_EQUAL( x[4], 5);
-  CHECK_EQUAL( y[4], 5);
-  CHECK_EQUAL( z[4], -5);
+  CHECK_EQUAL( x[4], 5  );
+  CHECK_EQUAL( y[4], 5  );
+  CHECK_EQUAL( z[4], -5 );
   // Vertex 6
-  CHECK_EQUAL( x[5], 5);
-  CHECK_EQUAL( y[5], -5);
-  CHECK_EQUAL( z[5], -5);
+  CHECK_EQUAL( x[5], 5  );
+  CHECK_EQUAL( y[5], -5 );
+  CHECK_EQUAL( z[5], -5 );
   // Vertex 7
-  CHECK_EQUAL( x[6], -5);
-  CHECK_EQUAL( y[6], -5);
-  CHECK_EQUAL( z[6], -5);
+  CHECK_EQUAL( x[6], -5 );
+  CHECK_EQUAL( y[6], -5 );
+  CHECK_EQUAL( z[6], -5 );
   // Vertex 8
-  CHECK_EQUAL( x[7], -5);
-  CHECK_EQUAL( y[7], 5);
-  CHECK_EQUAL( z[7], -5);
+  CHECK_EQUAL( x[7], -5 );
+  CHECK_EQUAL( y[7], 5  );
+  CHECK_EQUAL( z[7], -5 );
@@ -253,10 +254,10 @@ void delete_mesh_test()
  ErrorCode rval;
  Tag geom_tag;
  CHECK_ERR(rval);
  Range geom_sets[4];
@@ -266,7 +267,7 @@ void delete_mesh_test()
-        CHECK_ERR(rval);
@@ -280,11 +281,11 @@ void delete_mesh_test()
-        CHECK_ERR(rval);
-        CHECK_ERR(rval);
https://bitbucket.org/fathomteam/moab/commits/4f40271e3ba4/
Changeset:   4f40271e3ba4
Branch:      None
User:        pshriwise
Summary:     Clean up of read_cgm_senses_test.
Affected #:  1 file
index fcc2281..aa11cae 100644
@@ -33,7 +33,7 @@ void load_vol_sense_data( Interface* moab, EntityHandle surf, std::vector<int>&
-                             std::vector<int> known_wrt_ids, std::vector<int> known_senses);
+                             std::vector<int> known_wrt_ids, std::vector<int> known_senses );
@@ -57,7 +57,7 @@ int main(int /* argc */, char** /* argv */)
-  CHECK_ERR(rval);
@@ -73,7 +73,7 @@ void read_cube_curve_senses_test()
-  CHECK_ERR(rval);
@@ -82,17 +82,17 @@ void read_cube_curve_senses_test()
-  CHECK_ERR(rval);
-  CHECK_EQUAL(12 , number_of_curves);
+  CHECK_EQUAL( 12 , number_of_curves );
   Range curves;
 	  					    val, 1, curves );
-  CHECK_ERR(rval);
-  moab::GeomTopoTool gt(mb, false);
+  moab::GeomTopoTool gt( mb, false );
@@ -100,17 +100,18 @@ void read_cube_curve_senses_test()
-  surfs.clear();
-  senses.clear();
-  //Curve 1
-  gt.get_senses( curves[i], surfs, senses);
-  CHECK_ERR(rval);
-  //Load known curve-sense data
+   //Clean data from previous curve
+   surfs.clear();
+   senses.clear();
+   //Get sense info for the current curve
+   CHECK_ERR(rval);
+   //Clear reference data from previous curve
@@ -119,52 +120,58 @@ for(unsigned int i = 0; i < curves.size() ; i++)
-int geom_id_by_handle( Interface* moab, const EntityHandle set ) {
-ErrorCode rval;
+    ErrorCode rval;
     Tag id_tag;
-    rval = moab->tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, id_tag, moab::MB_TAG_DENSE);
-    assert(MB_SUCCESS==result || MB_ALREADY_ALLOCATED==result);
+    rval = moab->tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, id_tag, moab::MB_TAG_DENSE );
+    assert( MB_SUCCESS==result || MB_ALREADY_ALLOCATED==result );
     int id;
-    assert(MB_SUCCESS == result);
     return id;
+  //Get ID's of the wrt entities
-  for( unsigned int i=0 ; i<wrt_ents.size() ; i++)
+  for( unsigned int i=0 ; i<wrt_ents.size() ; i++ )
-      wrt_ent_ids.push_back(geom_id_by_handle(moab, wrt_ents[i]));
+      wrt_ent_ids.push_back( geom_id_by_handle( moab, wrt_ents[i] ));
-  for (unsigned int i=0; i< wrt_ent_ids.size() ; i++)
+  for ( unsigned int i=0; i< wrt_ent_ids.size() ; i++ )
-     for(unsigned int j=0; j< known_wrt_ids.size(); j++)
+     for( unsigned int j=0; j< known_wrt_ids.size(); j++ )
-       if(wrt_ent_ids[i] == known_wrt_ids [j])
+       if( wrt_ent_ids[i] == known_wrt_ids [j] )
-          CHECK_EQUAL(senses[i],known_senses[j]);
-          known_wrt_ids.erase(known_wrt_ids.begin()+j);
-          known_senses.erase(known_senses.begin()+j);
+          // Make sure the senses of the matching wrt entities
+          // are correct
+          CHECK_EQUAL( senses[i],known_senses[j] );
+          //Once a wrt entity is matched with a known entity,
+          // remove it from the list
+          known_wrt_ids.erase( known_wrt_ids.begin()+j );
+          known_senses.erase( known_senses.begin()+j );
+  // After both loops are complete, known_wrt_ents should be empty
-  CHECK_EQUAL(leftovers, 0 );
+  CHECK_EQUAL( leftovers, 0 );
-  int curve_id = geom_id_by_handle( moab, curve);
-  std::cout << curve_id << std::endl;
+  int curve_id = geom_id_by_handle( moab, curve );
   switch(curve_id)
@@ -233,11 +240,7 @@ void load_curve_sense_data( Interface* moab, EntityHandle curve, std::vector<int
   ErrorCode rval;
@@ -246,62 +249,59 @@ void read_cube_surf_senses_test()
-  //Get all curve handles
+  //Get geometry tag for gathering surface information from the mesh
   Tag geom_tag;
-  CHECK_ERR(rval);
   int dim = 2;
-  CHECK_ERR(rval);
-  CHECK_EQUAL(6 , number_of_curves);
+  CHECK_EQUAL( 6, number_of_curves );
   Range surfs;
 	  					    val, 1, surfs );
-  CHECK_ERR(rval);
-for(unsigned int i = 0; i < surfs.size() ; i++)
+for( unsigned int i = 0; i < surfs.size() ; i++ )
-  vols.clear();
-  senses.clear();
-  //Curve 1
-  gt.get_senses( surfs[i], vols, senses);
-  CHECK_ERR(rval);
+   //Clean data from previous surface
+   vols.clear();
+   senses.clear();
+   // Get sense information for the current
+   // surface from the mesh
+   CHECK_ERR(rval);
+   // Check sense information from the loaded mesh against
+   // reference sense information
-  int surf_id = geom_id_by_handle( moab, surf);
+  int surf_id = geom_id_by_handle( moab, surf );
   switch(surf_id)
@@ -329,17 +329,12 @@ void load_vol_sense_data( Interface* moab, EntityHandle surf, std::vector<int>&
     case 5:
     break;
     case 6:
     break;
https://bitbucket.org/fathomteam/moab/commits/ae3fb718fcdc/
Changeset:   ae3fb718fcdc
Branch:      None
User:        pshriwise
Date:        2014-02-14 01:10:44
Summary:     Added cgm flags to read_cgm_basic_test
Affected #:  2 files
diff --git a/src/io/ReadCGM.cpp b/src/io/ReadCGM.cpp
index bb9eb9a..e854a2e 100644
--- a/src/io/ReadCGM.cpp
+++ b/src/io/ReadCGM.cpp
@@ -16,7 +16,7 @@
 #pragma warning(disable:4786)
 #endif
-#include "cgm_version.h"
+//#include "cgm_version.h"
 #include "GeometryQueryTool.hpp"
 #include "ModelQueryEngine.hpp"
 #include "RefEntityName.hpp"
index 23b2c72..a23f4e9 100644
@@ -8,6 +8,8 @@
+#include "InitCGMA.hpp"
+#include "GeometryQueryTool.hpp"
@@ -56,6 +58,8 @@ int main(int /* argc */, char** /* argv */)
+  InitCGMA::initialize_cgma();
   CHECK_ERR(rval);
https://bitbucket.org/fathomteam/moab/commits/da0546b2ad37/
Changeset:   da0546b2ad37
Branch:      None
User:        pshriwise
Summary:     Finished fix for building ReadCGM tests with linked CGM libs.
Affected #:  3 files
index 31049a1..4389075 100644
@@ -73,7 +73,9 @@ ccmio_test_SOURCES = $(srcdir)/../TestUtil.hpp ccmio_test.cpp
 read_cgm_load_test_SOURCES = $(srcdir)/../TestUtil.hpp read_cgm_load_test.cpp
 read_cgm_load_test_CXXFLAGS = $(CGM_CPPFLAGS)  $(CXXFLAGS)
 read_cgm_basic_test_SOURCES = $(srcdir)/../TestUtil.hpp read_cgm_basic_test.cpp
-read_cgm_basic_test_CXXFLAGS = $(CGM_CPPFLAGS)  $(CXXFLAGS)
+read_cgm_basic_test_CXXFLAGS = $(CGM_CPPFLAGS) $(CGM_LIBS)  $(CXXFLAGS)
+read_cgm_senses_test_SOURCES = $(srcdir)/../TestUtil.hpp read_cgm_senses_test.cpp
+read_cgm_senses_test_CXXFLAGS = $(CGM_CPPFLAGS) $(CGM_LIBS)  $(CXXFLAGS)
 readutil_test_SOURCES = $(srcdir)/../TestUtil.hpp readutil_test.cpp
 cgns_test_SOURCES=$(srcdir)/../TestUtil.hpp cgns_test.cpp
index a23f4e9..fb9d796 100644
@@ -59,6 +59,7 @@ int main(int /* argc */, char** /* argv */)
+  GeometryQueryTool::instance()->delete_geometry();
   CHECK_ERR(rval);
index aa11cae..9fa9cd9 100644
@@ -9,6 +9,9 @@
@@ -49,13 +52,17 @@ int main(int /* argc */, char** /* argv */)
   int result = 0;
   return result;
   CHECK_ERR( rval );
https://bitbucket.org/fathomteam/moab/commits/a8042f20a9a1/
Changeset:   a8042f20a9a1
Branch:      None
User:        pshriwise
Summary:     Added all tests back into the read_cgm test files after fixing problems with the CGM instance's persistent geometry.
Affected #:  2 files
index fb9d796..0211b1f 100644
@@ -39,18 +39,24 @@ void read_file( Interface* moab, const char* input_file );
+void read_cube_tris_test();
-void read_cube_vertes_pos_test();
+void read_cube_vertex_pos_test();
   int result = 0;
+  result += RUN_TEST( read_cube_curves_test );
+  result += RUN_TEST( read_cube_surfs_test );
   return result;
index 9fa9cd9..3b0072e 100644
@@ -51,6 +51,7 @@ int main(int /* argc */, char** /* argv */)
   int result = 0;
   return result;
@@ -62,7 +63,6 @@ void read_file( Interface* moab, const char* input_file )
   CHECK_ERR( rval );
https://bitbucket.org/fathomteam/moab/commits/66ea188993d2/
Changeset:   66ea188993d2
Branch:      None
User:        pshriwise
Date:        2014-02-14 01:11:21
Summary:     Updated the ReadCGM test for vertex positions so it doesn't rely on a load order.
Affected #:  1 file
index 0211b1f..55bbe43 100644
@@ -50,12 +50,12 @@ int main(int /* argc */, char** /* argv */)
   int result = 0;
   return result;
@@ -215,45 +215,71 @@ void read_cube_vertex_pos_test()
+  std::vector<double> x_ref;
+  std::vector<double> y_ref;
+  std::vector<double> z_ref;
   // Vertex 1
-  CHECK_EQUAL( x[0], 5  );
-  CHECK_EQUAL( y[0], -5 );
-  CHECK_EQUAL( z[0], 5  );
+  x_ref.push_back( 5 );
+  y_ref.push_back( -5 );
+  z_ref.push_back( 5 );
   // Vertex 2
-  CHECK_EQUAL( x[1], 5  );
-  CHECK_EQUAL( y[1], 5  );
-  CHECK_EQUAL( z[1], 5  );
+  y_ref.push_back( 5 );
   // Vertex 3
-  CHECK_EQUAL( x[2], -5 );
-  CHECK_EQUAL( y[2], 5  );
-  CHECK_EQUAL( z[2], 5  );
+  x_ref.push_back( -5 );
   // Vertex 4
-  CHECK_EQUAL( x[3], -5 );
-  CHECK_EQUAL( y[3], -5 );
-  CHECK_EQUAL( z[3], 5  );
   // Vertex 5
-  CHECK_EQUAL( x[4], 5  );
-  CHECK_EQUAL( y[4], 5  );
-  CHECK_EQUAL( z[4], -5 );
+  z_ref.push_back( -5 );
   // Vertex 6
-  CHECK_EQUAL( x[5], 5  );
-  CHECK_EQUAL( y[5], -5 );
-  CHECK_EQUAL( z[5], -5 );
   // Vertex 7
-  CHECK_EQUAL( x[6], -5 );
-  CHECK_EQUAL( y[6], -5 );
-  CHECK_EQUAL( z[6], -5 );
   // Vertex 8
-  CHECK_EQUAL( x[7], -5 );
-  CHECK_EQUAL( y[7], 5  );
-  CHECK_EQUAL( z[7], -5 );
+  std::cout << verts.size() << std::endl;
+  std::cout << x_ref.size() << std::endl;
+  for (unsigned int i=0; i<verts.size(); i++)
+      for (unsigned int j=0; j<x_ref.size(); j++)
+	  if( x[i]==x_ref[j] && y[i]==y_ref[j] && z[i]==z_ref[j])
+              x_ref.erase( x_ref.begin()+j );
+              y_ref.erase( y_ref.begin()+j );
+              z_ref.erase( z_ref.begin()+j );
+  int leftovers = x_ref.size();
+  CHECK_EQUAL(0, leftovers );
https://bitbucket.org/fathomteam/moab/commits/77e8fefa7942/
Changeset:   77e8fefa7942
Branch:      None
User:        pshriwise
Summary:     Added a function set_options to ReadCGM.
Affected #:  2 files
index e854a2e..bc56c08 100644
@@ -114,6 +114,48 @@ ErrorCode ReadCGM::read_tag_values( const char* /* file_name */,
   return MB_NOT_IMPLEMENTED;
+//Sets options passed into ReadCGM::load_file
+ErrorCode ReadCGM::set_options( const FileOptions& opts,
+                                int& norm_tol,
+                                double& faceting_tol,
+                                double& len_tol,
+                                bool& act_att,
+                                bool& verbose_warnings)
+  ErrorCode rval;
+  //Default Values
+  int DEFAULT_NORM = 5;
+  double DEFAULT_FACET_TOL = 0.001;
+  double DEFAULT_LEN_TOL = 0.0;
+  act_att = true;
+  //check for the options.
+  if (MB_SUCCESS != opts.get_int_option( "FACET_NORMAL_TOLERANCE", norm_tol ))
+    norm_tol = DEFAULT_NORM;
+  if (MB_SUCCESS != opts.get_real_option("FACET_DISTANCE_TOLERANCE", faceting_tol))
+    faceting_tol = DEFAULT_FACET_TOL;
+  if (MB_SUCCESS != opts.get_real_option("MAX_FACET_EDGE_LENGTH", len_tol))
+    len_tol = DEFAULT_LEN_TOL;
+  if (MB_SUCCESS == opts.get_null_option("VERBOSE_CGM_WARNINGS"))
+    verbose_warnings = true;
+  const char* name = "CGM_ATTRIBS";
+  const char* value = "no";
+  rval = opts.match_option(name,value);
+  if(MB_SUCCESS == rval)
+    act_att = false;
+  return MB_SUCCESS;
 // copy geometry into mesh database
@@ -132,8 +174,16 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
   int norm_tol, DEFAULT_NORM = 5;
-  double faceting_tol, DEFAULT_FACET_TOL = 0.001, len_tol, DEFAULT_LEN_TOL = 0.0;
+  double faceting_tol, DEFAULT_FACET_TOL = 0.001;
+  double len_tol, DEFAULT_LEN_TOL = 0.0;
   bool act_att = true;
+  bool verbose_warnings = false;
+  rval = set_options( opts, norm_tol, faceting_tol, len_tol, act_att, verbose_warnings);
@@ -144,7 +194,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-  bool verbose_warnings = false;
@@ -153,6 +203,8 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
     act_att = false;
   // always tag with the faceting_tol and geometry absolute resolution
   // if file_set is defined, use that, otherwise (file_set == NULL) tag the interface
diff --git a/src/io/ReadCGM.hpp b/src/io/ReadCGM.hpp
index 531bdd9..2919cce 100644
--- a/src/io/ReadCGM.hpp
+++ b/src/io/ReadCGM.hpp
@@ -70,6 +70,14 @@ public:
                              std::vector<int>& tag_values_out,
                              const SubsetList* subset_list = 0 );
+  ErrorCode set_options( const FileOptions& opts,
+                                int& norm_tol,
+                                double& len_tol,
+			        bool& act_att,
+                                bool& verbose_warnings);
    //! Constructor
    ReadCGM(Interface* impl = NULL);
https://bitbucket.org/fathomteam/moab/commits/593265a8c269/
Changeset:   593265a8c269
Branch:      None
User:        pshriwise
Summary:     Created new file for testing that ReadCGM is loading entities with the correct connectivity.
Affected #:  1 file
diff --git a/test/io/read_cgm_connectivity_test.cpp b/test/io/read_cgm_connectivity_test.cpp
index 0000000..cbd0849
--- /dev/null
+++ b/test/io/read_cgm_connectivity_test.cpp
@@ -0,0 +1,193 @@
+#endif
+#ifdef MESHDIR
+#else
+#endif
+  int result = 0;
+  return result;
+  CHECK_ERR(rval);
+  ErrorCode rval;
+  Core moab;
+  int number_of_tris;
+  std::cout << "Number of Triangles = " << number_of_tris << std::endl;
+  CHECK_ERR(rval);
+  ErrorCode rval;
+  Core moab;
+  Range verts;
+  // Vertex 1
+  // Vertex 2
+  // Vertex 3
+  // Vertex 4
+  // Vertex 5
+  // Vertex 6
+  // Vertex 7
+  // Vertex 8
+void read_cube_connectivity_test()
+   ErrorCode rval;
+  Core moab;
+  //Get all triangles from the mesh
+  std::vector<EntityHandle> tris;
+  rval = mb->get_entities_by_type( 0, MBTRI, tris);
+  CHECK_ERR(rval);
https://bitbucket.org/fathomteam/moab/commits/c5b9601e6611/
Changeset:   c5b9601e6611
Branch:      None
User:        pshriwise
Summary:     Removed non-existant test calls from read_cgm_connectivity_test.
Affected #:  1 file
index cbd0849..e297bfa 100644
--- a/test/io/read_cgm_connectivity_test.cpp
@@ -37,12 +37,7 @@ int main(int /* argc */, char** /* argv */)
   int result = 0;
-  result += RUN_TEST( read_cube_verts_test );
-  result += RUN_TEST( read_cube_curves_test );
-  result += RUN_TEST( read_cube_surfs_test );
   return result;
https://bitbucket.org/fathomteam/moab/commits/a72cecb90ca7/
Changeset:   a72cecb90ca7
Branch:      None
User:        pshriwise
Summary:     Added read_cgm_connectivity_test to the MOAB make check system.
Affected #:  1 file
index 4389075..e9a73b3 100644
 endif
 if HAVE_CGM
-  CGM_TEST = read_cgm_load_test read_cgm_basic_test read_cgm_senses_test
+  CGM_TEST = read_cgm_load_test read_cgm_basic_test read_cgm_senses_test read_cgm_connectivity_test
 else
   CGM_TEST =
 endif
@@ -76,6 +76,8 @@ read_cgm_basic_test_SOURCES = $(srcdir)/../TestUtil.hpp read_cgm_basic_test.cpp
+read_cgm_connectivity_test_SOURCES = $(srcdir)/../TestUtil.hpp read_cgm_connectivity_test.cpp
+read_cgm_connectivity_test_CXXFLAGS = $(CGM_CPPFLAGS) $(CGM_LIBS)  $(CXXFLAGS)
https://bitbucket.org/fathomteam/moab/commits/d6f966f14835/
Changeset:   d6f966f14835
Branch:      None
User:        pshriwise
Summary:     Updates to read_cgm_connectivity_test
Affected #:  1 file
index e297bfa..843f2db 100644
@@ -30,14 +30,18 @@ void read_file( Interface* moab, const char* input_file );
+void read_cube_connectivity_test();
+//Function used to match triangle connectivity and verts
+void match_tri_connectivity( Range connectivity,
+                             std::vector<EntityHandle> &reference_verts);
   int result = 0;
+  RUN_TEST(read_cube_connectivity_test);
   return result;
@@ -180,9 +184,57 @@ void read_cube_connectivity_test()
+  //Get all vertex handles from the mesh
+  std::vector<EntityHandle> verts;
+  CHECK_ERR(rval);
+  //Duplicate the vertex handles to match the number of tris
+  //they should be connected to upon a correct load
+  std::vector<EntityHandle>  ref_verts=verts;
+  int copy_count = 0;
+  while (copy_count<4)
+      copy(verts.begin(),verts.end(),back_inserter(ref_verts));
+      copy_count++;
+  //Make sure everything duplicated without a problem
+  if( ref_verts.size()!=40 ) CHECK_ERR(MB_FAILURE);
-  std::vector<EntityHandle> tris;
+  Range tris;
   CHECK_ERR(rval);
+  //Test connectivity
+  for (Range::const_iterator i=tris.begin(); i!=tris.end(); i++)
+     //Get the connectivity of a triangle
+      Range connect;
+      rval = mb->get_connectivity( &(*i), 1, connect);
+      CHECK_ERR(rval);
+      match_tri_connectivity( connect, ref_verts);
+      std::cout << "ref_verts size = " << ref_verts.size() << std::endl;
+void match_tri_connectivity( Range connectivity, std::vector<EntityHandle> &reference_verts)
+  for(Range::const_iterator i=connectivity.begin(); i!=connectivity.end(); i++)
+      for(unsigned int j=0; j<reference_verts.size(); j++)
+	  std::cout << "Triangle Vert Handle = " << *i << std::endl;
+          if( *i == reference_verts[j]) reference_verts.erase(reference_verts.begin()+j);
https://bitbucket.org/fathomteam/moab/commits/502684839b4c/
Changeset:   502684839b4c
Branch:      None
User:        pshriwise
Summary:     Removed commented lines in ReadCGM that have are performed by set_options.
Affected #:  1 file
index bc56c08..55c5038 100644
@@ -180,30 +180,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-  //check for the options.
-  if (MB_SUCCESS != opts.get_int_option( "FACET_NORMAL_TOLERANCE", norm_tol ))
-    norm_tol = DEFAULT_NORM;
-  if (MB_SUCCESS != opts.get_real_option("FACET_DISTANCE_TOLERANCE", faceting_tol))
-    faceting_tol = DEFAULT_FACET_TOL;
-  if (MB_SUCCESS != opts.get_real_option("MAX_FACET_EDGE_LENGTH", len_tol))
-    len_tol = DEFAULT_LEN_TOL;
-  if (MB_SUCCESS == opts.get_null_option("VERBOSE_CGM_WARNINGS"))
-    verbose_warnings = true;
-  const char* name = "CGM_ATTRIBS";
-  const char* value = "no";
-  rval = opts.match_option(name,value);
-  if(MB_SUCCESS == rval)
-    act_att = false;
https://bitbucket.org/fathomteam/moab/commits/4886877cc809/
Changeset:   4886877cc809
Branch:      None
User:        pshriwise
Summary:     Added a new test to check that the cube vertices are connected reasonable numbers of triangles.
Updated int main so that it is properly connected to the testing framework.
Affected #:  1 file
index 843f2db..8d5f103 100644
@@ -30,18 +30,19 @@ void read_file( Interface* moab, const char* input_file );
-void read_cube_connectivity_test();
+void cube_verts_connectivity_test();
-void match_tri_connectivity( Range connectivity,
-                             std::vector<EntityHandle> &reference_verts);
+//void match_tri_connectivity( Range connectivity,
+//                             std::vector<EntityHandle> &reference_verts);
   int result = 0;
-  RUN_TEST(read_cube_connectivity_test);
+  result += RUN_TEST(cube_verts_connectivity_test);
+  result += RUN_TEST(read_cube_tris_test);
   return result;
@@ -76,165 +77,34 @@ void read_cube_tris_test()
-void read_cube_vertex_pos_test()
-  ErrorCode rval;
-  //Open the test file
-  Core moab;
-  Interface* mb = &moab;
-  read_file( mb, input_cube );
-  //First check that the correct number of vertices are present
-  int number_of_verts;
-  rval = mb->get_number_entities_by_type( 0, MBVERTEX, number_of_verts );
-  CHECK_ERR( rval );
-  CHECK_EQUAL( 8, number_of_verts );
-  //Retrieve all vertex handles from the mesh
-  Range verts;
-  rval = mb->get_entities_by_type( 0, MBVERTEX, verts );
-  //Get the vertex coordinates
-  double x[verts.size()];
-  double y[verts.size()];
-  double z[verts.size()];
-  rval = mb-> get_coords( verts, &x[0], &y[0], &z[0] );
-  //Check against known locations of the vertices
-  std::vector<double> x_ref;
-  std::vector<double> y_ref;
-  std::vector<double> z_ref;
-  // Vertex 1
-  x_ref.push_back( 5 );
-  y_ref.push_back( -5 );
-  z_ref.push_back( 5 );
-  // Vertex 2
-  y_ref.push_back( 5 );
-  // Vertex 3
-  x_ref.push_back( -5 );
-  // Vertex 4
-  // Vertex 5
-  z_ref.push_back( -5 );
-  // Vertex 6
-  // Vertex 7
-  // Vertex 8
-  std::cout << verts.size() << std::endl;
-  std::cout << x_ref.size() << std::endl;
-  for (unsigned int i=0; i<verts.size(); i++)
-      for (unsigned int j=0; j<x_ref.size(); j++)
-	  if( x[i]==x_ref[j] && y[i]==y_ref[j] && z[i]==z_ref[j])
-              x_ref.erase( x_ref.begin()+j );
-              y_ref.erase( y_ref.begin()+j );
-              z_ref.erase( z_ref.begin()+j );
-  int leftovers = x_ref.size();
-  CHECK_EQUAL(0, leftovers );
-   ErrorCode rval;
+  ErrorCode rval;
   Core moab;
+  read_file( mb, input_cube);
-  std::vector<EntityHandle> verts;
+  Range verts;
   CHECK_ERR(rval);
-  //Duplicate the vertex handles to match the number of tris
-  //they should be connected to upon a correct load
-  std::vector<EntityHandle>  ref_verts=verts;
-  int copy_count = 0;
-  while (copy_count<4)
-      copy(verts.begin(),verts.end(),back_inserter(ref_verts));
-      copy_count++;
-  //Make sure everything duplicated without a problem
-  if( ref_verts.size()!=40 ) CHECK_ERR(MB_FAILURE);
-  //Get all triangles from the mesh
-  Range tris;
-  rval = mb->get_entities_by_type( 0, MBTRI, tris);
-  CHECK_ERR(rval);
+  //Check that each vertex connects to less than 4 triangles and no more than 6
-  //Test connectivity
-  for (Range::const_iterator i=tris.begin(); i!=tris.end(); i++)
+  for(Range::const_iterator i = verts.begin(); i!=verts.end(); i++)
-     //Get the connectivity of a triangle
-      Range connect;
-      rval = mb->get_connectivity( &(*i), 1, connect);
+      std::vector<EntityHandle> adj_tris;
+      rval = mb->get_adjacencies( &(*i), 1, 2, false, adj_tris );
       CHECK_ERR(rval);
-      match_tri_connectivity( connect, ref_verts);
-      std::cout << "ref_verts size = " << ref_verts.size() << std::endl;
-void match_tri_connectivity( Range connectivity, std::vector<EntityHandle> &reference_verts)
-  for(Range::const_iterator i=connectivity.begin(); i!=connectivity.end(); i++)
+      int adj_size = adj_tris.size();
-      for(unsigned int j=0; j<reference_verts.size(); j++)
+      CHECK( adj_size >= 4 && adj_size <= 6);
-	  std::cout << "Triangle Vert Handle = " << *i << std::endl;
-          if( *i == reference_verts[j]) reference_verts.erase(reference_verts.begin()+j);
https://bitbucket.org/fathomteam/moab/commits/a015b4b9c416/
Changeset:   a015b4b9c416
Branch:      None
User:        pshriwise
Summary:     Corrected formatting in read_cgm_senses_test.cpp
Affected #:  1 file
index 3b0072e..9b3f038 100644
@@ -32,9 +32,9 @@ void read_file( Interface* moab, const char* input_file );
https://bitbucket.org/fathomteam/moab/commits/e91a151bf5c6/
Changeset:   e91a151bf5c6
Branch:      None
User:        pshriwise
Summary:     Added a test to ensure that each triangle in the loaded file is adjacent to 3 other triangles.
Affected #:  1 file
index 8d5f103..686ebaa 100644
@@ -10,7 +10,7 @@
+#include "moab/MeshTopoUtil.hpp"
@@ -31,6 +31,7 @@ void read_file( Interface* moab, const char* input_file );
+void cube_tris_connectivity_test();
@@ -43,6 +44,7 @@ int main(int /* argc */, char** /* argv */)
+  result += RUN_TEST(cube_tris_connectivity_test);
   return result;
@@ -100,11 +102,34 @@ void cube_verts_connectivity_test()
       CHECK_ERR(rval);
+    ErrorCode rval;
+  Core moab;
+  //Get triangles from the mesh
+  Range tris;
+  CHECK_ERR(rval);
+  for(Range::const_iterator i = tris.begin()+1; i!=tris.end(); i++)
+      Range adj_tris;
+      moab::MeshTopoUtil mu(mb);
+      rval = mu.get_bridge_adjacencies( *i, 1, 2, adj_tris);
+      CHECK_ERR(rval);
+      int number_of_adj_tris=adj_tris.size();
+      CHECK_EQUAL( 3, number_of_adj_tris);
https://bitbucket.org/fathomteam/moab/commits/83f8b9da56cb/
Changeset:   83f8b9da56cb
Branch:      None
User:        pshriwise
Summary:     Removed read_cube_tris_test from the connectivity test file.
Affected #:  1 file
index 686ebaa..651f635 100644
@@ -29,7 +29,6 @@ static const char input_cube[] = "/io/cube.sat";
-void read_cube_tris_test();
@@ -43,7 +42,6 @@ int main(int /* argc */, char** /* argv */)
   int result = 0;
-  result += RUN_TEST(read_cube_tris_test);
   return result;
@@ -60,25 +58,6 @@ void read_file( Interface* moab, const char* input_file )
   CHECK_ERR(rval);
-  ErrorCode rval;
-  Core moab;
-  int number_of_tris;
-  rval = mb->get_number_entities_by_type(0, MBTRI , number_of_tris);
-  std::cout << "Number of Triangles = " << number_of_tris << std::endl;
-  CHECK_ERR(rval);
-  CHECK_EQUAL( 12, number_of_tris);
https://bitbucket.org/fathomteam/moab/commits/18f8435d6fa8/
Changeset:   18f8435d6fa8
Branch:      None
User:        pshriwise
Summary:     Removed deprecated and commented test prototype.
Affected #:  1 file
index 651f635..f82d8cd 100644
@@ -32,10 +32,6 @@ void read_file( Interface* moab, const char* input_file );
-//Function used to match triangle connectivity and verts
-//void match_tri_connectivity( Range connectivity,
-//                             std::vector<EntityHandle> &reference_verts);
https://bitbucket.org/fathomteam/moab/commits/62b903bdb191/
Changeset:   62b903bdb191
Branch:      None
User:        pshriwise
Summary:     Added a test for triangle-edge coincidence in the case of a cube read by ReadCGM
Affected #:  1 file
index f82d8cd..903dfcb 100644
@@ -31,7 +31,10 @@ void read_file( Interface* moab, const char* input_file );
+void cube_tri_curve_coincidence_test();
+//Other functions
+ErrorCode match_tri_edges_w_curve( Interface* moab, Range tri_edges, Range curves);
@@ -39,6 +42,7 @@ int main(int /* argc */, char** /* argv */)
+  result += RUN_TEST(cube_tri_curve_coincidence_test);
   return result;
@@ -84,7 +88,7 @@ void cube_verts_connectivity_test()
-    ErrorCode rval;
+  ErrorCode rval;
   Core moab;
@@ -108,3 +112,58 @@ void cube_tris_connectivity_test()
+  ErrorCode rval;
+  Core moab;
+  //Get curves from the mesh
+  Range curves;
+  rval = mb->get_entities_by_type( 0, MBEDGE, curves);
+  CHECK_ERR(rval);
+  Range tris;
+  CHECK_ERR(rval);
+  for(Range::const_iterator i=tris.begin(); i!=tris.end(); i++)
+      //Get the any curve edges that are a part of the triangle
+      Range tri_edges;
+      rval = mb->get_adjacencies( &(*i), 1, 1, false, tri_edges);
+      CHECK_ERR(rval);
+      int num_of_tri_edges = tri_edges.size();
+      CHECK_EQUAL(2, num_of_tri_edges);
+      rval = match_tri_edges_w_curve( mb, tri_edges, curves);
+      CHECK_ERR(rval);
+  ErrorCode rval;
+  int match_counter;
+  std::cout << "Size of curves = " << curves.size() << std::endl;
+  for(Range::const_iterator i=tri_edges.begin(); i!=tri_edges.end(); i++)
+      for(Range::const_iterator j=curves.begin(); j!=curves.end(); j++)
+	  std::cout << "Tri edge ID = " <<  *i << std::endl;
+	  std::cout << "Curve edge ID = " << *j << std::endl;
+          if( *i  == *j  ) match_counter++;
+  CHECK_EQUAL( num_of_tri_edges, match_counter );
https://bitbucket.org/fathomteam/moab/commits/4333cf5321f9/
Changeset:   4333cf5321f9
Branch:      None
User:        pshriwise
Summary:     Added a test to read_cgm_connectivity_test to ensure that each triangle has three different vertices.
Affected #:  1 file
index 903dfcb..4d4bebf 100644
@@ -32,6 +32,8 @@ void read_file( Interface* moab, const char* input_file );
+void cube_edge_adjacencies_test();
+void cube_tri_vertex_test();
 //Other functions
@@ -43,6 +45,8 @@ int main(int /* argc */, char** /* argv */)
+  result += RUN_TEST(cube_tri_vertex_test);
   return result;
@@ -167,3 +171,59 @@ ErrorCode match_tri_edges_w_curve( Interface* moab, Range tri_edges, Range curve
   return MB_SUCCESS;
+  ErrorCode rval;
+  Core moab;
+  //Get the curves
+  Range curves;
+  rval = mb->get_entities_by_type(0, MBEDGE, curves);
+  CHECK_ERR(rval);
+  for(Range::const_iterator i=curves.begin(); i!=curves.end(); i++)
+      //Get triangle adjacent to each edge
+      Range adj_tris;
+      rval = mb->get_adjacencies( &(*i), 1, 2, false, adj_tris);
+      CHECK_ERR(rval);
+      int num_adj_tris = adj_tris.size();
+      //Ensure that an edge isn't adjacent to more than two triangles
+      CHECK( num_adj_tris <= 2);
+  ErrorCode rval;
+  Core moab;
+  Range tris;
+  CHECK_ERR(rval);
+      //Get all triangle vertices
+      Range verts;
+      rval = mb->get_connectivity( &(*i), 1, verts);
+      CHECK_ERR(rval);
+      int number_of_verts = verts.size();
+      CHECK( 3 == number_of_verts);
+      CHECK(verts[0]!=verts[1]);
+      CHECK(verts[1]!=verts[2]);
+      CHECK(verts[2]!=verts[0]);
https://bitbucket.org/fathomteam/moab/commits/097a292213a1/
Changeset:   097a292213a1
Branch:      None
User:        pshriwise
Date:        2014-02-14 01:12:05
Summary:     Added an error check to the new function set_options and removed commented code.
Affected #:  1 file
index 55c5038..aa5d972 100644
@@ -180,8 +180,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
+  if(MB_SUCCESS != rval) return rval;
https://bitbucket.org/fathomteam/moab/commits/01ea84f470e5/
Changeset:   01ea84f470e5
Branch:      None
User:        pshriwise
Summary:     Added a check that all entities in cube_tris_connectivity_test are triangles and removed deprecated print outs.
Affected #:  1 file
index 4d4bebf..65e8237 100644
@@ -108,10 +108,18 @@ void cube_tris_connectivity_test()
       Range adj_tris;
+      //Use Triangle edges to get all adjacent triangles
       CHECK_ERR(rval);
+      //Check that the entities we found from bridge_adjacencies
+      //are triangles
+      Range adj_tri_test = adj_tris.subset_by_type(MBTRI);
+      int number_tris_in_adj_tris = adj_tri_test.size();
+      CHECK_EQUAL( number_of_adj_tris, number_tris_in_adj_tris);
@@ -155,14 +163,11 @@ ErrorCode match_tri_edges_w_curve( Interface* moab, Range tri_edges, Range curve
   ErrorCode rval;
-  int match_counter;
-  std::cout << "Size of curves = " << curves.size() << std::endl;
+  int match_counter=0;
-	  std::cout << "Tri edge ID = " <<  *i << std::endl;
-	  std::cout << "Curve edge ID = " << *j << std::endl;
https://bitbucket.org/fathomteam/moab/commits/1769209e741a/
Changeset:   1769209e741a
Branch:      None
User:        pshriwise
Summary:     Formatting corrections for read_cgm_connectivity_test.cpp
Affected #:  1 file
index 65e8237..7137666 100644
@@ -36,7 +36,7 @@ void cube_edge_adjacencies_test();
 //Other functions
-ErrorCode match_tri_edges_w_curve( Interface* moab, Range tri_edges, Range curves);
+ErrorCode match_tri_edges_w_curve( Interface* moab, Range tri_edges, Range curves );
@@ -69,11 +69,11 @@ void cube_verts_connectivity_test()
   Core moab;
-  read_file( mb, input_cube);
   Range verts;
   CHECK_ERR(rval);
@@ -85,7 +85,7 @@ void cube_verts_connectivity_test()
       CHECK_ERR(rval);
-      CHECK( adj_size >= 4 && adj_size <= 6);
+      CHECK( adj_size >= 4 && adj_size <= 6 );
@@ -96,11 +96,11 @@ void cube_tris_connectivity_test()
   Core moab;
   Range tris;
+  rval = mb->get_entities_by_type( 0, MBTRI, tris );
   CHECK_ERR(rval);
@@ -109,16 +109,16 @@ void cube_tris_connectivity_test()
       Range adj_tris;
-      rval = mu.get_bridge_adjacencies( *i, 1, 2, adj_tris);
+      rval = mu.get_bridge_adjacencies( *i, 1, 2, adj_tris );
       CHECK_ERR(rval);
-      CHECK_EQUAL( 3, number_of_adj_tris);
+      CHECK_EQUAL( 3, number_of_adj_tris );
       //are triangles
-      Range adj_tri_test = adj_tris.subset_by_type(MBTRI);
+      Range adj_tri_test = adj_tris.subset_by_type( MBTRI );
-      CHECK_EQUAL( number_of_adj_tris, number_tris_in_adj_tris);
+      CHECK_EQUAL( number_of_adj_tris, number_tris_in_adj_tris );
@@ -131,35 +131,35 @@ void cube_tri_curve_coincidence_test()
   Core moab;
   Range curves;
-  rval = mb->get_entities_by_type( 0, MBEDGE, curves);
+  rval = mb->get_entities_by_type( 0, MBEDGE, curves );
   CHECK_ERR(rval);
   Range tris;
   CHECK_ERR(rval);
       Range tri_edges;
-      rval = mb->get_adjacencies( &(*i), 1, 1, false, tri_edges);
+      rval = mb->get_adjacencies( &(*i), 1, 1, false, tri_edges );
       CHECK_ERR(rval);
-      CHECK_EQUAL(2, num_of_tri_edges);
-      rval = match_tri_edges_w_curve( mb, tri_edges, curves);
+      CHECK_EQUAL( 2, num_of_tri_edges );
+      rval = match_tri_edges_w_curve( mb, tri_edges, curves );
       CHECK_ERR(rval);
   ErrorCode rval;
@@ -183,23 +183,23 @@ void cube_edge_adjacencies_test()
   Core moab;
   //Get the curves
   Range curves;
-  rval = mb->get_entities_by_type(0, MBEDGE, curves);
   CHECK_ERR(rval);
       Range adj_tris;
-      rval = mb->get_adjacencies( &(*i), 1, 2, false, adj_tris);
       CHECK_ERR(rval);
-      CHECK( num_adj_tris <= 2);
+      CHECK( num_adj_tris <= 2 );
@@ -210,25 +210,25 @@ void cube_tri_vertex_test()
   Core moab;
   //Get all triangles
   Range tris;
   CHECK_ERR(rval);
       Range verts;
-      rval = mb->get_connectivity( &(*i), 1, verts);
+      rval = mb->get_connectivity( &(*i), 1, verts );
       CHECK_ERR(rval);
-      CHECK( 3 == number_of_verts);
-      CHECK(verts[0]!=verts[1]);
-      CHECK(verts[1]!=verts[2]);
-      CHECK(verts[2]!=verts[0]);
+      CHECK( 3 == number_of_verts );
+      CHECK( verts[0]!=verts[1] );
+      CHECK( verts[1]!=verts[2] );
+      CHECK( verts[2]!=verts[0] );
https://bitbucket.org/fathomteam/moab/commits/bcea7088a3e2/
Changeset:   bcea7088a3e2
Branch:      None
User:        pshriwise
Date:        2014-02-14 01:12:06
Summary:     Formatting corrections for read_cgm_load_test.cpp
Affected #:  1 file
index 9704ee7..6791f50 100644
@@ -33,10 +33,10 @@ void read_multiple_test()
   Core mb;
-  ErrorCode rval = mb.load_file(input_file);
+  ErrorCode rval = mb.load_file( input_file );
   CHECK_ERR(rval);
   // second load
-  rval = mb.load_file(input_file);
+  rval = mb.load_file( input_file );
   CHECK_ERR(rval);
@@ -44,7 +44,7 @@ void read_multiple_test()
-  int result = RUN_TEST( read_multiple_test ) ;
+  int result = RUN_TEST( read_multiple_test );
   return result;
https://bitbucket.org/fathomteam/moab/commits/41ab91659a46/
Changeset:   41ab91659a46
Branch:      None
User:        pshriwise
Summary:     Formatting corrections to read_cgm_basic_test.cpp
Affected #:  1 file
index 55bbe43..69c848d 100644
   int result = 0;
+  result += RUN_TEST(read_cube_verts_test);
+  result += RUN_TEST(read_cube_curves_test);
+  result += RUN_TEST(read_cube_surfs_test);
+  result += RUN_TEST(read_cube_vols_test);
+  result += RUN_TEST(read_cube_vertex_pos_test);
   return result;
@@ -80,10 +80,10 @@ void read_cube_verts_test()
+  rval = mb->get_number_entities_by_type( 0, MBVERTEX, number_of_vertices );
   CHECK_ERR(rval);
-  CHECK_EQUAL( 8, number_of_vertices);
+  CHECK_EQUAL( 8, number_of_vertices );
@@ -97,11 +97,11 @@ void read_cube_tris_test()
   int number_of_tris;
+  rval = mb->get_number_entities_by_type( 0, MBTRI , number_of_tris );
   CHECK_ERR(rval);
+  CHECK_EQUAL( 12, number_of_tris );
@@ -127,7 +127,7 @@ void read_cube_curves_test()
   CHECK_ERR(rval);
-  CHECK_EQUAL( 12, number_of_curves);
+  CHECK_EQUAL( 12, number_of_curves );
@@ -151,7 +151,7 @@ void read_cube_surfs_test()
+  CHECK_ERR(rval);
@@ -170,7 +170,7 @@ void read_cube_vols_test()
   Tag geom_tag;
+  CHECK_ERR(rval);
   Range curves;
   int dim = 3;
@@ -178,7 +178,7 @@ void read_cube_vols_test()
   int number_of_vols;
+  CHECK_ERR(rval);
@@ -197,7 +197,7 @@ void read_cube_vertex_pos_test()
+  CHECK_ERR(rval);
@@ -211,7 +211,7 @@ void read_cube_vertex_pos_test()
+  CHECK_ERR(rval);
@@ -268,7 +268,7 @@ void read_cube_vertex_pos_test()
+	  if( x[i]==x_ref[j] && y[i]==y_ref[j] && z[i]==z_ref[j] )
@@ -279,7 +279,7 @@ void read_cube_vertex_pos_test()
+  CHECK_EQUAL( 0, leftovers );
@@ -304,7 +304,7 @@ void delete_mesh_test()
+        CHECK_ERR(rval);
@@ -318,11 +318,11 @@ void delete_mesh_test()
+        CHECK_ERR(rval);
+        CHECK_ERR(rval);
https://bitbucket.org/fathomteam/moab/commits/df8283db2936/
Changeset:   df8283db2936
Branch:      None
User:        pshriwise
Summary:     Formatting corrections to read_cgm_senses_test.cpp
Affected #:  1 file
index 9b3f038..904477a 100644
@@ -51,8 +51,8 @@ int main(int /* argc */, char** /* argv */)
   int result = 0;
-  result += RUN_TEST( read_cube_surf_senses_test );
+  result += RUN_TEST(read_cube_curve_senses_test);
+  result += RUN_TEST(read_cube_surf_senses_test);
   return result;
@@ -64,7 +64,7 @@ void read_file( Interface* moab, const char* input_file )
+  CHECK_ERR(rval);
@@ -80,7 +80,7 @@ void read_cube_curve_senses_test()
+  CHECK_ERR(rval);
@@ -89,14 +89,14 @@ void read_cube_curve_senses_test()
+  CHECK_ERR(rval);
   Range curves;
 	  					    val, 1, curves );
+  CHECK_ERR(rval);
@@ -112,7 +112,7 @@ for(unsigned int i = 0; i < curves.size() ; i++)
    surfs.clear();
    senses.clear();
+   gt.get_senses( curves[i], surfs, senses );
    CHECK_ERR(rval);
@@ -138,7 +138,7 @@ int geom_id_by_handle( Interface* moab, const EntityHandle set )
     int id;
+    CHECK_ERR(rval);
     return id;
@@ -148,20 +148,20 @@ void check_sense_data( Interface* moab, std::vector<EntityHandle> wrt_ents, std:
-  for( unsigned int i=0 ; i<wrt_ents.size() ; i++ )
+  for(unsigned int i=0 ; i<wrt_ents.size() ; i++)
-      wrt_ent_ids.push_back( geom_id_by_handle( moab, wrt_ents[i] ));
+      wrt_ent_ids.push_back( geom_id_by_handle( moab, wrt_ents[i] ) );
-  for ( unsigned int i=0; i< wrt_ent_ids.size() ; i++ )
+  for(unsigned int i=0; i< wrt_ent_ids.size() ; i++)
-     for( unsigned int j=0; j< known_wrt_ids.size(); j++ )
           // are correct
-          CHECK_EQUAL( senses[i],known_senses[j] );
+          CHECK_EQUAL( senses[i], known_senses[j] );
@@ -176,7 +176,8 @@ void check_sense_data( Interface* moab, std::vector<EntityHandle> wrt_ents, std:
-void load_curve_sense_data( Interface* moab, EntityHandle curve, std::vector<int>& surf_ids_out, std::vector<int>& senses_out ){
@@ -260,7 +261,7 @@ void read_cube_surf_senses_test()
   Tag geom_tag;
+  CHECK_ERR(rval);
   int dim = 2;
@@ -268,14 +269,14 @@ void read_cube_surf_senses_test()
+  CHECK_ERR(rval);
   Range surfs;
 	  					    val, 1, surfs );
+  CHECK_ERR(rval);
@@ -284,14 +285,14 @@ void read_cube_surf_senses_test()
-for( unsigned int i = 0; i < surfs.size() ; i++ )
+for(unsigned int i = 0; i < surfs.size(); i++)
    vols.clear();
    senses.clear();
+   gt.get_senses( surfs[i], vols, senses );
    CHECK_ERR(rval);
@@ -300,7 +301,7 @@ for( unsigned int i = 0; i < surfs.size() ; i++ )
-   check_sense_data( mb, vols, senses, known_vol_ids, known_senses);
+   check_sense_data( mb, vols, senses, known_vol_ids, known_senses );
https://bitbucket.org/fathomteam/moab/commits/219400200c1e/
Changeset:   219400200c1e
Branch:      None
User:        pshriwise
Summary:     Added comments to read_cgm_connectivity_test.cpp
Affected #:  1 file
index 7137666..afffbe7 100644
@@ -77,7 +77,6 @@ void cube_verts_connectivity_test()
   CHECK_ERR(rval);
@@ -149,29 +148,31 @@ void cube_tri_curve_coincidence_test()
       Range tri_edges;
       CHECK_ERR(rval);
+      //Check that we've retrieved two edges from get_adjacencies
+      //For a this file (cube), each triangle should have two curve
+      //edges
       CHECK_ERR(rval);
   ErrorCode rval;
+          // If the edge handle matches a curve handle, increment the number
+          // matches
+  //Make sure that each edge returned from triangle edges
+  //has been matched to a curve
   return MB_SUCCESS;
@@ -198,7 +199,7 @@ void cube_edge_adjacencies_test()
       CHECK_ERR(rval);
-      //Ensure that an edge isn't adjacent to more than two triangles
+      //Ensure that no edge is adjacent to more than two triangles
@@ -223,7 +224,8 @@ void cube_tri_vertex_test()
       Range verts;
       CHECK_ERR(rval);
+      //Make sure that each vertex making up
+      //the triangle is different
https://bitbucket.org/fathomteam/moab/commits/3504805e93ca/
Changeset:   3504805e93ca
Branch:      None
User:        pshriwise
Summary:     Removed white space in read_cgm_connectivity_test.cpp
Affected #:  1 file
index afffbe7..f0e67c24 100644
@@ -232,5 +232,4 @@ void cube_tri_vertex_test()
https://bitbucket.org/fathomteam/moab/commits/b4f2a9df4f9e/
Changeset:   b4f2a9df4f9e
Branch:      None
User:        pshriwise
Date:        2014-02-14 01:13:33
Summary:     Cleanup of read_cgm_basic_test.cpp
Affected #:  1 file
index 69c848d..3bd5dbe 100644
@@ -43,7 +43,7 @@ void read_cube_tris_test();
-void delete_mesh_test();
+//void delete_mesh_test();
@@ -82,7 +82,7 @@ void read_cube_verts_test()
   CHECK_ERR(rval);
+  //For a cube there should be exactly 8 vertices
@@ -100,9 +100,8 @@ void read_cube_tris_test()
   CHECK_ERR(rval);
+  //For a cube, there should be exactly 2 triangles per face
@@ -112,21 +111,19 @@ void read_cube_curves_test()
   Core moab;
+  //Get the geometry tag handle from the mesh
   Tag geom_tag;
   CHECK_ERR(rval);
-  Range curves;
+  //Get the curves from the mesh
   int dim = 1;
   CHECK_ERR(rval);
+  //For a cube, there should be exactly 12 curves loaded from the file
@@ -145,15 +142,14 @@ void read_cube_surfs_test()
   CHECK_ERR(rval);
-  Range curves;
+  //Get the number of surface from the mesh geometry data
   int dim = 2;
   CHECK_ERR(rval);
+  //For a cube, there should be exactly 6 surfaces
@@ -172,17 +168,14 @@ void read_cube_vols_test()
   CHECK_ERR(rval);
-  Range curves;
+  //Get the number of volumes from the mesh geometry data
   int dim = 3;
   int number_of_vols;
   CHECK_ERR(rval);
@@ -220,7 +213,6 @@ void read_cube_vertex_pos_test()
   // Vertex 1
@@ -260,29 +252,34 @@ void read_cube_vertex_pos_test()
+  for(unsigned int i=0; i<verts.size(); i++)
+      for(unsigned int j=0; j<x_ref.size(); j++)
+  //After looping through each vertex loaded from the mesh
+  //there should be no entities left in the reference vector
+//Superfluous test for ReadCGM, but perhaps better
+//than the test in place for moab::delete_geometry()
  Core moab;
@@ -326,4 +323,4 @@ void delete_mesh_test()
https://bitbucket.org/fathomteam/moab/commits/9b1dcbd75645/
Changeset:   9b1dcbd75645
Branch:      None
User:        pshriwise
Summary:     Cleanup of read_cgm_senses_test.cpp
Affected #:  1 file
index 904477a..4f0896d 100644
@@ -77,22 +77,20 @@ void read_cube_curve_senses_test()
   Tag geom_tag;
   CHECK_ERR(rval);
   int dim = 1;
-	  					    val, 1, number_of_curves );
   CHECK_ERR(rval);
-  // Get curve handles
+  //Get curve handles
   Range curves;
 	  					    val, 1, curves );
@@ -100,6 +98,7 @@ void read_cube_curve_senses_test()
+  // Initialize vectors for sense checking
@@ -118,12 +117,11 @@ for(unsigned int i = 0; i < curves.size() ; i++)
+   //Load known curve-sense ID data
+   //Check that each surf and sense has a match in the references
@@ -131,11 +129,11 @@ int geom_id_by_handle( Interface* moab, const EntityHandle set )
     ErrorCode rval;
+    //Get the id_tag handle
     Tag id_tag;
+    //Load the ID for the EntHandle given to the function
     int id;
     CHECK_ERR(rval);
@@ -176,6 +174,7 @@ void check_sense_data( Interface* moab, std::vector<EntityHandle> wrt_ents, std:
+//Loads two vectors with reference curve and curve_sense data
@@ -263,7 +262,7 @@ void read_cube_surf_senses_test()
   CHECK_ERR(rval);
-  // Check that the proper number of curves exist
+  // Check that the proper number of surfaces exist
   int dim = 2;
@@ -272,13 +271,13 @@ void read_cube_surf_senses_test()
   CHECK_ERR(rval);
+  // Get surface handles
   Range surfs;
 	  					    val, 1, surfs );
   CHECK_ERR(rval);
-  // Establish GeomTopoTool instance needed to get curve data
+  // Establish GeomTopoTool instance needed to get surf data
@@ -294,10 +293,11 @@ for(unsigned int i = 0; i < surfs.size(); i++)
    CHECK_ERR(rval);
+   //Clear previous reverence data
+   // Load known surface-volume data
+   // for this surface and check that it's correct
@@ -307,10 +307,10 @@ for(unsigned int i = 0; i < surfs.size(); i++)
+//Loads reference surface to volume sense data into the reference vectors
   switch(surf_id)
     case 1:
@@ -341,8 +341,8 @@ void load_vol_sense_data( Interface* moab, EntityHandle surf, std::vector<int>&
     case 6:
     break;
https://bitbucket.org/fathomteam/moab/commits/342f5f7c2914/
Changeset:   342f5f7c2914
Branch:      None
User:        pshriwise
Summary:     New function create_entity_sets_for_dim in ReadCGM.cpp (refactor)
Affected #:  2 files
index aa5d972..356b2bc 100644
@@ -156,7 +156,47 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
   return MB_SUCCESS;
+  ErrorCode ReadCGM::create_entity_sets_for_dim( Interface* moab,
+                                                 int dim,
+                                                 Tag geom_tag,
+                                                 Tag id_tag,
+                                                 Tag category_tag,
+                                                 DLIList<RefEntity*>& entlist,
+                                                 std::map<RefEntity*,EntityHandle>& entitymap )
+     ErrorCode rval;
+     const char geom_categories[][CATEGORY_TAG_SIZE] =
+     {"Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0"};
+     const char* const names[] = { "Vertex", "Curve", "Surface", "Volume"};
+     entlist.clean_out();
+    GeometryQueryTool::instance()->ref_entity_list( names[dim], entlist, true );
+    entlist.reset();
+    for (int i = entlist.size(); i--; ) {
+      RefEntity* ent = entlist.get_and_step();
+      EntityHandle handle;
+      rval = moab->create_meshset( dim == 1 ? MESHSET_ORDERED : MESHSET_SET, handle );
+      if (MB_SUCCESS != rval)
+        return rval;
+      entitymap[ent] = handle;
+      rval = moab->tag_set_data( geom_tag, &handle, 1, &dim );
+        return rval;
+      int id = ent->id();
+      rval = moab->tag_set_data( id_tag, &handle, 1, &id );
+        return rval;
+      rval = moab->tag_set_data( category_tag, &handle, 1, &geom_categories[dim] );
+        return rval;
@@ -227,33 +267,11 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
   // create entity sets for all geometric entities
-  for (int dim = 0; dim < 4; ++dim) {
-    entlist.clean_out();
-    GeometryQueryTool::instance()->ref_entity_list( names[dim], entlist, true );
-    entlist.reset();
-    for (int i = entlist.size(); i--; ) {
-      RefEntity* ent = entlist.get_and_step();
-      EntityHandle handle;
-      rval = mdbImpl->create_meshset( dim == 1 ? MESHSET_ORDERED : MESHSET_SET, handle );
-      if (MB_SUCCESS != rval)
-        return rval;
-      entmap[dim][ent] = handle;
-      rval = mdbImpl->tag_set_data( geom_tag, &handle, 1, &dim );
-        return rval;
-      int id = ent->id();
-      rval = mdbImpl->tag_set_data( id_tag, &handle, 1, &id );
-        return rval;
-      rval = mdbImpl->tag_set_data( category_tag, &handle, 1, &geom_categories[dim] );
-        return rval;
+  for (int dim = 0; dim < 4; ++dim)
+      rval = create_entity_sets_for_dim( mdbImpl, dim, geom_tag, id_tag, category_tag, entlist, entmap[dim] );
+      if ( rval!=MB_SUCCESS ) return rval;
     // create topology for all geometric entities
   for (int dim = 1; dim < 4; ++dim) {
index 2919cce..651c2c7 100644
@@ -35,6 +35,7 @@
 #include <string>
 #include "moab/ReaderIface.hpp"
+#include "RefEntityName.hpp"
 namespace moab {
@@ -77,6 +78,13 @@ public:
 			        bool& act_att,
+  ErrorCode create_entity_sets_for_dim( Interface* moab,
+                                        int dim,
+                                        Tag geom_tag,
+                                        Tag id_tag,
+                                        Tag category_tag,
+                                        std::map<RefEntity*,EntityHandle>& entitymap );
    //! Constructor
https://bitbucket.org/fathomteam/moab/commits/9e99a3077c2a/
Changeset:   9e99a3077c2a
Branch:      None
User:        pshriwise
Summary:     Cleanup of function definition for create_entity_sets_for_dim
Affected #:  1 file
index 356b2bc..e936b43 100644
@@ -166,35 +166,36 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
      ErrorCode rval;
-     {"Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0"};
-    entlist.reset();
-      rval = moab->create_meshset( dim == 1 ? MESHSET_ORDERED : MESHSET_SET, handle );
-        return rval;
-      entitymap[ent] = handle;
+     entlist.reset();
+            return rval;
-      rval = moab->tag_set_data( geom_tag, &handle, 1, &dim );
-        return rval;
+            return rval;
-      rval = moab->tag_set_data( id_tag, &handle, 1, &id );
-        return rval;
+            return rval;
-      rval = moab->tag_set_data( category_tag, &handle, 1, &geom_categories[dim] );
-        return rval;
+            return rval;
@@ -267,7 +268,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
+  for(int dim = 0; dim < 4; ++dim)
https://bitbucket.org/fathomteam/moab/commits/7ec4af8c1c97/
Changeset:   7ec4af8c1c97
Branch:      None
User:        pshriwise
Summary:     Added a function create_entity_sets to ReadCGM
Affected #:  2 files
index e936b43..6636651 100644
@@ -173,7 +173,7 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
      entlist.reset();
+     for(int i = entlist.size(); i--;)
@@ -196,9 +196,29 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
             return rval;
+ErrorCode ReadCGM::create_entity_sets( Interface* moab,
+                                       Tag geom_tag,
+                                       Tag id_tag,
+                                       Tag category_tag,
+                                       std::map<RefEntity*,EntityHandle>* entmap_ptr)
+  ErrorCode rval;
+  for(int dim=0; dim<4; dim++)
+      rval = create_entity_sets_for_dim( moab, dim, geom_tag, id_tag, category_tag, entlist, *entmap_ptr );
+      if (rval!=MB_SUCCESS) return rval;
+      entmap_ptr++;
                       const EntityHandle* file_set,
@@ -214,9 +234,9 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
     return MB_UNSUPPORTED_OPERATION;
-  int norm_tol, DEFAULT_NORM = 5;
-  double faceting_tol, DEFAULT_FACET_TOL = 0.001;
-  double len_tol, DEFAULT_LEN_TOL = 0.0;
+  int norm_tol;
+  double faceting_tol;
+  double len_tol;
@@ -268,12 +288,11 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-  for(int dim = 0; dim < 4; ++dim)
-      rval = create_entity_sets_for_dim( mdbImpl, dim, geom_tag, id_tag, category_tag, entlist, entmap[dim] );
-      if ( rval!=MB_SUCCESS ) return rval;
+  std::map<RefEntity*,EntityHandle>* entmap_ptr;
+  entmap_ptr = entmap;
+  rval = create_entity_sets( mdbImpl, geom_tag, id_tag, category_tag, entlist, entmap_ptr );
     for (ci = entmap[dim].begin(); ci != entmap[dim].end(); ++ci) {
index 651c2c7..0aae3ef 100644
@@ -86,6 +86,14 @@ public:
+  ErrorCode create_entity_sets( Interface* moab,
+                                Tag geom_tag,
+                                Tag id_tag,
+                                Tag category_tag,
+                                std::map<RefEntity*,EntityHandle>* entmap_ptr);
    //! Constructor
https://bitbucket.org/fathomteam/moab/commits/7ffdcc8be8d3/
Changeset:   7ffdcc8be8d3
Branch:      None
User:        pshriwise
Summary:     Cleanup of ReadCGM from addition of create_entity_sets()
Affected #:  2 files
index 6636651..d0dcb57 100644
@@ -253,12 +253,11 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
   // CGM data
-  std::map<RefEntity*,EntityHandle> entmap[5]; // one for each dim, and one for groups
   std::map<RefEntity*,EntityHandle>::iterator ci;
-  const char* const names[] = { "Vertex", "Curve", "Surface", "Volume"};
-  DLIList<RefEntity*> entlist;
   DLIList<ModelEntity*> me_list;
   // Initialize CGM
@@ -288,8 +287,9 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-  std::map<RefEntity*,EntityHandle>* entmap_ptr;
-  entmap_ptr = entmap;
+  DLIList<RefEntity*> entlist;
+  std::map<RefEntity*,EntityHandle> entmap[5]; // one for each dim, and one for groups
+  std::map<RefEntity*,EntityHandle>* entmap_ptr= entmap;
index 0aae3ef..a5bb127 100644
@@ -92,7 +92,7 @@ public:
                                 Tag id_tag,
                                 Tag category_tag,
-                                std::map<RefEntity*,EntityHandle>* entmap_ptr);
+                                std::map<RefEntity*,EntityHandle>* entmap_ptr );
    //! Constructor
https://bitbucket.org/fathomteam/moab/commits/271c76fbfb53/
Changeset:   271c76fbfb53
Branch:      None
User:        pshriwise
Summary:     Removed the DLI list from the function create_entity_sets_for_dim
Affected #:  2 files
index d0dcb57..80b2738 100644
@@ -203,17 +203,17 @@ ErrorCode ReadCGM::create_entity_sets( Interface* moab,
                                        Tag geom_tag,
                                        Tag id_tag,
                                        Tag category_tag,
-                                       DLIList<RefEntity*>& entlist,
   ErrorCode rval;
       entmap_ptr++;
   return MB_SUCCESS;
@@ -290,7 +290,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-  rval = create_entity_sets( mdbImpl, geom_tag, id_tag, category_tag, entlist, entmap_ptr );
+  rval = create_entity_sets( mdbImpl, geom_tag, id_tag, category_tag, entmap_ptr );
index a5bb127..c17f28f 100644
@@ -91,7 +91,6 @@ public:
                                 Tag geom_tag,
                                 Tag id_tag,
                                 Tag category_tag,
    //! Constructor
https://bitbucket.org/fathomteam/moab/commits/7178c16e4ffe/
Changeset:   7178c16e4ffe
Branch:      None
User:        pshriwise
Summary:     Removed entlist argument from create_entity_sets_for_dim.
Affected #:  2 files
index 80b2738..52a8c26 100644
@@ -161,14 +161,13 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
                                                  Tag geom_tag,
                                                  Tag id_tag,
                                                  Tag category_tag,
      ErrorCode rval;
@@ -207,13 +206,11 @@ ErrorCode ReadCGM::create_entity_sets( Interface* moab,
   ErrorCode rval;
-      rval = create_entity_sets_for_dim( moab, dim, geom_tag, id_tag, category_tag, entlist, *entmap_ptr );
+      rval = create_entity_sets_for_dim( moab, dim, geom_tag, id_tag, category_tag, *entmap_ptr );
       entmap_ptr++;
   return MB_SUCCESS;
index c17f28f..355549a 100644
@@ -83,7 +83,6 @@ public:
                                         Tag geom_tag,
                                         Tag id_tag,
                                         Tag category_tag,
https://bitbucket.org/fathomteam/moab/commits/85aee315ce58/
Changeset:   85aee315ce58
Branch:      None
User:        pshriwise
Summary:     Added function create_topology to ReadCGM.
(Not implemented in ReadCGM::load_file yet)
Affected #:  2 files
index 52a8c26..d4afee9 100644
@@ -216,6 +216,31 @@ ErrorCode ReadCGM::create_entity_sets( Interface* moab,
   return MB_SUCCESS;
+ErrorCode ReadCGM::create_topology( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5])
+  ErrorCode rval;
+  DLIList<RefEntity*> entitylist;
+  std::map<RefEntity*,EntityHandle>::iterator ci;
+  for (int dim = 1; dim < 4; ++dim) {
+    for (ci = entitymap[dim].begin(); ci != entitymap[dim].end(); ++ci) {
+      entitylist.clean_out();
+      ci->first->get_child_ref_entities( entitylist );
+      entitylist.reset();
+      for (int i = entitylist.size(); i--; ) {
+        RefEntity* ent = entitylist.get_and_step();
+        EntityHandle h = entitymap[dim-1][ent];
+        rval = moab->add_parent_child( ci->second, h );
+          return rval;
index 355549a..00bc020 100644
@@ -92,6 +92,8 @@ public:
                                 Tag category_tag,
+  ErrorCode create_topology( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5]);
    //! Constructor
https://bitbucket.org/fathomteam/moab/commits/33b0aae124d1/
Changeset:   33b0aae124d1
Branch:      None
User:        pshriwise
Summary:     Implemented the function create_topology in ReadCGM
Affected #:  1 file
index d4afee9..668d6fb 100644
@@ -237,7 +237,7 @@ ErrorCode ReadCGM::create_topology( Interface* moab, std::map<RefEntity*,EntityH
@@ -316,22 +316,10 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-  for (int dim = 1; dim < 4; ++dim) {
-    for (ci = entmap[dim].begin(); ci != entmap[dim].end(); ++ci) {
-      ci->first->get_child_ref_entities( entlist );
-      entlist.reset();
-        EntityHandle h = entmap[dim-1][ent];
-        rval = mdbImpl->add_parent_child( ci->second, h );
-          return rval;
+  rval = create_topology( mdbImpl, entmap );
     // store CoFace senses
   for (ci = entmap[2].begin(); ci != entmap[2].end(); ++ci) {
     RefFace* face = (RefFace*)(ci->first);
https://bitbucket.org/fathomteam/moab/commits/4bff8985b5a5/
Changeset:   4bff8985b5a5
Branch:      None
User:        pshriwise
Summary:     Small formatting change to ReadCGM
Affected #:  1 file
index 668d6fb..87b2f03 100644
@@ -315,8 +315,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-    // create topology for all geometric entities
+  // create topology for all geometric entities
https://bitbucket.org/fathomteam/moab/commits/9bba88e5df5a/
Changeset:   9bba88e5df5a
Branch:      None
User:        pshriwise
Date:        2014-02-14 01:13:34
Summary:     Removed the MOAB tag arguments from create_entity_sets_for_dim and create_entity_sets in ReadCGM
Affected #:  2 files
index 87b2f03..2bd0122 100644
@@ -158,9 +158,6 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
                                                  int dim,
-                                                 Tag geom_tag,
-                                                 Tag id_tag,
-                                                 Tag category_tag,
      ErrorCode rval;
@@ -199,16 +196,13 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
-                                       Tag geom_tag,
-                                       Tag id_tag,
-                                       Tag category_tag,
   ErrorCode rval;
-      rval = create_entity_sets_for_dim( moab, dim, geom_tag, id_tag, category_tag, *entmap_ptr );
+      rval = create_entity_sets_for_dim( moab, dim, *entmap_ptr );
       entmap_ptr++;
@@ -312,7 +306,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-  rval = create_entity_sets( mdbImpl, geom_tag, id_tag, category_tag, entmap_ptr );
+  rval = create_entity_sets( mdbImpl, entmap_ptr );
index 00bc020..f81b2a2 100644
@@ -80,16 +80,10 @@ public:
                                         int dim,
-                                        Tag geom_tag,
-                                        Tag id_tag,
-                                        Tag category_tag,
-                                Tag geom_tag,
-                                Tag id_tag,
-                                Tag category_tag,
https://bitbucket.org/fathomteam/moab/commits/52ca26ac5897/
Changeset:   52ca26ac5897
Branch:      None
User:        pshriwise
Summary:     Added the function store_surface_senses to ReadCGM
Affected #:  2 files
index 2bd0122..e8e9c20 100644
@@ -234,6 +234,55 @@ ErrorCode ReadCGM::create_topology( Interface* moab, std::map<RefEntity*,EntityH
   return MB_SUCCESS;
+ErrorCode ReadCGM::store_surface_senses( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] )
+  ErrorCode rval;
+  for (ci = entitymap[2].begin(); ci != entitymap[2].end(); ++ci) {
+    RefFace* face = (RefFace*)(ci->first);
+    BasicTopologyEntity *forward = 0, *reverse = 0;
+    for (SenseEntity* cf = face->get_first_sense_entity_ptr();
+         cf; cf = cf->next_on_bte()) {
+      BasicTopologyEntity* vol = cf->get_parent_basic_topology_entity_ptr();
+      if (cf->get_sense() == CUBIT_UNKNOWN ||
+          cf->get_sense() != face->get_surface_ptr()->bridge_sense()) {
+        if (reverse) {
+          std::cout << "Surface " << face->id() << " has reverse senes " <<
+                       "with multiple volume " << reverse->id() << " and " <<
+                       "volume " << vol->id() << std::endl;
+          return MB_FAILURE;
+        reverse = vol;
+          cf->get_sense() == face->get_surface_ptr()->bridge_sense()) {
+        if (forward) {
+          std::cout << "Surface " << face->id() << " has forward senes " <<
+                       "with multiple volume " << forward->id() << " and " <<
+        forward = vol;
+    if (forward) {
+      rval = myGeomTool->set_sense( ci->second, entitymap[3][forward], SENSE_FORWARD );
+        return rval;
+    if (reverse) {
+      rval = myGeomTool->set_sense( ci->second, entitymap[3][reverse], SENSE_REVERSE );
+        return rval;
@@ -313,46 +362,9 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-    // store CoFace senses
-  for (ci = entmap[2].begin(); ci != entmap[2].end(); ++ci) {
-    RefFace* face = (RefFace*)(ci->first);
-    BasicTopologyEntity *forward = 0, *reverse = 0;
-    for (SenseEntity* cf = face->get_first_sense_entity_ptr();
-         cf; cf = cf->next_on_bte()) {
-      BasicTopologyEntity* vol = cf->get_parent_basic_topology_entity_ptr();
-      if (cf->get_sense() == CUBIT_UNKNOWN ||
-          cf->get_sense() != face->get_surface_ptr()->bridge_sense()) {
-        if (reverse) {
-          std::cout << "Surface " << face->id() << " has reverse senes " <<
-                       "with multiple volume " << reverse->id() << " and " <<
-                       "volume " << vol->id() << std::endl;
-          return MB_FAILURE;
-        reverse = vol;
-          cf->get_sense() == face->get_surface_ptr()->bridge_sense()) {
-        if (forward) {
-          std::cout << "Surface " << face->id() << " has forward senes " <<
-                       "with multiple volume " << forward->id() << " and " <<
-        forward = vol;
-    if (forward) {
-      rval = myGeomTool->set_sense( ci->second, entmap[3][forward], SENSE_FORWARD );
-        return rval;
-    if (reverse) {
-      rval = myGeomTool->set_sense( ci->second, entmap[3][reverse], SENSE_REVERSE );
-        return rval;
+  // store CoFace senses
+  rval = store_surface_senses( mdbImpl, entmap );
     // store CoEdge senses
   std::vector<EntityHandle> ents;
index f81b2a2..06b0187 100644
@@ -88,6 +88,8 @@ public:
+  ErrorCode store_surface_senses( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] );
    //! Constructor
https://bitbucket.org/fathomteam/moab/commits/d7d98e5a0fbc/
Changeset:   d7d98e5a0fbc
Branch:      None
User:        pshriwise
Summary:     Formatting corrections to ReadCGM
Affected #:  2 files
index e8e9c20..77329b4 100644
@@ -354,7 +354,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-  std::map<RefEntity*,EntityHandle>* entmap_ptr= entmap;
+  std::map<RefEntity*,EntityHandle>* entmap_ptr = entmap;
index 06b0187..480cc48 100644
@@ -86,7 +86,7 @@ public:
-  ErrorCode create_topology( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5]);
+  ErrorCode create_topology( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] );
https://bitbucket.org/fathomteam/moab/commits/96aa485ccb28/
Changeset:   96aa485ccb28
Branch:      None
User:        pshriwise
Summary:     Added comments/corrections to store_surface_senses in ReadCGM
Affected #:  1 file
index 77329b4..a173cff 100644
@@ -245,10 +245,12 @@ ErrorCode ReadCGM::store_surface_senses( Interface* moab, std::map<RefEntity*,En
+      // allocate vol to the proper topology entity (forward or reverse)
+        //check that each surface has a sense for only one volume
         if (reverse) {
+          std::cout << "Surface " << face->id() << " has reverse sense " <<
           return MB_FAILURE;
@@ -257,8 +259,9 @@ ErrorCode ReadCGM::store_surface_senses( Interface* moab, std::map<RefEntity*,En
         if (forward) {
+          std::cout << "Surface " << face->id() << " has forward sense " <<
           return MB_FAILURE;
https://bitbucket.org/fathomteam/moab/commits/e33be4a0bb59/
Changeset:   e33be4a0bb59
Branch:      None
User:        pshriwise
Summary:     Small formatting corrections to ReadCGM.cpp
Affected #:  1 file
index a173cff..7654b01 100644
@@ -282,7 +282,6 @@ ErrorCode ReadCGM::store_surface_senses( Interface* moab, std::map<RefEntity*,En
   return MB_SUCCESS;
@@ -415,7 +414,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
 #else
     //true argument is optional, but for large multi-names situation, it should save
     //some cpu time
-    RefEntityName::instance()->get_refentity_name(grp, name_list,true);
+    RefEntityName::instance()->get_refentity_name(grp, name_list, true);
 #endif
     if (name_list.size() == 0)
       continue;
https://bitbucket.org/fathomteam/moab/commits/d57db27ecbf3/
Changeset:   d57db27ecbf3
Branch:      None
User:        pshriwise
Summary:     Added a function store_curve_senses to ReadCGM
Affected #:  2 files
index 7654b01..4cca13f 100644
@@ -285,6 +285,40 @@ ErrorCode ReadCGM::store_surface_senses( Interface* moab, std::map<RefEntity*,En
   return MB_SUCCESS;
+ErrorCode ReadCGM::store_curve_senses( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] )
+  ErrorCode rval;
+  std::vector<EntityHandle> ents;
+  std::vector<int> senses;
+  for (ci = entitymap[1].begin(); ci != entitymap[1].end(); ++ci) {
+    RefEdge* edge = (RefEdge*)(ci->first);
+    ents.clear();
+    senses.clear();
+    for (SenseEntity* ce = edge->get_first_sense_entity_ptr();
+         ce; ce = ce->next_on_bte()) {
+      BasicTopologyEntity* fac = ce->get_parent_basic_topology_entity_ptr();
+      EntityHandle face = entitymap[2][fac];
+      if (ce->get_sense() == CUBIT_UNKNOWN ||
+          ce->get_sense() != edge->get_curve_ptr()->bridge_sense()) {
+        ents.push_back(face);
+        senses.push_back(SENSE_REVERSE);
+          ce->get_sense() == edge->get_curve_ptr()->bridge_sense()) {
+        senses.push_back(SENSE_FORWARD);
+    rval = myGeomTool->set_senses( ci->second, ents, senses);
+      return rval;
@@ -368,33 +402,9 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-    // store CoEdge senses
-  std::vector<EntityHandle> ents;
-  std::vector<int> senses;
-  for (ci = entmap[1].begin(); ci != entmap[1].end(); ++ci) {
-    RefEdge* edge = (RefEdge*)(ci->first);
-    ents.clear();
-    senses.clear();
-    for (SenseEntity* ce = edge->get_first_sense_entity_ptr();
-         ce; ce = ce->next_on_bte()) {
-      BasicTopologyEntity* fac = ce->get_parent_basic_topology_entity_ptr();
-      EntityHandle face = entmap[2][fac];
-      if (ce->get_sense() == CUBIT_UNKNOWN ||
-          ce->get_sense() != edge->get_curve_ptr()->bridge_sense()) {
-        ents.push_back(face);
-        senses.push_back(SENSE_REVERSE);
-          ce->get_sense() == edge->get_curve_ptr()->bridge_sense()) {
-        senses.push_back(SENSE_FORWARD);
-    rval = myGeomTool->set_senses( ci->second, ents, senses);
-      return rval;
+  // store CoEdge senses
+  rval = store_curve_senses( mdbImpl, entmap);
     // create entity sets for all ref groups
   std::vector<Tag> extra_name_tags;
index 480cc48..d9d3a29 100644
@@ -90,6 +90,8 @@ public:
+  ErrorCode store_curve_senses( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] );
    //! Constructor
https://bitbucket.org/fathomteam/moab/commits/3511a68ccc66/
Changeset:   3511a68ccc66
Branch:      None
User:        pshriwise
Summary:     Removed MOAB interface argument from store_surface_senses function in ReadCGM
Affected #:  2 files
index 4cca13f..4cc5b2c 100644
@@ -234,7 +234,7 @@ ErrorCode ReadCGM::create_topology( Interface* moab, std::map<RefEntity*,EntityH
   return MB_SUCCESS;
-ErrorCode ReadCGM::store_surface_senses( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] )
+ErrorCode ReadCGM::store_surface_senses( std::map<RefEntity*,EntityHandle> entitymap[5] )
   ErrorCode rval;
@@ -399,7 +399,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-  rval = store_surface_senses( mdbImpl, entmap );
+  rval = store_surface_senses( entmap );
index d9d3a29..848b27c 100644
@@ -88,7 +88,7 @@ public:
-  ErrorCode store_surface_senses( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] );
+  ErrorCode store_surface_senses( std::map<RefEntity*,EntityHandle> entitymap[5] );
https://bitbucket.org/fathomteam/moab/commits/45de710c95c0/
Changeset:   45de710c95c0
Branch:      None
User:        pshriwise
Summary:     Removed MOAB interface argument from store_curve_senses in ReadCGM
Affected #:  2 files
index 4cc5b2c..9800acb 100644
@@ -285,7 +285,7 @@ ErrorCode ReadCGM::store_surface_senses( std::map<RefEntity*,EntityHandle> entit
   return MB_SUCCESS;
-ErrorCode ReadCGM::store_curve_senses( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] )
+ErrorCode ReadCGM::store_curve_senses( std::map<RefEntity*,EntityHandle> entitymap[5] )
   ErrorCode rval;
@@ -403,7 +403,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-  rval = store_curve_senses( mdbImpl, entmap);
+  rval = store_curve_senses( entmap );
index 848b27c..406cef8 100644
@@ -90,7 +90,7 @@ public:
-  ErrorCode store_curve_senses( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] );
+  ErrorCode store_curve_senses( std::map<RefEntity*,EntityHandle> entitymap[5] );
    //! Constructor
https://bitbucket.org/fathomteam/moab/commits/496f817a16b2/
Changeset:   496f817a16b2
Branch:      None
User:        pshriwise
Summary:     Added comments to section on group entity creation in ReadCGM
Affected #:  1 file
index 9800acb..d1137bf 100644
@@ -414,11 +414,15 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
   DLIList<CubitString*> name_list;
 #endif
+  //get all entity groups from the CGM model
   GeometryQueryTool::instance()->ref_entity_list( "group", entlist );
   entlist.reset();
+  //loop over all groups
+    //take the next group
     RefEntity* grp = entlist.get_and_step();
     name_list.clean_out();
+//get the names of all entities in this group from the solid model
 #if  CGM_MAJOR_VERSION>13
     RefEntityName::instance()->get_refentity_name(grp, name_list);
 #else
@@ -428,19 +432,19 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
 #endif
       continue;
+    //set pointer to first name of the group and set the first name to name1
     name_list.reset();
     CubitString name1 = name_list.get();
 #else
     CubitString name1 = *name_list.get();
 #endif
+    // create entity handle for the group
     EntityHandle h;
     rval = mdbImpl->create_meshset( MESHSET_SET, h );
       return rval;
+    //set tag data for the group
     char namebuf[NAME_TAG_SIZE];
     memset( namebuf, '\0', NAME_TAG_SIZE );
     strncpy( namebuf, name1.c_str(), NAME_TAG_SIZE - 1 );
@@ -459,7 +463,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
     rval = mdbImpl->tag_set_data( category_tag, &h, 1, &geom_categories[4] );
       return MB_FAILURE;
+    //check for extra group names
     if (name_list.size() > 1) {
       for (int j = extra_name_tags.size(); j < name_list.size(); ++j) {
         sprintf( namebuf, "EXTRA_%s%d", NAME_TAG_NAME, j );
@@ -468,7 +472,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
         assert(!rval);
         extra_name_tags.push_back(t);
+      //add extra group names to the group handle
       for (int j = 0; j < name_list.size(); ++j) {
         name1 = name_list.get_and_step();
@@ -485,7 +489,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
           return MB_FAILURE;
+    //add the group handle
     entmap[4][grp] = h;
https://bitbucket.org/fathomteam/moab/commits/22564cd4f7c1/
Changeset:   22564cd4f7c1
Branch:      None
User:        pshriwise
Summary:     Added the function create group entities to ReadCGM
Affected #:  2 files
index d1137bf..5616365 100644
@@ -319,6 +319,101 @@ ErrorCode ReadCGM::store_curve_senses( std::map<RefEntity*,EntityHandle> entitym
   return MB_SUCCESS;
+ErrorCode ReadCGM::create_group_entities( Interface* moab, std::map<RefEntity*,EntityHandle>* entitymap )
+  ErrorCode rval;
+ // create entity sets for all ref groups
+  std::vector<Tag> extra_name_tags;
+#if  CGM_MAJOR_VERSION>13
+  DLIList<CubitString> name_list;
+#else
+  DLIList<CubitString*> name_list;
+#endif
+  GeometryQueryTool::instance()->ref_entity_list( "group", entitylist );
+    RefEntity* grp = entitylist.get_and_step();
+    name_list.clean_out();
+    RefEntityName::instance()->get_refentity_name(grp, name_list);
+#else
+    //true argument is optional, but for large multi-names situation, it should save
+    //some cpu time
+#endif
+    if (name_list.size() == 0)
+      continue;
+    name_list.reset();
+    CubitString name1 = name_list.get();
+#else
+    CubitString name1 = *name_list.get();
+#endif
+    EntityHandle h;
+    rval = moab->create_meshset( MESHSET_SET, h );
+      return rval;
+    char namebuf[NAME_TAG_SIZE];
+    memset( namebuf, '\0', NAME_TAG_SIZE );
+    strncpy( namebuf, name1.c_str(), NAME_TAG_SIZE - 1 );
+    if (name1.length() >= (unsigned)NAME_TAG_SIZE)
+      std::cout << "WARNING: group name '" << name1.c_str()
+                << "' truncated to '" << namebuf << "'" << std::endl;
+    rval = moab->tag_set_data( name_tag, &h, 1, namebuf );
+    int id = grp->id();
+    rval = moab->tag_set_data( id_tag, &h, 1, &id );
+    rval = moab->tag_set_data( category_tag, &h, 1, &geom_categories[4] );
+    if (name_list.size() > 1) {
+      for (int j = extra_name_tags.size(); j < name_list.size(); ++j) {
+        sprintf( namebuf, "EXTRA_%s%d", NAME_TAG_NAME, j );
+        Tag t;
+        rval = moab->tag_get_handle( namebuf, NAME_TAG_SIZE, MB_TYPE_OPAQUE, t, MB_TAG_SPARSE|MB_TAG_CREAT );
+        assert(!rval);
+        extra_name_tags.push_back(t);
+      for (int j = 0; j < name_list.size(); ++j) {
+        name1 = name_list.get_and_step();
+#else
+        name1 = *name_list.get_and_step();
+#endif
+        rval = moab->tag_set_data( extra_name_tags[j], &h, 1, namebuf );
+    entitymap[4][grp] = h;
index 406cef8..51d84ad 100644
@@ -92,6 +92,9 @@ public:
+  ErrorCode create_group_entities( Interface* moab, std::map<RefEntity*,EntityHandle>* entitymap );
    //! Constructor
https://bitbucket.org/fathomteam/moab/commits/5d29b19b02ad/
Changeset:   5d29b19b02ad
Branch:      None
User:        pshriwise
Summary:     Added a new file for sense checking and re-directed the ReadCGM sense tests to that file
Affected #:  2 files
diff --git a/MeshFiles/unittest/io/cylcube.sat b/MeshFiles/unittest/io/cylcube.sat
new file mode 100644
index 0000000..0b65976
--- /dev/null
+++ b/MeshFiles/unittest/io/cylcube.sat
@@ -0,0 +1,202 @@
+1900 0 2 0
+10 Cubit 12.2 17 ACIS 19.0.2 Linux 24 Thu Feb  6 08:36:54 2014
+1 9.9999999999999995e-07 1e-10
+body $2 -1 -1 $-1 $3 $-1 $4 T 25 -5 -5 35 5 5 #
+body $5 -1 -1 $-1 $6 $-1 $-1 T -5 -5 -5 5 5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $7 $-1 $0 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+lump $8 -1 -1 $-1 $-1 $9 $0 T 25 -5 -5 35 5 5 #
+transform $-1 -1 1 0 0 0 1 0 0 0 1 0 0 0 1 no_rotate no_reflect no_shear #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $10 $-1 $1 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 2 #
+lump $11 -1 -1 $-1 $-1 $12 $1 T -5 -5 -5 5 5 5 #
+simple-snl-attrib $-1 -1 $-1 $2 $0 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 1 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $13 $-1 $3 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+shell $-1 -1 -1 $-1 $-1 $-1 $14 $-1 $3 T 25 -5 -5 35 5 5 #
+simple-snl-attrib $-1 -1 $-1 $5 $1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 2 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $15 $-1 $6 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 2 #
+shell $-1 -1 -1 $-1 $-1 $-1 $16 $-1 $6 T -5 -5 -5 5 5 5 #
+simple-snl-attrib $-1 -1 $17 $8 $3 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 1 -2147483648 -1 #
+face $18 -1 -1 $-1 $19 $20 $9 $-1 $21 forward single T 25 -5 5 35 5 5 F #
+simple-snl-attrib $-1 -1 $22 $11 $6 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 2 -2147483648 -1 #
+face $23 -1 -1 $-1 $24 $25 $12 $-1 $26 forward single T -5 -5 -5 5 5 5 F #
+simple-snl-attrib $-1 -1 $27 $13 $3 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 2 @5 GROUP @7 Group 2 0 7 1 2 618932362 0 0 0 0 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $28 $-1 $14 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+face $29 -1 -1 $-1 $30 $31 $9 $-1 $32 reversed single T 25 -5 -5 35 5 -5 F #
+loop $-1 -1 -1 $-1 $-1 $33 $14 T 25 -5 5 35 5 5 unknown #
+plane-surface $-1 -1 -1 $-1 30 0 5 0 0 1 1 0 0 forward_v I I I I #
+simple-snl-attrib $-1 -1 $34 $15 $6 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 2 @5 GROUP @7 Group 3 0 7 1 3 885205176 0 0 0 0 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $35 $-1 $16 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 7 #
+face $36 -1 -1 $-1 $37 $38 $12 $-1 $39 forward single T -5 -5 -5 5 5 -5 F #
+loop $-1 -1 -1 $-1 $40 $41 $16 T -5 -5 -5 5 5 -5 unknown #
+cone-surface $-1 -1 -1 $-1 0 0 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+simple-snl-attrib $-1 -1 $-1 $17 $3 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 7 @16 GRAPHICS_OPTIONS @14 geometry color @10 mesh color @19 geometry visibility @15 mesh visibility @11 render mode @11 transparent 0 6 4 4 1 1 0 0 #
+simple-snl-attrib $-1 -1 $42 $18 $14 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 1 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $43 $-1 $19 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 2 #
+face $44 -1 -1 $-1 $45 $46 $9 $-1 $47 reversed single T 25 -5 -5 35 -5 5 F #
+loop $-1 -1 -1 $-1 $-1 $48 $19 T 25 -5 -5 35 5 -5 unknown #
+plane-surface $-1 -1 -1 $-1 30 0 -5 0 0 1 1 0 0 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $49 $50 $51 $52 forward $20 $-1 #
+simple-snl-attrib $-1 -1 $-1 $22 $6 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 7 @16 GRAPHICS_OPTIONS @14 geometry color @10 mesh color @19 geometry visibility @15 mesh visibility @11 render mode @11 transparent 0 6 5 5 1 1 0 0 #
+simple-snl-attrib $-1 -1 $53 $23 $16 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 7 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $54 $-1 $24 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 8 #
+face $55 -1 -1 $-1 $-1 $56 $12 $-1 $57 forward single T -5 -5 5 5 5 5 F #
+loop $-1 -1 -1 $-1 $-1 $58 $24 T -5 -5 -5 5 5 -5 unknown #
+plane-surface $-1 -1 -1 $-1 0 0 -5 0 0 -1 -1 0 0 forward_v I I I I #
+loop $-1 -1 -1 $-1 $-1 $59 $16 T -5 -5 5 5 5 5 unknown #
+coedge $-1 -1 -1 $-1 $41 $41 $58 $60 reversed $25 $-1 #
+simple-snl-attrib $-1 -1 $-1 $28 $14 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 LIMP @4 LIMP 2 1 0 5 1 0 0 1 1 #
+simple-snl-attrib $-1 -1 $61 $29 $19 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 2 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $62 $-1 $30 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 3 #
+face $63 -1 -1 $-1 $64 $65 $9 $-1 $66 reversed single T 25 -5 -5 25 5 5 F #
+loop $-1 -1 -1 $-1 $-1 $67 $30 T 25 -5 -5 35 -5 5 unknown #
+plane-surface $-1 -1 -1 $-1 30 -5 0 0 1 0 0 0 1 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $68 $69 $70 $71 forward $31 $-1 #
+coedge $-1 -1 -1 $-1 $72 $33 $73 $74 forward $20 $-1 #
+coedge $-1 -1 -1 $-1 $33 $72 $75 $76 forward $20 $-1 #
+coedge $-1 -1 -1 $-1 $77 $78 $33 $52 reversed $79 $-1 #
+edge $80 -1 -1 $-1 $81 -5 $82 5 $51 $83 forward @7 unknown T 35 -5 5 35 5 5 #
+simple-snl-attrib $-1 -1 $-1 $35 $16 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 LIMP @4 LIMP 2 1 0 5 1 0 0 1 1 #
+simple-snl-attrib $-1 -1 $84 $36 $24 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 8 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $85 $-1 $37 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 9 #
+loop $-1 -1 -1 $-1 $-1 $86 $37 T -5 -5 5 5 5 5 unknown #
+plane-surface $-1 -1 -1 $-1 0 0 5 0 0 1 1 0 0 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $58 $58 $41 $60 forward $38 $-1 #
+coedge $-1 -1 -1 $-1 $59 $59 $86 $87 reversed $40 $-1 #
+edge $88 -1 -1 $-1 $89 0 $89 6.2831853071795862 $58 $90 forward @7 unknown T -5 -5 -5 5 5 -5 #
+simple-snl-attrib $-1 -1 $-1 $43 $19 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 LIMP @4 LIMP 2 1 0 5 1 0 0 1 1 #
+simple-snl-attrib $-1 -1 $91 $44 $30 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 3 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $92 $-1 $45 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 4 #
+face $93 -1 -1 $-1 $94 $95 $9 $-1 $96 reversed single T 25 5 -5 35 5 5 F #
+loop $-1 -1 -1 $-1 $-1 $97 $45 T 25 -5 -5 25 5 5 unknown #
+plane-surface $-1 -1 -1 $-1 25 0 0 1 0 0 0 0 -1 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $98 $75 $99 $100 forward $46 $-1 #
+coedge $-1 -1 -1 $-1 $101 $48 $98 $102 forward $31 $-1 #
+coedge $-1 -1 -1 $-1 $48 $101 $103 $104 forward $31 $-1 #
+coedge $-1 -1 -1 $-1 $78 $77 $48 $71 reversed $79 $-1 #
+edge $105 -1 -1 $-1 $106 -5 $107 5 $70 $108 forward @7 unknown T 35 -5 -5 35 5 -5 #
+coedge $-1 -1 -1 $-1 $50 $49 $109 $110 forward $20 $-1 #
+coedge $-1 -1 -1 $-1 $111 $112 $49 $74 reversed $95 $-1 #
+edge $113 -1 -1 $-1 $82 -5 $114 5 $73 $115 forward @7 unknown T 25 5 5 35 5 5 #
+coedge $-1 -1 -1 $-1 $67 $116 $50 $76 reversed $46 $-1 #
+edge $117 -1 -1 $-1 $118 -5 $81 5 $75 $119 forward @7 unknown T 25 -5 5 35 -5 5 #
+coedge $-1 -1 -1 $-1 $70 $51 $116 $120 forward $79 $-1 #
+coedge $-1 -1 -1 $-1 $51 $70 $111 $121 reversed $79 $-1 #
+loop $-1 -1 -1 $-1 $-1 $77 $94 T 35 -5 -5 35 5 5 unknown #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $122 $-1 $52 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+vertex $123 -1 -1 $-1 $52 $124 #
+vertex $125 -1 -1 $-1 $52 $126 #
+straight-curve $-1 -1 -1 $-1 35 0 5 0 1 0 I I #
+simple-snl-attrib $-1 -1 $-1 $54 $24 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 LIMP @4 LIMP 2 1 0 5 1 0 0 1 1 #
+simple-snl-attrib $-1 -1 $127 $55 $37 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 9 -2147483648 -1 #
+coedge $-1 -1 -1 $-1 $86 $86 $59 $87 forward $56 $-1 #
+edge $128 -1 -1 $-1 $129 0 $129 6.2831853071795862 $86 $130 forward @7 unknown T -5 -5 5 5 5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $131 $-1 $60 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 13 #
+vertex $132 -1 -1 $-1 $60 $133 #
+ellipse-curve $-1 -1 -1 $-1 0 0 -5 0 0 -1 5 0 0 1 I I #
+simple-snl-attrib $-1 -1 $-1 $62 $30 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 LIMP @4 LIMP 2 1 0 5 1 0 0 1 1 #
+simple-snl-attrib $-1 -1 $134 $63 $45 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 4 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $135 $-1 $64 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 5 #
+face $136 -1 -1 $-1 $-1 $79 $9 $-1 $137 reversed single T 35 -5 -5 35 5 5 F #
+loop $-1 -1 -1 $-1 $-1 $111 $64 T 25 5 -5 35 5 5 unknown #
+plane-surface $-1 -1 -1 $-1 30 5 0 0 -1 0 0 0 -1 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $138 $109 $112 $139 forward $65 $-1 #
+coedge $-1 -1 -1 $-1 $116 $67 $68 $102 reversed $46 $-1 #
+coedge $-1 -1 -1 $-1 $109 $138 $67 $100 reversed $65 $-1 #
+edge $140 -1 -1 $-1 $118 -5 $141 5 $99 $142 forward @7 unknown T 25 -5 -5 25 -5 5 #
+coedge $-1 -1 -1 $-1 $69 $68 $138 $143 forward $31 $-1 #
+edge $144 -1 -1 $-1 $107 -5 $141 5 $98 $145 forward @7 unknown T 25 -5 -5 35 -5 -5 #
+coedge $-1 -1 -1 $-1 $112 $111 $69 $104 reversed $95 $-1 #
+edge $146 -1 -1 $-1 $147 -5 $106 5 $103 $148 forward @7 unknown T 25 5 -5 35 5 -5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $149 $-1 $71 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 5 #
+vertex $150 -1 -1 $-1 $71 $151 #
+vertex $152 -1 -1 $-1 $120 $153 #
+straight-curve $-1 -1 -1 $-1 35 0 -5 0 -1 0 I I #
+coedge $-1 -1 -1 $-1 $97 $99 $72 $110 reversed $65 $-1 #
+edge $154 -1 -1 $-1 $114 -5 $118 5 $109 $155 forward @7 unknown T 25 -5 5 25 5 5 #
+coedge $-1 -1 -1 $-1 $103 $73 $78 $121 forward $95 $-1 #
+coedge $-1 -1 -1 $-1 $73 $103 $97 $139 reversed $95 $-1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $156 $-1 $74 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 2 #
+vertex $157 -1 -1 $-1 $74 $158 #
+straight-curve $-1 -1 -1 $-1 30 5 5 -1 0 0 I I #
+coedge $-1 -1 -1 $-1 $75 $98 $77 $120 reversed $46 $-1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $159 $-1 $76 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 4 #
+vertex $160 -1 -1 $-1 $110 $161 #
+straight-curve $-1 -1 -1 $-1 30 -5 5 1 0 0 I I #
+edge $162 -1 -1 $-1 $81 -5 $107 5 $77 $163 forward @7 unknown T 35 -5 -5 35 -5 5 #
+edge $164 -1 -1 $-1 $82 -5 $106 5 $78 $165 forward @7 unknown T 35 5 -5 35 5 5 #
+simple-snl-attrib $-1 -1 $-1 $80 $52 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 1 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $166 $-1 $81 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+point $-1 -1 -1 $-1 35 -5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $167 $-1 $82 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 2 #
+point $-1 -1 -1 $-1 35 5 5 #
+simple-snl-attrib $-1 -1 $-1 $85 $37 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 LIMP @4 LIMP 2 1 0 5 1 0 0 1 1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $168 $-1 $87 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 14 #
+vertex $169 -1 -1 $-1 $87 $170 #
+ellipse-curve $-1 -1 -1 $-1 0 0 5 0 0 1 5 0 0 1 I I #
+simple-snl-attrib $-1 -1 $-1 $88 $60 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 13 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $171 $-1 $89 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 9 #
+point $-1 -1 -1 $-1 5 0 -5 #
+simple-snl-attrib $-1 -1 $-1 $92 $45 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 LIMP @4 LIMP 2 1 0 5 1 0 0 1 1 #
+simple-snl-attrib $-1 -1 $172 $93 $64 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 5 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $173 $-1 $94 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 6 #
+plane-surface $-1 -1 -1 $-1 35 0 0 -1 0 0 0 0 1 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $99 $97 $101 $143 reversed $65 $-1 #
+edge $174 -1 -1 $-1 $114 -5 $147 5 $112 $175 forward @7 unknown T 25 5 -5 25 5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $176 $-1 $100 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 9 #
+vertex $177 -1 -1 $-1 $143 $178 #
+straight-curve $-1 -1 -1 $-1 25 -5 0 0 0 -1 I I #
+edge $179 -1 -1 $-1 $141 -5 $147 5 $138 $180 forward @7 unknown T 25 -5 -5 25 5 -5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $181 $-1 $102 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 6 #
+straight-curve $-1 -1 -1 $-1 30 -5 -5 -1 0 0 I I #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $182 $-1 $104 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 8 #
+vertex $183 -1 -1 $-1 $104 $184 #
+straight-curve $-1 -1 -1 $-1 30 5 -5 1 0 0 I I #
+simple-snl-attrib $-1 -1 $-1 $105 $71 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 5 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $185 $-1 $106 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 5 #
+point $-1 -1 -1 $-1 35 5 -5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $186 $-1 $107 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 6 #
+point $-1 -1 -1 $-1 35 -5 -5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $187 $-1 $110 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 3 #
+straight-curve $-1 -1 -1 $-1 25 0 5 0 -1 0 I I #
+simple-snl-attrib $-1 -1 $-1 $113 $74 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 2 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $188 $-1 $114 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 3 #
+point $-1 -1 -1 $-1 25 5 5 #
+simple-snl-attrib $-1 -1 $-1 $117 $76 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 4 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $189 $-1 $118 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 4 #
+point $-1 -1 -1 $-1 25 -5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $190 $-1 $120 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 10 #
+straight-curve $-1 -1 -1 $-1 35 -5 0 0 0 -1 I I #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $191 $-1 $121 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 12 #
+straight-curve $-1 -1 -1 $-1 35 5 0 0 0 -1 I I #
+simple-snl-attrib $-1 -1 $-1 $123 $81 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 1 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $125 $82 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 2 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $128 $87 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 14 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $192 $-1 $129 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 10 #
+point $-1 -1 -1 $-1 5 0 5 #
+simple-snl-attrib $-1 -1 $-1 $132 $89 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 9 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $135 $64 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 LIMP @4 LIMP 2 1 0 5 1 0 0 1 1 #
+simple-snl-attrib $-1 -1 $193 $136 $94 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 6 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $194 $-1 $139 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 11 #
+straight-curve $-1 -1 -1 $-1 25 5 0 0 0 -1 I I #
+simple-snl-attrib $-1 -1 $-1 $140 $100 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 9 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $195 $-1 $141 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 7 #
+point $-1 -1 -1 $-1 25 -5 -5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $196 $-1 $143 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 7 #
+straight-curve $-1 -1 -1 $-1 25 0 -5 0 1 0 I I #
+simple-snl-attrib $-1 -1 $-1 $144 $102 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 6 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $146 $104 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 8 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $197 $-1 $147 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 8 #
+point $-1 -1 -1 $-1 25 5 -5 #
+simple-snl-attrib $-1 -1 $-1 $150 $106 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 5 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $152 $107 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 6 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $154 $110 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 3 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $157 $114 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 3 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $160 $118 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 4 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $162 $120 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 10 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $164 $121 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 12 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $169 $129 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 10 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $173 $94 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 3 @13 MESH_INTERVAL @4 LIMP @4 LIMP 2 1 0 5 1 0 0 1 1 #
+simple-snl-attrib $-1 -1 $-1 $174 $139 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 11 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $177 $141 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 7 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $179 $143 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 7 -2147483648 -1 #
+simple-snl-attrib $-1 -1 $-1 $183 $147 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 8 -2147483648 -1 #
+End-of-ACIS-data
\ No newline at end of file
diff --git a/test/io/read_cgm_senses_test.cpp b/test/io/read_cgm_senses_test.cpp
index 4f0896d..0b45b99 100644
--- a/test/io/read_cgm_senses_test.cpp
+++ b/test/io/read_cgm_senses_test.cpp
@@ -21,9 +21,9 @@ using namespace moab;
 #ifdef MESHDIR
-static const char input_cube[] = STRINGIFY(MESHDIR) "/io/cube.sat";
+static const char input_cube[] = STRINGIFY(MESHDIR) "/io/cylcube.sat";
 #else
-static const char input_cube[] = "/io/cube.sat";
+static const char input_cube[] = "/io/cylcube.sat";
 #endif
 // Function used to load the test file
https://bitbucket.org/fathomteam/moab/commits/c40f4830b8df/
Changeset:   c40f4830b8df
Branch:      None
User:        pshriwise
Summary:     Updated names of test functions; made a correction to a variable name in read_cylcube_surf_senses_test()
Affected #:  1 file
index 0b45b99..07713a9 100644
@@ -42,8 +42,8 @@ void check_sense_data( Interface* moab, std::vector<EntityHandle> wrt_ents, std:
 int geom_id_by_handle( Interface* moab, const EntityHandle set );
 // List of tests in this file
-void read_cube_curve_senses_test();
-void read_cube_surf_senses_test();
+void read_cylcube_curve_senses_test();
+void read_cylcube_surf_senses_test();
   int result = 0;
-  result += RUN_TEST(read_cube_curve_senses_test);
-  result += RUN_TEST(read_cube_surf_senses_test);
+  result += RUN_TEST(read_cylcube_curve_senses_test);
+  result += RUN_TEST(read_cylcube_surf_senses_test);
   return result;
@@ -67,7 +67,7 @@ void read_file( Interface* moab, const char* input_file )
   CHECK_ERR(rval);
   ErrorCode rval;
   //Open the test file
@@ -248,7 +248,7 @@ void load_curve_sense_data( Interface* moab, EntityHandle curve, std::vector<int
 ///SURFACE SENSE CHECKING
   ErrorCode rval;
@@ -265,11 +265,11 @@ void read_cube_surf_senses_test()
   int dim = 2;
   void *val[] = {&dim};
-  int number_of_curves;
+  int number_of_surfs;
   rval = mb->get_number_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag,
+	  					    val, 1, number_of_surfs );
   CHECK_ERR(rval);
-  CHECK_EQUAL( 6, number_of_curves );
+  CHECK_EQUAL( 6, number_of_surfs );
   Range surfs;
https://bitbucket.org/fathomteam/moab/commits/342892a9a922/
Changeset:   342892a9a922
Branch:      None
User:        pshriwise
Summary:     Updated reference information to match the new file
Affected #:  1 file
index 07713a9..0ec0db7 100644
@@ -88,7 +88,7 @@ void read_cylcube_curve_senses_test()
   CHECK_ERR(rval);
-  CHECK_EQUAL( 12 , number_of_curves );
+  CHECK_EQUAL( 14, number_of_curves );
   //Get curve handles
   Range curves;
@@ -186,63 +186,72 @@ void load_curve_sense_data( Interface* moab, EntityHandle curve, std::vector<int
     case 1:
           surf_ids_out.push_back(1); surf_ids_out.push_back(6);
           senses_out.push_back(1); senses_out.push_back(-1);
+          break;
-    break;
     case 2:
           surf_ids_out.push_back(1); surf_ids_out.push_back(5);
+          break;
-    break;
     case 3:
           surf_ids_out.push_back(1); surf_ids_out.push_back(4);
+          break;
-    break;
     case 4:
           surf_ids_out.push_back(1); surf_ids_out.push_back(3);
+          break;
-    break;
     case 5:
           surf_ids_out.push_back(2); surf_ids_out.push_back(6);
+          break;
-    break;
     case 6:
           surf_ids_out.push_back(2); surf_ids_out.push_back(3);
+          break;
-    break;
     case 7:
           surf_ids_out.push_back(2); surf_ids_out.push_back(4);
+          break;
-    break;
     case 8:
           surf_ids_out.push_back(2); surf_ids_out.push_back(5);
+          break;
-    break;
     case 9:
           surf_ids_out.push_back(3); surf_ids_out.push_back(4);
+          break;
-    break;
     case 10:
           surf_ids_out.push_back(3); surf_ids_out.push_back(6);
           senses_out.push_back(-1); senses_out.push_back(1);
+          break;
-    break;
     case 11:
           surf_ids_out.push_back(4); surf_ids_out.push_back(5);
+          break;
-    break;
     case 12:
           surf_ids_out.push_back(5); surf_ids_out.push_back(6);
+          break;
-    break;
+    case 13:
+      surf_ids_out.push_back(7); surf_ids_out.push_back(8);
+      senses_out.push_back(-1); senses_out.push_back(1);
+      break;
+    case 14:
+      surf_ids_out.push_back(7); surf_ids_out.push_back(9);
+      break;
@@ -269,7 +278,7 @@ void read_cylcube_surf_senses_test()
   CHECK_ERR(rval);
-  CHECK_EQUAL( 6, number_of_surfs );
+  CHECK_EQUAL( 9, number_of_surfs );
   Range surfs;
@@ -316,33 +325,47 @@ void load_vol_sense_data( Interface* moab, EntityHandle surf, std::vector<int>&
     case 1:
           vol_ids_out.push_back(1);
+          break;
-    break;
     case 2:
-    break;
+          break;
     case 3:
+          break;
-    break;
     case 4:
+          break;
-    break;
     case 5:
-    break;
+          break;
     case 6:
+          break;
+    case 7:
+          vol_ids_out.push_back(2);
+          senses_out.push_back(1);
+          break;
+    case 8:
+          break;
-    break;
+    case 9:
+          break;
https://bitbucket.org/fathomteam/moab/commits/5dcca0a2f916/
Changeset:   5dcca0a2f916
Branch:      None
User:        pshriwise
Summary:     Updated sense settings to use macros in case the CGM convention ever changes again.
Affected #:  1 file
index 0ec0db7..2dcda2e 100644
@@ -12,6 +12,9 @@
 #include "InitCGMA.hpp"
 #include "GeometryQueryTool.hpp"
+#define SENSE_FORWARD 1
+#define SENSE_REVERSE -1
+#define SENSE_UNKNOWN 0
 #define CHKERR(A) do { if (MB_SUCCESS != (A)) { \
@@ -185,72 +188,72 @@ void load_curve_sense_data( Interface* moab, EntityHandle curve, std::vector<int
     case 1:
-          senses_out.push_back(1); senses_out.push_back(-1);
+          senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
           break;
     case 2:
           break;
     case 3:
           break;
     case 4:
           break;
     case 5:
           break;
     case 6:
           break;
     case 7:
           break;
     case 8:
           break;
     case 9:
           break;
     case 10:
-          senses_out.push_back(-1); senses_out.push_back(1);
+          senses_out.push_back(SENSE_REVERSE); senses_out.push_back(SENSE_FORWARD);
           break;
     case 11:
           break;
     case 12:
           break;
     case 13:
       break;
     case 14:
       break;
@@ -324,47 +327,47 @@ void load_vol_sense_data( Interface* moab, EntityHandle surf, std::vector<int>&
     case 1:
           break;
     case 2:
           break;
     case 3:
           break;
     case 4:
           break;
     case 5:
           break;
     case 6:
           break;
     case 7:
           break;
     case 8:
           break;
     case 9:
           break;
https://bitbucket.org/fathomteam/moab/commits/3a9b96952fcd/
Changeset:   3a9b96952fcd
Branch:      None
User:        pshriwise
Summary:     Added new ReadCGM test file read_cgm_group_test.cpp. Included this in the /test/io Makefile.am
Affected #:  2 files
diff --git a/test/io/Makefile.am b/test/io/Makefile.am
index e9a73b3..61f932a 100644
--- a/test/io/Makefile.am
+++ b/test/io/Makefile.am
@@ -25,7 +25,8 @@ else
 endif
 if HAVE_CGM
-  CGM_TEST = read_cgm_load_test read_cgm_basic_test read_cgm_senses_test read_cgm_connectivity_test
+  CGM_TEST = read_cgm_load_test read_cgm_basic_test read_cgm_senses_test read_cgm_connectivity_test \
+             read_cgm_group_test
 else
   CGM_TEST =
 endif
@@ -78,6 +79,8 @@ read_cgm_senses_test_SOURCES = $(srcdir)/../TestUtil.hpp read_cgm_senses_test.cp
 read_cgm_senses_test_CXXFLAGS = $(CGM_CPPFLAGS) $(CGM_LIBS)  $(CXXFLAGS)
 read_cgm_connectivity_test_SOURCES = $(srcdir)/../TestUtil.hpp read_cgm_connectivity_test.cpp
 read_cgm_connectivity_test_CXXFLAGS = $(CGM_CPPFLAGS) $(CGM_LIBS)  $(CXXFLAGS)
+read_cgm_group_test_SOURCES = $(srcdir)/../TestUtil.hpp read_cgm_group_test.cpp
+read_cgm_group_test_CXXFLAGS = $(CGM_CPPFLAGS) $(CGM_LIBS)  $(CXXFLAGS)
 readutil_test_SOURCES = $(srcdir)/../TestUtil.hpp readutil_test.cpp
 cgns_test_SOURCES=$(srcdir)/../TestUtil.hpp cgns_test.cpp
diff --git a/test/io/read_cgm_group_test.cpp b/test/io/read_cgm_group_test.cpp
index 0000000..5596880
--- /dev/null
+++ b/test/io/read_cgm_group_test.cpp
@@ -0,0 +1,51 @@
+#include <iostream>
+#include "moab/Interface.hpp"
+#ifndef IS_BUILDING_MB
+#define IS_BUILDING_MB
+#endif
+#include "TestUtil.hpp"
+#include "Internals.hpp"
+#include "moab/Core.hpp"
+#include "MBTagConventions.hpp"
+#include "InitCGMA.hpp"
+#include "GeometryQueryTool.hpp"
+using namespace moab;
+#define CHKERR(A) do { if (MB_SUCCESS != (A)) { \
+  std::cerr << "Failure (error code " << (A) << ") at " __FILE__ ":" \
+            << __LINE__ << std::endl; \
+  return A; } } while(false)
+#ifdef MESHDIR
+static const char input_cube[] = STRINGIFY(MESHDIR) "/io/cube.sat";
+#else
+static const char input_cube[] = "/io/cube.sat";
+#endif
+// Function used to load the test file
+void read_file( Interface* moab, const char* input_file );
+// List of tests in this file
+int main(int /* argc */, char** /* argv */)
+  int result = 0;
+  return result;
+  InitCGMA::initialize_cgma();
+  GeometryQueryTool::instance()->delete_geometry();
+  ErrorCode rval = moab->load_file( input_file );
+  CHECK_ERR(rval);
https://bitbucket.org/fathomteam/moab/commits/84411bd3ca21/
Changeset:   84411bd3ca21
Branch:      None
User:        pshriwise
Summary:     Added testing of groups and group names to read_cgm_group_test
Affected #:  1 file
index 5596880..04d4787 100644
--- a/test/io/read_cgm_group_test.cpp
@@ -20,21 +20,32 @@ using namespace moab;
 #ifdef MESHDIR
+static const char input_cylcube[] = STRINGIFY(MESHDIR) "/io/cylcube.sat";
 #else
+static const char input_cylcube[] = "/io/cylcube.sat";
 #endif
-// List of tests in this file
+//Function for getting entity ids
+int geom_id_by_handle( Interface* moab, const EntityHandle set );
+//Function for checking retrieved group data
+void check_group_data( std::vector<int> group_ids, std::vector<std::string> group_names, std::vector<int> group_ent_ids );
+//Function for loading all reference data
+void load_group_references( std::vector<int>& ids, std::vector<std::string>& names, std::vector<int>& ent_ids);
+void read_cylcube_groups_test();
   int result = 0;
+  result+=RUN_TEST(read_cylcube_groups_test);
   return result;
@@ -49,3 +60,126 @@ void read_file( Interface* moab, const char* input_file )
   CHECK_ERR(rval);
+  ErrorCode rval;
+  //Open the test file
+  Core moab;
+  Interface* mb = &moab;
+  read_file( mb, input_cylcube);
+  //Get (or create) the name and category tags
+  Tag name_tag, category_tag;
+  rval = mb->tag_get_handle( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TYPE_OPAQUE,
+                             name_tag, moab::MB_TAG_SPARSE|moab::MB_TAG_CREAT );
+  CHECK_ERR(rval);
+  rval = mb->tag_get_handle( CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE,
+                             MB_TYPE_OPAQUE, category_tag,
+                             moab::MB_TAG_SPARSE|moab::MB_TAG_CREAT );
+  CHECK_ERR(rval);
+  //Get the group entity handles
+  Range group_sets;
+  char query[] = "Group\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0";
+  //Has to be this way because of the way tags are created
+  void* val[] = {&query};
+  rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &category_tag, val, 1, group_sets);
+  CHECK_ERR(rval);
+  std::vector<int> g_ids;
+  std::vector<std::string> g_names;
+  std::vector<int> g_ent_ids;
+  int j = 0;
+  for(Range::iterator i=group_sets.begin(); i!=group_sets.end(); i++)
+      int group_id = geom_id_by_handle( mb, *i );
+      g_ids.push_back(group_id);
+      //Get the group name
+      char group_name[NAME_TAG_SIZE+1];
+      rval = mb->tag_get_data( name_tag, &(*i), 1, &group_name);
+      CHECK_ERR(rval);
+      //Store group name
+      std::string temp(group_name);
+      g_names.push_back(temp);
+      //Ensure the group is named correctly
+      CHECK( strcmp( group_name, "Group 2") || strcmp(group_name, "Group 3"));
+      //Get all entities in the group
+      Range group_ents;
+      rval = mb->get_entities_by_type( *i, MBENTITYSET, group_ents, false);
+      CHECK_ERR(rval);
+      if( group_ents.size() != 1) CHECK(false);
+      int grp_ent_id = geom_id_by_handle( mb, group_ents[0] );
+      g_ent_ids.push_back(grp_ent_id);
+  check_group_data(g_ids, g_names, g_ent_ids);
+void check_group_data(std::vector<int> group_ids, std::vector<std::string> group_names, std::vector<int> group_ent_ids )
+  //Initialize reference data
+  std::vector<int> group_ref_ids;
+  std::vector<std::string> group_ref_names;
+  std::vector<int> group_ref_ent_ids;
+  load_group_references( group_ref_ids, group_ref_names, group_ref_ent_ids );
+  // check that the correct number of entities were found
+  CHECK_EQUAL ( group_ref_ids.size(), group_ids.size() );
+  //  CHECK_EQUAL ( group_ref_names.size(), group_names.size() );
+  CHECK_EQUAL ( group_ref_ent_ids.size(), group_ent_ids.size() );
+  //now make sure that each group has a matching group
+  for(unsigned int i=0 ; i<group_ids.size(); i++)
+      for(unsigned int j=0; j<group_ref_ids.size(); j++)
+          if( group_ids[i]==group_ref_ids[j]
+	      && group_names[i] ==  group_ref_names[j]
+              && group_ent_ids[i]==group_ref_ent_ids[j])
+              group_ref_ids.erase(group_ref_ids.begin()+j);
+              group_ref_names.erase(group_ref_names.begin()+j);
+              group_ref_ent_ids.erase(group_ref_ent_ids.begin()+j);
+              continue;
+  // Check sizes of reference vectors after matching
+  // (all should be zero)
+   int leftovers = group_ref_ids.size();
+  CHECK_EQUAL( 0, leftovers );
+  leftovers = group_ref_names.size();
+  leftovers = group_ref_ent_ids.size();
+void load_group_references( std::vector<int>& ids, std::vector<std::string>& names, std::vector<int>& ent_ids )
+  //First set of group info
+  names.push_back("Group 3"); ids.push_back(3); ent_ids.push_back(2);
+  //Second set of group info
+  names.push_back("Group 2"); ids.push_back(2); ent_ids.push_back(1);
+    ErrorCode rval;
+    Tag id_tag;
+    rval = moab->tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, id_tag, moab::MB_TAG_DENSE );
+    assert( MB_SUCCESS==result || MB_ALREADY_ALLOCATED==result );
+    int id;
+    rval = moab->tag_get_data( id_tag, &set, 1, &id );
+    CHECK_ERR(rval);
+    return id;
https://bitbucket.org/fathomteam/moab/commits/2f045f63d3a8/
Changeset:   2f045f63d3a8
Branch:      None
User:        pshriwise
Summary:     Implemented the create_group_entities function in ReadCGM
Affected #:  2 files
diff --git a/src/io/ReadCGM.cpp b/src/io/ReadCGM.cpp
index 5616365..002b212 100644
--- a/src/io/ReadCGM.cpp
+++ b/src/io/ReadCGM.cpp
@@ -319,7 +319,7 @@ ErrorCode ReadCGM::store_curve_senses( std::map<RefEntity*,EntityHandle> entitym
   return MB_SUCCESS;
-ErrorCode ReadCGM::create_group_entities( Interface* moab, std::map<RefEntity*,EntityHandle>* entitymap )
+ErrorCode ReadCGM::create_group_entities( Interface* moab, std::map<RefEntity*,EntityHandle>& entitymap )
   ErrorCode rval;
@@ -410,7 +410,7 @@ ErrorCode ReadCGM::create_group_entities( Interface* moab, std::map<RefEntity*,E
-    entitymap[4][grp] = h;
+    entitymap[grp] = h;
   return MB_SUCCESS;
@@ -501,93 +501,10 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-    // create entity sets for all ref groups
-  std::vector<Tag> extra_name_tags;
-#if  CGM_MAJOR_VERSION>13
-  DLIList<CubitString> name_list;
-#else
-  DLIList<CubitString*> name_list;
-#endif
-  //get all entity groups from the CGM model
-  GeometryQueryTool::instance()->ref_entity_list( "group", entlist );
-  entlist.reset();
-  //loop over all groups
-    //take the next group
-    RefEntity* grp = entlist.get_and_step();
-    name_list.clean_out();
-//get the names of all entities in this group from the solid model
-    RefEntityName::instance()->get_refentity_name(grp, name_list);
-#else
-    //true argument is optional, but for large multi-names situation, it should save
-    //some cpu time
-    RefEntityName::instance()->get_refentity_name(grp, name_list, true);
-#endif
-    if (name_list.size() == 0)
-      continue;
-    //set pointer to first name of the group and set the first name to name1
-    name_list.reset();
-    CubitString name1 = name_list.get();
-#else
-    CubitString name1 = *name_list.get();
-#endif
-    // create entity handle for the group
-    EntityHandle h;
-    rval = mdbImpl->create_meshset( MESHSET_SET, h );
-      return rval;
-    //set tag data for the group
-    char namebuf[NAME_TAG_SIZE];
-    memset( namebuf, '\0', NAME_TAG_SIZE );
-    strncpy( namebuf, name1.c_str(), NAME_TAG_SIZE - 1 );
-    if (name1.length() >= (unsigned)NAME_TAG_SIZE)
-      std::cout << "WARNING: group name '" << name1.c_str()
-                << "' truncated to '" << namebuf << "'" << std::endl;
-    rval = mdbImpl->tag_set_data( name_tag, &h, 1, namebuf );
-    int id = grp->id();
-    rval = mdbImpl->tag_set_data( id_tag, &h, 1, &id );
-    rval = mdbImpl->tag_set_data( category_tag, &h, 1, &geom_categories[4] );
-    //check for extra group names
-    if (name_list.size() > 1) {
-      for (int j = extra_name_tags.size(); j < name_list.size(); ++j) {
-        sprintf( namebuf, "EXTRA_%s%d", NAME_TAG_NAME, j );
-        Tag t;
-        rval = mdbImpl->tag_get_handle( namebuf, NAME_TAG_SIZE, MB_TYPE_OPAQUE, t, MB_TAG_SPARSE|MB_TAG_CREAT );
-        assert(!rval);
-        extra_name_tags.push_back(t);
-      //add extra group names to the group handle
-      for (int j = 0; j < name_list.size(); ++j) {
-        name1 = name_list.get_and_step();
-#else
-        name1 = *name_list.get_and_step();
-#endif
-        rval = mdbImpl->tag_set_data( extra_name_tags[j], &h, 1, namebuf );
-    //add the group handle
-    entmap[4][grp] = h;
+  // create eneity setes for all ref groups
+  rval = create_group_entities( mdbImpl, entmap[4] );
+  if(rval!=MB_SUCCESS) return rval;
     // store contents for each group
   entlist.reset();
   for (ci = entmap[4].begin(); ci != entmap[4].end(); ++ci) {
diff --git a/src/io/ReadCGM.hpp b/src/io/ReadCGM.hpp
index 51d84ad..af26b73 100644
--- a/src/io/ReadCGM.hpp
+++ b/src/io/ReadCGM.hpp
-  ErrorCode create_group_entities( Interface* moab, std::map<RefEntity*,EntityHandle>* entitymap );
+  ErrorCode create_group_entities( Interface* moab, std::map<RefEntity*,EntityHandle>& entitymap );
    //! Constructor
https://bitbucket.org/fathomteam/moab/commits/a045acebe303/
Changeset:   a045acebe303
Branch:      None
User:        pshriwise
Summary:     Cleanup of ReadCGM.hpp
Affected #:  1 file
index af26b73..72bb1d0 100644
@@ -86,14 +86,15 @@ public:
-  ErrorCode create_topology( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] );
+                             std::map<RefEntity*,EntityHandle> entitymap[5] );
-  ErrorCode create_group_entities( Interface* moab, std::map<RefEntity*,EntityHandle>& entitymap );
    //! Constructor
    ReadCGM(Interface* impl = NULL);
https://bitbucket.org/fathomteam/moab/commits/c9e846c31cc3/
Changeset:   c9e846c31cc3
Branch:      None
User:        pshriwise
Summary:     Cleanup of read_cgm_group_test.cpp
Affected #:  1 file
index 04d4787..1357fb3 100644
@@ -89,7 +89,7 @@ void read_cylcube_groups_test()
   CHECK_ERR(rval);
+  //Get group names and IDs
@@ -105,18 +105,16 @@ void read_cylcube_groups_test()
       //Store group name
-      //Ensure the group is named correctly
-      CHECK( strcmp( group_name, "Group 2") || strcmp(group_name, "Group 3"));
       Range group_ents;
-      rval = mb->get_entities_by_type( *i, MBENTITYSET, group_ents, false);
+      rval = mb->get_entities_by_type( *i, MBENTITYSET, group_ents, false );
       CHECK_ERR(rval);
-  check_group_data(g_ids, g_names, g_ent_ids);
+  check_group_data( g_ids, g_names, g_ent_ids );
@@ -131,7 +129,7 @@ void check_group_data(std::vector<int> group_ids, std::vector<std::string> group
-  //  CHECK_EQUAL ( group_ref_names.size(), group_names.size() );
+  CHECK_EQUAL ( group_ref_names.size(), group_names.size() );
https://bitbucket.org/fathomteam/moab/commits/ebf2d270ca19/
Changeset:   ebf2d270ca19
Branch:      None
User:        pshriwise
Summary:     Small changes to ReadCGM.cpp
Affected #:  1 file
index 002b212..6a8b8d6 100644
@@ -195,9 +195,7 @@ ErrorCode ReadCGM::set_options( const FileOptions& opts,
      return MB_SUCCESS;
-ErrorCode ReadCGM::create_entity_sets( Interface* moab,
+ErrorCode ReadCGM::create_entity_sets( Interface* moab, std::map<RefEntity*,EntityHandle>* entmap_ptr )
   ErrorCode rval;
@@ -210,7 +208,7 @@ ErrorCode ReadCGM::create_entity_sets( Interface* moab,
   return MB_SUCCESS;
-ErrorCode ReadCGM::create_topology( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5])
+ErrorCode ReadCGM::create_topology( Interface* moab, std::map<RefEntity*,EntityHandle> entitymap[5] )
   ErrorCode rval;
https://bitbucket.org/fathomteam/moab/commits/3ebbc12732bf/
Changeset:   3ebbc12732bf
Branch:      None
User:        pshriwise
Summary:     Added a new functions store_group_contents() to ReadCGM
Affected #:  2 files
index 6a8b8d6..53b6578 100644
@@ -413,6 +413,67 @@ ErrorCode ReadCGM::create_group_entities( Interface* moab, std::map<RefEntity*,E
   return MB_SUCCESS;
+ErrorCode ReadCGM::store_group_content( Interface* moab, std::map<RefEntity*,EntityHandle>* entitymap )
+  ErrorCode rval;
+    // store contents for each group
+  entlist.reset();
+  for (ci = entitymap[4].begin(); ci != entitymap[4].end(); ++ci) {
+    RefGroup* grp = (RefGroup*)(ci->first);
+    entlist.clean_out();
+    grp->get_child_ref_entities( entlist );
+    Range entities;
+    while (entlist.size()) {
+      RefEntity* ent = entlist.pop();
+      int dim = ent->dimension();
+      if (dim < 0) {
+	Body* body;
+        if (entitymap[4].find(ent) != entitymap[4].end()){
+          // child is another group; examine its contents
+	  entities.insert( entitymap[4][ent] );
+	else if( (body = dynamic_cast<Body*>(ent)) != NULL ){
+	  // Child is a CGM Body, which presumably comprises some volumes--
+	  // extract volumes as if they belonged to group.
+	  DLIList<RefVolume*> vols;
+	  body->ref_volumes( vols );
+	  for( int vi = vols.size(); vi--; ){
+	    RefVolume* vol = vols.get_and_step();
+	    if( entitymap[3].find(vol) != entitymap[3].end() ){
+	      entities.insert( entitymap[3][vol] );
+	    else{
+	      std::cerr << "Warning: CGM Body has orphan RefVolume" << std::endl;
+	else{
+	  // otherwise, warn user.
+	  std::cerr << "Warning: A dim<0 entity is being ignored by ReadCGM." << std::endl;
+      else if (dim < 4) {
+        if (entitymap[dim].find(ent) != entitymap[dim].end())
+          entities.insert( entitymap[dim][ent] );
+    if (!entities.empty()) {
+      rval = mdbImpl->add_entities( ci->second, entities );
+      if (MB_SUCCESS != rval)
 // copy geometry into mesh database
                       const EntityHandle* file_set,
index 72bb1d0..54948a1 100644
@@ -96,6 +96,8 @@ public:
+  ErrorCode store_group_content( Interface* moab, std::map<RefEntity*,EntityHandle>* entitymap );
    //! Constructor
https://bitbucket.org/fathomteam/moab/commits/8f322d693cc1/
Changeset:   8f322d693cc1
Branch:      None
User:        pshriwise
Summary:     Implemented the store_group_content() function in ReadCGM.
Affected #:  1 file
index 53b6578..5dccad0 100644
@@ -432,7 +432,6 @@ ErrorCode ReadCGM::store_group_content( Interface* moab, std::map<RefEntity*,Ent
       if (dim < 0) {
 	Body* body;
@@ -471,9 +470,9 @@ ErrorCode ReadCGM::store_group_content( Interface* moab, std::map<RefEntity*,Ent
         return MB_FAILURE;
+  return MB_SUCCESS;
@@ -564,65 +563,15 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-    // store contents for each group
-  entlist.reset();
-  for (ci = entmap[4].begin(); ci != entmap[4].end(); ++ci) {
-    RefGroup* grp = (RefGroup*)(ci->first);
-    entlist.clean_out();
-    grp->get_child_ref_entities( entlist );
-    Range entities;
-    while (entlist.size()) {
-      RefEntity* ent = entlist.pop();
-      int dim = ent->dimension();
-      if (dim < 0) {
-	Body* body;
-        if (entmap[4].find(ent) != entmap[4].end()){
-          // child is another group; examine its contents
-	  entities.insert( entmap[4][ent] );
-	else if( (body = dynamic_cast<Body*>(ent)) != NULL ){
-	  // Child is a CGM Body, which presumably comprises some volumes--
-	  // extract volumes as if they belonged to group.
-	  DLIList<RefVolume*> vols;
-	  body->ref_volumes( vols );
-	  for( int vi = vols.size(); vi--; ){
-	    RefVolume* vol = vols.get_and_step();
-	    if( entmap[3].find(vol) != entmap[3].end() ){
-	      entities.insert( entmap[3][vol] );
-	    else{
-	      std::cerr << "Warning: CGM Body has orphan RefVolume" << std::endl;
-	else{
-	  // otherwise, warn user.
-	  std::cerr << "Warning: A dim<0 entity is being ignored by ReadCGM." << std::endl;
-      else if (dim < 4) {
-        if (entmap[dim].find(ent) != entmap[dim].end())
-          entities.insert( entmap[dim][ent] );
-    if (!entities.empty()) {
-      rval = mdbImpl->add_entities( ci->second, entities );
-      if (MB_SUCCESS != rval)
-    // done with volumes and groups
+  rval = store_group_content( mdbImpl, entmap );
+  // done with volumes and groups
   entmap[3].clear();
   entmap[4].clear();
-    // create geometry for all vertices and replace
-    // vertex set handles with vertex handles in map
+  // create geometry for all vertices and replace
+  // vertex set handles with vertex handles in map
   for (ci = entmap[0].begin(); ci != entmap[0].end(); ++ci) {
     CubitVector pos = dynamic_cast<RefVertex*>(ci->first)->coordinates();
     double coords[3] = {pos.x(), pos.y(), pos.z()};
https://bitbucket.org/fathomteam/moab/commits/04c05d1ef169/
Changeset:   04c05d1ef169
Branch:      None
User:        pshriwise
Summary:     Added function store_geom_senses() to ReadCGM
Affected #:  2 files
index 5dccad0..49cdf0a 100644
@@ -232,6 +232,21 @@ ErrorCode ReadCGM::create_topology( Interface* moab, std::map<RefEntity*,EntityH
   return MB_SUCCESS;
+ErrorCode ReadCGM::store_geom_senses( std::map<RefEntity*,EntityHandle> entitymap[5] )
+  ErrorCode rval;
+  rval = store_surface_senses( entitymap );
+  if (rval!=MB_SUCCESS) return rval;
+  rval = store_curve_senses( entitymap );
   ErrorCode rval;
@@ -549,7 +564,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
-  if (rval!=MB_SUCCESS) return rval;
index 54948a1..17cf14a 100644
@@ -89,6 +89,8 @@ public:
+  ErrorCode store_geom_senses( std::map<RefEntity*,EntityHandle> entitymap[5] );
https://bitbucket.org/fathomteam/moab/commits/0261cf1ef4f0/
Changeset:   0261cf1ef4f0
Branch:      None
User:        pshriwise
Summary:     Implemented function store_geom_senses in ReadCGM
Affected #:  1 file
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/08429aad2211/
Changeset:   08429aad2211
Branch:      None
User:        pshriwise
Summary:     Added/corrected comments in ReadCGM.cpp
Affected #:  1 file
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/829fac1bfeab/
Changeset:   829fac1bfeab
Branch:      None
User:        pshriwise
Summary:     Added a function store_groups to ReadCGM
Affected #:  2 files
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/ad9f0b5bbcdd/
Changeset:   ad9f0b5bbcdd
Branch:      None
User:        pshriwise
Date:        2014-02-14 01:13:35
Summary:     Implemented the function store_groups in ReadCGM::load_file()
Affected #:  1 file
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/78de3ee4e514/
Changeset:   78de3ee4e514
Branch:      None
User:        pshriwise
Date:        2014-02-28 20:16:20
Summary:     Merge branch 'master' into ReadCGM_refactor
Conflicts:
	test/io/read_cgm_basic_test.cpp
	test/io/read_cgm_connectivity_test.cpp
Affected #:  23 files
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/746c4bcd5251/
Changeset:   746c4bcd5251
Branch:      None
User:        pshriwise
Date:        2014-02-28 20:35:04
Summary:     Uncommented cgm_version.h. Building with CGM 13.1 now.
Affected #:  1 file
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/6fa3c2a7e2be/
Changeset:   6fa3c2a7e2be
Branch:      None
User:        pshriwise
Date:        2014-03-28 19:09:54
Summary:     Merge branch 'ReadCGM_refactor'
Affected #:  2 files
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/0cf64556cacb/
Changeset:   0cf64556cacb
Branch:      None
User:        pshriwise
Date:        2014-03-29 04:31:27
Summary:     Added cube and cylcube file to the distcheck path.
Affected #:  1 file
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/33f4b79721d8/
Changeset:   33f4b79721d8
Branch:      None
User:        pshriwise
Date:        2014-04-07 21:03:58
Summary:     Embedded the create_ent_sets_for_dim inside of create_entity_sets.
Affected #:  2 files
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/e52c4be9883e/
Changeset:   e52c4be9883e
Branch:      None
User:        pshriwise
Date:        2014-04-07 21:34:25
Summary:     Removed store_coFace_senses and store_CoEdge_senses from store_geom_senses and placed them in ReadCGM load_file.
Affected #:  2 files
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/037441b40a8c/
Changeset:   037441b40a8c
Branch:      None
User:        pshriwise
Date:        2014-04-07 21:52:21
Summary:     Changed the name store_group_entities to store_group_entsets.
Affected #:  2 files
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/e8eecad0bac4/
Changeset:   e8eecad0bac4
Branch:      None
User:        pshriwise
Date:        2014-04-07 22:37:38
Summary:     Updated the create_ent_sets function to take a reference to a std::map rather than a pointer.
Affected #:  2 files
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/9a9f3bbc7615/
Changeset:   9a9f3bbc7615
Branch:      None
User:        pshriwise
Date:        2014-04-07 23:02:45
Summary:     Removed a deprecated line from create_entity_sets.
Affected #:  1 file
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/86c1afab1597/
Changeset:   86c1afab1597
Branch:      None
User:        pshriwise
Date:        2014-04-11 20:41:36
Summary:     Created a new function for handling cgm instance settings in ReadCGM.
Affected #:  2 files
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/ecae1e928b0c/
Changeset:   ecae1e928b0c
Branch:      None
User:        pshriwise
Date:        2014-04-28 16:55:01
Summary:     Merge branch 'master' of https://bitbucket.org/fathomteam/moab
Affected #:  7 files
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/7d0cf24a70f3/
Changeset:   7d0cf24a70f3
Branch:      None
User:        pshriwise
Date:        2014-05-05 19:37:31
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/a790e30983c6/
Changeset:   a790e30983c6
Branch:      None
User:        pshriwise
Date:        2014-05-19 16:31:10
Conflicts:
	MeshFiles/unittest/io/Makefile.am
Affected #:  44 files
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/69618c4580ed/
Changeset:   69618c4580ed
Branch:      master
User:        gonuke
Date:        2014-05-20 07:32:23
Summary:     Merge remote-tracking branch 'pshriwise/master' to begin refactor of ReadCGM
Affected #:  3 files
Diff not available.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
