[MOAB-dev] Build failed in Jenkins: moab_serial #309
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Mon May 19 14:28:44 CDT 2014
Iulian, the hdf5 and netcdf dependencies for the Jenkins build need to
be updated (or at least the config in gnep). And make sure both the
serial and parallel builds + tests are run after every commit/merge.
Vijay
On Tue, May 20, 2014 at 12:53 AM,  <jenkins-ci at mcs.anl.gov> wrote:
> See <https://jenkins-ci.mcs.anl.gov/job/moab_serial/309/changes>
> Changes:
> [wuda] For NC reader, dimensions (coordinate variables) can be excluded from user specified variables as they are read to the file set by default.
> Started by an SCM change
> [EnvInject] - Loading node environment variables.
> Building remotely on churn.mcs.anl.gov in workspace <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/>
> Checkout:moab_serial / <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/> - hudson.remoting.Channel at 696ed704:churn.mcs.anl.gov
> Using strategy: Default
> Last Built Revision: Revision cf2ba4e531d5d2db0753a5b0ffdefdcc17b05ddf (origin/master)
> Fetching changes from 1 remote Git repository
> Fetching upstream changes from origin
> Commencing build of Revision 05cc593b26bb95145f827239ead0ce40f0d6e543 (origin/master)
> Checking out Revision 05cc593b26bb95145f827239ead0ce40f0d6e543 (origin/master)
> [EnvInject] - Executing scripts and injecting environment variables after the SCM step.
> [EnvInject] - Injecting as environment variables the properties content
> INSTALLDIR=/home/autotest/jenkins
> HDF5SH=/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc
> NETCDFSER=/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc
> LD_LIBRARY_PATH=$HDF5SH/lib:$NETCDFSER/lib:/usr/lib/jvm/java-6-openjdk-amd64/jre/lib/amd64/server:/usr/lib/jvm/java-6-openjdk-amd64/jre/lib/amd64:/usr/lib/jvm/java-6-openjdk-amd64/jre/../lib/amd64
> [EnvInject] - Variables injected successfully.
> [moab_serial] $ /bin/sh -xe /tmp/hudson8457451716141929683.sh
> + autoreconf -fi
> libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `config'.
> libtoolize: copying file `config/config.guess'
> libtoolize: copying file `config/config.sub'
> libtoolize: copying file `config/install-sh'
> libtoolize: copying file `config/ltmain.sh'
> libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `config'.
> libtoolize: copying file `config/libtool.m4'
> libtoolize: copying file `config/ltoptions.m4'
> libtoolize: copying file `config/ltsugar.m4'
> libtoolize: copying file `config/ltversion.m4'
> libtoolize: copying file `config/lt~obsolete.m4'
> MeshFiles/unittest/io/Makefile.am:8: whitespace following trailing backslash
> + ./configure --prefix=/home/autotest/jenkins/moab_ser --with-hdf5=/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc --with-netcdf=/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc
> checking build system type... x86_64-unknown-linux-gnu
> checking host system type... x86_64-unknown-linux-gnu
> checking target system type... x86_64-unknown-linux-gnu
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for a thread-safe mkdir -p... /bin/mkdir -p
> checking for gawk... gawk
> checking whether make sets $(MAKE)... yes
> checking for sed... sed
> checking for style of include used by make... GNU
> checking for gcc... gcc
> checking whether the C compiler works... yes
> checking for C compiler default output file name... a.out
> checking for suffix of executables...
> checking whether we are cross compiling... no
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ISO C89... none needed
> checking dependency style of gcc... gcc3
> checking how to run the C preprocessor... gcc -E
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking dependency style of g++... gcc3
> checking how to run the C++ preprocessor... g++ -E
> checking for gfortran... gfortran
> checking whether we are using the GNU Fortran compiler... yes
> checking whether gfortran accepts -g... yes
> checking for g77... no
> checking for xlf... no
> checking for f77... f77
> checking whether we are using the GNU Fortran 77 compiler... yes
> checking whether f77 accepts -g... yes
> checking whether ln -s works... yes
> checking whether make sets $(MAKE)... (cached) yes
> checking how to print strings... printf
> checking for a sed that does not truncate output... sed
> checking for grep that handles long lines and -e... /bin/grep
> checking for egrep... /bin/grep -E
> checking for fgrep... /bin/grep -F
> checking for ld used by gcc... /usr/bin/ld
> checking if the linker (/usr/bin/ld) is GNU ld... yes
> checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
> checking the name lister (/usr/bin/nm -B) interface... BSD nm
> checking the maximum length of command line arguments... 1572864
> checking whether the shell understands some XSI constructs... yes
> checking whether the shell understands "+="... yes
> checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
> checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
> checking for /usr/bin/ld option to reload object files... -r
> checking for objdump... objdump
> checking how to recognize dependent libraries... pass_all
> checking for dlltool... no
> checking how to associate runtime and link libraries... printf %s\n
> checking for ar... ar
> checking for archiver @FILE support... @
> checking for strip... strip
> checking for ranlib... ranlib
> checking command to parse /usr/bin/nm -B output from gcc object... ok
> checking for sysroot... no
> checking for mt... mt
> checking if mt is a manifest tool... no
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking for dlfcn.h... yes
> checking for objdir... .libs
> checking if gcc supports -fno-rtti -fno-exceptions... no
> checking for gcc option to produce PIC... -fPIC -DPIC
> checking if gcc PIC flag -fPIC -DPIC works... yes
> checking if gcc static flag -static works... yes
> checking if gcc supports -c -o file.o... yes
> checking if gcc supports -c -o file.o... (cached) yes
> checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
> checking dynamic linker characteristics... GNU/Linux ld.so
> checking how to hardcode library paths into programs... immediate
> checking whether stripping libraries is possible... yes
> checking if libtool supports shared libraries... yes
> checking whether to build shared libraries... no
> checking whether to build static libraries... yes
> checking for ld used by g++... /usr/bin/ld -m elf_x86_64
> checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
> checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
> checking for g++ option to produce PIC... -fPIC -DPIC
> checking if g++ PIC flag -fPIC -DPIC works... yes
> checking if g++ static flag -static works... yes
> checking if g++ supports -c -o file.o... yes
> checking if g++ supports -c -o file.o... (cached) yes
> checking dynamic linker characteristics... (cached) GNU/Linux ld.so
> checking for f77 option to produce PIC... -fPIC
> checking if f77 PIC flag -fPIC works... yes
> checking if f77 static flag -static works... yes
> checking if f77 supports -c -o file.o... yes
> checking if f77 supports -c -o file.o... (cached) yes
> checking whether the f77 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
> checking for gfortran option to produce PIC... -fPIC
> checking if gfortran PIC flag -fPIC works... yes
> checking if gfortran static flag -static works... yes
> checking if gfortran supports -c -o file.o... yes
> checking if gfortran supports -c -o file.o... (cached) yes
> checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
> checking for known C compilers... GNU
> checking for known compiler/OS combinations... GNU:x86_64
> checking for known c++ compilers... GNU
> checking whether make supports nested variables... yes
> checking whether byte ordering is bigendian... no
> checking if platform is IBM BlueGene... no
> checking for gunzip... gunzip -c
> checking for gzip... (cached) gunzip -c
> checking for zcat... (cached) gunzip -c
> checking if C++ compiler supports template class specialization... yes
> checking if C++ compiler supports template function specialization... yes
> checking if g++ works... yes
> checking how to get verbose linking output from gfortran... -v
> checking for Fortran libraries of gfortran...  -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lgfortran -lm -lquadmath
> checking for dummy main to link with Fortran libraries... none
> checking for Fortran name-mangling scheme... lower case, underscore, no extra underscore
> checking whether Fortran 77 supports Cray-style pointer... yes
> checking for Fortran 77 compiler flag for Cray-style pointer... -fcray-pointer
> checking whether Fortran 90 supports Cray-style pointer... yes
> checking for Fortran 90 compiler flag for Cray-style pointer... -fcray-pointer
> checking for vsnprintf... yes
> checking if std::vector has templatized insert method... yes
> checking if std::copy must be old SGI format... no
> checking for inttypes.h... (cached) yes
> checking for stdint.h... (cached) yes
> checking for sys/types.h... (cached) yes
> checking stddef.h usability... yes
> checking stddef.h presence... yes
> checking for stddef.h... yes
> checking for stdlib.h... (cached) yes
> checking size of void *... 8
> checking for size_t... yes
> checking for ptrdiff_t... yes
> checking size of EntityHandle... 8
> checking if iMesh support is to be built... yes
> checking if iGeom support is to be built... no
> configure: creating ./config.lt
> config.lt: creating libtool
> checking ieeefp.h usability... no
> checking ieeefp.h presence... no
> checking for ieeefp.h... no
> checking for C++ unordered_map... std::tr1
> checking for deflate in -lz... yes
> checking for SZ_Decompress in -lsz... no
> checking if HDF5 support is enabled... yes
> configure: error: "/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc is not a directory."
> Build step 'Execute shell' marked build as failure
