[MOAB-dev] commit/MOAB: danwu: Updated NC reader and writer to support reading variables whose timesteps spread across files and writing them to a file.
commits-noreply at bitbucket.org
Thu May 15 12:57:31 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/a5907807ffc2/
Changeset: a5907807ffc2
Branch: master
User: danwu
Date: 2014-05-15 19:57:18
Summary: Updated NC reader and writer to support reading variables whose timesteps spread across files and writing them to a file.
Affected #: 5 files
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 59d6df4..ccca80c 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -61,7 +61,8 @@ NCHelper* NCHelper::get_nc_helper(ReadNC* readNC, int fileId, const FileOptions&
return NULL;
-ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums) {
+ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
Interface*& mbImpl = _readNC->mbImpl;
std::vector<std::string>& dimNames = _readNC->dimNames;
std::vector<int>& dimLens = _readNC->dimLens;
@@ -327,6 +328,58 @@ ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
return MB_SUCCESS;
+ErrorCode NCHelper::update_time_tag_vals()
+ Interface*& mbImpl = _readNC->mbImpl;
+ std::vector<std::string>& dimNames = _readNC->dimNames;
+ ErrorCode rval;
+ // The time tag might be a dummy one (e.g. 'Time' for MPAS)
+ std::string time_tag_name = dimNames[tDim];
+ if (dummyVarNames.find(time_tag_name) != dummyVarNames.end())
+ return MB_SUCCESS;
+ Tag time_tag = 0;
+ const void* data = NULL;
+ int time_tag_size = 0;
+ rval = mbImpl->tag_get_handle(time_tag_name.c_str(), 0, MB_TYPE_DOUBLE, time_tag, MB_TAG_VARLEN);
+ ERRORR(rval, "Trouble getting time tag.");
+ rval = mbImpl->tag_get_by_ptr(time_tag, &_fileSet, 1, &data, &time_tag_size);
+ ERRORR(rval, "Trouble getting values for time tag.");
+ const double* time_tag_vals = static_cast<const double*>(data);
+ // Merge tVals (read from current file) to existing time tag
+ // Assume that time_tag_vals and tVals are both sorted
+ std::vector<double> merged_time_vals;
+ merged_time_vals.reserve(time_tag_size + nTimeSteps);
+ int i = 0;
+ int j = 0;
+ // Merge time values from time_tag_vals and tVals
+ while (i < time_tag_size && j < nTimeSteps) {
+ if (time_tag_vals[i] < tVals[j])
+ merged_time_vals.push_back(time_tag_vals[i++]);
+ else
+ merged_time_vals.push_back(tVals[j++]);
+ // Append remaining time values of time_tag_vals (if any)
+ while (i < time_tag_size)
+ // Append remaining time values of tVals (if any)
+ while (j < nTimeSteps)
+ data = &merged_time_vals[0];
+ time_tag_size = merged_time_vals.size();
+ rval = mbImpl->tag_set_by_ptr(time_tag, &_fileSet, 1, &data, &time_tag_size);
+ ERRORR(rval, "Failed to set data for time tag.");
ErrorCode NCHelper::read_variable_setup(std::vector<std::string>& var_names, std::vector<int>& tstep_nums,
std::vector<ReadNC::VarData>& vdatas, std::vector<ReadNC::VarData>& vsetdatas)
@@ -636,6 +689,10 @@ ErrorCode NCHelper::get_tag_to_set(ReadNC::VarData& var_data, int tstep_num, Tag
DebugOutput& dbgOut = _readNC->dbgOut;
+ int& tStepBase = _readNC->tStepBase;
+ if (tStepBase > 0)
+ tstep_num += tStepBase;
std::ostringstream tag_name;
if (var_data.has_tsteps)
@@ -673,6 +730,10 @@ ErrorCode NCHelper::get_tag_to_nonset(ReadNC::VarData& var_data, int tstep_num,
tag_name << var_data.varName << tstep_num;
diff --git a/src/io/NCHelper.hpp b/src/io/NCHelper.hpp
index 817257c..d134249 100644
--- a/src/io/NCHelper.hpp
+++ b/src/io/NCHelper.hpp
@@ -35,6 +35,9 @@ public:
//! Create NC conventional tags
ErrorCode create_conventional_tags(const std::vector<int>& tstep_nums);
+ //! Update time tag values if timesteps spread across files
+ ErrorCode update_time_tag_vals();
protected:
//! Separate set and non-set variables (common to scd mesh and ucd mesh)
ErrorCode read_variable_setup(std::vector<std::string>& var_names,
diff --git a/src/io/NCWriteHelper.cpp b/src/io/NCWriteHelper.cpp
index 635b595..028bce4 100644
--- a/src/io/NCWriteHelper.cpp
+++ b/src/io/NCWriteHelper.cpp
@@ -224,12 +224,19 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
else {
// The number of coordinates should be exactly the same as dimension length
- assert(sizeCoordinate == coordDimLen);
+ // However, if timesteps spread across files and time tag has been updated,
+ // sizeCoordinate will be larger
+ if (varCoordData.varDims[0] != tDim)
+ assert(sizeCoordinate == coordDimLen);
// For time, the actual output size and values are determined by tstep_nums
if (varCoordData.varDims[0] == tDim) {
- assert(tstep_nums.size() > 0 && tstep_nums.size() <= (size_t)sizeCoordinate);
+ // Does not apply to dummy time tag (e.g. 'Time' tag of MPAS), when timesteps
+ // spread across files
+ if (NULL != data)
+ assert(tstep_nums.size() > 0 && tstep_nums.size() <= (size_t)sizeCoordinate);
sizeCoordinate = tstep_nums.size();
if (NULL != data) {
diff --git a/src/io/ReadNC.cpp b/src/io/ReadNC.cpp
index 0a41cfa..98bf6b3 100644
--- a/src/io/ReadNC.cpp
+++ b/src/io/ReadNC.cpp
@@ -25,7 +25,7 @@ ReadNC::ReadNC(Interface* impl) :
myPcomm(NULL),
#endif
noMesh(false), noVars(false), spectralMesh(false), noMixedElements(false), noEdges(false),
- gatherSetRank(-1), myHelper(NULL)
+ gatherSetRank(-1), tStepBase(-1), myHelper(NULL)
assert(impl != NULL);
impl->query_interface(readMeshIface);
@@ -119,7 +119,9 @@ ErrorCode ReadNC::load_file(const char* file_name, const EntityHandle* file_set,
// Create some conventional tags, e.g. __NUM_DIMS
- // Keep a flag on the file set to prevent conventional tags from being created again on a second read
+ // For multiple reads to a specified file set, we assume a single file, or a series of
+ // files with separated timesteps. Keep a flag on the file set to prevent conventional
+ // tags from being created again on a second read
Tag convTagsCreated = 0;
int def_val = 0;
rval = mbImpl->tag_get_handle("__CONV_TAGS_CREATED", 1, MB_TYPE_INTEGER, convTagsCreated,
@@ -127,6 +129,7 @@ ErrorCode ReadNC::load_file(const char* file_name, const EntityHandle* file_set,
ERRORR(rval, "Trouble getting _CONV_TAGS_CREATED tag.");
int create_conv_tags_flag = 0;
rval = mbImpl->tag_get_data(convTagsCreated, &tmp_set, 1, &create_conv_tags_flag);
+ // The first read to the file set
if (0 == create_conv_tags_flag) {
// Read dimension variables to create tags like __<var_name>_DIMS
rval = myHelper->read_variables(dimNames, tstep_nums);
@@ -139,6 +142,15 @@ ErrorCode ReadNC::load_file(const char* file_name, const EntityHandle* file_set,
rval = mbImpl->tag_set_data(convTagsCreated, &tmp_set, 1, &create_conv_tags_flag);
ERRORR(rval, "Trouble setting data for _CONV_TAGS_CREATED tag.");
+ // Another read to the file set
+ else {
+ if (tStepBase > -1) {
+ // If timesteps spread across files, merge time values read
+ // from current file to existing time tag
+ rval = myHelper->update_time_tag_vals();
+ ERRORR(rval, "Trouble updating time tag values.");
// Create mesh vertex/edge/face sequences
Range faces;
@@ -205,8 +217,10 @@ ErrorCode ReadNC::parse_options(const FileOptions& opts, std::vector<std::string
noVars = true;
else
noVars = false;
opts.get_ints_option("TIMESTEP", tstep_nums);
opts.get_reals_option("TIMEVAL", tstep_vals);
rval = opts.get_null_option("NOMESH");
if (MB_SUCCESS == rval)
noMesh = true;
@@ -230,12 +244,14 @@ ErrorCode ReadNC::parse_options(const FileOptions& opts, std::vector<std::string
std::cerr << var_names[i];
std::cerr << std::endl;
if (!tstep_nums.empty()) {
std::cerr << "Timesteps requested: ";
for (unsigned int i = 0; i < tstep_nums.size(); i++)
std::cerr << tstep_nums[i];
if (!tstep_vals.empty()) {
std::cerr << "Time vals requested: ";
for (unsigned int i = 0; i < tstep_vals.size(); i++)
@@ -250,6 +266,12 @@ ErrorCode ReadNC::parse_options(const FileOptions& opts, std::vector<std::string
return rval;
+ rval = opts.get_int_option("TIMESTEPBASE", 0, tStepBase);
+ if (MB_TYPE_OUT_OF_RANGE == rval) {
+ readMeshIface->report_error("Invalid value for TIMESTEPBASE option");
+ return rval;
#ifdef USE_MPI
isParallel = (opts.match_option("PARALLEL","READ_PART") != MB_ENTITY_NOT_FOUND);
diff --git a/src/io/ReadNC.hpp b/src/io/ReadNC.hpp
index 1a0ae91..1b81d15 100644
--- a/src/io/ReadNC.hpp
+++ b/src/io/ReadNC.hpp
@@ -208,6 +208,7 @@ private:
bool noMixedElements;
bool noEdges;
int gatherSetRank;
+ int tStepBase;
//! Helper class instance
NCHelper* myHelper;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
