[MOAB-dev] commit/MOAB: danwu: Removed some compiler warnings on unused variables for unit test gcrm_par.cpp, and added gcrm_par to ignore.
commits-noreply at bitbucket.org
Tue May 13 14:40:35 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/53009bd1d8ae/
Changeset: 53009bd1d8ae
Branch: master
User: danwu
Date: 2014-05-13 21:40:09
Summary: Removed some compiler warnings on unused variables for unit test gcrm_par.cpp, and added gcrm_par to ignore.
Affected #: 2 files
diff --git a/.gitignore b/.gitignore
index e2ba6f4..073629d 100644
--- a/.gitignore
+++ b/.gitignore
@@ -187,6 +187,7 @@ test/obb/obb_time
test/obb/obb_tree_tool
test/obb_test
test/oldinc/test_oldinc
+test/parallel/gcrm_par
test/parallel/*.h5m
test/parallel/mbparallelcomm_test
test/parallel/mhdf_parallel
diff --git a/test/parallel/gcrm_par.cpp b/test/parallel/gcrm_par.cpp
index e9ff71d..83e89a6 100644
--- a/test/parallel/gcrm_par.cpp
+++ b/test/parallel/gcrm_par.cpp
@@ -281,8 +281,10 @@ void read_mesh_parallel(bool rcbzoltan, bool no_mixed_elements)
CHECK_ERR(rval);
ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
+#if 0
int procs = pcomm->proc_config().proc_size();
int rank = pcomm->proc_config().proc_rank();
+#endif
rval = pcomm->check_all_shared_handles();
CHECK_ERR(rval);
@@ -292,8 +294,9 @@ void read_mesh_parallel(bool rcbzoltan, bool no_mixed_elements)
rval = mb.get_entities_by_type(0, MBVERTEX, local_verts);
CHECK_ERR(rval);
- int verts_num = local_verts.size();
#if 0
+ int verts_num = local_verts.size();
if (2 == procs) {
if (rcbzoltan) {
if (0 == rank)
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
