[MOAB-dev] commit/MOAB: danwu: Removed a compiler warning for NCWriteGCRM.cpp (variable 'num_timesteps' set but not used).
commits-noreply at bitbucket.org
Tue May 13 13:47:09 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/7be3f66f1196/
Changeset: 7be3f66f1196
Branch: master
User: danwu
Date: 2014-05-13 20:46:29
Summary: Removed a compiler warning for NCWriteGCRM.cpp (variable 'num_timesteps' set but not used).
Affected #: 1 file
diff --git a/src/io/NCWriteGCRM.cpp b/src/io/NCWriteGCRM.cpp
index b9f412c..6d245b6 100644
--- a/src/io/NCWriteGCRM.cpp
+++ b/src/io/NCWriteGCRM.cpp
@@ -289,7 +289,7 @@ ErrorCode NCWriteGCRM::write_nonset_variables(std::vector<WriteNC::VarData>& vda
num_lev = 1;
- for (unsigned int t = 0; t < tstep_nums.size(); t++) {
+ for (unsigned int t = 0; t < num_timesteps; t++) {
// We will write one time step, and count will be one; start will be different
// Use tag_get_data instead of tag_iterate to copy tag data, as localEntsOwned
// might not be contiguous.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
