[MOAB-dev] Build failed in Jenkins: moab32par #417
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Sat May 10 07:32:30 CDT 2014
It looks like a false alarm; maybe it is something with the process manager, as all par tests failed
they worked fine on gnep; this is on octagon, a 32 bit machine
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of jenkins-ci at mcs.anl.gov [jenkins-ci at mcs.anl.gov]
Sent: Saturday, May 10, 2014 12:19 AM
To: moab-dev at mcs.anl.gov
Subject: [MOAB-dev] Build failed in Jenkins: moab32par #417
See <https://jenkins-ci.mcs.anl.gov/job/moab32par/417/changes>
Changes:
[wuda] Some minor code changes to NC reader and writer. The default value of VarData::numLev is now set to 0.
[iulian] add some examples/tools for nc data
[iulian] mpas file can have vars without any dimensions
[wuda] If a non-set variable of MPAS (or GCRM) has no level dimension (so numLev is still 0), we should set numLev to 1, otherwise the variable size will be calculated as 0.
[...truncated 2925 lines...]
/usr/lib/openmpi/include/openmpi/ompi/mpi/cxx/comm_inln.h:671:1: warning: unused parameter ‘extra_state’ [-Wunused-parameter]
mv -f .deps/read_nc.Tpo .deps/read_nc.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o read_nc_par read_nc.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_nc_par read_nc.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/include    -I/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include -isystem /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/parallel -I../../src/io/mhdf/include   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT ucdtrvpart.o -MD -MP -MF .deps/ucdtrvpart.Tpo -c -o ucdtrvpart.o ucdtrvpart.cpp
In file included from /usr/lib/openmpi/include/openmpi/ompi/mpi/cxx/mpicxx.h:288:0,
                 from /usr/lib/openmpi/include/mpi.h:1886,
                 from ../../src/parallel/moab_mpi.h:19,
                 from ../../src/parallel/moab/ProcConfig.hpp:19,
                 from ../../src/parallel/moab/ParallelComm.hpp:23,
                 from ucdtrvpart.cpp:3:
/usr/lib/openmpi/include/openmpi/ompi/mpi/cxx/comm_inln.h:644:1: warning: unused parameter ‘oldcomm’ [-Wunused-parameter]
/usr/lib/openmpi/include/openmpi/ompi/mpi/cxx/comm_inln.h:644:1: warning: unused parameter ‘comm_keyval’ [-Wunused-parameter]
/usr/lib/openmpi/include/openmpi/ompi/mpi/cxx/comm_inln.h:644:1: warning: unused parameter ‘extra_state’ [-Wunused-parameter]
/usr/lib/openmpi/include/openmpi/ompi/mpi/cxx/comm_inln.h:644:1: warning: unused parameter ‘attribute_val_in’ [-Wunused-parameter]
/usr/lib/openmpi/include/openmpi/ompi/mpi/cxx/comm_inln.h:644:1: warning: unused parameter ‘attribute_val_out’ [-Wunused-parameter]
/usr/lib/openmpi/include/openmpi/ompi/mpi/cxx/comm_inln.h:671:1: warning: unused parameter ‘comm’ [-Wunused-parameter]
/usr/lib/openmpi/include/openmpi/ompi/mpi/cxx/comm_inln.h:671:1: warning: unused parameter ‘comm_keyval’ [-Wunused-parameter]
/usr/lib/openmpi/include/openmpi/ompi/mpi/cxx/comm_inln.h:671:1: warning: unused parameter ‘attribute_val’ [-Wunused-parameter]
mv -f .deps/ucdtrvpart.Tpo .deps/ucdtrvpart.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o ucdtrvpart ucdtrvpart.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o ucdtrvpart ucdtrvpart.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/include    -I/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include -isystem /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/parallel -I../../src/io/mhdf/include   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT mpastrvpart.o -MD -MP -MF .deps/mpastrvpart.Tpo -c -o mpastrvpart.o mpastrvpart.cpp
                 from mpastrvpart.cpp:3:
mv -f .deps/mpastrvpart.Tpo .deps/mpastrvpart.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o mpastrvpart mpastrvpart.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mpastrvpart mpastrvpart.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/include    -I/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include -isystem /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/parallel -I../../src/io/mhdf/include   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT gcrm_par.o -MD -MP -MF .deps/gcrm_par.Tpo -c -o gcrm_par.o gcrm_par.cpp
                 from gcrm_par.cpp:3:
gcrm_par.cpp: In function ‘void read_mesh_parallel(bool, bool)’:
gcrm_par.cpp:284:7: warning: unused variable ‘procs’ [-Wunused-variable]
gcrm_par.cpp:285:7: warning: unused variable ‘rank’ [-Wunused-variable]
gcrm_par.cpp:295:7: warning: unused variable ‘verts_num’ [-Wunused-variable]
mv -f .deps/gcrm_par.Tpo .deps/gcrm_par.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o gcrm_par gcrm_par.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o gcrm_par gcrm_par.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/include    -I/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include -isystem /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/parallel -I../../src/io/mhdf/include   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT parallel_hdf5_test.o -MD -MP -MF .deps/parallel_hdf5_test.Tpo -c -o parallel_hdf5_test.o parallel_hdf5_test.cc
                 from parallel_hdf5_test.cc:5:
mv -f .deps/parallel_hdf5_test.Tpo .deps/parallel_hdf5_test.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o parallel_hdf5_test parallel_hdf5_test.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o parallel_hdf5_test parallel_hdf5_test.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
mpicc -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/include    -I/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include -isystem /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/parallel -I../../src/io/mhdf/include   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT mhdf_parallel.o -MD -MP -MF .deps/mhdf_parallel.Tpo -c -o mhdf_parallel.o mhdf_parallel.c
mv -f .deps/mhdf_parallel.Tpo .deps/mhdf_parallel.Po
/bin/sh ../../libtool  --tag=CC   --mode=link mpicc  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o mhdf_parallel mhdf_parallel.o ../../src/libMOAB.la -lhdf5   -lm
libtool: link: mpicc -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mhdf_parallel mhdf_parallel.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -lz -lm -pthread -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/include    -I/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include -isystem /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/parallel -I../../src/io/mhdf/include   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT parallel_write_test.o -MD -MP -MF .deps/parallel_write_test.Tpo -c -o parallel_write_test.o parallel_write_test.cc
                 from parallel_write_test.cc:2:
mv -f .deps/parallel_write_test.Tpo .deps/parallel_write_test.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o parallel_write_test parallel_write_test.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o parallel_write_test parallel_write_test.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/include    -I/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include -isystem /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/parallel -I../../src/io/mhdf/include   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT mbparallelcomm_test.o -MD -MP -MF .deps/mbparallelcomm_test.Tpo -c -o mbparallelcomm_test.o mbparallelcomm_test.cpp
                 from mbparallelcomm_test.cpp:9:
mv -f .deps/mbparallelcomm_test.Tpo .deps/mbparallelcomm_test.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o mbparallelcomm_test mbparallelcomm_test.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mbparallelcomm_test mbparallelcomm_test.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/include    -I/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include -isystem /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/parallel -I../../src/io/mhdf/include   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT partcheck.o -MD -MP -MF .deps/partcheck.Tpo -c -o partcheck.o partcheck.cpp
                 from partcheck.cpp:3:
mv -f .deps/partcheck.Tpo .deps/partcheck.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o partcheck partcheck.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o partcheck partcheck.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/include    -I/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include -isystem /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/parallel -I../../src/io/mhdf/include   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT structured3.o -MD -MP -MF .deps/structured3.Tpo -c -o structured3.o structured3.cpp
                 from structured3.cpp:2:
mv -f .deps/structured3.Tpo .deps/structured3.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o structured3 structured3.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o structured3 structured3.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/include    -I/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include -isystem /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I. -I.. -I./.. -I../../src -I../../src -I../../src/parallel -I../../src/io/mhdf/include   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT parmerge.o -MD -MP -MF .deps/parmerge.Tpo -c -o parmerge.o parmerge.cpp
                 from ../../src/parallel/moab/ParallelMergeMesh.hpp:7,
                 from parmerge.cpp:6:
mv -f .deps/parmerge.Tpo .deps/parmerge.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o parmerge parmerge.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o parmerge parmerge.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/parallel'>
make  check-TESTS
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/parallel'>
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/parallel'>
FAIL: pcomm_unit
FAIL: parallel_unit_tests
FAIL: uber_parallel_test
FAIL: scdtest
FAIL: pcomm_serial
FAIL: par_spatial_locator_test
FAIL: scdpart
FAIL: read_nc_par
FAIL: ucdtrvpart
FAIL: mpastrvpart
FAIL: gcrm_par
FAIL: parallel_hdf5_test
FAIL: mhdf_parallel
FAIL: parallel_write_test
14 of 14 tests failed
See test/parallel/test-suite.log
make[4]: *** [test-suite.log] Error 1
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/parallel'>
make[3]: *** [check-TESTS] Error 2
make[2]: *** [check-am] Error 2
make[2]: Target `check' not remade because of errors.
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/parallel'>
Making check in oldinc
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/oldinc'>
make  test_oldinc
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/oldinc'>
mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/include    -I/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include -isystem /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM -I../../src -I../../src/parallel -I../../src/oldinc -I../../src -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT test_oldinc.o -MD -MP -MF .deps/test_oldinc.Tpo -c -o test_oldinc.o test_oldinc.cpp
                 from ../../src/oldinc/MBmpi.h:3,
                 from test_oldinc.cpp:46:
mv -f .deps/test_oldinc.Tpo .deps/test_oldinc.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o test_oldinc test_oldinc.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_oldinc test_oldinc.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/oldinc'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/oldinc'>
make[1]: *** [check-recursive] Error 1
make[1]: Target `check' not remade because of errors.
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test'>
Making check in doc
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/doc'>
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/doc'>
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/'>
make: *** [check-recursive] Error 1
make: Target `check' not remade because of errors.
Build step 'Execute shell' marked build as failure
