[MOAB-dev] commit/MOAB: iulian07: filter out not owned entities, for writing
commits-noreply at bitbucket.org
Wed Apr 30 14:18:01 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/912e5d377ff3/
Changeset: 912e5d377ff3
Branch: master
User: iulian07
Date: 2014-04-30 21:17:09
Summary: filter out not owned entities, for writing
modify the test also, as Jayesh
needs cleanup
Affected #: 2 files
diff --git a/src/io/NCWriteHelper.cpp b/src/io/NCWriteHelper.cpp
index 9072e38..995bf3f 100644
--- a/src/io/NCWriteHelper.cpp
+++ b/src/io/NCWriteHelper.cpp
@@ -12,6 +12,7 @@
#include "NCWriteMPAS.hpp"
#include "moab/WriteUtilIface.hpp"
+#include "MBTagConventions.hpp"
#include <sstream>
@@ -540,8 +541,18 @@ ErrorCode ScdNCWriteHelper::write_values(std::vector<std::string>& var_names)
switch (variableData.entLoc) {
case WriteNC::ENTLOCFACE:
// Faces
rval = mbImpl->get_entities_by_dimension(_fileSet, 2, ents);
ERRORR(rval, "Can't get entities for faces.");
+#ifdef USE_MPI
+ bool &isParallel = _writeNC->isParallel;
+ if (isParallel) {
+ ParallelComm*& myPcomm = _writeNC->myPcomm;
+ rval = myPcomm->filter_pstatus(ents, PSTATUS_NOT_OWNED, PSTATUS_NOT);
+ ERRORR(rval, "Can't get filter for owned entities");
+#endif
break;
default:
ERRORR(MB_FAILURE, "Not implemented yet.");
diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp
index 7f9df60..54d16d5 100644
--- a/test/io/write_nc.cpp
+++ b/test/io/write_nc.cpp
@@ -111,11 +111,13 @@ void test_eul_read_write_T()
ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
CHECK_ERR(rval);
- // Load non-set variable T, set variable gw, and the mesh
- read_opts += ";DEBUG_IO=0;VARIABLE=T,gw";
+ read_opts = "PARALLEL=READ_PART;PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1;PARTITION_METHOD=SQIJ;VARIABLE=";
rval = mb.load_file(example_eul, &set, read_opts.c_str());
CHECK_ERR(rval);
+ read_opts = "PARALLEL=READ_PART;PARTITION;PARTITION_METHOD=SQIJ;VARIABLE=T,gw;NOMESH;";
+ rval = mb.load_file(example_eul, &set, read_opts.c_str());
+ CHECK_ERR(rval);
// Write variables T and gw
std::string write_opts;
write_opts = std::string(";;VARIABLE=T,gw;DEBUG_IO=0");
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
