[MOAB-dev] commit/MOAB: 2 new changesets
    commits-noreply at bitbucket.org
    Tue Apr 29 17:46:31 CDT 2014
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/091ff53b306d/
Changeset:   091ff53b306d
Branch:      None
User:        iulian07
Date:        2014-04-30 00:33:12
Summary:     introduce RENAME option
option to rename a variable, requested by Jayesh
Some users might want to save a variable with a different name
only the initialization is modified; keep a list of desired names, which is
parallel to the variable names;
the test exercises the append option at the same time
Affected #:  5 files
diff --git a/src/io/NCWriteHelper.cpp b/src/io/NCWriteHelper.cpp
index 923fe02..9072e38 100644
--- a/src/io/NCWriteHelper.cpp
+++ b/src/io/NCWriteHelper.cpp
@@ -209,7 +209,7 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
   return MB_SUCCESS;
-ErrorCode NCWriteHelper::init_file(std::vector<std::string>& var_names, bool append)
+ErrorCode NCWriteHelper::init_file(std::vector<std::string>& var_names, std::vector<std::string>& desired_names, bool append)
   std::vector<std::string>& dimNames = _writeNC->dimNames;
   std::set<std::string>& usedCoordinates = _writeNC->usedCoordinates;
@@ -334,13 +334,14 @@ ErrorCode NCWriteHelper::init_file(std::vector<std::string>& var_names, bool app
     // Define the variable now:
-    int errCode = NCFUNC(def_var)(_fileId, var_names[i].c_str(), variableData.varDataType,
+    int errCode = NCFUNC(def_var)(_fileId, desired_names[i].c_str(), variableData.varDataType,
         (int)variableData.varDims.size(), &(variableData.varDims[0]),
         &variableData.varId);
     if ( errCode != NC_NOERR)
       ERRORR(MB_FAILURE, "Failed to create coordinate variable.");
-    dbgOut.tprintf(2, "    for variable %s variable id is %d \n", var_names[i].c_str(), variableData.varId);
+    dbgOut.tprintf(2, "    for variable %s with desired name %s variable id is %d \n", var_names[i].c_str(),
+        desired_names[i].c_str(), variableData.varId);
     // Now define the variable, with all dimensions
diff --git a/src/io/NCWriteHelper.hpp b/src/io/NCWriteHelper.hpp
index ed2443a..25a3120 100644
--- a/src/io/NCWriteHelper.hpp
+++ b/src/io/NCWriteHelper.hpp
@@ -34,7 +34,7 @@ public:
   //! Initialize file: this is where all defines are done
   //! The VarData dimension ids are filled up after define
-  ErrorCode init_file(std::vector<std::string>& var_names, bool _append);
+  ErrorCode init_file(std::vector<std::string>& var_names, std::vector<std::string>& desired_names, bool _append);
 protected:
   template <typename T> void jik_to_kji(size_t ni, size_t nj, size_t nk, T* dest, T* source)
diff --git a/src/io/WriteNC.cpp b/src/io/WriteNC.cpp
index 98f4e3b..d4d79dd 100644
--- a/src/io/WriteNC.cpp
+++ b/src/io/WriteNC.cpp
@@ -62,6 +62,7 @@ ErrorCode WriteNC::write_file(const char* file_name,
   ErrorCode rval;
   // See if opts has variable(s) specified
   std::vector<std::string> var_names;
+  std::vector<std::string> desired_names;
   std::vector<int> tstep_nums;
   std::vector<double> tstep_vals;
@@ -75,7 +76,7 @@ ErrorCode WriteNC::write_file(const char* file_name,
   if (num_set != 1)
     ERRORR(MB_FAILURE, "We should write only one set, the file set used to read data into.");
-  rval = parse_options(options, var_names, tstep_nums, tstep_vals);
+  rval = parse_options(options, var_names, desired_names, tstep_nums, tstep_vals);
   ERRORR(rval, "Trouble parsing option string.");
   // Important to create some data that will be used to write the file; dimensions, variables, etc
@@ -135,7 +136,7 @@ ErrorCode WriteNC::write_file(const char* file_name,
   rval = myHelper->collect_variable_data(var_names);
   ERRORR(rval, "Trouble collecting variable data.");
-  rval = myHelper->init_file(var_names, append);
+  rval = myHelper->init_file(var_names, desired_names, append);
   ERRORR(rval, "Failed to initialize file.");
   rval = myHelper->write_values(var_names);
@@ -147,7 +148,8 @@ ErrorCode WriteNC::write_file(const char* file_name,
   return MB_SUCCESS;
-ErrorCode WriteNC::parse_options(const FileOptions& opts, std::vector<std::string>& var_names, std::vector<int>& tstep_nums,
+ErrorCode WriteNC::parse_options(const FileOptions& opts, std::vector<std::string>& var_names,
+    std::vector<std::string>& desired_names, std::vector<int>& tstep_nums,
                                 std::vector<double>& tstep_vals)
   int tmpval;
@@ -161,6 +163,20 @@ ErrorCode WriteNC::parse_options(const FileOptions& opts, std::vector<std::strin
     noVars = true;
   else
     noVars = false;
+  rval = opts.get_strs_option("RENAME", desired_names);
+  if (MB_ENTITY_NOT_FOUND == rval)
+    if(!noVars)
+      desired_names.resize(var_names.size());
+      std::copy(var_names.begin(), var_names.end(), desired_names.begin());
+  // either way
+  assert(desired_names.size() == var_names.size());
   opts.get_ints_option("TIMESTEP", tstep_nums);
   opts.get_reals_option("TIMEVAL", tstep_vals);
   rval = opts.get_null_option("NOMESH");
diff --git a/src/io/WriteNC.hpp b/src/io/WriteNC.hpp
index 5827680..60c295e 100644
--- a/src/io/WriteNC.hpp
+++ b/src/io/WriteNC.hpp
@@ -153,6 +153,7 @@ private:
   ErrorCode parse_options(const FileOptions& opts,
                           std::vector<double>& tstep_vals);
diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp
index f48e4c6..7fe2e82 100644
--- a/test/io/write_nc.cpp
+++ b/test/io/write_nc.cpp
@@ -261,7 +261,7 @@ void test_eul_read_write_append()
   CHECK_ERR(rval);
   // Load non-set variable T, set variable gw, and the mesh
-  read_opts += ";DEBUG_IO=0;VARIABLE=T,U,gw";
+  read_opts += ";DEBUG_IO=0;VARIABLE=T,U,V,gw";
   rval = mb.load_file(example_eul, &set, read_opts.c_str());
   CHECK_ERR(rval);
@@ -289,6 +289,19 @@ void test_eul_read_write_append()
   else
     rval = mb.write_file("test_eul_TU.nc", 0, write_opts2.c_str(), &set, 1);
   CHECK_ERR(rval);
+  // append to the file variable V, renamed to VNEWNAME
+  std::string write_opts3;
+  write_opts3 = std::string(";;VARIABLE=V;RENAME=VNEWNAME;DEBUG_IO=0;APPEND");
+#ifdef USE_MPI
+  // Use parallel options
+  write_opts3 += std::string(";PARALLEL=WRITE_PART");
+#endif
+  if (procs > 1)
+    rval = mb.write_file("test_par_eul_TU.nc", 0, write_opts3.c_str(), &set, 1);
+  else
+    rval = mb.write_file("test_eul_TU.nc", 0, write_opts3.c_str(), &set, 1);
+  CHECK_ERR(rval);
 // We also write coordinate variables slat and slon to the output file, so that
https://bitbucket.org/fathomteam/moab/commits/3bac343d8274/
Changeset:   3bac343d8274
Branch:      master
User:        iulian07
Date:        2014-04-30 00:40:14
Summary:     Merge branch 'master' of https://bitbucket.org/fathomteam/moab
Affected #:  3 files
diff --git a/src/io/NCWriteMPAS.cpp b/src/io/NCWriteMPAS.cpp
index 72dc35f..8058726 100644
--- a/src/io/NCWriteMPAS.cpp
+++ b/src/io/NCWriteMPAS.cpp
@@ -6,6 +6,7 @@
 #include "NCWriteMPAS.hpp"
 #include "moab/WriteUtilIface.hpp"
+#include "MBTagConventions.hpp"
 #define ERRORR(rval, str) \
   if (MB_SUCCESS != rval) { _writeNC->mWriteIface->report_error("%s", str); return rval; }
@@ -22,12 +23,401 @@ NCWriteMPAS::~NCWriteMPAS()
 ErrorCode NCWriteMPAS::collect_mesh_info()
-  return MB_NOT_IMPLEMENTED;
+  Interface*& mbImpl = _writeNC->mbImpl;
+  std::vector<std::string>& dimNames = _writeNC->dimNames;
+  std::vector<int>& dimLens = _writeNC->dimLens;
+  Tag& mGlobalIdTag = _writeNC->mGlobalIdTag;
+  ErrorCode rval;
+  // Look for time dimension
+  std::vector<std::string>::iterator vecIt;
+  if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "Time")) != dimNames.end())
+    tDim = vecIt - dimNames.begin();
+  else if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "time")) != dimNames.end())
+  else {
+    ERRORR(MB_FAILURE, "Couldn't find 'Time' or 'time' dimension.");
+  nTimeSteps = dimLens[tDim];
+  // Get number of levels
+  if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "nVertLevels")) != dimNames.end())
+    levDim = vecIt - dimNames.begin();
+  else {
+    ERRORR(MB_FAILURE, "Couldn't find 'nVertLevels' dimension.");
+  nLevels = dimLens[levDim];
+  Range local_verts;
+  rval = mbImpl->get_entities_by_dimension(_fileSet, 0, local_verts);
+  ERRORR(rval, "Trouble getting local vertices in current file set.");
+  assert(!local_verts.empty());
+  // Depends on whether NO_EDGES read option is set or not
+  Range local_edges;
+  rval = mbImpl->get_entities_by_dimension(_fileSet, 1, local_edges);
+  ERRORR(rval, "Trouble getting local edges in current file set.");
+  noEdges = local_edges.empty();
+  Range local_cells;
+  rval = mbImpl->get_entities_by_dimension(_fileSet, 2, local_cells);
+  ERRORR(rval, "Trouble getting local cells in current file set.");
+  assert(!local_cells.empty());
+#ifdef USE_MPI
+  bool& isParallel = _writeNC->isParallel;
+  if (isParallel) {
+    ParallelComm*& myPcomm = _writeNC->myPcomm;
+    int rank = myPcomm->proc_config().proc_rank();
+    int procs = myPcomm->proc_config().proc_size();
+    if (procs > 1) {
+      rval = myPcomm->filter_pstatus(local_verts, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &localVertsOwned);
+      ERRORR(rval, "Trouble getting owned vertices in set.");
+      // Assume that PARALLEL_RESOLVE_SHARED_ENTS option is set
+      // We should avoid writing in parallel with overlapped data
+      if (procs - 1 == rank)
+        assert("PARALLEL_RESOLVE_SHARED_ENTS option is set" && localVertsOwned.size() < local_verts.size());
+      if (!noEdges) {
+        rval = myPcomm->filter_pstatus(local_edges, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &localEdgesOwned);
+        ERRORR(rval, "Trouble getting owned edges in set.");
+      rval = myPcomm->filter_pstatus(local_cells, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &localCellsOwned);
+      ERRORR(rval, "Trouble getting owned cells in set.");
+    else {
+      localVertsOwned = local_verts;
+      localEdgesOwned = local_edges;
+      localCellsOwned = local_cells;
+  else {
+    // Not running in parallel, but still with MPI
+#else
+#endif
+  std::vector<int> gids(localVertsOwned.size());
+  rval = mbImpl->tag_get_data(mGlobalIdTag, localVertsOwned, &gids[0]);
+  ERRORR(rval, "Trouble getting global IDs on local vertices.");
+  // Restore localGidVerts
+  std::copy(gids.rbegin(), gids.rend(), range_inserter(localGidVertsOwned));
+  nLocalVerticesOwned = localGidVertsOwned.size();
+  gids.resize(localEdgesOwned.size());
+  rval = mbImpl->tag_get_data(mGlobalIdTag, localEdgesOwned, &gids[0]);
+  ERRORR(rval, "Trouble getting global IDs on local edges.");
+  // Restore localGidEdges
+  std::copy(gids.rbegin(), gids.rend(), range_inserter(localGidEdgesOwned));
+  nLocalEdgesOwned = localGidEdgesOwned.size();
+  gids.resize(localCellsOwned.size());
+  rval = mbImpl->tag_get_data(mGlobalIdTag, localCellsOwned, &gids[0]);
+  ERRORR(rval, "Trouble getting global IDs on local cells.");
+  // Restore localGidCells
+  std::copy(gids.rbegin(), gids.rend(), range_inserter(localGidCellsOwned));
+  nLocalCellsOwned = localGidCellsOwned.size();
+  return MB_SUCCESS;
-ErrorCode NCWriteMPAS::write_values(std::vector<std::string>& /* var_names */)
+ErrorCode NCWriteMPAS::collect_variable_data(std::vector<std::string>& var_names)
+  NCWriteHelper::collect_variable_data(var_names);
+  // Dimension numbers for other optional levels
+  std::vector<unsigned int> opt_lev_dims;
+  unsigned int lev_idx;
+  // Get number of vertex levels P1
+  if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "nVertLevelsP1")) != dimNames.end()) {
+    lev_idx = vecIt - dimNames.begin();
+    opt_lev_dims.push_back(lev_idx);
+  // Get number of vertex levels P2
+  if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "nVertLevelsP2")) != dimNames.end()) {
+  // Get number of soil levels
+  if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "nSoilLevels")) != dimNames.end()) {
+  std::map<std::string, WriteNC::VarData>& varInfo = _writeNC->varInfo;
+  for (size_t i = 0; i < var_names.size(); i++) {
+    std::string varname = var_names[i];
+    std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(varname);
+    if (vit == varInfo.end())
+      ERRORR(MB_FAILURE, "Can't find one variable.");
+    WriteNC::VarData& currentVarData = vit->second;
+    std::vector<int>& varDims = currentVarData.varDims;
+    // If nVertLevels dimension is not found, try other optional levels such as nVertLevelsP1
+    if (std::find(varDims.begin(), varDims.end(), levDim) == varDims.end()) {
+      for (unsigned int j = 0; j < opt_lev_dims.size(); j++) {
+        if (std::find(varDims.begin(), varDims.end(), opt_lev_dims[j]) != varDims.end()) {
+          currentVarData.numLev = dimLens[opt_lev_dims[j]];
+          break;
+    if (currentVarData.has_tsteps) {
+      // Support non-set variables with 3 dimensions like (Time, nCells, nVertLevels), or
+      // 2 dimensions like (Time, nCells)
+      assert(3 == currentVarData.varDims.size() || 2 == currentVarData.varDims.size());
+      // Time should be the first dimension
+      assert(tDim == currentVarData.varDims[0]);
+      // Set up writeStarts and writeCounts
+      currentVarData.writeStarts.resize(3);
+      currentVarData.writeCounts.resize(3);
+      // First: Time
+      currentVarData.writeStarts[0] = 0; // This value is timestep dependent, will be set later
+      currentVarData.writeCounts[0] = 1;
+      // Next: nVertices / nCells / nEdges
+      switch (currentVarData.entLoc) {
+        case WriteNC::ENTLOCVERT:
+          // Vertices
+          // Start from the first localGidVerts
+          // Actually, this will be reset later for writing
+          currentVarData.writeStarts[1] = localGidVertsOwned[0] - 1;
+          currentVarData.writeCounts[1] = nLocalVerticesOwned;
+          break;
+        case WriteNC::ENTLOCFACE:
+          // Faces
+          // Start from the first localGidCells
+          currentVarData.writeStarts[1] = localGidCellsOwned[0] - 1;
+          currentVarData.writeCounts[1] = nLocalCellsOwned;
+          break;
+        case WriteNC::ENTLOCEDGE:
+          // Edges
+          // Start from the first localGidEdges
+          currentVarData.writeStarts[1] = localGidEdgesOwned[0] - 1;
+          currentVarData.writeCounts[1] = nLocalEdgesOwned;
+          break;
+        default:
+          ERRORR(MB_FAILURE, "Unexpected entity location type for MPAS non-set variable.");
+      // Finally: nVertLevels or other optional levels, it is possible that there
+      // is no level dimension for this non-set variable
+      currentVarData.writeStarts[2] = 0;
+      currentVarData.writeCounts[2] = currentVarData.numLev;
+    // Get variable size
+    currentVarData.sz = 1;
+    for (std::size_t idx = 0; idx != currentVarData.writeCounts.size(); idx++)
+      currentVarData.sz *= currentVarData.writeCounts[idx];
+ErrorCode NCWriteMPAS::write_values(std::vector<std::string>& var_names)
+  std::set<std::string>& usedCoordinates = _writeNC->usedCoordinates;
+  std::set<std::string>& dummyVarNames = _writeNC->dummyVarNames;
+  int success;
+  Range* pLocalEntsOwned = NULL;
+  Range* pLocalGidEntsOwned = NULL;
+  // Now look at requested var_names; if they have time, we will have a list, and write one at a time
+  // For each variable tag in the indexed lists, write a time step data
+  // Assume the first dimension is time (need to check); if not, just write regularly
+    std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(var_names[i]);
+      ERRORR(MB_FAILURE, "Can't find variable requested.");
+    WriteNC::VarData& variableData = vit->second;
+    int numTimeSteps = (int)variableData.varTags.size();
+    if (variableData.has_tsteps) {
+      assert(tDim == variableData.varDims[0]);
+      // Assume this variable is on vertices for the time being
+      switch (variableData.entLoc) {
+          // Vertices
+          pLocalEntsOwned = &localVertsOwned;
+          pLocalGidEntsOwned = &localGidVertsOwned;
+          break;
+          // Edges
+          pLocalEntsOwned = &localEdgesOwned;
+          pLocalGidEntsOwned = &localGidEdgesOwned;
+          break;
+          // Cells
+          pLocalEntsOwned = &localCellsOwned;
+          pLocalGidEntsOwned = &localGidCellsOwned;
+          break;
+        default:
+      // A typical variable has 3 dimensions as (Time, nCells, nVertLevels)
+      // FIXME: Should use tstep_nums (from writing options) later
+      for (int j = 0; j < numTimeSteps; j++) {
+        // We will write one time step, and count will be one; start will be different
+        // Use tag_get_data instead of tag_iterate to get values, as localEntsOwned
+        // might not be contiguous.
+        variableData.writeStarts[0] = j; // This is time, again
+        std::vector<double> tag_data(pLocalEntsOwned->size() * variableData.numLev);
+        ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[j], *pLocalEntsOwned, &tag_data[0]);
+        ERRORR(rval, "Trouble getting tag data on owned vertices.");
+#ifdef PNETCDF_FILE
+        size_t nb_writes = pLocalGidEntsOwned->psize();
+        std::vector<int> requests(nb_writes), statuss(nb_writes);
+        size_t idxReq = 0;
+#endif
+        // Now write from memory directly
+        switch (variableData.varDataType) {
+          case NC_DOUBLE: {
+            size_t indexInDoubleArray = 0;
+            size_t ic = 0;
+            for (Range::pair_iterator pair_iter = pLocalGidEntsOwned->pair_begin();
+                pair_iter != pLocalGidEntsOwned->pair_end(); ++pair_iter, ic++) {
+              EntityHandle starth = pair_iter->first;
+              EntityHandle endh = pair_iter->second;
+              variableData.writeStarts[1] = (NCDF_SIZE)(starth - 1);
+              variableData.writeCounts[1] = (NCDF_SIZE)(endh - starth + 1);
+              // Do a partial write, in each subrange
+              // Wait outside this loop
+              success = NCFUNCREQP(_vara_double)(_fileId, variableData.varId,
+                  &(variableData.writeStarts[0]), &(variableData.writeCounts[0]),
+                             &(tag_data[indexInDoubleArray]), &requests[idxReq++]);
+#else
+              success = NCFUNCAP(_vara_double)(_fileId, variableData.varId,
+                             &(tag_data[indexInDoubleArray]));
+#endif
+              ERRORS(success, "Failed to read double data in loop");
+              // We need to increment the index in double array for the
+              // next subrange
+              indexInDoubleArray += (endh - starth + 1) * variableData.numLev;
+            assert(ic == pLocalGidEntsOwned->psize());
+            success = ncmpi_wait_all(_fileId, requests.size(), &requests[0], &statuss[0]);
+            ERRORS(success, "Failed on wait_all.");
+#endif
+            break;
+          default:
+            ERRORR(MB_FAILURE, "Not implemented yet.");
+    } // if (variableData.has_tsteps)
+    else {
+        case NC_DOUBLE:
+          success = NCFUNCAP(_vara_double)(_fileId, variableData.varId, &variableData.writeStarts[0],
+                    &variableData.writeCounts[0], (double*)(variableData.memoryHogs[0]));
+          ERRORS(success, "Failed to write double data.");
+          break;
+        default:
+  // Write coordinates used by requested var_names
+  // Use independent I/O mode put, since this write is only for the root processor
+  // CAUTION: if the NetCDF ID is from a previous call to ncmpi_create rather than ncmpi_open,
+  // all processors need to call ncmpi_begin_indep_data(). If only the root processor does so,
+  // ncmpi_begin_indep_data() call will be blocked forever :(
+  // Enter independent I/O mode
+  success = NCFUNC(begin_indep_data)(_fileId);
+  ERRORS(success, "Failed to begin independent I/O mode.");
+#endif
+  int rank = 0;
+#ifdef USE_MPI
+  if (isParallel) {
+    rank = myPcomm->proc_config().proc_rank();
+#endif
+  if (0 == rank) {
+    for (std::set<std::string>::iterator setIt = usedCoordinates.begin();
+        setIt != usedCoordinates.end(); ++setIt) {
+      const std::string& coordName = *setIt;
+      // Skip dummy coordinate variables (e.g. ncol)
+      if (dummyVarNames.find(coordName) != dummyVarNames.end())
+        continue;
+      std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(coordName);
+        ERRORR(MB_FAILURE, "Can't find one coordinate variable.");
+      WriteNC::VarData& varCoordData = vit->second;
+      switch (varCoordData.varDataType) {
+        case NC_DOUBLE:
+          // Independent I/O mode put
+          success = NCFUNCP(_vara_double)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
+                    &varCoordData.writeCounts[0], (double*)(varCoordData.memoryHogs[0]));
+          break;
+        case NC_INT:
+          success = NCFUNCP(_vara_int)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
+                    &varCoordData.writeCounts[0], (int*)(varCoordData.memoryHogs[0]));
+          ERRORS(success, "Failed to write int data.");
+          break;
+        default:
+  // End independent I/O mode
+  success = NCFUNC(end_indep_data)(_fileId);
+  ERRORS(success, "Failed to end independent I/O mode.");
+#endif
 } /* namespace moab */
diff --git a/src/io/NCWriteMPAS.hpp b/src/io/NCWriteMPAS.hpp
index 702984f..89842f3 100644
--- a/src/io/NCWriteMPAS.hpp
+++ b/src/io/NCWriteMPAS.hpp
@@ -17,7 +17,7 @@ class NCWriteMPAS: public UcdNCWriteHelper
 public:
   NCWriteMPAS(WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
-: UcdNCWriteHelper(writeNC, fileId, opts, fileSet) {}
+: UcdNCWriteHelper(writeNC, fileId, opts, fileSet), noEdges(false) {}
   virtual ~NCWriteMPAS();
@@ -26,7 +26,13 @@ private:
   virtual ErrorCode collect_mesh_info();
   //! Collect data for specified variables
+  virtual ErrorCode collect_variable_data(std::vector<std::string>& var_names);
+  //! Implementation of NCWriteHelper::write_values()
   virtual ErrorCode write_values(std::vector<std::string>& var_names);
+private:
+  bool noEdges;
 } // namespace moab
index 7fe2e82..7f9df60 100644
@@ -71,10 +71,11 @@ int main(int argc, char* argv[])
   result += RUN_TEST(test_eul_check_T);
   result += RUN_TEST(test_eul_read_write_append);
   result += RUN_TEST(test_fv_read_write_T);
+  result += RUN_TEST(test_fv_check_T);
   result += RUN_TEST(test_homme_read_write_T);
   result += RUN_TEST(test_homme_check_T);
- // result += RUN_TEST(test_mpas_read_write_vars);
- // result += RUN_TEST(test_mpas_check_vars);
+  result += RUN_TEST(test_mpas_read_write_vars);
+  result += RUN_TEST(test_mpas_check_vars);
 #ifdef USE_MPI
   fail = MPI_Finalize();
@@ -235,6 +236,7 @@ void test_eul_check_T()
 // We read and write variables T and U; U after we write T, so we append
 // we will also write gw, just to test the file after writing
@@ -466,7 +468,7 @@ void test_homme_read_write_T()
   CHECK_ERR(rval);
   // Write variables T, lat and lon
-  std::string write_opts = ";;VARIABLE=T,lat,lon;DEBUG_IO=0;";
+  std::string write_opts = ";;VARIABLE=T,lat,lon;DEBUG_IO=0";
 #ifdef USE_MPI
   write_opts += std::string(";PARALLEL=WRITE_PART");
@@ -626,7 +628,7 @@ void test_mpas_read_write_vars()
   CHECK_ERR(rval);
   // Write variables u, ke and vorticity (no mesh information)
-  std::string write_opts = ";;VARIABLE=u,ke,vorticity;DEBUG_IO=0;";
+  std::string write_opts = ";;VARIABLE=u,ke,vorticity;DEBUG_IO=0";
 #ifdef USE_MPI
@@ -662,9 +664,9 @@ void test_mpas_check_vars()
     std::string filename;
     if (procs > 1)
-      filename = "test_mpas_vars.nc";
-    else
       filename = "test_par_mpas_vars.nc";
+    else
+      filename = "test_mpas_vars.nc";
 #ifdef PNETCDF_FILE
     success = NCFUNC(open)(MPI_COMM_SELF, filename.c_str(), NC_NOWRITE, MPI_INFO_NULL, &ncid);
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
