[MOAB-dev] commit/MOAB: 2 new changesets
    commits-noreply at bitbucket.org
    Sun Mar 30 10:36:58 CDT 2014
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/9bfb3fe9c697/
Changeset:   9bfb3fe9c697
Branch:      None
User:        iulian07
Date:        2014-03-30 03:24:41
Summary:     process attributes for each variable and global attributes
these are saved when the original file is read with nomesh, novars option
the attributes are concatenated, I saved them all as char
do we really need them
AttData is different compared to ReadNC
why save the name again?
well, not sure anybody needs them yet
Affected #:  2 files
diff --git a/src/io/WriteNC.cpp b/src/io/WriteNC.cpp
index a65548a..5af6fdf 100644
--- a/src/io/WriteNC.cpp
+++ b/src/io/WriteNC.cpp
@@ -13,6 +13,7 @@
 #include <set>
 #include <iostream>
+#include <sstream>
 #define ERRORR(rval, str) \
   if (MB_SUCCESS != rval) { mWriteIface->report_error("%s", str); return rval; }
@@ -365,6 +366,7 @@ ErrorCode WriteNC::process_conventional_tags(EntityHandle fileSet)
       ERRORR(rval, " size of dimensions for variable");
       dbgOut.tprintf(2, "var name: %s has %d dimensions \n", var_name.c_str(), sz);
+      variableDataStruct.varDims.resize(sz);
       //std::vector<const pcdim*> dims(sz, NULL);
       const void* ptr = NULL;
       rval = mbImpl->tag_get_by_ptr(dims_tag, &fileSet, 1, &ptr);
@@ -376,123 +378,124 @@ ErrorCode WriteNC::process_conventional_tags(EntityHandle fileSet)
         rval = mbImpl->tag_get_name(ptags[j], dim_name);
         ERRORR(rval, "name of tag for dimension");
         dbgOut.tprintf(2, "var name: %s has %s as dimension \n", var_name.c_str(), dim_name.c_str() );
+        std::vector<std::string>::iterator vit=std::find(dimNames.begin(), dimNames.end(), dim_name);
+        if (vit==dimNames.end())
+          ERRORR(MB_FAILURE, "dimension not found\n");
+        variableDataStruct.varDims[j]=(int)(vit-dimNames.begin()); // will be used for writing
+        // do we have a variable for each dimension? I mean, a tag?
         //dims[j] = &(get_dim(dim_name));
-      /*insert(var_name,
-          *(new fvar(var_name, moab::MB_TYPE_DOUBLE, dims,
-              locmap[varLoc[nthVar++]])));*/
+      // attributes for this variable
+      std::stringstream ssTagName;
+      ssTagName << "__" << var_name << "_ATTRIBS";
+      tag_name = ssTagName.str();
+      Tag varAttTag = 0;
+      rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_OPAQUE, varAttTag, MB_TAG_SPARSE | MB_TAG_VARLEN);
+      ERRORR(rval, "Trouble getting __<var_name>_ATTRIBS tag.");
+      std::string varAttVal;
+      std::vector<int> varAttLen;
+      const void* varAttPtr = 0;
+      int varAttSz = 0;
+      rval = mbImpl->tag_get_by_ptr(varAttTag, &fileSet, 1, &varAttPtr, &varAttSz);
+      ERRORR(rval, "Trouble setting data for __<var_name>_ATTRIBS tag.");
+      if (MB_SUCCESS == rval)
+        dbgOut.tprintf(2, "Tag retrieved for variable %s\n", tag_name.c_str());
+      ssTagName << "_LEN";
+      Tag varAttLenTag = 0;
+      rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_INTEGER, varAttLenTag, MB_TAG_ANY);
+      ERRORR(rval, "Trouble getting __<var_name>_ATTRIBS_LEN tag.");
+      int varAttLenSz=0;
+      rval = mbImpl->tag_get_length(varAttLenTag, varAttLenSz);
+      ERRORR(rval, "Trouble getting __<var_name>_ATTRIBS_LEN length.");
+      varAttLen.resize(varAttLenSz);
+      rval = mbImpl->tag_get_data(varAttLenTag, &fileSet, 1, &varAttLen[0]);
+      ERRORR(rval, "Trouble getting data for __<var_name>_ATTRIBS_LEN tag.");
+      rval = process_concatenated_attribute(varAttPtr, varAttSz, varAttLen, variableDataStruct.varAtts);
+      ERRORR(rval, " trouble processing global attributes ");
+        dbgOut.tprintf(2, "Tag metadata for variable %s\n", tag_name.c_str());
+      // end attribute
       start = i + 1;
       idxVar++;
   // attributes
-#if 0
-  std::vector<std::string> nameVec(num_vars+1);
-        nameVec[0] = "GLOBAL";
-        std::map<std::string, const fvar*>::iterator it = m_vars.begin();
-        for (std::size_t i=1; it != m_vars.end(); ++it, ++i)
-          nameVec[i] = it->first;
-        for (std::size_t vec_counter = 0; vec_counter != nameVec.size(); ++vec_counter)
-      // read __<var_name>_ATTRIBS tag
-      moab::Tag tag = 0;
-      std::string tag_name = "__"+nameVec[vec_counter]+"_ATTRIBS";
-      const void * data = NULL;
-      int sz = 0;
-      moab::ErrorCode rval = m_mb.tag_get_handle(tag_name.c_str(), 0, moab::MB_TYPE_OPAQUE, tag, moab::MB_TAG_ANY);
-      if (rval != moab::MB_SUCCESS)
-        throw pargal_except("Error: " + m_mb.get_error_string(rval),
-                __FILE__, __LINE__, __PRETTY_FUNCTION__);
-      rval = m_mb.tag_get_by_ptr(tag, &m_file_set, 1, &data, &sz);
-      const char * p = static_cast<const char *>(data);
-      std::string att_val(&p[0], sz);
-      if (vec_counter == 0) nameVec[0]="MOAB_GLOBAL";
-      const std::string& var_name = nameVec[vec_counter];
-      // read __<var_name>_ATTRIBS_LEN tag
-      moab::Tag attLenTag = 0;
-      tag_name = tag_name + "_LEN";
-      const void * len_data = NULL;
-      int len_sz = 0;
-      rval = m_mb.tag_get_handle(tag_name.c_str(), 0, moab::MB_TYPE_INTEGER, attLenTag, moab::MB_TAG_ANY);
-      rval = m_mb.tag_get_by_ptr(attLenTag, &m_file_set, 1, &len_data, &len_sz);
-      const int * len_p = static_cast<const int *>(len_data);
-      std::vector<int> attLen(len_sz);
-      std::copy(len_p, len_p+len_sz, attLen.begin());
-      // create attribute
-      insert(var_name, *(new pcatt(var_name, att_val, attLen)));
-#endif
+  tag_name = "__GLOBAL_ATTRIBS";
+  Tag globalAttTag = 0;
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_OPAQUE, globalAttTag, MB_TAG_SPARSE | MB_TAG_VARLEN);
+  ERRORR(rval, "Trouble getting __GLOBAL_ATTRIBS tag.");
+  std::string gattVal;
+  std::vector<int> gattLen;
+  const void* gattptr;
+  int globalAttSz=0;
+  rval = mbImpl->tag_get_by_ptr(globalAttTag, &fileSet, 1, &gattptr, &globalAttSz);
+  ERRORR(rval, "Trouble getting data for __GLOBAL_ATTRIBS tag.");
+      dbgOut.tprintf(2, "Tag value retrieved for %s size %d\n", tag_name.c_str(), globalAttSz);
+    // <__GLOBAL_ATTRIBS_LEN>
+  tag_name = "__GLOBAL_ATTRIBS_LEN";
+  Tag globalAttLenTag = 0;
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_INTEGER, globalAttLenTag, MB_TAG_ANY);
+  ERRORR(rval, "Trouble getting __GLOBAL_ATTRIBS_LEN tag.");
+  int sizeGAtt =0;
+  rval = mbImpl->tag_get_length(globalAttLenTag, sizeGAtt);
+  ERRORR(rval, "Trouble getting length of __GLOBAL_ATTRIBS_LEN tag ");
+  gattLen.resize(sizeGAtt);
+  rval = mbImpl->tag_get_data(globalAttLenTag, &fileSet, 1, &gattLen[0]);
+  ERRORR(rval, "Trouble setting data for __GLOBAL_ATTRIBS_LEN tag.");
+  rval = process_concatenated_attribute(gattptr, globalAttSz, gattLen, globalAtts);
   return MB_SUCCESS;
-#if 0
+ErrorCode WriteNC::process_concatenated_attribute(const void * gattptr, int globalAttSz, std::vector<int> & gattLen,
+      std::map<std::string, AttData> & attributes)
-    void
-    fileinfo::init_atts()
-      std::vector<std::string> nameVec(m_vars.size()+1);
-    int sz = 0;
-    int len_sz = 0;
+  std::size_t start = 0;
+  std::size_t att_counter = 0;
+  std::string concatString( (char*)gattptr, (char*)gattptr+globalAttSz);
-    void
-    fileinfo::init_grid_type()
+  for (std::size_t i = 0; i != (size_t)globalAttSz; ++i)
+    if (concatString[i] == '\0')
-      std::string tag_name = "__MESH_TYPE";
-      int sz = 0;
-      moab::ErrorCode rval;
-      rval = m_mb.tag_get_handle(tag_name.c_str(), 0, moab::MB_TYPE_OPAQUE, tag, moab::MB_TAG_ANY);
-      m_grid_type = std::string(&p[0], sz);
+      std::string att_name(&concatString[start], i - start);
+      start = i + 1;
+      while (concatString[i] != ';')
+        ++i;
+      std::string data_type(&concatString[start], i - start);
+      ++i;
+      start = i;
+      i = gattLen[att_counter];
+      if (concatString[i] != ';')
+        ERRORR(MB_FAILURE, "Error parsing attributes ");
+      std::string data_val(&concatString[start], i - start);
+      start = i + 1;
+      AttData attrib = attributes[att_name];
+      attrib.attValue = data_val;
+      ++att_counter;
+      dbgOut.tprintf(2, "       Process attribute %s with value %s \n",att_name.c_str(), data_val.c_str() );
   return MB_SUCCESS;
-#endif
 } // end moab namespace
diff --git a/src/io/WriteNC.hpp b/src/io/WriteNC.hpp
index c3b893a..6b75d59 100644
--- a/src/io/WriteNC.hpp
+++ b/src/io/WriteNC.hpp
@@ -110,7 +110,7 @@ private:
     NCDF_SIZE attLen;
     int attVarId;
     nc_type attDataType;
-    std::string attName;
+    std::string attValue;
   class VarData
@@ -152,6 +152,9 @@ private:
    * ErrorCode NCHelper::create_conventional_tags
   ErrorCode process_conventional_tags(EntityHandle fileSet);
+  ErrorCode process_concatenated_attribute(const void * gattptr, int globalAttSz, std::vector<int> & gattLen,
+      std::map<std::string, AttData> & globalAtts);
     // interface instance
   Interface *mbImpl;
   WriteUtilIface* mWriteIface;
https://bitbucket.org/fathomteam/moab/commits/e64001b99718/
Changeset:   e64001b99718
Branch:      ncwriter
User:        iulian07
Date:        2014-03-30 17:23:36
Summary:     start collecting data
will have to populate VarData with appropriate info;
start gathering tag info for nonset variables
"set" variables are coordinate variables (dimensions), usually
time is integer (time steps, or time values?)
Affected #:  2 files
index 5af6fdf..05fcc3f 100644
@@ -122,6 +122,9 @@ ErrorCode WriteNC::write_file(const char *file_name,
                             const size_t count[], const double *dp);
+  rval = collect_variable_data(var_names, tstep_nums, tstep_vals, *file_set);
+  ERRORR(rval, "Trouble collecting data.");
   return MB_SUCCESS;
@@ -348,7 +351,11 @@ ErrorCode WriteNC::process_conventional_tags(EntityHandle fileSet)
       dbgOut.tprintf(2, "var name: %s index %d \n", var_name.c_str(), idxVar);
       // process var name:
       // this will create/initiate map; we will populate variableDataStruct wit info about dims, tags, etc
-      VarData  variableDataStruct = varInfo[var_name];
+      // reference & is important; otherwise variableDataStruct will go out of scope, and deleted :(
+      VarData  & variableDataStruct = varInfo[var_name];
+      dbgOut.tprintf(2, "at var name %s varInfo size %d \n", var_name.c_str(), varInfo.size() );
       sz = 0;
       Tag dims_tag = 0;
       std::string dim_names = "__" + var_name + "_DIMS";
@@ -371,6 +378,7 @@ ErrorCode WriteNC::process_conventional_tags(EntityHandle fileSet)
       const Tag * ptags = static_cast<const moab::Tag*>(ptr);
       for (std::size_t j = 0; j != static_cast<std::size_t>(sz); ++j)
@@ -381,7 +389,8 @@ ErrorCode WriteNC::process_conventional_tags(EntityHandle fileSet)
-        variableDataStruct.varDims[j]=(int)(vit-dimNames.begin()); // will be used for writing
+        variableDataStruct.varDims[j]= (int)(vit-dimNames.begin()) ; // will be used for writing
@@ -462,7 +471,7 @@ ErrorCode WriteNC::process_conventional_tags(EntityHandle fileSet)
   return MB_SUCCESS;
+// reverse process from create_attrib_string
@@ -498,4 +507,106 @@ ErrorCode WriteNC::process_concatenated_attribute(const void * gattptr, int glob
   return MB_SUCCESS;
+ErrorCode WriteNC::collect_variable_data( std::vector<std::string>& var_names, std::vector<int>& tstep_nums,
+     std::vector<double>& tstep_vals, EntityHandle fileSet)
+  // in general, in netcdf, variables that have the same name as their only dimension are called
+  // coordinate variables
+  // for the time being, check if all dimensions for variables are coordinate variables
+  ErrorCode rval;
+  usedCoordinates.clear();
+  for (size_t i=0; i<var_names.size(); i++)
+    std::string varname=var_names[i];
+    std::map<std::string, VarData>::iterator vit = varInfo.find(varname);
+    if (vit==varInfo.end())
+      ERRORR(MB_FAILURE, "can't find one variable");
+    size_t sizeVar = 1;// get multiplied by dim lengths
+    VarData  & currentVarData = vit->second;
+    dbgOut.tprintf(2, "    for variable %s varDims.size %d \n", varname.c_str(), (int)currentVarData.varDims.size() );
+    for (size_t j =0; j<currentVarData.varDims.size(); j++)
+      std::string dimName= dimNames[ currentVarData.varDims[j] ];
+      vit = varInfo.find(dimName);
+        ERRORR(MB_FAILURE, "can't find one coordinate variable");
+      if( (dimName == "time" || dimName == "Time" || dimName == "t") &&
+          currentVarData.varDims.size()>1 ) // so it is not time itself
+        currentVarData.has_tsteps=true;
+      // probably will have to look at tstep_vals to match them
+      sizeVar *= dimLens[j];
+      usedCoordinates.insert(dimName); // collect those used, we will need to write them to the file
+      dbgOut.tprintf(2, "    for variable %s need dimension %s with length %d\n", varname.c_str(), dimName.c_str(), dimLens[j] );
+    currentVarData.sz=sizeVar;
+    if (currentVarData.has_tsteps)
+      int index=0;
+      while(1)
+        Tag indexedTag;
+        std::stringstream ssTagNameWithIndex;
+        ssTagNameWithIndex << varname << index;
+        rval = mbImpl->tag_get_handle(ssTagNameWithIndex.str().c_str(), indexedTag);
+        if (rval!=MB_SUCCESS)
+          break;
+        dbgOut.tprintf(2, "    found indexed tag %d with name %s\n", index,  ssTagNameWithIndex.str().c_str());
+        currentVarData.varTags.push_back(indexedTag);
+        index++; // we should get out of the loop at some point
+        // we will have to collect data for these tags; maybe even allocate memory again
+    else
+      // get the tag with varname
+      Tag coordtag=0;
+      rval = mbImpl->tag_get_handle(varname.c_str(), coordtag);
+      ERRORR(rval, "can't find one tag");
+      currentVarData.varTags.push_back(coordtag); // really, only one for these
+      const void * data;
+      int sizeCoordinate;
+      rval = mbImpl->tag_get_by_ptr(coordtag, &fileSet, 1, &data, &sizeCoordinate);
+      ERRORR(rval, "can't get coordinate values");
+      assert(currentVarData.memoryHogs.size()==0);// nothing so far
+      currentVarData.memoryHogs.push_back((void*)data);
+  // check that for used coordinates we have found the tags
+  for (std::set<std::string>::iterator setIt = usedCoordinates.begin(); setIt!=usedCoordinates.end(); setIt++)
+    std::string coordName=*setIt; // a deep copy ; is it needed?
+    std::map<std::string, VarData>::iterator vit = varInfo.find(coordName);
+    VarData & varCoordData = vit->second;
+    Tag coordtag=0;
+    rval = mbImpl->tag_get_handle(coordName.c_str(), coordtag);
+    varCoordData.varTags.push_back(coordtag); // really, only one for these
+    dbgOut.tprintf(2, "    found coordinate tag with name %s and length %d\n", coordName.c_str(),
+        sizeCoordinate);
+    assert(varCoordData.memoryHogs.size()==0);// nothing so far
+    varCoordData.memoryHogs.push_back((void*)data);
+  return MB_SUCCESS;
index 6b75d59..df89af1 100644
@@ -139,6 +139,9 @@ private:
   //! Dimension lengths
   std::vector<int> dimLens;
+  // will collect used dimensions (ccordinate variables)
+  std::set<std::string> usedCoordinates;
   //! Global attribs
   std::map<std::string, AttData> globalAtts;
@@ -155,6 +158,11 @@ private:
+  // will collect data; it should be only on gather processor, but for the time being, collect
+  // for everybody
+  ErrorCode collect_variable_data( std::vector<std::string>& var_names, std::vector<int>& tstep_nums,
+      std::vector<double>& tstep_vals, EntityHandle fileSet);
   Interface *mbImpl;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
