[MOAB-dev] cubit file
kanaev at ibrae.ac.ru
Wed Apr 9 16:14:07 CDT 2014
Hello Iulian,
Sorry, the mesh file i've sent you was prepared for me by my
colleague (in Cubit 14.1), so i'm not really sure of how he managed to
do that
That mesh is a refined version of the previous coarser one that
worked all right, i've remeshed it myself and now moab reads all of
ids for surfaces right!
Not sure what's going on there though, since you can see all of the
surface ids in Cubit in the "wrong" file, but cannot say what's
exactly wrong with it
Thanks
Anton
On Wed, 9 Apr 2014 19:00:29 +0000, "Grindeanu, Iulian R." wrote:
P {margin-top:0;margin-bottom:0;} The file can be opened in cubit
14.0 too
We do have cubit 14.1, I just extracted it, and put it in
/homes/fathom/3rdparty/cubit/Cubit64/cubit-14.1
We are processing acis records, and it seems that some format
changed, and we will have to (re)interpret stuff again.
Actually, I created another file in cubit14.1, and I see no issues
with global ids.
It could be something specific to this
file, or the way the file was
created.
Anton, can you try creating the file again (even in 14.1), and see
if you still have issues?
Or can you do it in cubit 14.0?
The process of identifying global ids is not easy, it is in a part
of the code "process acis attributes"
Some records are not interpreted by us, so we miss extracting the
cubit ids. I will look at it more.
Iulian
Sent: Wednesday, April 09, 2014 12:33 PM
To: Grindeanu, Iulian R.
Subject: Re: cubit file
Iulian,
Did you have cubit14.1? Can you open the file in cubit? If so,
I'd like to access it too. Thanks. So far, I stopped at
Tqdcfr.cpp line 2166, but could not figure out the actual global id
yet for the 51 entities sets. Hope you have good luck!
Jane
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who
are called according to his purpose,
all things are working together
for good." (Romans 8:28) On Wednesday, April 9, 2014 11:14 AM,
Jiangtao Hu wrote:
Yes, I've got it, and looks like that there're many with
GLOBAL_ID = 0. Also looks like the version is 14.1 instead of 14.0...
Jane
Asst. Researcher
UW @ Madison
are called according to his purpose, all things are working together
for good." (Romans 8:28) On Wednesday, April 9, 2014 10:33 AM,
Hi Jane,
It was attached to this email, sent on moab dev. You might already
have it in your moab folder.
Iulian
From: kanaev at ibrae.ac.ru [1] [kanaev at ibrae.ac.ru [1]]
Sent: Tuesday, April 08, 2014 2:32 PM
Cc: MOAB dev
Subject: RE: [MOAB-dev] write_file freezes on Cetus
Hello Iulian,
Thanks for advise, i've built the latest version in my home
dir and
it
worked as well as on my pc
There's something strange still happening while getting global_ids
from
Cubit surfaces
Please do mbconvert to .h5m with attached .cub file, and then check
global_ids of surface mbentitysets with mbsize - part of them (5-9)
got the
proper ids and the others got zeroes
Anton
Links:
[1] mailto:kanaev at ibrae.ac.ru
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140409/006ddefa/attachment.html>
