[MOAB-dev] write_file freezes on Cetus
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Mon Apr  7 19:45:43 CDT 2014
Hi Anton,
It worked for me on Vesta, even with your file, so it must be something with your build
this is how I configure moab on vesta, mira should be very similar.
You do not need mbcslam, or zoltan for your test (or pnetcdf)
../moab/configure CC=mpixlc CFLAGS=-qarch=qp CXX=mpixlcxx CXXFLAGS="-qarch=qp -qpic=large -qmaxmem=-1" FC=mpixlf90 FCFLAGS=-qarch=qp --prefix=/home/grindean/lib/moab --enable-optimize --disable-debug --with-mpi --build=ppc64-redhat-linux --host=powerpc64-bgq-linux --with-zlib=/soft/libraries/alcf/current/xl/ZLIB --with-hdf5=/soft/libraries/hdf5/current/cnk-xl/current --disable-shared --enable-static QTDIR=/usr/lib64/qt-3.3 build_alias=ppc64-redhat-linux host_alias=powerpc64-bgq-linux --with-pnetcdf=/soft/libraries/pnetcdf/current/cnk-xl/V1R2M0-20131217  --enable-mbcslam --with-zoltan=/home/grindean/3rdparty/lib/Zoltan_trilinos --with-netcdf=/soft/libraries/netcdf/4.3.0-f4.2/cnk-xl/current
All needed libraries are under /soft
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of kanaev at ibrae.ac.ru [kanaev at ibrae.ac.ru]
Sent: Sunday, April 06, 2014 10:57 AM
To: Vijay S. Mahadevan
Cc: MOAB dev
Subject: Re: [MOAB-dev] write_file freezes on Cetus
Hi Vijay,
The problem is still there and really seems to be about my mesh file. I've
tried to run ReduceExchangeTags with 64bricks_1khex.h5m
qsub -n 4 -t 00:30:00 -A ThermHydraX ReduceExchangeTags 64bricks_1khex.h5m
USERTAG 100
 and it works but then i tried it with my file
qsub -n 4 -t 00:30:00 -A ThermHydraX ReduceExchangeTags karmanp4.h5m
USERTAG 100
and it freezes on writing test.h5m
i've also tried
qsub -n 2 -t 00:30:00 -A ThermHydraX ReduceExchangeTags karmanp4.h5m
USERTAG 100
and it worked
What can be the problem? I've attached the mesh file i used - i made mesh
in Cubit, converted it to h5m with mbconvert and parted it with mbpart for
4 processors. My MOAB version is 4.7.0 and so are the tools mentioned
above. MOAB version installed on Mira is older.
Where can those bin tools from MOAB build be found on Mira filesystem?
Should i build a new version in my home folder?
Anton
On Fri, 4 Apr 2014 13:56:50 -0500, "Vijay S. Mahadevan" <vijay.m at gmail.com>
wrote:
>> I run [akanaev at cetuslac1 ~]$ qsub -n 4 -t 01:00:00 -A ThermHydraX
>> ReduceExchangeTags karmanp4.h5m USERTAG 100
>> It makes 7600 Bytes file test.h5m and freezes like this forever
> Can you verify if it works on other combinations of processors (2, 8
> etc) ? If the example still fails, please send over the input mesh
> file so that we can find out the actual issue.
> Vijay
> On Fri, Apr 4, 2014 at 1:34 PM,  <kanaev at ibrae.ac.ru> wrote:
>> Hello MOAB-dev,
>> I've tried to run one of your examples ReduceExchangeTags.cpp on Cetus
>> Makefile i used:
>> ZLIB_DIR=/soft/libraries/alcf/current/xl/ZLIB
>> HDF5_DIR=/soft/libraries/hdf5/current/cnk-xl/current
>> MOAB_DIR=/soft/applications/moab/4.6.0/cnk-xl/current
>> LDADD = -lMOAB -liMesh -lhdf5
>> LIBS =-lz
>> CXX = mpixlcxx
>> CXXFLAGS = -O0
>> LDFLAGS =  -L$(ZLIB_DIR)/lib  -L$(HDF5_DIR)/lib -L$(MOAB_DIR)/lib
>> INCLUDES=-I$(MOAB_DIR)/include
>> CXXCOMPILE = $(CXX) $(CXXFLAGS) $(INCLUDES)
>> ReduceExchangeTags: ReduceExchangeTags.o
>> @rm -f ReduceExchangeTags
>> $(CXXCOMPILE) ReduceExchangeTags.o -o ReduceExchangeTags $(LDFLAGS)
> $(LDADD)
>> $(LIBS)
>> ReduceExchangeTags.o: ReduceExchangeTags.cpp
>> $(CXXCOMPILE) -c ReduceExchangeTags.cpp
>> clean:
>> rm -rf *o ReduceExchangeTags
>> Please check what's wrong
>> Anton
