[MOAB-dev] commit/MOAB: iulian07: wrap up ncwriter prototype
    commits-noreply at bitbucket.org
    Mon Mar 31 00:18:12 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/8e78aa3cec40/
Changeset:   8e78aa3cec40
Branch:      ncwriter
User:        iulian07
Date:        2014-03-31 07:14:25
Summary:     wrap up ncwriter prototype
still left to do: transpose data for levels
the file written by the test does not have any attributes
they could be retrieved, though
also, need to use gather set for parallel
this test covers just CAM euler data
need to work more on unstructured mesh
Affected #:  2 files
diff --git a/src/io/WriteNC.cpp b/src/io/WriteNC.cpp
index 05fcc3f..0342da5 100644
--- a/src/io/WriteNC.cpp
+++ b/src/io/WriteNC.cpp
@@ -101,31 +101,19 @@ ErrorCode WriteNC::write_file(const char *file_name,
   success = NCFUNC(create)(file_name,  overwrite ? NC_CLOBBER : NC_NOCLOBBER, &fileId);
 #endif
   ERRORS(success, "failed to create file");
-  /* int nc_def_dim (int ncid, const char *name, size_t len, int *dimidp);
-   * example:  status = nc_def_dim(fileId, "lat", 18L, &latid);
-   * int nc_def_var (int ncid, const char *name, nc_type xtype,
-                     int ndims, const int dimids[], int *varidp);
-     example: http://www.unidata.ucar.edu/software/netcdf/docs/netcdf-c/nc_005fdef_005fvar.html#nc_005fdef_005fvar
-     * Write an Entire Variable: nc_put_var_ type (double, int)
-     * int nc_put_var_double(int ncid, int varid, const double *dp);
-   * Write an Array of Values: nc_put_vara_ type
-   * int nc_put_vara_double(int ncid, int varid, const size_t start[],
-                            const size_t count[], const double *dp);
   rval = collect_variable_data(var_names, tstep_nums, tstep_vals, *file_set);
   ERRORR(rval, "Trouble collecting data.");
+  rval = initialize_file(var_names);
+  ERRORR(rval, "failed to initialize file.");
+  rval = write_values( var_names, *file_set);
+  ERRORR(rval, "failed to write values ");
+  success =  NCFUNC(close)(fileId);
+  ERRORS(success, "failed to close file");
   return MB_SUCCESS;
@@ -390,6 +378,7 @@ ErrorCode WriteNC::process_conventional_tags(EntityHandle fileSet)
         if (vit==dimNames.end())
           ERRORR(MB_FAILURE, "dimension not found\n");
         variableDataStruct.varDims[j]= (int)(vit-dimNames.begin()) ; // will be used for writing
+        // this will have to change to actual file dimension, for writing
         // do we have a variable for each dimension? I mean, a tag?
         //dims[j] = &(get_dim(dim_name));
@@ -541,7 +530,7 @@ ErrorCode WriteNC::collect_variable_data( std::vector<std::string>& var_names, s
       // probably will have to look at tstep_vals to match them
       sizeVar *= dimLens[j];
       usedCoordinates.insert(dimName); // collect those used, we will need to write them to the file
-      dbgOut.tprintf(2, "    for variable %s need dimension %s with length %d\n", varname.c_str(), dimName.c_str(), dimLens[j] );
+      dbgOut.tprintf(2, "    for variable %s need dimension %s with length %d\n", varname.c_str(), dimName.c_str(), dimLens[ currentVarData.varDims[j] ] );
     currentVarData.sz=sizeVar;
@@ -562,6 +551,15 @@ ErrorCode WriteNC::collect_variable_data( std::vector<std::string>& var_names, s
         currentVarData.varTags.push_back(indexedTag);
         index++; // we should get out of the loop at some point
         // we will have to collect data for these tags; maybe even allocate memory again
+        // the type of the tag is fixed though
+        DataType type;
+        rval = mbImpl->tag_get_data_type(indexedTag, type);
+        ERRORR(rval, "can't get tag type");
+        currentVarData.varDataType = NC_DOUBLE;
+        if (type==MB_TYPE_INTEGER)
+          currentVarData.varDataType = NC_INT;
     else
@@ -584,7 +582,7 @@ ErrorCode WriteNC::collect_variable_data( std::vector<std::string>& var_names, s
   // check that for used coordinates we have found the tags
   for (std::set<std::string>::iterator setIt = usedCoordinates.begin(); setIt!=usedCoordinates.end(); setIt++)
-    std::string coordName=*setIt; // a deep copy ; is it needed?
+    std::string coordName=*setIt; // deep copy
     std::map<std::string, VarData>::iterator vit = varInfo.find(coordName);
     if (vit==varInfo.end())
@@ -602,6 +600,20 @@ ErrorCode WriteNC::collect_variable_data( std::vector<std::string>& var_names, s
     ERRORR(rval, "can't get coordinate values");
     dbgOut.tprintf(2, "    found coordinate tag with name %s and length %d\n", coordName.c_str(),
         sizeCoordinate);
+    // this is the length
+    varCoordData.sz = sizeCoordinate;
+    varCoordData.writeStarts.resize(1);
+    varCoordData.writeStarts[0]=0;
+    varCoordData.writeCounts.resize(1);
+    varCoordData.writeCounts[0]=sizeCoordinate;
+    // find the type of tag, and use it
+    DataType type;
+    rval = mbImpl->tag_get_data_type(coordtag, type);
+    varCoordData.varDataType = NC_DOUBLE;
+      varCoordData.varDataType = NC_INT;
     assert(varCoordData.memoryHogs.size()==0);// nothing so far
     varCoordData.memoryHogs.push_back((void*)data);
@@ -609,4 +621,193 @@ ErrorCode WriteNC::collect_variable_data( std::vector<std::string>& var_names, s
   return MB_SUCCESS;
+ErrorCode WriteNC::initialize_file( std::vector<std::string> & var_names)
+  // first initialize all coordinates, then fill VarData for actual variables (and dimensions)
+  // check that for used coordinates we have found the tags
+  for (std::set<std::string>::iterator setIt = usedCoordinates.begin(); setIt!=usedCoordinates.end(); setIt++)
+    std::map<std::string, VarData>::iterator vit = varInfo.find(coordName);
+    if (vit==varInfo.end())
+      ERRORR(MB_FAILURE, "can't find one coordinate variable");
+    VarData & varCoordData = vit->second;
+    varCoordData.varDims.resize(1);
+    /* int nc_def_dim (int ncid, const char *name, size_t len, int *dimidp);
+       * example:  status = nc_def_dim(fileId, "lat", 18L, &latid);
+    // actually define a dimension
+    if (NCFUNC(def_dim)(fileId, coordName.c_str() , (size_t)varCoordData.sz ,
+        &varCoordData.varDims[0]) != NC_NOERR)
+     ERRORR(MB_FAILURE, "failed to generate dimension");
+    dbgOut.tprintf(2, "    for coordName %s dim id is %d \n", coordName.c_str(), (int)varCoordData.varDims[0] );
+    // create a variable with the same name, and its only dimension the one we just defined
+     * int nc_def_var (int ncid, const char *name, nc_type xtype,
+                       int ndims, const int dimids[], int *varidp);
+       example: http://www.unidata.ucar.edu/software/netcdf/docs/netcdf-c/nc_005fdef_005fvar.html#nc_005fdef_005fvar
+    if (NCFUNC(def_var)(fileId, coordName.c_str(), varCoordData.varDataType,
+        1, &(varCoordData.varDims[0]), &varCoordData.varId) != NC_NOERR)
+      ERRORR(MB_FAILURE, "failed to create coordinate variable");
+    dbgOut.tprintf(2, "    for coordName %s variable id is %d \n", coordName.c_str(), varCoordData.varId );
+  // now look at requested variables, and update from the index in dimNames to the actual dimension id
+  for (size_t i=0; i<var_names.size(); i++)
+    std::map<std::string, VarData>::iterator vit = varInfo.find(var_names[i]);
+      ERRORR(MB_FAILURE, "can't find variable requested");
+    VarData & variableData = vit->second;
+    int numDims = (int) variableData.varDims.size();
+    // the index is for dimNames; we need to find out the actual dimension id (from above)
+    for (int j=0; j< numDims; j++)
+      std::string dimName = dimNames[variableData.varDims[j]];
+      std::map<std::string, VarData>::iterator vit2 = varInfo.find(dimName);
+      if (vit2==varInfo.end())
+        ERRORR(MB_FAILURE, "can't find coordinate variable requested");
+      VarData & coordData = vit2->second;
+      variableData.varDims[j] = coordData.varDims[0]; // this one, being a coordinate, is the only one
+      dbgOut.tprintf(2, "          dimension with index %d name %s has ID %d \n",
+          j, dimName.c_str(), variableData.varDims[j]);
+      variableData.writeStarts.push_back(0); // assume we will write all, so start at 0 for all dimensions
+      variableData.writeCounts.push_back(coordData.sz); // again, write all; times will be one at a time
+    // define the variable now :
+    if (NCFUNC(def_var)(fileId, var_names[i].c_str(), variableData.varDataType,
+            (int)variableData.varDims.size() , &(variableData.varDims[0]),
+            &variableData.varId) != NC_NOERR)
+    dbgOut.tprintf(2, "    for variable %s variable id is %d \n", var_names[i].c_str(), variableData.varId );
+    // now define the variable, with all dimensions
+  // take it out of define mode
+  if (NC_NOERR != NCFUNC(enddef)(fileId))
+    ERRORR(MB_FAILURE, "failed to close define mode");
+  return MB_SUCCESS;
+ErrorCode WriteNC::write_values(std::vector<std::string> & var_names, EntityHandle fileSet)
+  * Write an Array of Values: nc_put_vara_ type
+  * int nc_put_vara_double(int ncid, int varid, const size_t start[],
+                           const size_t count[], const double *dp);
+  // start with coordinates
+   int success =0;
+   switch (varCoordData.varDataType) {
+      case NC_DOUBLE:
+        success = NCFUNCAP(_vara_double)(fileId, varCoordData.varId,  &varCoordData.writeStarts[0],
+            &varCoordData.writeCounts[0], (double*) (varCoordData.memoryHogs[0])  );
+        ERRORS(success, "Failed to write double data.");
+        break;
+      case NC_INT:
+        success = NCFUNCAP(_vara_int)(fileId, varCoordData.varId,  &varCoordData.writeStarts[0],
+            &varCoordData.writeCounts[0], (int*) (varCoordData.memoryHogs[0]) );
+        ERRORS(success, "Failed to write int data.");
+        break;
+      default:
+        success = 1;
+        break;
+   // now look at requested var_names; if they have time, we will have a list, and write one at a time
+  // we may also need to gather, and transpose stuff
+  Range ents2d;
+  // get all entities of dimension 2 from set; assume now location is on cells;
+  // need to reorder stuff in the order from the file, also transpose from lev dimension
+  ErrorCode rval = mbImpl->get_entities_by_dimension(fileSet, 2, ents2d);
+  ERRORR(rval, "can't get entities for 2d");
+  // for each variabletag in the indexed lists, write a time step data
+  // assume the first dimension is time (need to check); if not, just write regularly
+    int numTimeSteps = (int)variableData.varTags.size();
+    if (variableData.has_tsteps)
+      variableData.writeCounts[0] = 1; // we will write one time step
+      for(int j=0; j<numTimeSteps; j++)
+        // we will write one time step, and count will be one; start will be different
+        // we will write values directly from tag_iterate, but we should also transpose for level
+        // so that means deep copy for transpose
+        //  FIXME !!!!!!!!!!!
+        variableData.writeStarts[0] = j; // this is time, again
+        int count;
+        void * dataptr;
+        rval = mbImpl->tag_iterate(variableData.varTags[j], ents2d.begin(), ents2d.end(), count, dataptr );
+        assert(count == ents2d.size());
+        // now write from memory directly   FIXME: we need to transpose and gather for multiple processors
+        int success = 0;
+        switch (variableData.varDataType)
+        case NC_DOUBLE:
+          success = NCFUNCAP(_vara_double)(fileId, variableData.varId,
+              &variableData.writeStarts[0], &variableData.writeCounts[0],
+              (double*) (dataptr));
+          break;
+        case NC_INT:
+          success =NCFUNCAP(_vara_int)(fileId, variableData.varId,
+              (int*) (dataptr));
+          break;
+        default:
+          success = 1;
+          break;
+    else
+      // FIXME
 } // end moab namespace
diff --git a/src/io/WriteNC.hpp b/src/io/WriteNC.hpp
index df89af1..b027bf6 100644
--- a/src/io/WriteNC.hpp
+++ b/src/io/WriteNC.hpp
@@ -42,6 +42,9 @@
 //! Collective I/O mode get
 #define NCFUNCAG(func) ncmpi_get ## func ## _all
+//! Collective I/O mode put
+#define NCFUNCAP(func) ncmpi_put ## func ## _all
 //! Independent I/O mode get
 #define NCFUNCG(func) ncmpi_get ## func
@@ -54,6 +57,7 @@
 #include "netcdf.h"
 #define NCFUNC(func) nc_ ## func
 #define NCFUNCAG(func) nc_get ## func
+#define NCFUNCAP(func) nc_put ## func
 #define NCFUNCG(func) nc_get ## func
 #define NCDF_SIZE size_t
 #define NCDF_DIFF ptrdiff_t
@@ -163,6 +167,13 @@ private:
   // for everybody
   ErrorCode collect_variable_data( std::vector<std::string>& var_names, std::vector<int>& tstep_nums,
       std::vector<double>& tstep_vals, EntityHandle fileSet);
+  // initialize file: this is where all defines are done
+  // the VarData dimension ids are filled up after define
+  ErrorCode initialize_file( std::vector<std::string> & var_names); // these are from options
+  // take the info from VarData and write first the coordinates, then the actual variables
+  ErrorCode write_values(std::vector<std::string> & var_names, EntityHandle fileSet);
     // interface instance
   Interface *mbImpl;
   WriteUtilIface* mWriteIface;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
