[MOAB-dev] DAGMC HDF5 Issues
Andrew Davis
davisa at engr.wisc.edu
Thu Mar 27 13:04:15 CDT 2014
Hi Paul, Vijay
I/We ran make check before our commit, but not the others.
Andy
On 03/27/2014 12:52 PM, Vijay S. Mahadevan wrote:
> Paul,
> I think we definitely need to enforce running: "make check", before
> all commits and I think it is fair to just perform the other tests
> before merging/approving a pull request. We run "make dist distcheck"
> in the buildbot tests daily and so our regular configurations should
> be tested nightly anyway.
> Vijay
> On Thu, Mar 27, 2014 at 12:48 PM, Paul Wilson <wilsonp at engr.wisc.edu> wrote:
>> Hi Andy,
>> I think I learned that we need to run more tests before we push:
>> make check
>> make dist
>> make distcheck
>> The last of these is important (and nominally a superset of the first 2) and
>> makes sure that tests pass from a tarball, not just from the repo.
>> Paul
>> On 03/27/2014 12:23 PM, Andrew Davis wrote:
>> HI Iulian
>> Just tried them thanks works great. Is there a source of documentation that
>> would have described the process to adding those things? I tried and failed
>> miserably at this end.
>> Andy
>> On 03/27/2014 12:14 PM, Grindeanu, Iulian R. wrote:
>> I think I fixed those, you should git pull and try.
>> (I modified dagmc/Makefile.am )
>> ________________________________
>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf
>> of Andrew Davis [davisa at engr.wisc.edu]
>> Sent: Thursday, March 27, 2014 11:50 AM
>> To: moab-dev at mcs.anl.gov
>> Subject: [MOAB-dev] DAGMC HDF5 Issues
>> Ive added the lines
>> dagmc/dagmc_rayfire_test \
>> dagmc/dagmc_simple_test \
>> dagmc/dagmc_pointinvol_test
>> (I also tried without the starting dagmc/)
>> to if HDF5_FILE in Makefile.am in /test/
>> I also added the h5m file we require MeshFiles/unittest/Makefile.am
>> I then build build without hdf5, and the test still run.
>> Could you please clarify that these are the correct locations for these
>> files
>> Thanks
>> Andy
>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
>> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
>> Faculty Director, Advanced Computing Infrastructure
