[MOAB-dev] buildbot failure in moab-netcdf: failed test
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Thu Mar 27 09:41:42 CDT 2014
Iuian, Does this need any changes in the test files to use MESHDIR variable
like in the others to abstract out the actual location of the mesh files ?
Paul, please verify if the latest merge passed all tests on your end for an
out-of-source build.
Vijay
On Thu, Mar 27, 2014 at 9:00 AM, Grindeanu, Iulian R. <iulian at mcs.anl.gov>wrote:
>  this particular error was caused by reliance on building with hdf5
> these tests, that load an hdf5 file, need to be launched only when
> building with hdf5
> Some of the configurations in buildbot test moab without hdf5
> (moab-netcdf, moab-bare) etc
> example is this
> if HDF5_FILE
>   TESTS += mbfacet_test \
>         gttool_test \
>         cropvol_test \
>         mergemesh_test \
>         mbground_test \
>         lloyd_smoother_test
> endif
> in test/Makefile.am
> distcheck fails because it is an out of source build, and the mesh files
> that are loaded need to be included in the distribution  (EXTRA_DIST
> variable in Makefile.am in mesh files directory)
> *From:* moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
> behalf of moab-dev at mcs.anl.gov [moab-dev at mcs.anl.gov]
> *Sent:* Thursday, March 27, 2014 1:08 AM
> *To:* moab-dev at mcs.anl.gov
> *Subject:* [MOAB-dev] buildbot failure in moab-netcdf: failed test
>   Fathom <http://gnep.mcs.anl.gov:8010/>: moab-netcdf<http://gnep.mcs.anl.gov:8010/builders/moab-netcdf>build
> #309 <http://gnep.mcs.anl.gov:8010/builders/moab-netcdf/builds/309>
> *Results:* failed test  *Buildslave:* gnep  *Revision:* None  *Reason:* The
> Nightly scheduler named 'moab-netcdf' triggered this build  Log Excerpt
> dagmc_pointinvol_test.cpp:39:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:39: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:51:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:51: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:59:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:59: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:81:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:81: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:103:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:103: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:125:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:125: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:147:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:147: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:169:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:169: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:191:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:191: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:221:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:221: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:251:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:251: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:281:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:281: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:311:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:311: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:341:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:341: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:371:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:371: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp:401:25: warning: integer constant is so large that it is unsigned
> dagmc_pointinvol_test.cpp:401: warning: this decimal constant is unsigned only in ISO C90
> dagmc_pointinvol_test.cpp: In function 'void dagmc_point_in()':
> dagmc_pointinvol_test.cpp:52: warning: unused variable 'rval'
> dagmc_pointinvol_test.cpp: In function 'void dagmc_setup_test()':
> dagmc_pointinvol_test.cpp:38: warning: 'vol' may be used uninitialized in this function
> mv -f .deps/dagmc_pointinvol_test-dagmc_pointinvol_test.Tpo .deps/dagmc_pointinvol_test-dagmc_pointinvol_test.Po
> /bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -lnetcdf -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc -lhdf5_hl -lhdf5 -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc -lz      -o dagmc_pointinvol_test dagmc_pointinvol_test-dagmc_pointinvol_test.o ../../src/libMOAB.la ../../tools/dagmc/DagMC.lo -lm
> libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o dagmc_pointinvol_test dagmc_pointinvol_test-dagmc_pointinvol_test.o ../../tools/dagmc/DagMC.o  -L/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc -L/usr/lib/mpich/lib/ -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /usr/lib/libhdf5_hl.so /usr/lib/libhdf5.so -lpthread -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdpart
>  ...make  check-TESTS
> make[4]: Entering directory `/disks/itaps-buildslave/moab-netcdf/build/test/dagmc'
> make[5]: Entering directory `/disks/itaps-buildslave/moab-
> ?[0;31mFAIL?[m: dagmc_simple_test
> ?[0;31mFAIL?[m: dagmc_rayfire_test
> ?[0;31mFAIL?[m: dagmc_pointinvol_test
> ?[0;31m=============================
> 3 of 3 tests failed
> See test/dagmc/test-suite.log
> ?[mmake[5]: *** [test-suite.log] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140327/47f62c35/attachment.html>
