[MOAB-dev] buildbot failure in moab-netcdf: failed test
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Thu Mar 27 09:00:43 CDT 2014
this particular error was caused by reliance on building with hdf5
these tests, that load an hdf5 file, need to be launched only when building with hdf5
Some of the configurations in buildbot test moab without hdf5
(moab-netcdf, moab-bare) etc
example is this
if HDF5_FILE
  TESTS += mbfacet_test \
        gttool_test \
        cropvol_test \
        mergemesh_test \
        mbground_test \
        lloyd_smoother_test
endif
in test/Makefile.am
distcheck fails because it is an out of source build, and the mesh files that are loaded need to be included in the distribution  (EXTRA_DIST variable in Makefile.am in mesh files directory)
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of moab-dev at mcs.anl.gov [moab-dev at mcs.anl.gov]
Sent: Thursday, March 27, 2014 1:08 AM
To: moab-dev at mcs.anl.gov
Subject: [MOAB-dev] buildbot failure in moab-netcdf: failed test
Fathom<http://gnep.mcs.anl.gov:8010/>: moab-netcdf<http://gnep.mcs.anl.gov:8010/builders/moab-netcdf> build #309<http://gnep.mcs.anl.gov:8010/builders/moab-netcdf/builds/309>
Results:        failed test
Buildslave:     gnep
Revision:       None
Reason: The Nightly scheduler named 'moab-netcdf' triggered this build
Log Excerpt
dagmc_pointinvol_test.cpp:39:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:39: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:51:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:51: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:59:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:59: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:81:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:81: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:103:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:103: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:125:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:125: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:147:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:147: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:169:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:169: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:191:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:191: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:221:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:221: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:251:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:251: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:281:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:281: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:311:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:311: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:341:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:341: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:371:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:371: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp:401:25: warning: integer constant is so large that it is unsigned
dagmc_pointinvol_test.cpp:401: warning: this decimal constant is unsigned only in ISO C90
dagmc_pointinvol_test.cpp: In function ‘void dagmc_point_in()’:
dagmc_pointinvol_test.cpp:52: warning: unused variable ‘rval’
dagmc_pointinvol_test.cpp: In function ‘void dagmc_setup_test()’:
dagmc_pointinvol_test.cpp:38: warning: ‘vol’ may be used uninitialized in this function
mv -f .deps/dagmc_pointinvol_test-dagmc_pointinvol_test.Tpo .deps/dagmc_pointinvol_test-dagmc_pointinvol_test.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -lnetcdf -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc -lhdf5_hl -lhdf5 -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc -lz      -o dagmc_pointinvol_test dagmc_pointinvol_test-dagmc_pointinvol_test.o ../../src/libMOAB.la ../../tools/dagmc/DagMC.lo -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o dagmc_pointinvol_test dagmc_pointinvol_test-dagmc_pointinvol_test.o ../../tools/dagmc/DagMC.o  -L/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc -L/usr/lib/mpich/lib/ -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /usr/lib/libhdf5_hl.so /usr/lib/libhdf5.so -lpthread -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdpart
 ...make  check-TESTS
make[4]: Entering directory `/disks/itaps-buildslave/moab-netcdf/build/test/dagmc'
make[5]: Entering directory `/disks/itaps-buildslave/moab-netcdf/build/test/dagmc'
?[0;31mFAIL?[m: dagmc_simple_test
?[0;31mFAIL?[m: dagmc_rayfire_test
?[0;31mFAIL?[m: dagmc_pointinvol_test
?[0;31m=============================
3 of 3 tests failed
See test/dagmc/test-suite.log
?[mmake[5]: *** [test-suite.log] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140327/36f09e5a/attachment-0001.html>
