[MOAB-dev] OCC CGM testing
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Mon Mar 24 10:48:53 CDT 2014
Hi Paul,
occ 653 was built on gnep.mcs.anl.gov. It is not built every night, as part of buildbot. gnep is at ubuntu 10.04, but I did built it on my laptop successfully, too, which is 12.04
Maybe I don't understand the question.
What kind of instructions? Maybe they are not up-to-date. Or the patch fails to be applied ?
Iulian
Sent: Monday, March 24, 2014 10:05 AM
To: Grindeanu, Iulian R.; Patrick Shriwise; MOAB-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] OCC CGM testing
Hi Iulian,
I was unsuccessful in following the instructions for building OCC653
with the provided patch. (Note: the instructions didn't work perfectly
either, but that's a different issue).
Can you provide the script or automated instructions that are used to
build this on buildbot?
Paul
On 03/21/2014 10:09 AM, Grindeanu, Iulian R. wrote:
> http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
> any build that contains occ in its name is built with occ653
> We actually test on cgm13.1 too, on buildbot
> http://gnep.mcs.anl.gov:8010/builders/cgm131-occ
> "trunk", "tr", "tru" means current cgm master repo (former trunk on svn)
> the others are with cgm branch cgm12.2
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Grindeanu, Iulian R. [iulian at mcs.anl.gov]
> Sent: Thursday, March 20, 2014 3:59 PM
> To: Patrick Shriwise; MOAB-dev at mcs.anl.gov
> occ 653 with cgm master, and occ 653 with cgm branch cgm12.2 (serial and parallel)
> we used to test with cgm13.1 branch, too, but it should be fine
> Iulian
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Patrick Shriwise [shriwise at wisc.edu]
> Sent: Thursday, March 20, 2014 1:52 PM
> To: MOAB-dev at mcs.anl.gov
> Subject: [MOAB-dev] OCC CGM testing
> Hi all,
> What version(s) of OCC and CGM are tested in the MOAB nightlies?
> Going to create a similar set of builds for testing on my local machine.
> Thanks!
> Patrick C. Shriwise
> Research Assistant
> University of Wisconsin - Madison
> Engineering Research Building - Rm. 428
> 1500 Engineering Drive
> Madison, WI 53706
> (608) 446-8173
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
