[MOAB-dev] OCC CGM testing
    Jiangtao Hu
    jiangtao_ma at yahoo.com
    Mon Mar 24 10:11:27 CDT 2014
Are you building occ653 following CGM ITAPS wiki site? Did patch command failed?
Jane
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called according to his purpose, all things are working together for good." (Romans 8:28)
On Monday, March 24, 2014 10:05 AM, Paul Wilson <wilsonp at engr.wisc.edu> wrote:
Hi Iulian,
I was unsuccessful in following the instructions for building OCC653
with the provided patch. (Note: the instructions didn't work perfectly
either, but that's a different issue).
Can you provide the script or automated instructions that are used to
build this on buildbot?
Paul
On 03/21/2014 10:09 AM, Grindeanu, Iulian R. wrote:
> http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
> any build that contains occ in its name is built with occ653
> We actually test on cgm13.1 too, on buildbot
> http://gnep.mcs.anl.gov:8010/builders/cgm131-occ
> "trunk", "tr", "tru" means current cgm master repo (former trunk on svn)
> the others are with cgm branch cgm12.2
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Grindeanu, Iulian R. [iulian at mcs.anl.gov]
> Sent: Thursday, March 20, 2014 3:59 PM
> To: Patrick Shriwise; MOAB-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] OCC CGM testing
> occ 653 with cgm master, and occ 653 with cgm branch cgm12.2 (serial and parallel)
> we used to test with cgm13.1 branch, too, but it should be fine
> Iulian
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Patrick Shriwise [shriwise at wisc.edu]
> Sent: Thursday, March 20, 2014 1:52 PM
> To: MOAB-dev at mcs.anl.gov
> Subject: [MOAB-dev] OCC CGM testing
> Hi all,
> What version(s) of OCC and CGM are tested in the MOAB nightlies?
> Going to create a similar set of builds for testing on my local machine.
> Thanks!
> Patrick C. Shriwise
> Research Assistant
> University of Wisconsin - Madison
> Engineering Research Building - Rm. 428
> 1500 Engineering Drive
> Madison, WI 53706
> (608) 446-8173
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140324/0c581b59/attachment.html>
