[MOAB-dev] get_entities_by_handle - entities do not include meshset entities
    MICHAEL CORTIS
    m.cortis.1 at research.gla.ac.uk
    Fri Mar 14 17:56:12 CDT 2014
Thanks Tim for you're assertion.
Was hoping to get all the meshsets too, recursively contained in the entity.
But its not a problem, I will work in another way,
in which I am not interested in the meshsets tree,
hence I can get all the entities and save them in a single meshset.
Thanks once again and
Kind regards
Michael
On 14 Mar 2014, at 20:44, Tim Tautges (ANL) <tautges at mcs.anl.gov> wrote:
> [cc'ing moab-dev because this might be of general interest...]
> Ok, yes, that is expected behavior.  The reasoning behind it is that if you're asking to recurse through contained sets,
> chances are you're interested in entities and not sets.  I can see where in some cases this might not be the case, but I
> would still assert that this isn't the more common case.
> Note that this behavior is noted in the documentation of the 'recursive' argument to that function, at least in the
> master version (but I'm guessing probably in 4.6 as well, since I don't recall that changing recently).
> - tim
> On 03/14/2014 01:08 PM, MICHAEL CORTIS wrote:
>> Tim,
>> I've create a simple example and discovered the following:
>> if use TRUE for recursive search, such as:
>> Range tempRange
>> rval = mb->get_entities_by_handle(*mit,tempRange,true);
>> then, the contained meshsets won't be listed in the range,
>> but if the recursive is FALSE,
>> I will get those meshset 1 level below listed in the range.
>> Why, when recursive search in all contained meshsets, these contained meshsets won't be listed in the range?
>> if you want the program, please let me know, and btw, I am using MOAB 4.6.
>> Kind regards
>> Michael
>> On 14 Mar 2014, at 15:03, "Tim Tautges (ANL)" <tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>> wrote:
>>> That's almost certainly not true.  Can you confirm this with a simple test?
>>> - tim
>>> On 03/14/2014 09:17 AM, MICHAEL CORTIS wrote:
>>>> Dear Tim,
>>>> I've noticed that when using get_entities_by_handle,
>>>> the range won't contained meshset entities which are in the handle.
>>>> Believe that one should remark in the documentation that only vertices/edges/tri/tet are retrieved,
>>>> if there is no plan to gather the meshset entities from a handle into the range/vector.
>>>> Kind regards
>>>> Michael
>>> "You will keep in perfect peace him whose mind is
>>>  steadfast, because he trusts in you."               Isaiah 26:3
>>>             Tim Tautges            Argonne National Laboratory
>>>         (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>)      (telecommuting from UW-Madison)
>>> phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>>>            fax: (608) 263-4499      Madison, WI 53706
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
