[MOAB-dev] commit/MOAB: danwu: Renamed a few member functions of NCHelper classes.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Fri Mar 14 17:53:37 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/601ac5fba7d4/
Changeset:   601ac5fba7d4
Branch:      error_handling_enhancement
User:        danwu
Date:        2014-03-14 23:53:13
Summary:     Renamed a few member functions of NCHelper classes.
Affected #:  6 files
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 85afdba..58e9e16 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -301,7 +301,7 @@ ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
   return MB_SUCCESS;
-ErrorCode NCHelper::read_variable_setup(std::vector<std::string>& var_names, std::vector<int>& tstep_nums,
+ErrorCode NCHelper::read_variables_setup(std::vector<std::string>& var_names, std::vector<int>& tstep_nums,
                                         std::vector<ReadNC::VarData>& vdatas, std::vector<ReadNC::VarData>& vsetdatas)
   std::map<std::string, ReadNC::VarData>& varInfo = _readNC->varInfo;
@@ -381,12 +381,12 @@ ErrorCode NCHelper::read_variable_setup(std::vector<std::string>& var_names, std
   return MB_SUCCESS;
-ErrorCode NCHelper::read_variable_to_set(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelper::read_variables_to_set(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
   Interface*& mbImpl = _readNC->mbImpl;
   DebugOutput& dbgOut = _readNC->dbgOut;
-  ErrorCode rval = read_variable_to_set_allocate(vdatas, tstep_nums); \
+  ErrorCode rval = read_variables_to_set_allocate(vdatas, tstep_nums); \
   CHK_ERR1(rval, "Trouble allocating space to read set variables");
   // Finally, read into that space
@@ -784,7 +784,7 @@ ErrorCode NCHelper::create_dummy_variables()
   return MB_SUCCESS;
-ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelper::read_variables_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
   std::vector<int>& dimLens = _readNC->dimLens;
@@ -1006,7 +1006,7 @@ ErrorCode ScdNCHelper::read_variables(std::vector<std::string>& var_names, std::
   std::vector<ReadNC::VarData> vdatas;
   std::vector<ReadNC::VarData> vsetdatas;
-  ErrorCode rval = read_variable_setup(var_names, tstep_nums, vdatas, vsetdatas); \
+  ErrorCode rval = read_variables_setup(var_names, tstep_nums, vdatas, vsetdatas); \
   CHK_ERR1(rval, "Trouble setting up read variable");
   // Create COORDS tag for quads
@@ -1014,12 +1014,12 @@ ErrorCode ScdNCHelper::read_variables(std::vector<std::string>& var_names, std::
   CHK_ERR1(rval, "Trouble creating coordinate tags to entities quads");
   if (!vsetdatas.empty()) {
-    rval = read_variable_to_set(vsetdatas, tstep_nums); \
+    rval = read_variables_to_set(vsetdatas, tstep_nums); \
     CHK_ERR1(rval, "Trouble read variables to set");
   if (!vdatas.empty()) {
-    rval = read_scd_variable_to_nonset(vdatas, tstep_nums);
+    rval = read_scd_variables_to_nonset(vdatas, tstep_nums);
     if (MB_SUCCESS != rval)
       SET_ERR(rval, "Trouble reading variables to entities verts/edges/faces");
@@ -1027,7 +1027,7 @@ ErrorCode ScdNCHelper::read_variables(std::vector<std::string>& var_names, std::
   return MB_SUCCESS;
-ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode ScdNCHelper::read_scd_variables_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -1149,11 +1149,11 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(std::vector<ReadNC::
   return rval;
-ErrorCode ScdNCHelper::read_scd_variable_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode ScdNCHelper::read_scd_variables_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
-  ErrorCode rval = read_scd_variable_to_nonset_allocate(vdatas, tstep_nums); \
+  ErrorCode rval = read_scd_variables_to_nonset_allocate(vdatas, tstep_nums); \
   CHK_ERR1(rval, "Trouble allocating space to read non-set variables");
@@ -1340,22 +1340,22 @@ ErrorCode UcdNCHelper::read_variables(std::vector<std::string>& var_names, std::
   CHK_ERR1(rval, "Trouble setting up to read variables");
     CHK_ERR1(rval, "Trouble reading variables to set");
 #ifdef PNETCDF_FILE
     // With pnetcdf support, we will use async read
-    rval = read_ucd_variable_to_nonset_async(vdatas, tstep_nums); \
+    rval = read_ucd_variables_to_nonset_async(vdatas, tstep_nums); \
     CHK_ERR1(rval, "Trouble reading variables to entities verts/edges/faces");
 #else
     // Without pnetcdf support, we will use old read
-    rval = read_ucd_variable_to_nonset(vdatas, tstep_nums); \
+    rval = read_ucd_variables_to_nonset(vdatas, tstep_nums); \
 #endif
diff --git a/src/io/NCHelper.hpp b/src/io/NCHelper.hpp
index 817257c..25103a3 100644
--- a/src/io/NCHelper.hpp
+++ b/src/io/NCHelper.hpp
@@ -37,15 +37,15 @@ public:
 protected:
   //! Separate set and non-set variables (common to scd mesh and ucd mesh)
-  ErrorCode read_variable_setup(std::vector<std::string>& var_names,
+  ErrorCode read_variables_setup(std::vector<std::string>& var_names,
                                             std::vector<ReadNC::VarData>& vsetdatas);
   //! Read set variables (common to scd mesh and ucd mesh)
-  ErrorCode read_variable_to_set(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums);
+  ErrorCode read_variables_to_set(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums);
-  //! Convert variables in place
+  //! Convert a variable in place
   ErrorCode convert_variable(ReadNC::VarData& var_data, int tstep_num);
   ErrorCode read_coordinate(const char* var_name, int lmin, int lmax,
@@ -69,8 +69,8 @@ protected:
   ErrorCode create_dummy_variables();
 private:
-  //! Used by read_variable_to_set()
-  ErrorCode read_variable_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums);
+  //! Used by read_variables_to_set()
+  ErrorCode read_variables_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums);
 protected:
   //! Allow NCHelper to directly access members of ReadNC
@@ -126,9 +126,9 @@ private:
   virtual ErrorCode read_variables(std::vector<std::string>& var_names, std::vector<int>& tstep_nums);
   //! Read non-set variables for scd mesh
-  ErrorCode read_scd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas,
+  ErrorCode read_scd_variables_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas,
-  ErrorCode read_scd_variable_to_nonset(std::vector<ReadNC::VarData>& vdatas,
+  ErrorCode read_scd_variables_to_nonset(std::vector<ReadNC::VarData>& vdatas,
   //! Create COORDS tag for quads coordinate
@@ -194,13 +194,13 @@ private:
                                    std::vector<int> &tstep_nums);
   //! Read non-set variables for ucd mesh (implemented differently in child classes)
-  virtual ErrorCode read_ucd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas,
+  virtual ErrorCode read_ucd_variables_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas,
                                                          std::vector<int>& tstep_nums) = 0;
 #ifdef PNETCDF_FILE
-  virtual ErrorCode read_ucd_variable_to_nonset_async(std::vector<ReadNC::VarData>& vdatas,
+  virtual ErrorCode read_ucd_variables_to_nonset_async(std::vector<ReadNC::VarData>& vdatas,
 #else
-  virtual ErrorCode read_ucd_variable_to_nonset(std::vector<ReadNC::VarData>& vdatas,
+  virtual ErrorCode read_ucd_variables_to_nonset(std::vector<ReadNC::VarData>& vdatas,
 #endif
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index 53fa9ad..b2dea5e 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -551,7 +551,7 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
   return MB_SUCCESS;
-ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -634,11 +634,11 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC
 #ifdef PNETCDF_FILE
-ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_async(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset_async(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
-  ErrorCode rval = read_ucd_variable_to_nonset_allocate(vdatas, tstep_nums);
+  ErrorCode rval = read_ucd_variables_to_nonset_allocate(vdatas, tstep_nums);
   ERRORR(rval, "Trouble allocating read variables.");
@@ -796,11 +796,11 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_async(std::vector<ReadNC::V
   return rval;
 #else
-ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperHOMME::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
diff --git a/src/io/NCHelperHOMME.hpp b/src/io/NCHelperHOMME.hpp
index a6d50f0..4c383bb 100644
--- a/src/io/NCHelperHOMME.hpp
+++ b/src/io/NCHelperHOMME.hpp
@@ -30,16 +30,16 @@ private:
   //! Implementation of NCHelper::get_mesh_type_name()
   virtual std::string get_mesh_type_name() { return "CAM_SE"; }
-  //! Implementation of UcdNCHelper::read_ucd_variable_to_nonset_allocate()
+  //! Implementation of UcdNCHelper::read_ucd_variables_to_nonset_allocate()
 #ifdef PNETCDF_FILE
-  //! Implementation of UcdNCHelper::read_ucd_variable_to_nonset_async()
+  //! Implementation of UcdNCHelper::read_ucd_variables_to_nonset_async()
 #else
-  //! Implementation of UcdNCHelper::read_ucd_variable_to_nonset()
+  //! Implementation of UcdNCHelper::read_ucd_variables_to_nonset()
 #endif
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 9c70b80..58093e3 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -509,7 +509,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   return MB_SUCCESS;
-ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -646,13 +646,13 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC:
 #ifdef PNETCDF_FILE
-ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_async(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_async(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
   bool& noEdges = _readNC->noEdges;
@@ -803,13 +803,13 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_async(std::vector<ReadNC::Va
   return rval;
 #else
-ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
+ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
diff --git a/src/io/NCHelperMPAS.hpp b/src/io/NCHelperMPAS.hpp
index 6c6dc99..b4a3c01 100644
--- a/src/io/NCHelperMPAS.hpp
+++ b/src/io/NCHelperMPAS.hpp
   virtual std::string get_mesh_type_name() { return "MPAS"; }
 #ifdef PNETCDF_FILE
 #else
 #endif
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
