[MOAB-dev] commit/MOAB: danwu: Updated macro-based error handling	interface.
    commits-noreply at bitbucket.org
    Thu Mar 13 15:13:54 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/fcc05cd64a00/
Changeset:   fcc05cd64a00
Branch:      error_handling_enhancement
User:        danwu
Date:        2014-03-13 21:13:08
Summary:     Updated macro-based error handling interface.
Affected #:  1 file
diff --git a/src/moab/ErrorHandler.hpp b/src/moab/ErrorHandler.hpp
index 42c1758..2adc868 100644
--- a/src/moab/ErrorHandler.hpp
+++ b/src/moab/ErrorHandler.hpp
@@ -120,121 +120,186 @@ ErrorCode MBError(int line, const char* func, const char* file, const char* dir,
 #endif
 #ifdef USE_ERROR_INFO_CLASS
+//! Set a new error with passed error code and passed error message string
 #define SET_ERR(err_code, err_msg) \
   return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, ErrorInfo(err_code, err_msg), MB_ERROR_TYPE_NEW_LOCAL)
-#define SET_ERR1(err_info) \
-  return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_info, MB_ERROR_TYPE_NEW_LOCAL)
+//! Set a new error with passed error code and passed error message string stream
 #define SET_ERR_STR(err_code, err_msg_str) \
-  ErrorInfo err_info; \
-  err_info << err_msg_str; \
+  do { \
+    ErrorInfo err_info(err_code); \
+    err_info << err_msg_str; \
+    return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_info, MB_ERROR_TYPE_NEW_LOCAL); \
+  } while (false)
+//! Set a new global error with passed error code and passed error message string
 #define SET_GLB_ERR(err_code, err_msg) \
   return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, ErrorInfo(err_code, err_msg), MB_ERROR_TYPE_NEW_GLOBAL)
-#define SET_GLB_ERR1(err_info) \
-  return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_info, MB_ERROR_TYPE_NEW_GLOBAL)
+//! Set a new global error with passed error code and passed error message string stream
 #define SET_GLB_ERR_STR(err_code, err_msg_str) \
+  do { \
+    return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_info, MB_ERROR_TYPE_NEW_GLOBAL); \
+  } while (false)
+//! Check returned error code against MB_SUCCESS
 #define CHK_ERR(err_info) \
   do { \
     if (MB_SUCCESS != err_info) \
       return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_info, MB_ERROR_TYPE_EXISTING); \
   } while (false)
+//! Set a new error with the returned error code and passed error message string
 #define CHK_ERR1(err_info, err_msg_to_set) \
   do { \
     if (MB_SUCCESS != err_info) { \
-      err_info.set_error_msg(err_msg_to_set); \
-      SET_ERR(err_info); \
+      ErrorCode err_code = err_info.get_error_code(); \
+      SET_ERR(err_code, err_msg_to_set); \
   } while (false)
-#define CHK_ERR2(err_info, err_code_to_set, err_msg_to_set) \
+//! Set a new error with the returned error code and passed error message string stream
+#define CHK_ERR1_STR(err_info, err_msg_str_to_set) \
   do { \
-      err_info.set_error_code(err_code_to_set); \
+      SET_ERR_STR(err_code, err_msg_str_to_set); \
   } while (false)
+#define CHK_ERR2(err_info, err_code_to_set, err_msg_to_set) \
+  do { \
+    if (MB_SUCCESS != err_info) \
+      SET_ERR(err_code_to_set, err_msg_to_set); \
+  } while (false)
+#define CHK_ERR2_STR(err_info, err_code_to_set, err_msg_str_to_set) \
+  do { \
+      SET_ERR_STR(err_code_to_set, err_msg_str_to_set); \
+  } while (false)
+//! Check returned error code against an expected one
+//! Set a new error with default error code and default error message string
 #define CHK_EQL(err_info, exp_err_code) \
   do { \
-    if (exp_err_code != err_info) { \
-      err_info.set_error_code(MB_FAILURE); \
-      err_info.set_error_msg("Returned error code is not expected"); \
+    if (exp_err_code != err_info) \
+      SET_ERR(MB_FAILURE, "Returned error code is not expected"); \
   } while (false)
+//! Set a new error with default error code and passed error message string
 #define CHK_EQL1(err_info, exp_err_code, err_msg_to_set) \
   do { \
+      SET_ERR(MB_FAILURE, err_msg_to_set); \
+  } while (false)
+//! Set a new error with default error code and passed error message string stream
+#define CHK_EQL1_STR(err_info, exp_err_code, err_msg_str_to_set) \
+  do { \
+      SET_ERR_STR(MB_FAILURE, err_msg_str_to_set); \
   } while (false)
 #define CHK_EQL2(err_info, exp_err_code, err_code_to_set, err_msg_to_set) \
   do { \
+  } while (false)
+#define CHK_EQL2_STR(err_info, exp_err_code, err_code_to_set, err_msg_str_to_set) \
+  do { \
   } while (false)
 #else
   return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_code, err_msg, MB_ERROR_TYPE_NEW_LOCAL)
-  std::ostringstream ostr; \
-  ostr << err_msg_str; \
-  return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_code, ostr.str().c_str(), MB_ERROR_TYPE_NEW_LOCAL)
+  do { \
+    std::ostringstream ostr; \
+    ostr << err_msg_str; \
+    return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_code, ostr.str().c_str(), MB_ERROR_TYPE_NEW_LOCAL); \
+  } while (false)
   return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_code, err_msg, MB_ERROR_TYPE_NEW_GLOBAL)
-  return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_code, ostr.str().c_str(), MB_ERROR_TYPE_NEW_GLOBAL)
+  do { \
+    return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_code, ostr.str().c_str(), MB_ERROR_TYPE_NEW_GLOBAL); \
+  } while (false)
 #define CHK_ERR(err_code) \
   do { \
     if (MB_SUCCESS != err_code) \
       return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_code, "", MB_ERROR_TYPE_EXISTING); \
   } while (false)
 #define CHK_ERR1(err_code, err_msg_to_set) \
   do { \
-    if (MB_SUCCESS != err_code) { \
+    if (MB_SUCCESS != err_code) \
   } while (false)
+#define CHK_ERR1_STR(err_code, err_msg_str_to_set) \
+  do { \
+  } while (false)
 #define CHK_ERR2(err_code, err_code_to_set, err_msg_to_set) \
   do { \
   } while (false)
+#define CHK_ERR2_STR(err_code, err_code_to_set, err_msg_str_to_set) \
+  do { \
+  } while (false)
 #define CHK_EQL(err_code, exp_err_code) \
   do { \
-    if (exp_err_code != err_code) { \
+    if (exp_err_code != err_code) \
   } while (false)
 #define CHK_EQL1(err_code, exp_err_code, err_msg_to_set) \
   do { \
@@ -242,11 +307,28 @@ ErrorCode MBError(int line, const char* func, const char* file, const char* dir,
   } while (false)
+#define CHK_EQL1_STR(err_code, exp_err_code, err_msg_str_to_set) \
+  do { \
+  } while (false)
 #define CHK_EQL2(err_code, exp_err_code, err_code_to_set, err_msg_to_set) \
   do { \
+  } while (false)
+#define CHK_EQL2_STR(err_code, exp_err_code, err_code_to_set, err_msg_str_to_set) \
+  do { \
   } while (false)
 #endif
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
