[MOAB-dev] commit/MOAB: iulian07: enable mbcslam should work in serial builds too
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Wed Mar 12 21:55:00 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/6694ba1ab8f8/
Changeset:   6694ba1ab8f8
Branch:      master
User:        iulian07
Date:        2014-03-13 03:52:37
Summary:     enable mbcslam should work in serial builds too
the parallel tests are disabled, and USE_MPI define is
used as a guard for parallel specific code
some rearranging was needed
Affected #:  4 files
diff --git a/tools/mbcslam/Intx2Mesh.cpp b/tools/mbcslam/Intx2Mesh.cpp
index e055beb..b17cc33 100644
--- a/tools/mbcslam/Intx2Mesh.cpp
+++ b/tools/mbcslam/Intx2Mesh.cpp
@@ -5,8 +5,9 @@
 #include "Intx2Mesh.hpp"
-//#include "Coupler.hpp"
+#ifdef USE_MPI
 #include "moab/ParallelComm.hpp"
+#endif /* USE_MPI */
 #include "moab/AdaptiveKDTree.hpp"
 #include "MBParallelConventions.h"
 #include "MBTagConventions.hpp"
@@ -18,7 +19,10 @@
 namespace moab {
-Intx2Mesh::Intx2Mesh(Interface * mbimpl): mb(mbimpl), parcomm(NULL), remote_cells(NULL)
+Intx2Mesh::Intx2Mesh(Interface * mbimpl): mb(mbimpl)
+#ifdef USE_MPI
+   , parcomm(NULL), remote_cells(NULL)
+#endif
   dbg_1=0;
   box_error=0;
@@ -33,11 +37,13 @@ Intx2Mesh::Intx2Mesh(Interface * mbimpl): mb(mbimpl), parcomm(NULL), remote_cell
 Intx2Mesh::~Intx2Mesh()
   // TODO Auto-generated destructor stub
+#ifdef USE_MPI
   if (remote_cells)
     delete remote_cells;
     remote_cells=NULL;
+#endif
 void Intx2Mesh::createTags()
@@ -404,11 +410,13 @@ ErrorCode Intx2Mesh::intersect_meshes(EntityHandle mbset1, EntityHandle mbset2,
   // before cleaning up , we need to settle the position of the intersection points
   // on the boundary edges
   // this needs to be collective, so we should maybe wait something
+#ifdef USE_MPI
   rval = correct_intersection_points_positions();
   if (rval!=MB_SUCCESS)
     std::cout << "can't correct position, Intx2Mesh.cpp \n";
+#endif
   clean();
   return MB_SUCCESS;
@@ -438,7 +446,38 @@ void Intx2Mesh::clean()
   localEnts.clear();*/
+// this method will reduce number of nodes, collapse edges that are of length 0
+  // so a polygon like 428 431 431 will become a line 428 431
+  // or something like 428 431 431 531 -> 428 431 531
+void Intx2Mesh::correct_polygon(EntityHandle * nodes, int & nP)
+  int i = 0;
+  while(i<nP)
+    int nextIndex = (i+1)%nP;
+    if (nodes[i]==nodes[nextIndex])
+      // we need to reduce nP, and collapse nodes
+      if (dbg_1)
+        std::cout<<" nodes duplicated in list: " ;
+        for (int j=0; j<nP; j++)
+          std::cout<<nodes[j] << " " ;
+        std::cout<<"\n";
+        std::cout<<" node " << nodes[i] << " at index " << i << " is duplicated" << "\n";
+      // this will work even if we start from 1 2 3 1; when i is 3, we find nextIndex is 0, then next thing does nothing
+      //  (nP-1 is 3, so k is already >= nP-1); it will result in nodes -> 1, 2, 3
+      for (int k=i; k<nP-1; k++)
+        nodes[k] = nodes[k+1];
+      nP--; // decrease the number of nodes; also, decrease i, just if we may need to check again
+      i--;
+    i++;
+  return;
+#if USE_MPI
 ErrorCode Intx2Mesh::build_processor_euler_boxes(EntityHandle euler_set, Range & local_verts)
   localEnts.clear();
@@ -1119,37 +1158,6 @@ ErrorCode Intx2Mesh::create_departure_mesh_3rd_alg(EntityHandle & lagr_set,
   return MB_SUCCESS;
   //end copy
-// this method will reduce number of nodes, collapse edges that are of length 0
-  // so a polygon like 428 431 431 will become a line 428 431
-  // or something like 428 431 431 531 -> 428 431 531
-void Intx2Mesh::correct_polygon(EntityHandle * nodes, int & nP)
-  int i = 0;
-  while(i<nP)
-    int nextIndex = (i+1)%nP;
-    if (nodes[i]==nodes[nextIndex])
-      // we need to reduce nP, and collapse nodes
-      if (dbg_1)
-        std::cout<<" nodes duplicated in list: " ;
-        for (int j=0; j<nP; j++)
-          std::cout<<nodes[j] << " " ;
-        std::cout<<"\n";
-        std::cout<<" node " << nodes[i] << " at index " << i << " is duplicated" << "\n";
-      // this will work even if we start from 1 2 3 1; when i is 3, we find nextIndex is 0, then next thing does nothing
-      //  (nP-1 is 3, so k is already >= nP-1); it will result in nodes -> 1, 2, 3
-      for (int k=i; k<nP-1; k++)
-        nodes[k] = nodes[k+1];
-      nP--; // decrease the number of nodes; also, decrease i, just if we may need to check again
-      i--;
-    i++;
-  return;
 ErrorCode Intx2Mesh::correct_intersection_points_positions()
@@ -1169,4 +1177,5 @@ ErrorCode Intx2Mesh::correct_intersection_points_positions()
   return MB_SUCCESS;
 } /* namespace moab */
diff --git a/tools/mbcslam/Intx2Mesh.hpp b/tools/mbcslam/Intx2Mesh.hpp
index d54b0b5..528ab7e 100644
--- a/tools/mbcslam/Intx2Mesh.hpp
+++ b/tools/mbcslam/Intx2Mesh.hpp
@@ -32,9 +32,11 @@ namespace moab {
 #define ERRORV(rval, str) \
     if (MB_SUCCESS != rval) {std::cout << str << "\n"; return ;}
+#ifdef USE_MPI
 // forward declarations
 class ParallelComm;
 class TupleList;
+#endif
 class Intx2Mesh
@@ -93,9 +95,9 @@ public:
   ErrorCode build_processor_euler_boxes(EntityHandle euler_set, Range & local_verts);
   void correct_polygon(EntityHandle * foundIds, int & nP);
+#ifdef USE_MPI
   ErrorCode correct_intersection_points_positions();
+#endif
   void enable_debug()  {dbg_1 = 1;}
   void disable_debug() {dbg_1 = 0;}
 protected: // so it can be accessed in derived classes, InPlane and OnSphere
@@ -141,20 +143,21 @@ protected: // so it can be accessed in derived classes, InPlane and OnSphere
   double epsilon_1;
   double epsilon_area;
-  ParallelComm * parcomm;
   std::vector<double> allBoxes;
   double box_error;
   /* \brief Local root of the kdtree */
   EntityHandle localRoot;
   Range localEnts;// this range is for local elements of interest, euler cells
   unsigned int my_rank;
-  int max_edges; // maximum number of edges in the euler set
+#ifdef USE_MPI
+  ParallelComm * parcomm;
   TupleList * remote_cells;
   std::map<int, EntityHandle> globalID_to_eh;// needed for parallel, mostly
+#endif
+  int max_edges; // maximum number of edges in the euler set
diff --git a/tools/mbcslam/Intx2MeshOnSphere.cpp b/tools/mbcslam/Intx2MeshOnSphere.cpp
index ac33e91..5b7a88a 100644
--- a/tools/mbcslam/Intx2MeshOnSphere.cpp
+++ b/tools/mbcslam/Intx2MeshOnSphere.cpp
@@ -7,8 +7,10 @@
 #include "Intx2MeshOnSphere.hpp"
 #include "moab/GeomUtil.hpp"
-#include "moab/ParallelComm.hpp"
 #include <queue>
+#ifdef USE_MPI
+#include "moab/ParallelComm.hpp"
+#endif
 namespace moab {
@@ -481,6 +483,7 @@ ErrorCode Intx2MeshOnSphere::update_tracer_data(EntityHandle out_set, Tag & tagE
     rval = mb->tag_get_data(corrTag, &blue, 1, &redArr);
     if (0==redArr || MB_TAG_NOT_FOUND==rval)
+#ifdef USE_MPI
       if (!remote_cells)
         ERRORR( MB_FAILURE, "no remote cells, failure\n");
       // maybe the element is remote, from another processor
@@ -492,6 +495,7 @@ ErrorCode Intx2MeshOnSphere::update_tracer_data(EntityHandle out_set, Tag & tagE
       if (index_in_remote==-1)
         ERRORR( MB_FAILURE, "can't find the global id element in remote cells\n");
       remote_cells->vr_wr[index_in_remote] += currentVals[redIndex]*areap;
+#endif
     else if (MB_SUCCESS==rval)
@@ -506,6 +510,7 @@ ErrorCode Intx2MeshOnSphere::update_tracer_data(EntityHandle out_set, Tag & tagE
   // now, send back the remote_cells to the processors they came from, with the updated values for
   // the tracer mass in a cell
+#ifdef USE_MPI
   if (remote_cells)
     // so this means that some cells will be sent back with tracer info to the procs they were sent from
@@ -522,7 +527,7 @@ ErrorCode Intx2MeshOnSphere::update_tracer_data(EntityHandle out_set, Tag & tagE
       newValues[arrRedIndex] += remote_cells->vr_rd[j];
   // now divide by red area (current)
   int j=0;
   Range::iterator iter = rs2.begin();
@@ -543,6 +548,8 @@ ErrorCode Intx2MeshOnSphere::update_tracer_data(EntityHandle out_set, Tag & tagE
   rval = mb->tag_set_data(tagElem, rs2, &newValues[0]);
   ERRORR(rval, "can't set new values tag");
+#ifdef USE_MPI
   double total_mass=0.;
   double total_intx_area =0;
   int mpi_err = MPI_Reduce(&total_mass_local, &total_mass, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD);
@@ -553,7 +560,7 @@ ErrorCode Intx2MeshOnSphere::update_tracer_data(EntityHandle out_set, Tag & tagE
   if (my_rank==0)
     std::cout <<"total mass now:" << total_mass << "\n";
-    std::cout <<"check: total intersection area: (4 * M_PI * R^2): " << total_intx_area << "\n";
+    std::cout <<"check: total intersection area: (4 * M_PI * R^2): " << 4 * M_PI * R*R << " " << total_intx_area << "\n";
   if (remote_cells)
@@ -561,6 +568,10 @@ ErrorCode Intx2MeshOnSphere::update_tracer_data(EntityHandle out_set, Tag & tagE
     remote_cells=NULL;
+#else
+  std::cout <<"total mass now:" << total_mass_local << "\n";
+  std::cout <<"check: total intersection area: (4 * M_PI * R^2): "  << 4 * M_PI * R*R << " " << check_intx_area << "\n";
+#endif
   return MB_SUCCESS;
diff --git a/tools/mbcslam/Makefile.am b/tools/mbcslam/Makefile.am
index 0dac164..ffc3dff 100644
--- a/tools/mbcslam/Makefile.am
+++ b/tools/mbcslam/Makefile.am
@@ -24,7 +24,11 @@ LDADD = libmbcslam.la  $(top_builddir)/src/libMOAB.la
 libmbcslam_la_SOURCES = \
    Intx2Mesh.cpp Intx2Mesh.hpp Intx2MeshOnSphere.cpp Intx2MeshOnSphere.hpp \
-     CslamUtils.cpp CslamUtils.hpp Intx2MeshInPlane.cpp Intx2MeshInPlane.hpp wrap_intx.cpp
+     CslamUtils.cpp CslamUtils.hpp Intx2MeshInPlane.cpp Intx2MeshInPlane.hpp
+if PARALLEL
+    libmbcslam_la_SOURCES += wrap_intx.cpp
+endif
 # these will be installed
 libmbcslam_la_include_HEADERS =
@@ -38,24 +42,36 @@ libmbcslam_la_includedir = $(includedir)
 cfgdir = $(libdir)
 TESTS = intx_on_sphere_test  intx_in_plane_test spherical_area_test \
-         case1_test  intx_mpas
-noinst_PROGRAMS =  cslam_par_test diffusion proj1 intx_imesh create_dp advection
+         case1_test
+if PARALLEL
+     TESTS+=intx_mpas
+endif
+noinst_PROGRAMS =  proj1 create_dp
+if PARALLEL
+  noinst_PROGRAMS +=cslam_par_test diffusion  intx_imesh advection
+endif
 check_PROGRAMS = $(TESTS)
 intx_on_sphere_test_SOURCES = intx_on_sphere_test.cpp
-diffusion_SOURCES = diffusion.cpp
 intx_in_plane_test_SOURCES = intx_in_plane_test.cpp
 # spec_visu_test_SOURCES = spec_visu_test.cpp
 spherical_area_test_SOURCES = spherical_area_test.cpp
 case1_test_SOURCES = case1_test.cpp
-intx_mpas_SOURCES = intx_mpas.cpp
-cslam_par_test_SOURCES = cslam_par_test.cpp
 proj1_SOURCES = proj1.cpp
-intx_imesh_SOURCES = intx_imesh.cpp
-intx_imesh_LDADD = $(LDADD) $(top_builddir)/itaps/imesh/libiMesh.la
 create_dp_SOURCES = create_dp.cpp
-advection_SOURCES = advection.F90
-advection_LDADD = $(LDADD) $(top_builddir)/itaps/imesh/libiMesh.la
+if PARALLEL
+  diffusion_SOURCES = diffusion.cpp
+  intx_imesh_SOURCES = intx_imesh.cpp
+  intx_imesh_LDADD = $(LDADD) $(top_builddir)/itaps/imesh/libiMesh.la
+  cslam_par_test_SOURCES = cslam_par_test.cpp
+  intx_mpas_SOURCES = intx_mpas.cpp
+  advection_SOURCES = advection.F90
+  advection_LDADD = $(LDADD) $(top_builddir)/itaps/imesh/libiMesh.la
+endif
 EXTRA_DIST  = lagrangeHomme.vtk  \
               eulerHomme.vtk \
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
