[MOAB-dev] commit/MOAB: iulian07: add a crystal router example
Tim Tautges (ANL) tautges at mcs.anl.gov
Tue Feb 18 17:51:09 CST 2014
We could really use something in the dev manual describing this and TupleList in depth.  I've done this verbally many
times, and there are several things that are important to why TupleList is such a good thing, and a few times when it
isn't.  I'll put that on my list of things to document.
- tim
On 02/17/2014 11:34 AM, Vijay S. Mahadevan wrote:
> Good job Iulian. This was a much needed example.
> If you were also able to test with different Intel compiler versions
> and replicate the bug we were facing in this context, that would be a
> useful unit test case.
> Vijay
> On Mon, Feb 17, 2014 at 11:22 AM,  <commits-noreply at bitbucket.org> wrote:
>> 1 new commit in MOAB:
>> https://bitbucket.org/fathomteam/moab/commits/b2e3b2514782/
>> Changeset:   b2e3b2514782
>> Branch:      master
>> User:        iulian07
>> Date:        2014-02-17 18:15:48
>> Summary:     add a crystal router example
>> crystal router is one of the building blocks of parallel
>> infrastructure in MOAB, so in my opinion, it deserves
>> an example.
>> In this example, it is shown how to gather-scatter homogeneous
>> data between processors, with one call. It is assumed that the
>> communication matrix is relatively sparse, and this is the case
>> for most applications.
>> Affected #:  2 files
>> diff --git a/examples/CrystalRouterExample.cpp b/examples/CrystalRouterExample.cpp
>> new file mode 100644
>> index 0000000..200f012
>> --- /dev/null
>> +++ b/examples/CrystalRouterExample.cpp
>> @@ -0,0 +1,130 @@
>> + * This example will show one of the building blocks of parallel infrastructure in MOAB
>> + * More exactly, if we have some homogeneous data to communicate from each processor to a list of other
>> + * processors, how do we do it?
>> + * introduce the TupleList and crystal router to MOAB users.
>> + * This technology is used in resolving shared vertices / sets between partitions
>> + * It is used in the mbcoupler for sending data (target points) to the proper processor, and communicate
>> + *   back the results.
>> + * Also, it is used to communicate departure mesh for intersection in parallel
>> + *  It is a way of doing  MPI_gatheralltoallv(), when the communication matrix is sparse
>> + *  It is assumed that every proc needs to communicate only with a few of the other processors.
>> + *  If every processor needs to communicate with all other, then we will have to use paired isend and irecv, the
>> + *  communication matrix is full
>> + *  the example needs to be launched in parallel.
>> + *  Every proc will build a list of tuples, that will be send to a few procs;
>> + *  every proc will send 1 tuple, to proc rank + 1 and rank + rank*(size-1)+2 , with value
>> + *    10000 * send + 100* rank
>> + *  at the receive, we verify we received
>> + *    10000 * rank + 100 * from
>> + *    For some reportrank we also print the tuples.
>> + *  after routing, we will see if we received, as expected. Should run on at least 2 processors.
>> + * Note: We do not need a moab instance for this example
>> +/** @example CrystalRouterExample.cpp \n
>> + * \brief generalized gather scatter using tuples \n
>> + * <b>To run</b>: mpiexec -np <n> CrystalRouterExample [reportrank] \n
>> +#include "moab/ProcConfig.hpp"
>> +#include "moab/TupleList.hpp"
>> +#include <iostream>
>> +using namespace moab;
>> +using namespace std;
>> +int main(int argc, char **argv)
>> +  MPI_Init(&argc, &argv);
>> +  int reportrank = 1;
>> +  if (argc>1)
>> +    reportrank = atoi(argv[1]);
>> +  ProcConfig pc(MPI_COMM_WORLD);
>> +  int size = pc.proc_size();
>> +  int rank = pc.proc_rank();
>> +  if (reportrank==rank)
>> +    std::cout << " there are " << size << " procs in example\n";
>> +  // send some data from proc i to i+n/2, also to i +n/2+1 modulo n, wher en is num procs
>> +  gs_data::crystal_data *cd = pc.crystal_router();
>> +  TupleList tl;
>> +  // at most 100 to send
>> +  // we do a preallocate with this; some tuples on some processors might need more memory, to be able
>> +  // to grow locally; 100 is a very large number for this example, considering that each task sends only
>> +  // 2 tuples. Some tasks might receive more tuples though, and in the process, some might grow more than
>> +  // others. By doing these logP sends/receives, we do not grow local memory too much.
>> +  tl.initialize(1, 1, 0, 1, 100);
>> +  tl.enableWriteAccess();
>> +  // form 2 tuples, send to rank+1 and rank+2 (mod size)
>> +  unsigned int n = tl.get_n();
>> +  int sendTo = rank+1;
>> +  sendTo = sendTo%size;
>> +  long intToSend = 100*rank + 10000*sendTo;
>> +  tl.vi_wr[n]= sendTo;
>> +  tl.vl_wr[n]= intToSend;
>> +  tl.vr_wr[n]= 100.*rank;
>> +  tl.inc_n();
>> +  n = tl.get_n();
>> +  sendTo = rank+(rank+1)*rank+2;// just some number relatively different from rank
>> +  intToSend = 100*rank + 10000*sendTo;
>> +  tl.vr_wr[n]= 1000.*rank;
>> +  tl.inc_n();
>> +    std::cout << "rank " << rank << "\n";
>> +    tl.print(" before sending");
>> +  // all communication happens here:
>> +  ErrorCode rval = cd->gs_transfer(1,tl,0);
>> +  if (MB_SUCCESS!= rval)
>> +    std::cout << "error in tuple transfer\n";
>> +    tl.print(" after transfer");
>> +  // check that all tuples received have the form 10000* rank + 100*from
>> +  unsigned int received = tl.get_n();
>> +  for (int i=0; i<received; i++)
>> +    int from = tl.vi_rd[i];
>> +    long valrec = tl.vl_rd[i];
>> +    int remainder = valrec -10000*rank -100*from;
>> +    if (remainder != 0 )
>> +      std::cout << " error: tuple " << i << " received at proc rank " << rank << " from proc " << from << " has value " <<
>> +         valrec << " remainder " <<  remainder << "\n";
>> +  MPI_Finalize();
>> +  return 0;
>> diff --git a/examples/makefile b/examples/makefile
>> index 8a84899..3692b26 100644
>> --- a/examples/makefile
>> +++ b/examples/makefile
>> @@ -8,7 +8,7 @@ include ${MOAB_DIR}/lib/iMesh-Defs.inc
>>   MESH_DIR="../MeshFiles/unittest"
>>   EXAMPLES = HelloMOAB GetEntities SetsNTags structuredmesh StructuredMeshSimple DirectAccessWithHoles DirectAccessNoHoles point_in_elem_search DeformMeshRemap
>> -PAREXAMPLES = HelloParMOAB ReduceExchangeTags LloydRelaxation
>> +PAREXAMPLES = HelloParMOAB ReduceExchangeTags LloydRelaxation CrystalRouterExample
>>   EXOIIEXAMPLES = TestExodusII
>>   F90EXAMPLES = DirectAccessNoHolesF90 PushParMeshIntoMoabF90
>> @@ -47,6 +47,9 @@ ReduceExchangeTags : ReduceExchangeTags.o ${MOAB_LIBDIR}/libMOAB.la
>>   HelloParMOAB: HelloParMOAB.o ${MOAB_LIBDIR}/libMOAB.la
>>          ${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
>> +CrystalRouterExample: CrystalRouterExample.o  ${MOAB_LIBDIR}/libMOAB.la
>> +       ${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
>>   TestExodusII: TestExodusII.o ${MOAB_LIBDIR}/libMOAB.la
>> Repository URL: https://bitbucket.org/fathomteam/moab/
>> This is a commit notification from bitbucket.org. You are receiving
>> this because you have the service enabled, addressing the recipient of
>> this email.
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
