Good job Iulian. This was a much needed example.
If you were also able to test with different Intel compiler versions
and replicate the bug we were facing in this context, that would be a
useful unit test case.
Vijay
On Mon, Feb 17, 2014 at 11:22 AM, <commits-noreply at bitbucket.org> wrote:
> 1 new commit in MOAB:
> https://bitbucket.org/fathomteam/moab/commits/b2e3b2514782/
> Changeset: b2e3b2514782
> Branch: master
> User: iulian07
> Date: 2014-02-17 18:15:48
> Summary: add a crystal router example
> crystal router is one of the building blocks of parallel
> infrastructure in MOAB, so in my opinion, it deserves
> an example.
> In this example, it is shown how to gather-scatter homogeneous
> data between processors, with one call. It is assumed that the
> communication matrix is relatively sparse, and this is the case
> for most applications.
> Affected #: 2 files
> diff --git a/examples/CrystalRouterExample.cpp b/examples/CrystalRouterExample.cpp
> new file mode 100644
> index 0000000..200f012
> --- /dev/null
> +++ b/examples/CrystalRouterExample.cpp
> @@ -0,0 +1,130 @@
> + * This example will show one of the building blocks of parallel infrastructure in MOAB
> + * More exactly, if we have some homogeneous data to communicate from each processor to a list of other
> + * processors, how do we do it?
> + * introduce the TupleList and crystal router to MOAB users.
> + * This technology is used in resolving shared vertices / sets between partitions
> + * It is used in the mbcoupler for sending data (target points) to the proper processor, and communicate
> + * back the results.
> + * Also, it is used to communicate departure mesh for intersection in parallel
> + * It is a way of doing MPI_gatheralltoallv(), when the communication matrix is sparse
> + * It is assumed that every proc needs to communicate only with a few of the other processors.
> + * If every processor needs to communicate with all other, then we will have to use paired isend and irecv, the
> + * communication matrix is full
> + * the example needs to be launched in parallel.
> + * Every proc will build a list of tuples, that will be send to a few procs;
> + * every proc will send 1 tuple, to proc rank + 1 and rank + rank*(size-1)+2 , with value
> + * 10000 * send + 100* rank
> + * at the receive, we verify we received
> + * 10000 * rank + 100 * from
> + * For some reportrank we also print the tuples.
> + * after routing, we will see if we received, as expected. Should run on at least 2 processors.
> + * Note: We do not need a moab instance for this example
> +/** @example CrystalRouterExample.cpp \n
> + * \brief generalized gather scatter using tuples \n
> + * <b>To run</b>: mpiexec -np <n> CrystalRouterExample [reportrank] \n
> +#include "moab/ProcConfig.hpp"
> +#include "moab/TupleList.hpp"
> +#include <iostream>
> +using namespace moab;
> +using namespace std;
> +int main(int argc, char **argv)
> + MPI_Init(&argc, &argv);
> + int reportrank = 1;
> + if (argc>1)
> + reportrank = atoi(argv[1]);
> + ProcConfig pc(MPI_COMM_WORLD);
> + int size = pc.proc_size();
> + int rank = pc.proc_rank();
> + if (reportrank==rank)
> + std::cout << " there are " << size << " procs in example\n";
> + // send some data from proc i to i+n/2, also to i +n/2+1 modulo n, wher en is num procs
> + gs_data::crystal_data *cd = pc.crystal_router();
> + TupleList tl;
> + // at most 100 to send
> + // we do a preallocate with this; some tuples on some processors might need more memory, to be able
> + // to grow locally; 100 is a very large number for this example, considering that each task sends only
> + // 2 tuples. Some tasks might receive more tuples though, and in the process, some might grow more than
> + // others. By doing these logP sends/receives, we do not grow local memory too much.
> + tl.initialize(1, 1, 0, 1, 100);
> + tl.enableWriteAccess();
> + // form 2 tuples, send to rank+1 and rank+2 (mod size)
> + unsigned int n = tl.get_n();
> + int sendTo = rank+1;
> + sendTo = sendTo%size;
> + long intToSend = 100*rank + 10000*sendTo;
> + tl.vi_wr[n]= sendTo;
> + tl.vl_wr[n]= intToSend;
> + tl.vr_wr[n]= 100.*rank;
> + tl.inc_n();
> + n = tl.get_n();
> + sendTo = rank+(rank+1)*rank+2;// just some number relatively different from rank
> + intToSend = 100*rank + 10000*sendTo;
> + tl.vr_wr[n]= 1000.*rank;
> + tl.inc_n();
> + std::cout << "rank " << rank << "\n";
> + tl.print(" before sending");
> + // all communication happens here:
> + ErrorCode rval = cd->gs_transfer(1,tl,0);
> + if (MB_SUCCESS!= rval)
> + std::cout << "error in tuple transfer\n";
> + tl.print(" after transfer");
> + // check that all tuples received have the form 10000* rank + 100*from
> + unsigned int received = tl.get_n();
> + for (int i=0; i<received; i++)
> + int from = tl.vi_rd[i];
> + long valrec = tl.vl_rd[i];
> + int remainder = valrec -10000*rank -100*from;
> + if (remainder != 0 )
> + std::cout << " error: tuple " << i << " received at proc rank " << rank << " from proc " << from << " has value " <<
> + valrec << " remainder " << remainder << "\n";
> + MPI_Finalize();
> + return 0;
> diff --git a/examples/makefile b/examples/makefile
> index 8a84899..3692b26 100644
> --- a/examples/makefile
> +++ b/examples/makefile
> @@ -8,7 +8,7 @@ include ${MOAB_DIR}/lib/iMesh-Defs.inc
> MESH_DIR="../MeshFiles/unittest"
> EXAMPLES = HelloMOAB GetEntities SetsNTags structuredmesh StructuredMeshSimple DirectAccessWithHoles DirectAccessNoHoles point_in_elem_search DeformMeshRemap
> -PAREXAMPLES = HelloParMOAB ReduceExchangeTags LloydRelaxation
> +PAREXAMPLES = HelloParMOAB ReduceExchangeTags LloydRelaxation CrystalRouterExample
> EXOIIEXAMPLES = TestExodusII
> F90EXAMPLES = DirectAccessNoHolesF90 PushParMeshIntoMoabF90
> @@ -47,6 +47,9 @@ ReduceExchangeTags : ReduceExchangeTags.o ${MOAB_LIBDIR}/libMOAB.la
> HelloParMOAB: HelloParMOAB.o ${MOAB_LIBDIR}/libMOAB.la
> ${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
> +CrystalRouterExample: CrystalRouterExample.o ${MOAB_LIBDIR}/libMOAB.la
> + ${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
> TestExodusII: TestExodusII.o ${MOAB_LIBDIR}/libMOAB.la
> Repository URL: https://bitbucket.org/fathomteam/moab/
> This is a commit notification from bitbucket.org. You are receiving
> this because you have the service enabled, addressing the recipient of
> this email.
