[MOAB-dev] commit/MOAB: 3 new changesets
    commits-noreply at bitbucket.org
    Mon Feb  3 16:18:59 CST 2014
3 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/3569b60c9bf1/
Changeset:   3569b60c9bf1
Branch:      None
User:        vijaysm
Date:        2014-01-11 07:46:55
Summary:     Merged fathomteam/moab into master
Affected #:  7 files
diff --git a/config/compiler.m4 b/config/compiler.m4
index ce83a5f..4787100 100644
--- a/config/compiler.m4
+++ b/config/compiler.m4
@@ -548,6 +548,8 @@ case "$cc_compiler:$host_cpu" in
       bgq)
         FATHOM_CC_32BIT=-q32
         FATHOM_CC_64BIT=-q64
+	FATHOM_CC_SPECIAL=-qarch=qp
+	FATHOM_CXX_SPECIAL="-qarch=qp -qpic=large -qmaxmem=-1"
         AR="ar"
         NM="nm -B"
diff --git a/src/SpatialLocator.cpp b/src/SpatialLocator.cpp
index f765ab9..36016c1 100644
--- a/src/SpatialLocator.cpp
+++ b/src/SpatialLocator.cpp
@@ -72,7 +72,7 @@ namespace moab
       locTable.enableWriteAccess();
         // pass storage directly into locate_points, since we know those arrays are contiguous
-      ErrorCode rval = locate_points(pos, num_points, locTable.vul_wr, locTable.vr_wr, NULL, rel_iter_tol, abs_iter_tol,
+      ErrorCode rval = locate_points(pos, num_points, (EntityHandle*)locTable.vul_wr, locTable.vr_wr, NULL, rel_iter_tol, abs_iter_tol,
                                      inside_tol);
       std::fill(locTable.vi_wr, locTable.vi_wr+num_points, 0);
       locTable.set_n(num_points);
diff --git a/tools/mbcslam/CslamUtils.cpp b/tools/mbcslam/CslamUtils.cpp
index e806d61..43668a6 100644
--- a/tools/mbcslam/CslamUtils.cpp
+++ b/tools/mbcslam/CslamUtils.cpp
@@ -906,16 +906,34 @@ void velocity_case1(CartVect & arrival_point, double t, CartVect & velo)
 ErrorCode enforce_convexity(Interface * mb, EntityHandle lset, int my_rank)
-  // look at each quad; compute all 4 angles; if one is reflex, break along that diagonal
+  // look at each polygon; compute all angles; if one is reflex, break that angle with
+  // the next triangle; put the 2 new polys in the set;
+  // still look at the next poly
   // replace it with 2 triangles, and remove from set;
   // it should work for all polygons / tested first for case 1, with dt 0.5 (too much deformation)
   // get all entities of dimension 2
   // then get the connectivity, etc
   Range inputRange;
   ErrorCode rval = mb->get_entities_by_dimension(lset, 2, inputRange);
   if (MB_SUCCESS != rval)
     return rval;
+  Tag corrTag=0;
+  EntityHandle dumH=0;
+  rval = mb->tag_get_handle(CORRTAGNAME,
+           1, MB_TYPE_HANDLE, corrTag,
+           MB_TAG_DENSE, &dumH);
+  if(rval==MB_TAG_NOT_FOUND)
+    corrTag = 0;
+  Tag gidTag;
+  rval = mb->tag_get_handle("GLOBAL_ID", 1, MB_TYPE_INTEGER,
+        gidTag, MB_TAG_DENSE);
+  if(rval!=MB_SUCCESS)
+    return rval;
   std::vector<double> coords;
   coords.resize(3*MAXEDGES); // at most 10 vertices per polygon
   // we should create a queue with new polygons that need processing for reflex angles
@@ -942,6 +960,17 @@ ErrorCode enforce_convexity(Interface * mb, EntityHandle lset, int my_rank)
     rval = mb->get_connectivity(eh, verts, num_nodes);
       return rval;
+    EntityHandle corrHandle=0;
+    if (corrTag)
+      rval = mb->tag_get_data(corrTag, &eh, 1, &corrHandle);
+      if (MB_SUCCESS != rval)
+        return rval;
+    int gid=0;
+    rval = mb->tag_get_data(gidTag, &eh, 1, &gid);
+      return rval;
     coords.resize(3 * num_nodes);
     if (num_nodes < 4)
       continue; // if already triangles, don't bother
@@ -998,6 +1027,15 @@ ErrorCode enforce_convexity(Interface * mb, EntityHandle lset, int my_rank)
         rval = mb->add_entities(lset, &newElement, 1);
           return rval;
+        if (corrTag)
+          rval = mb->tag_set_data(corrTag, &newElement, 1, &corrHandle);
+            return rval;
+        rval = mb->tag_set_data(gidTag, &newElement, 1, &gid);
+          return rval;
         if (num_nodes == 4)
           // create another triangle
@@ -1017,6 +1055,15 @@ ErrorCode enforce_convexity(Interface * mb, EntityHandle lset, int my_rank)
           return rval;
+        if (corrTag)
+            return rval;
+           return rval;
         mb->remove_entities(lset, &eh, 1);
         brokenPolys++;
         /*std::cout<<"remove: " ;
@@ -1029,7 +1076,7 @@ ErrorCode enforce_convexity(Interface * mb, EntityHandle lset, int my_rank)
-  std::cout << "on rank " << my_rank << " " <<  brokenPolys << " concave polygons were decomposed in convex ones \n";
+  std::cout << "on local process " << my_rank << " " <<  brokenPolys << " concave polygons were decomposed in convex ones \n";
   return MB_SUCCESS;
 ErrorCode create_span_quads(Interface * mb, EntityHandle euler_set, int rank)
diff --git a/tools/mbcslam/Intx2Mesh.cpp b/tools/mbcslam/Intx2Mesh.cpp
index 625a442..99d7ca3 100644
--- a/tools/mbcslam/Intx2Mesh.cpp
+++ b/tools/mbcslam/Intx2Mesh.cpp
@@ -800,6 +800,12 @@ ErrorCode Intx2Mesh::create_departure_mesh_2nd_alg(EntityHandle & euler_set, Ent
       ERRORR(rval, "can't set global id tag on new el");
+  // order the remote cells tuple list, with the global id, because we will search in it
+  //remote_cells->print("remote_cells before sorting");
+  moab::TupleList::buffer sort_buffer;
+  sort_buffer.buffer_init(n);
+  remote_cells->sort(1, &sort_buffer);
+  sort_buffer.reset();
   return MB_SUCCESS;
diff --git a/tools/mbcslam/create_dp.cpp b/tools/mbcslam/create_dp.cpp
index bd2459b..43e1735 100644
--- a/tools/mbcslam/create_dp.cpp
+++ b/tools/mbcslam/create_dp.cpp
@@ -185,10 +185,11 @@ int main(int argc, char **argv)
   if (argc < 3)
-    std::cout << " usage: create_dp <input><output> -t <time>  -dt <delta_t> -h \n";
+    std::cout << " usage: create_dp <input><output> -t <time>  -dt <delta_t> [-skipdp] -f <field> -h \n";
     return 1;
+  bool skip= false;
   double dt=0.1;
   double t=0.1; // corresponding to diffusion first step
@@ -208,9 +209,18 @@ int main(int argc, char **argv)
     if (!strcmp(argv[index], "-h"))
       return 1;
+    if (!strcmp(argv[index], "-f")) // delete partition sets
+      field_type = atoi(argv[++index]);
+    if (!strcmp(argv[index], "-skipdp") )
+      skip = true;
     index++;
@@ -224,43 +234,50 @@ int main(int argc, char **argv)
   std::cout  << " -t " << t <<  " -dt " << dt << " input: " << input_mesh1 <<
       "  output: " << output << "\n";
-  Range verts;
-  rval = mb.get_entities_by_dimension(0, 0, verts);
-  if (MB_SUCCESS != rval)
-    return 1;
-  double *x_ptr, *y_ptr, *z_ptr;
-  int count;
-  rval = mb.coords_iterate(verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count);
+  // skip if we need for DP (already existing)
+  if (skip)
+    std::cout<<" do not add DP tag \n";
+  else
+    Range verts;
+    rval = mb.get_entities_by_dimension(0, 0, verts);
       return 1;
-  assert(count == (int) verts.size()); // should end up with just one contiguous chunk of vertices
-  Tag tagh = 0;
-  std::string tag_name("DP");
-  rval = mb.tag_get_handle(tag_name.c_str(), 3, MB_TYPE_DOUBLE, tagh, MB_TAG_DENSE | MB_TAG_CREAT);
-  CHECK_ERR(rval);
-  void *data; // pointer to the LOC in memory, for each vertex
-  int count_tag;
+    double *x_ptr, *y_ptr, *z_ptr;
+    int count;
+    rval = mb.coords_iterate(verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count);
+        return 1;
+    assert(count == (int) verts.size()); // should end up with just one contiguous chunk of vertices
-  rval = mb.tag_iterate(tagh, verts.begin(), verts.end(), count_tag, data);
-  CHECK_ERR(rval);
-  // here we are checking contiguity
-  assert(count_tag == (int) verts.size());
-  double * ptr_DP=(double*)data;
+    Tag tagh = 0;
+    std::string tag_name("DP");
+    rval = mb.tag_get_handle(tag_name.c_str(), 3, MB_TYPE_DOUBLE, tagh, MB_TAG_DENSE | MB_TAG_CREAT);
+    CHECK_ERR(rval);
+    void *data; // pointer to the LOC in memory, for each vertex
+    int count_tag;
-  for (int v = 0; v < count; v++) {
-     //EntityHandle v = verts[v];
-     CartVect pos( x_ptr[v], y_ptr[v] , z_ptr[v]);
-     CartVect newPos;
-     departure_point_case1(pos, t, dt, newPos);
-     ptr_DP[0]=newPos[0];
-     ptr_DP[1]=newPos[1];
-     ptr_DP[2]=newPos[2];
-     ptr_DP+=3; // increment to the next vertex
+    rval = mb.tag_iterate(tagh, verts.begin(), verts.end(), count_tag, data);
+    CHECK_ERR(rval);
+    // here we are checking contiguity
+    assert(count_tag == (int) verts.size());
+    double * ptr_DP=(double*)data;
+    for (int v = 0; v < count; v++) {
+       //EntityHandle v = verts[v];
+       CartVect pos( x_ptr[v], y_ptr[v] , z_ptr[v]);
+       CartVect newPos;
+       departure_point_case1(pos, t, dt, newPos);
+       ptr_DP[0]=newPos[0];
+       ptr_DP[1]=newPos[1];
+       ptr_DP[2]=newPos[2];
+       ptr_DP+=3; // increment to the next vertex
   rval = add_field_value(mb);
   mb.write_file(output);
diff --git a/tools/mbcslam/intx_mpas.cpp b/tools/mbcslam/intx_mpas.cpp
index 570c97f..d737156 100644
--- a/tools/mbcslam/intx_mpas.cpp
+++ b/tools/mbcslam/intx_mpas.cpp
@@ -216,7 +216,7 @@ int main(int argc, char **argv)
   if (Verbose)
     std::stringstream lagrIni;
-    lagrIni<<"def0" << rank<<".h5m";
+    lagrIni<<"lagr0" << rank<<".h5m";
     rval = mb.write_file(lagrIni.str().c_str(), 0, 0, &covering_lagr_set, 1);
@@ -226,7 +226,7 @@ int main(int argc, char **argv)
   if (Verbose)
     std::stringstream ste;
-    ste<<"lagr0" << rank<<".h5m";
+    ste<<"euler0" << rank<<".h5m";
     rval = mb.write_file(ste.str().c_str(), 0, 0, &euler_set, 1);
diff --git a/tools/mbcslam/wrap_intx.cpp b/tools/mbcslam/wrap_intx.cpp
index b973acf..878a832 100644
--- a/tools/mbcslam/wrap_intx.cpp
+++ b/tools/mbcslam/wrap_intx.cpp
@@ -17,7 +17,7 @@
 using namespace moab;
 double radius = 1.;
 double gtol = 1.e-9;
-bool debug = false;
+bool debug = true;
 #ifdef __cplusplus
 extern "C" {
@@ -52,6 +52,10 @@ void update_tracer( iMesh_Instance instance, iBase_EntitySetHandle imesh_euler_s
     ERRORV(rval , "can't write covering set ");
+  rval = enforce_convexity(mb, covering_lagr_set);
+  ERRORV(rval , "can't write covering set ");
   EntityHandle outputSet;
   rval = mb->create_meshset(MESHSET_SET, outputSet);
   ERRORV(rval , "can't create output set ");
https://bitbucket.org/fathomteam/moab/commits/963a275cea8b/
Changeset:   963a275cea8b
Branch:      None
User:        vijaysm
Date:        2014-02-03 23:11:59
Summary:     Use the fortran linker for fortran examples.
Affected #:  1 file
diff --git a/examples/makefile b/examples/makefile
index a6e3d1f..6c1ed9a 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -36,7 +36,7 @@ DirectAccessNoHoles: DirectAccessNoHoles.o ${MOAB_LIBDIR}/libMOAB.la
 	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
 DirectAccessNoHolesF90: DirectAccessNoHolesF90.o ${MOAB_LIBDIR}/libMOAB.la
-	${MOAB_CXX} -o $@ $< ${IMESH_LIBS}
+	${MOAB_FC} -o $@ $< ${IMESH_LIBS}
 ReduceExchangeTags : ReduceExchangeTags.o ${MOAB_LIBDIR}/libMOAB.la
@@ -51,7 +51,7 @@ point_in_elem_search: point_in_elem_search.o ${MOAB_LIBDIR}/libMOAB.la
 PushParMeshIntoMoabF90: PushParMeshIntoMoabF90.o
-	${MOAB_CXX} -o $@ $< ${IMESH_LIBS} -lgfortran -L/usr/lib/openmpi/lib -lmpi_f90 -lmpi_f77 -lmpi -lopen-rte -lopen-pal -ldl
 DeformMeshRemap: DeformMeshRemap.o ${MOAB_LIBDIR}/libMOAB.la
 	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK} -lmbcoupler ${MOAB_LIBS_LINK}
https://bitbucket.org/fathomteam/moab/commits/be8a392b1845/
Changeset:   be8a392b1845
Branch:      master
User:        vijaysm
Date:        2014-02-03 23:13:58
Summary:     Merge remote-tracking branch 'upstream/master'
Affected #:  2 files
diff --git a/tools/mbcslam/diffusion.cpp b/tools/mbcslam/diffusion.cpp
index 378473e..be70cd6 100644
--- a/tools/mbcslam/diffusion.cpp
+++ b/tools/mbcslam/diffusion.cpp
@@ -397,17 +397,28 @@ ErrorCode compute_tracer_case1(Interface * mb, Intx2MeshOnSphere & worker, Entit
   // if in parallel, we have to move some elements to another proc, and receive other cells
   // from other procs
   // lagr and euler are preserved
+  if (writeFiles) // so if need to write lagr files too
   EntityHandle covering_set;
   rval = worker.create_departure_mesh_3rd_alg(lagr_set, covering_set);
   if (writeFiles) // so if write
+    std::stringstream departureMesh;
+    departureMesh << "Departure" << rank << "_" << tStep << ".vtk";
+    rval = mb->write_file(departureMesh.str().c_str(), 0, 0, &lagr_set, 1);
+    CHECK_ERR(rval);
     std::stringstream newTracer;
     newTracer << "Tracer" << rank << "_" << tStep << ".vtk";
     rval = mb->write_file(newTracer.str().c_str(), 0, 0, &euler_set, 1);
+    CHECK_ERR(rval);
     std::stringstream lagr_cover;
     lagr_cover << "Cover" << rank << "_" << tStep << ".vtk";
     rval = mb->write_file(lagr_cover.str().c_str(), 0, 0, &covering_set, 1);
+    CHECK_ERR(rval);
   // so we have now the departure at the previous time
index d737156..b3d49d9 100644
@@ -22,6 +22,7 @@
 #include "moab/ParallelComm.hpp"
 #include "CslamUtils.hpp"
+#include <time.h>
 #ifdef MESHDIR
 std::string TestDir( STRINGIFY(MESHDIR) );
@@ -43,6 +44,7 @@ double radius = 1.;// in m:  6371220.
 double t = 0.1, delta_t = 0.05; // check the script
 bool Verbose = false;
+double rot= M_PI/10;
 ErrorCode manufacture_lagrange_mesh_on_sphere(Interface * mb,
     EntityHandle euler_set)
@@ -84,7 +86,7 @@ ErrorCode manufacture_lagrange_mesh_on_sphere(Interface * mb,
   //int vix=0; // vertex index in new array
   double T=5;// check the script
-  double rot= M_PI/10;
   for (Range::iterator vit=connecVerts.begin();vit!=connecVerts.end(); vit++ )
     EntityHandle oldV=*vit;
@@ -152,12 +154,23 @@ int main(int argc, char **argv)
       if (!strcmp(argv[index], "-FF"))
         flux_form= true;
-        index++;
       if (!strcmp(argv[index], "-v"))
         Verbose = true;
-        index++;
+      if (!strcmp(argv[index], "-t"))
+        t = atof(argv[++index]);
+      if (!strcmp(argv[index], "-rot"))
+        rot = atof(argv[++index]);
+        rot = M_PI/rot; // so rot 50 means rotate with M_PI/50 radians
       index++;
@@ -165,7 +178,7 @@ int main(int argc, char **argv)
   // start copy
   std::string opts = std::string("PARALLEL=READ_PART;PARTITION_METHOD=RCBZOLTAN")+
-            std::string(";PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=;")+extra_read_opts;
+            std::string(";PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=;NO_EDGES;")+extra_read_opts;
   Core moab;
   Interface & mb = moab;
   EntityHandle euler_set;
@@ -173,20 +186,30 @@ int main(int argc, char **argv)
   rval = mb.create_meshset(MESHSET_SET, euler_set);
   CHECK_ERR(rval);
+  clock_t tt = clock();
   rval = mb.load_file(filename_mesh1, &euler_set, opts.c_str());
+  CHECK_ERR(rval);
   ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
   CHECK_ERR(rval);
-  rval = pcomm->check_all_shared_handles();
-  CHECK_ERR(rval);
+  /*rval = pcomm->check_all_shared_handles();
+  CHECK_ERR(rval);*/
   // end copy
   int rank = pcomm->proc_config().proc_rank();
+  int procs = pcomm->proc_config().proc_size();
   if (0==rank)
     std::cout << " case 1: use -gtol " << gtol << " -dt " << delta_t <<
-        " -R " << radius << " -input " << filename_mesh1 << "\n";
+        " -R " << radius << " -input " << filename_mesh1 << " -t " << t << " -rot " << rot <<  "\n";
+  if (0==rank)
+      std::cout << "load mesh from " << filename_mesh1 << "\n  on " << procs << " processors in "
+            << (clock() - tt) / (double) CLOCKS_PER_SEC << " seconds" << std::endl;
+      tt = clock();
   rval = manufacture_lagrange_mesh_on_sphere(&mb, euler_set);
@@ -208,11 +231,23 @@ int main(int argc, char **argv)
   //double radius = 1.; // input
   worker.SetRadius(radius);
+  if (0==rank)
+     std::cout << "manufacture departure mesh " << filename_mesh1 << "\n  on " << procs << " processors in "
+     tt = clock();
   worker.SetErrorTolerance(gtol);
   rval = worker.create_departure_mesh_2nd_alg(euler_set, covering_lagr_set);
   CHECK_ERR(rval);
+  if (0==rank)
+     std::cout << "communicate covering mesh on " << procs << " processors in "
+     tt = clock();
   if (Verbose)
@@ -240,8 +275,13 @@ int main(int argc, char **argv)
   rval = worker.intersect_meshes(covering_lagr_set, euler_set, outputSet);
     return 1;
-  if (rank<=4)
+  if (0==rank)
+     std::cout << "intersect meshes in " << procs << " processors in "
+     tt = clock();
+  if (Verbose && rank<=4)
     std::string opts_write("");
     std::stringstream outf;
@@ -250,11 +290,15 @@ int main(int argc, char **argv)
       std::cout << "can't write output\n";
-  double intx_area = area_on_sphere_lHuiller(&mb, outputSet, radius);
-  double arrival_area = area_on_sphere_lHuiller(&mb, euler_set, radius);
-  std::cout << " Arrival area: " << arrival_area
-      << "  intersection area:" << intx_area << " rel error: "
-      << fabs((intx_area - arrival_area) / arrival_area) << "\n";
+  if (rank <= 4)
+    double intx_area = area_on_sphere_lHuiller(&mb, outputSet, radius);
+    double arrival_area = area_on_sphere_lHuiller(&mb, euler_set, radius);
+    std::cout << "On proc " << rank << "  arrival area: " << arrival_area
+        << "  intersection area:" << intx_area << " rel error: "
+        << fabs((intx_area - arrival_area) / arrival_area) << "\n";
   MPI_Finalize();
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
