[MOAB-dev] Discussion on return type of MOAB routines
Wu, Danqing
wuda at mcs.anl.gov
Fri Jan 24 11:50:21 CST 2014
Even with C style struct, without explicitly defined constructors, there is still noticeable difference.
Used g++ -O3 to build.
For returning plain enum type, the result on my laptop is
real 0m0.003s
user 0m0.000s
sys 0m0.000s
For returning struct, the result is
real 0m4.114s
user 0m4.112s
sys 0m0.000s
#include <iostream>
using namespace std;
enum ErrorCode { MB_SUCCESS = 0, MB_FAILURE = 1 };
struct ErrorInfo {
ErrorCode mErrorCode;
ErrorCode test_return_0(long n)
if (n > 0)
return test_return_0(n - 1);
return MB_SUCCESS;
ErrorInfo test_return_1(long n)
if (n > 0)
return test_return_1(n - 1);
return ErrorInfo();
int main()
for (long i = 0; i < 100000; i++)
test_return_0(100000); // Change to test_return_1(100000) for comparison
return 0;
Sent: Friday, January 24, 2014 11:30 AM
To: Tautges, Timothy J.; Vijay S. Mahadevan
Cc: Wu, Danqing; Paul Wilson; moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] Discussion on return type of MOAB routines
"Tim Tautges (ANL)" <tautges at mcs.anl.gov> writes:
> Yeah, but even the ErrorCode-only class version was way slower than
> the one returning only ErrorCode, that's what makes me think there's
> C++ stuff going on behind the scenes (or optimizations the class
> version doesn't get) that is causing the big jump.
Where is the exact code? Also, it should be obvious in the assembly.
