[MOAB-dev] Discussion on return type of MOAB routines
    Jed Brown
    jed at jedbrown.org
    Fri Jan 24 11:30:30 CST 2014
"Tim Tautges (ANL)" <tautges at mcs.anl.gov> writes:
> Yeah, but even the ErrorCode-only class version was way slower than
> the one returning only ErrorCode, that's what makes me think there's
> C++ stuff going on behind the scenes (or optimizations the class
> version doesn't get) that is causing the big jump.
Where is the exact code?  Also, it should be obvious in the assembly.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140124/bec5be2f/attachment.pgp>
