[MOAB-dev] Closing/opening moab instances
Tim Tautges (ANL) tautges at mcs.anl.gov
Mon Jan 20 13:43:07 CST 2014
Hmm, then I'd add a ticket for MOAB that requests this entity set get populated appropriately.  Are you sure this isn't
being handled properly outside CGM, on the MOAB side?
- tim
On 01/18/2014 07:40 AM, Paul Wilson wrote:
> On Jan 17, 2014, at 20:48, "Tautges, Timothy J." <tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>> wrote:
>> I think it should be optional too.  Patrick, each separate read should be passing in an entity set anyway, so either
>> way you should be able to tell what resulted from a given read.
> This is only true if the geom gets cleared each time because ReadCGM calls import_solid_model w/o any notion of a set to
> hold it separate.  ReadCGM then queries the geom for all RefEntities of a given dimension.  Thus, even with a distinct
> entity set on the MOAB side, it will contain all the entities from prior reads if the geom doesn't get cleared.
> Paul
> Professor, Nuclear Engineering
> Faculty Director, Advanced Computing Infrastructure
> UW-Madison
> wilsonp at engr.wisc.edu <mailto:wilsonp at engr.wisc.edu>, 608.263.0807
> Sent from my iPhone
>> And, dated reply, but you can't create/destroy multiple cgm instances in the same session, due to the singletons and
>> some other things in cgm.
>> Tim
>> Sent via the Samsung GALAXY S®4, an AT&T 4G LTE smartphone
>> -------- Original message --------
>> From: Paul Wilson
>> Date:01/17/2014 4:33 PM (GMT-06:00)
>> To: "Grindeanu, Iulian R."
>> Cc: Patrick Shriwise ,"Tautges, Timothy J." ,moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>
>> Subject: Re: [MOAB-dev] Closing/opening moab instances
>> Hi all
>> Actually, I don't think we should always delete_ geometry after ReadCGM.  There is theoretically a DAGMC capability to
>> use the geometry for some ray-firing calls that would require the geometry to be loaded. (We need to add tests for this.)
>> We could add options to ReadCGM:
>> • on/off delete on entering ReadCGM()
>> • on/off delete on exiting ReadCGM()
>> Paul
>> UW-Madison
>> Sent from my iPhone
>> > On Jan 17, 2014, at 16:15, "Grindeanu, Iulian R." <iulian at mcs.anl.gov <mailto:iulian at mcs.anl.gov>> wrote:
>> > I think we should call "delete_geometry" on cgm instance after read_cgm finishes its job.
>> > I cannot think of any instance in which we would want the entities persistent.
>> > maybe Rajeev has though issues when coregen-type calls are made in meshkit. I know that there multiple files
>> > are loaded; I assume that these files are sat/occ files, and are read as geometry, not converted to mesh by ReadCGM. Tim or Rajeev could confirm if calling "delete_geometry" is a problem or not;
>> > Thanks,
>> > Iulian
>> > ________________________________________
>> > From:moab-dev-bounces at mcs.anl.gov <mailto:moab-dev-bounces at mcs.anl.gov> [moab-dev-bounces at mcs.anl.gov
>> <mailto:moab-dev-bounces at mcs.anl.gov>] on behalf of Patrick Shriwise [shriwise at wisc.edu <mailto:shriwise at wisc.edu>]
>> > Sent: Friday, January 17, 2014 4:02 PM
>> > To: Tautges, Timothy J.
>> > Cc:moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>
>> >> On 01/14/2014 09:46 AM, Patrick Shriwise wrote:
>> >>> On 01/09/2014 12:43 PM, Tim Tautges (ANL) wrote:
>> >>> Either declare the Core instance in a local variable, e.g. as in the
>> >>> test/MBTest.cpp test (mb_vertex_coordinate_test function and the ones
>> >>> following), or use Interface::delete_mesh.  I'd recommend the former,
>> >>> as that gives you a clean instance.
>> >>> - tim
>> >>>> On 01/09/2014 12:22 PM, Patrick Shriwise wrote:
>> >>>> Hi all,
>> >>>> Working on a set of tests in which I would like to read an ACIS file
>> >>>> independently in several different functions using
>> >>>> moab::Core::load_file. I believe that I am creating a new moab
>> >>>> instance in every function. However when I load the file
>> >>>> in a new function, the data from the original load seems to remain.
>> >>>> Any advice on how to load the file without having it
>> >>>> overlap between functions?
>> >>>> Cheers,
>> >>> I've setup my local moab instance calls just as in MBTest.cpp and
>> >>> mb_vertex_coordinate_test but am still having the same problem. When
>> >>> I load a simple cube geometry and check that it has the appropriate
>> >>> number of vertices it works the first time, but if I repeat the test
>> >>> in main it will find twice the number of vertices as expected upon a
>> >>> repeated test run. Any thoughts?
>> > Hey all,
>> >  Got this problem figured out. When loading a file using
>> > ReadCGM::load_file , a CGM instance is created which is persistent (see
>> > InitCGMA.cpp lines 65-80). This means that unless the CGMA geometry is
>> > removed before leaving ReadCGM, it still exists when loading another
>> > file or the same file whether this occurs in the same MOAB instance or
>> > not. By adding to ReadCGM a line calling delete_geometry() from CGM at
>> > the end of ReadCGM::load_file it allows the CGMA data to be removed and
>> > leave the existing MOAB Entities in tact.
>> > This leads to a question: Is there ever a case in which we would want to
>> > re-access the CGMA geometry data from a file after transferring it to
>> > MOAB (loading a file twice, loading multiple files into CGMA then moving
>> > it to MOAB, etc. ) or should this be the default behavior for ReadCGM?
>> > For the current DAGMC workflow its is not necessary or problematic that
>> > the CGM instance is persistent. Since we have all the ACIS geometry in a
>> > single file loaded once it is not an issue, however in testing that
>> > involves multiple file loads even in separate MOAB instances containing
>> > the original geometry AND the new geometry.
>> > Which leads up to my real question, will adding a delete_geometry() call
>> > from CGM cause problems in everyone else's workflow? (This change does
>> > not break other tests.)
>> > Thanks ,
>> > Patrick
>> > Patrick C. Shriwise
>> > Research Assistant
>> > University of Wisconsin - Madison
>> > Engineering Research Building - Rm. 428
>> > 1500 Engineering Drive
>> > Madison, WI 53706
>> > (608) 446-8173
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
