[MOAB-dev] Closing/opening moab instances
    Paul Wilson
    wilsonp at engr.wisc.edu
    Sat Jan 18 07:40:37 CST 2014
> On Jan 17, 2014, at 20:48, "Tautges, Timothy J." <tautges at mcs.anl.gov> wrote:
> I think it should be optional too.  Patrick, each separate read should be passing in an entity set anyway, so either way you should be able to tell what resulted from a given read.
This is only true if the geom gets cleared each time because ReadCGM calls import_solid_model w/o any notion of a set to hold it separate.  ReadCGM then queries the geom for all RefEntities of a given dimension.  Thus, even with a distinct entity set on the MOAB side, it will contain all the entities from prior reads if the geom doesn't get cleared.
Paul
Professor, Nuclear Engineering
Faculty Director, Advanced Computing Infrastructure
UW-Madison
wilsonp at engr.wisc.edu, 608.263.0807
Sent from my iPhone
> And, dated reply, but you can't create/destroy multiple cgm instances in the same session, due to the singletons and some other things in cgm.
> Tim
> Sent via the Samsung GALAXY S®4, an AT&T 4G LTE smartphone
> -------- Original message --------
> From: Paul Wilson
> Date:01/17/2014 4:33 PM (GMT-06:00)
> To: "Grindeanu, Iulian R."
> Cc: Patrick Shriwise ,"Tautges, Timothy J." ,moab-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] Closing/opening moab instances
> Hi all
> Actually, I don't think we should always delete_ geometry after ReadCGM.  There is theoretically a DAGMC capability to use the geometry for some ray-firing calls that would require the geometry to be loaded. (We need to add tests for this.)
> We could add options to ReadCGM:
> • on/off delete on entering ReadCGM()
> • on/off delete on exiting ReadCGM()
> Paul
> UW-Madison
> Sent from my iPhone
> > On Jan 17, 2014, at 16:15, "Grindeanu, Iulian R." <iulian at mcs.anl.gov> wrote:
> > I think we should call "delete_geometry" on cgm instance after read_cgm finishes its job.
> > I cannot think of any instance in which we would want the entities persistent.
> > maybe Rajeev has though issues when coregen-type calls are made in meshkit. I know that there multiple files
> > are loaded; I assume that these files are sat/occ files, and are read as geometry, not converted to mesh by ReadCGM. Tim or Rajeev could confirm if calling "delete_geometry" is a problem or not;
> > Thanks,
> > Iulian
> > ________________________________________
> > From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Patrick Shriwise [shriwise at wisc.edu]
> > Sent: Friday, January 17, 2014 4:02 PM
> > To: Tautges, Timothy J.
> > Cc: moab-dev at mcs.anl.gov
> >> On 01/14/2014 09:46 AM, Patrick Shriwise wrote:
> >>> On 01/09/2014 12:43 PM, Tim Tautges (ANL) wrote:
> >>> Either declare the Core instance in a local variable, e.g. as in the
> >>> test/MBTest.cpp test (mb_vertex_coordinate_test function and the ones
> >>> following), or use Interface::delete_mesh.  I'd recommend the former,
> >>> as that gives you a clean instance.
> >>> - tim
> >>>> On 01/09/2014 12:22 PM, Patrick Shriwise wrote:
> >>>> Hi all,
> >>>> Working on a set of tests in which I would like to read an ACIS file
> >>>> independently in several different functions using
> >>>> moab::Core::load_file. I believe that I am creating a new moab
> >>>> instance in every function. However when I load the file
> >>>> in a new function, the data from the original load seems to remain.
> >>>> Any advice on how to load the file without having it
> >>>> overlap between functions?
> >>>> Cheers,
> >>> I've setup my local moab instance calls just as in MBTest.cpp and
> >>> mb_vertex_coordinate_test but am still having the same problem. When
> >>> I load a simple cube geometry and check that it has the appropriate
> >>> number of vertices it works the first time, but if I repeat the test
> >>> in main it will find twice the number of vertices as expected upon a
> >>> repeated test run. Any thoughts?
> > Hey all,
> >  Got this problem figured out. When loading a file using
> > ReadCGM::load_file , a CGM instance is created which is persistent (see
> > InitCGMA.cpp lines 65-80). This means that unless the CGMA geometry is
> > removed before leaving ReadCGM, it still exists when loading another
> > file or the same file whether this occurs in the same MOAB instance or
> > not. By adding to ReadCGM a line calling delete_geometry() from CGM at
> > the end of ReadCGM::load_file it allows the CGMA data to be removed and
> > leave the existing MOAB Entities in tact.
> > This leads to a question: Is there ever a case in which we would want to
> > re-access the CGMA geometry data from a file after transferring it to
> > MOAB (loading a file twice, loading multiple files into CGMA then moving
> > it to MOAB, etc. ) or should this be the default behavior for ReadCGM?
> > For the current DAGMC workflow its is not necessary or problematic that
> > the CGM instance is persistent. Since we have all the ACIS geometry in a
> > single file loaded once it is not an issue, however in testing that
> > involves multiple file loads even in separate MOAB instances containing
> > the original geometry AND the new geometry.
> > Which leads up to my real question, will adding a delete_geometry() call
> > from CGM cause problems in everyone else's workflow? (This change does
> > not break other tests.)
> > Thanks ,
> > Patrick
> > Patrick C. Shriwise
> > Research Assistant
> > University of Wisconsin - Madison
> > Engineering Research Building - Rm. 428
> > 1500 Engineering Drive
> > Madison, WI 53706
> > (608) 446-8173
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140118/f15e3add/attachment-0001.html>
