[MOAB-dev] Build failed in Jenkins: moab_serial #214
    jenkins-ci at mcs.anl.gov
    Tue Jan  7 14:15:06 CST 2014
See <https://jenkins-ci.mcs.anl.gov/job/moab_serial/214/changes>
Changes:
[tautges] Adding a Lloyd smoother tool, and a test of it.
[tautges] Adding ability to smooth based on a tag instead of coords.
[tautges] Adding deformed mesh example.
[tautges] Adding option processing to DeformMeshRemap, and making
[tautges] Make a DeformMeshRemap class and implement through that.
[tautges] DeformMeshRemap: add some of the data interpolation calls, basically filling
[tautges] General debugging and small feature additions.
[tautges] LloydSmoother: proper handling of communicator.
[tautges] Handle case of parallel compile but 1 proc.
[tautges] Add support for parallel, and a few better comments for DeformMeshRemap class.
[tautges] Small fixes revealed by make check.
[tautges] Revert "LloydSmoother: proper handling of communicator."
[tautges] Revert "General debugging and small feature additions."
[tautges] Revert "DeformMeshRemap: add some of the data interpolation calls, basically filling"
[tautges] Revert "Make a DeformMeshRemap class and implement through that."
[...truncated 941 lines...]
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/LocalDiscretization'>
make[3]: Nothing to be done for `check'.
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/LocalDiscretization'>
Making check in .
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src'>
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src'>
Making check in oldinc
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/oldinc'>
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/oldinc'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src'>
Making check in MeshFiles
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/MeshFiles'>
Making check in unittest
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/MeshFiles/unittest'>
Making check in io
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/MeshFiles/unittest/io'>
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/MeshFiles/unittest/io'>
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/MeshFiles/unittest'>
make[3]: Nothing to be done for `check-am'.
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/MeshFiles/unittest'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/MeshFiles/unittest'>
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/MeshFiles'>
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/MeshFiles'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/MeshFiles'>
Making check in itaps
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps'>
Making check in imesh
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
make  check-am
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
make  testc_cbind MOAB_iMesh_unit_tests MOAB_iMesh_extensions_tests ScdMeshF90 ScdMeshF77 FindAdjacencyF90
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT testc_cbind.o -MD -MP -MF .deps/testc_cbind.Tpo -c -o testc_cbind.o testc_cbind.cpp
mv -f .deps/testc_cbind.Tpo .deps/testc_cbind.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o testc_cbind testc_cbind.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o testc_cbind testc_cbind.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/.libs/libMOAB.a> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT MOAB_iMesh_unit_tests.o -MD -MP -MF .deps/MOAB_iMesh_unit_tests.Tpo -c -o MOAB_iMesh_unit_tests.o MOAB_iMesh_unit_tests.cpp
mv -f .deps/MOAB_iMesh_unit_tests.Tpo .deps/MOAB_iMesh_unit_tests.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o MOAB_iMesh_unit_tests MOAB_iMesh_unit_tests.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o MOAB_iMesh_unit_tests MOAB_iMesh_unit_tests.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/.libs/libMOAB.a> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT MOAB_iMesh_extensions_tests.o -MD -MP -MF .deps/MOAB_iMesh_extensions_tests.Tpo -c -o MOAB_iMesh_extensions_tests.o MOAB_iMesh_extensions_tests.cpp
mv -f .deps/MOAB_iMesh_extensions_tests.Tpo .deps/MOAB_iMesh_extensions_tests.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o MOAB_iMesh_extensions_tests MOAB_iMesh_extensions_tests.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o MOAB_iMesh_extensions_tests MOAB_iMesh_extensions_tests.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/.libs/libMOAB.a> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
gfortran -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -O2 -fcray-pointer -c -o ScdMeshF90.o ScdMeshF90.F90
/bin/sh ../../libtool  --tag=FC   --mode=link gfortran  -O2 -fcray-pointer -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o ScdMeshF90 ScdMeshF90.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm
libtool: link: gfortran -O2 -fcray-pointer -o ScdMeshF90 ScdMeshF90.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/.libs/libMOAB.a> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
f77 -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -O2 -fcray-pointer -c -o ScdMeshF77.o ScdMeshF77.F
/bin/sh ../../libtool  --tag=F77   --mode=link f77  -O2 -fcray-pointer -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o ScdMeshF77 ScdMeshF77.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm
libtool: link: f77 -O2 -fcray-pointer -o ScdMeshF77 ScdMeshF77.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/.libs/libMOAB.a> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
gfortran -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -O2 -fcray-pointer -c -o FindAdjacencyF90.o FindAdjacencyF90.F90
/bin/sh ../../libtool  --tag=FC   --mode=link gfortran  -O2 -fcray-pointer -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o FindAdjacencyF90 FindAdjacencyF90.o libiMesh.la ../../src/libMOAB.la -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm
libtool: link: gfortran -O2 -fcray-pointer -o FindAdjacencyF90 FindAdjacencyF90.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/src/.libs/libMOAB.a> -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.6 -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.6/../../.. -lstdc++ -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
make  check-TESTS
make[5]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
PASS: testc_cbind
PASS: MOAB_iMesh_unit_tests
PASS: MOAB_iMesh_extensions_tests
PASS: ScdMeshF90
PASS: ScdMeshF77
PASS: FindAdjacencyF90
All 6 tests passed
make[5]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps/imesh'>
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/itaps'>
Making check in tools
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools'>
Making check in .
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools'>
Making check in dagmc
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
make  test_geom pt_vol_test ray_fire_test
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -I../../src -I../../src -I../../tools   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT test_geom.o -MD -MP -MF .deps/test_geom.Tpo -c -o test_geom.o test_geom.cc
mv -f .deps/test_geom.Tpo .deps/test_geom.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_geom test_geom.o libdagmc.la ../../src/libMOAB.la  -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_geom test_geom.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libdagmc.a ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -I../../src -I../../src -I../../tools   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT pt_vol_test.o -MD -MP -MF .deps/pt_vol_test.Tpo -c -o pt_vol_test.o pt_vol_test.cc
mv -f .deps/pt_vol_test.Tpo .deps/pt_vol_test.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o pt_vol_test pt_vol_test.o libdagmc.la ../../src/libMOAB.la  -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o pt_vol_test pt_vol_test.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libdagmc.a ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -I../../src -I../../src -I../../tools   -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT ray_fire_test.o -MD -MP -MF .deps/ray_fire_test.Tpo -c -o ray_fire_test.o ray_fire_test.cc
mv -f .deps/ray_fire_test.Tpo .deps/ray_fire_test.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o ray_fire_test ray_fire_test.o libdagmc.la ../../src/libMOAB.la  -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o ray_fire_test ray_fire_test.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ./.libs/libdagmc.a ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
make  check-TESTS
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
PASS: test_geom
1 test passed
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools/dagmc'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/tools'>
Making check in test
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
Making check in .
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make  range_test moab_test homxform_test scdseq_test scd_test_partn test_adj seq_man_test geom_util_test xform_test obb_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test mbcn_test bsp_tree_poly_test reorder_test test_prog_opt coords_connect_iterate elem_eval_test spatial_locator_test test_boundbox lloyd_smoother_test mbfacet_test gttool_test cropvol_test mergemesh_test mbground_test kd_tree_tool kd_tree_time
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT range_test.o -MD -MP -MF .deps/range_test.Tpo -c -o range_test.o range_test.cpp
mv -f .deps/range_test.Tpo .deps/range_test.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o range_test range_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o range_test range_test.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT moab_test-MBTest.o -MD -MP -MF .deps/moab_test-MBTest.Tpo -c -o moab_test-MBTest.o `test -f 'MBTest.cpp' || echo './'`MBTest.cpp
mv -f .deps/moab_test-MBTest.Tpo .deps/moab_test-MBTest.Po
gunzip -c ../MeshFiles/unittest/mb_big_test.g.gz > mb_big_test.g
gunzip -c ../MeshFiles/unittest/cell1.gen.gz > cell1.gen
gunzip -c ../MeshFiles/unittest/cell2.gen.gz > cell2.gen
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o moab_test moab_test-MBTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o moab_test moab_test-MBTest.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -DTEST -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT homxform_test-HomXform.o -MD -MP -MF .deps/homxform_test-HomXform.Tpo -c -o homxform_test-HomXform.o `test -f '../src/HomXform.cpp' || echo './'`../src/HomXform.cpp
mv -f .deps/homxform_test-HomXform.Tpo .deps/homxform_test-HomXform.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o homxform_test homxform_test-HomXform.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o homxform_test homxform_test-HomXform.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT scdseq_test.o -MD -MP -MF .deps/scdseq_test.Tpo -c -o scdseq_test.o scdseq_test.cpp
mv -f .deps/scdseq_test.Tpo .deps/scdseq_test.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o scdseq_test scdseq_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o scdseq_test scdseq_test.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT scd_test_partn.o -MD -MP -MF .deps/scd_test_partn.Tpo -c -o scd_test_partn.o scd_test_partn.cpp
mv -f .deps/scd_test_partn.Tpo .deps/scd_test_partn.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o scd_test_partn scd_test_partn.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o scd_test_partn scd_test_partn.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT test_adj.o -MD -MP -MF .deps/test_adj.Tpo -c -o test_adj.o test_adj.cpp
mv -f .deps/test_adj.Tpo .deps/test_adj.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_adj test_adj.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_adj test_adj.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT TestTypeSequenceManager.o -MD -MP -MF .deps/TestTypeSequenceManager.Tpo -c -o TestTypeSequenceManager.o TestTypeSequenceManager.cpp
mv -f .deps/TestTypeSequenceManager.Tpo .deps/TestTypeSequenceManager.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o seq_man_test TestTypeSequenceManager.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o seq_man_test TestTypeSequenceManager.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT GeomUtilTests.o -MD -MP -MF .deps/GeomUtilTests.Tpo -c -o GeomUtilTests.o GeomUtilTests.cpp
mv -f .deps/GeomUtilTests.Tpo .deps/GeomUtilTests.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o geom_util_test GeomUtilTests.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o geom_util_test GeomUtilTests.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -DTEST -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT xform_test-AffineXform.o -MD -MP -MF .deps/xform_test-AffineXform.Tpo -c -o xform_test-AffineXform.o `test -f '../src/AffineXform.cpp' || echo './'`../src/AffineXform.cpp
mv -f .deps/xform_test-AffineXform.Tpo .deps/xform_test-AffineXform.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o xform_test xform_test-AffineXform.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o xform_test xform_test-AffineXform.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT OBBTest.o -MD -MP -MF .deps/OBBTest.Tpo -c -o OBBTest.o OBBTest.cpp
mv -f .deps/OBBTest.Tpo .deps/OBBTest.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o obb_test OBBTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_test OBBTest.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT adaptive_kd_tree_tests.o -MD -MP -MF .deps/adaptive_kd_tree_tests.Tpo -c -o adaptive_kd_tree_tests.o adaptive_kd_tree_tests.cpp
mv -f .deps/adaptive_kd_tree_tests.Tpo .deps/adaptive_kd_tree_tests.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT bsp_tree_test.o -MD -MP -MF .deps/bsp_tree_test.Tpo -c -o bsp_tree_test.o bsp_tree_test.cpp
mv -f .deps/bsp_tree_test.Tpo .deps/bsp_tree_test.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o bsp_tree_test bsp_tree_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o bsp_tree_test bsp_tree_test.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -DTEST -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT file_options_test-FileOptions.o -MD -MP -MF .deps/file_options_test-FileOptions.Tpo -c -o file_options_test-FileOptions.o `test -f '../src/FileOptions.cpp' || echo './'`../src/FileOptions.cpp
mv -f .deps/file_options_test-FileOptions.Tpo .deps/file_options_test-FileOptions.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o file_options_test file_options_test-FileOptions.o  -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o file_options_test file_options_test-FileOptions.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -lm
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT kd_tree_test-kd_tree_test.o -MD -MP -MF .deps/kd_tree_test-kd_tree_test.Tpo -c -o kd_tree_test-kd_tree_test.o `test -f 'kd_tree_test.cpp' || echo './'`kd_tree_test.cpp
mv -f .deps/kd_tree_test-kd_tree_test.Tpo .deps/kd_tree_test-kd_tree_test.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o kd_tree_test kd_tree_test-kd_tree_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o kd_tree_test kd_tree_test-kd_tree_test.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT VarLenTagTest.o -MD -MP -MF .deps/VarLenTagTest.Tpo -c -o VarLenTagTest.o VarLenTagTest.cpp
mv -f .deps/VarLenTagTest.Tpo .deps/VarLenTagTest.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o var_len_test VarLenTagTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o var_len_test VarLenTagTest.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -UTEMPLATE_SPECIALIZATION -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT var_len_test_no_template-VarLenTagTest.o -MD -MP -MF .deps/var_len_test_no_template-VarLenTagTest.Tpo -c -o var_len_test_no_template-VarLenTagTest.o `test -f 'VarLenTagTest.cpp' || echo './'`VarLenTagTest.cpp
mv -f .deps/var_len_test_no_template-VarLenTagTest.Tpo .deps/var_len_test_no_template-VarLenTagTest.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o var_len_test_no_template var_len_test_no_template-VarLenTagTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o var_len_test_no_template var_len_test_no_template-VarLenTagTest.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT TagTest.o -MD -MP -MF .deps/TagTest.Tpo -c -o TagTest.o TagTest.cpp
mv -f .deps/TagTest.Tpo .deps/TagTest.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o tag_test TagTest.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o tag_test TagTest.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT Test_MBMeshSet.o -MD -MP -MF .deps/Test_MBMeshSet.Tpo -c -o Test_MBMeshSet.o Test_MBMeshSet.cpp
mv -f .deps/Test_MBMeshSet.Tpo .deps/Test_MBMeshSet.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mesh_set_test Test_MBMeshSet.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mesh_set_test Test_MBMeshSet.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT CN.o -MD -MP -MF .deps/CN.Tpo -c -o CN.o `test -f '../src/CN.cpp' || echo './'`../src/CN.cpp
mv -f .deps/CN.Tpo .deps/CN.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT mbcn_test.o -MD -MP -MF .deps/mbcn_test.Tpo -c -o mbcn_test.o mbcn_test.cc
mv -f .deps/mbcn_test.Tpo .deps/mbcn_test.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o mbcn_test CN.o mbcn_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mbcn_test CN.o mbcn_test.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT bsp_tree_poly_test.o -MD -MP -MF .deps/bsp_tree_poly_test.Tpo -c -o bsp_tree_poly_test.o bsp_tree_poly_test.cpp
mv -f .deps/bsp_tree_poly_test.Tpo .deps/bsp_tree_poly_test.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o bsp_tree_poly_test bsp_tree_poly_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o bsp_tree_poly_test bsp_tree_poly_test.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT reorder_test.o -MD -MP -MF .deps/reorder_test.Tpo -c -o reorder_test.o reorder_test.cpp
mv -f .deps/reorder_test.Tpo .deps/reorder_test.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o reorder_test reorder_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o reorder_test reorder_test.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT test_prog_opt-test_prog_opt.o -MD -MP -MF .deps/test_prog_opt-test_prog_opt.Tpo -c -o test_prog_opt-test_prog_opt.o `test -f 'test_prog_opt.cpp' || echo './'`test_prog_opt.cpp
mv -f .deps/test_prog_opt-test_prog_opt.Tpo .deps/test_prog_opt-test_prog_opt.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o test_prog_opt test_prog_opt-test_prog_opt.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_prog_opt test_prog_opt-test_prog_opt.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT coords_connect_iterate-coords_connect_iterate.o -MD -MP -MF .deps/coords_connect_iterate-coords_connect_iterate.Tpo -c -o coords_connect_iterate-coords_connect_iterate.o `test -f 'coords_connect_iterate.cpp' || echo './'`coords_connect_iterate.cpp
mv -f .deps/coords_connect_iterate-coords_connect_iterate.Tpo .deps/coords_connect_iterate-coords_connect_iterate.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o coords_connect_iterate coords_connect_iterate-coords_connect_iterate.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o coords_connect_iterate coords_connect_iterate-coords_connect_iterate.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT elem_eval_test.o -MD -MP -MF .deps/elem_eval_test.Tpo -c -o elem_eval_test.o elem_eval_test.cpp
mv -f .deps/elem_eval_test.Tpo .deps/elem_eval_test.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o elem_eval_test elem_eval_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o elem_eval_test elem_eval_test.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -I../src  -I/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/include    -I/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include -isystem /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DSRCDIR=. -DMESHDIR=../MeshFiles/unittest -I../src -I../src -I../src/LocalDiscretization  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT spatial_locator_test.o -MD -MP -MF .deps/spatial_locator_test.Tpo -c -o spatial_locator_test.o spatial_locator_test.cpp
mv -f .deps/spatial_locator_test.Tpo .deps/spatial_locator_test.Po
/bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib      -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib   -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -o spatial_locator_test spatial_locator_test.o ../src/libMOAB.la -lm
libtool: link: g++ -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o spatial_locator_test spatial_locator_test.o  -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -L/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib ../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so -L/home/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -L/home/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5_hl.so -L/homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib /homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.so /homes/sharp/3rdparty/szip/szip-2.1/gcc/lib/libsz.so -lz -lm -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib -Wl,-rpath -Wl,/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib
spatial_locator_test.o: In function `moab::SpatialLocator::~SpatialLocator()':
spatial_locator_test.cpp:(.text._ZN4moab14SpatialLocatorD2Ev[_ZN4moab14SpatialLocatorD5Ev]+0x2c): undefined reference to `moab::TupleList::reset()'
spatial_locator_test.cpp:(.text._ZN4moab14SpatialLocatorD2Ev[_ZN4moab14SpatialLocatorD5Ev]+0x35): undefined reference to `moab::TupleList::reset()'
spatial_locator_test.cpp:(.text._ZN4moab14SpatialLocatorD2Ev[_ZN4moab14SpatialLocatorD5Ev]+0x54): undefined reference to `moab::TupleList::reset()'
spatial_locator_test.cpp:(.text._ZN4moab14SpatialLocatorD2Ev[_ZN4moab14SpatialLocatorD5Ev]+0x67): undefined reference to `moab::TupleList::reset()'
spatial_locator_test.cpp:(.text._ZN4moab14SpatialLocatorD0Ev[_ZN4moab14SpatialLocatorD5Ev]+0x2c): undefined reference to `moab::TupleList::reset()'
spatial_locator_test.o:spatial_locator_test.cpp:(.text._ZN4moab14SpatialLocatorD0Ev[_ZN4moab14SpatialLocatorD5Ev]+0x35): more undefined references to `moab::TupleList::reset()' follow
../src/.libs/libMOAB.a(SpatialLocator.o): In function `moab::SpatialLocator::SpatialLocator(moab::Interface*, moab::Range&, moab::Tree*, moab::ElemEvaluator*)':
SpatialLocator.cpp:(.text+0x66): undefined reference to `moab::TupleList::TupleList()'
SpatialLocator.cpp:(.text+0x75): undefined reference to `moab::TupleList::TupleList()'
SpatialLocator.cpp:(.text+0x126): undefined reference to `moab::TupleList::reset()'
SpatialLocator.cpp:(.text+0x12e): undefined reference to `moab::TupleList::reset()'
../src/.libs/libMOAB.a(SpatialLocator.o): In function `moab::SpatialLocator::locate_points(double const*, int, double, double, double)':
SpatialLocator.cpp:(.text+0x11c0): undefined reference to `moab::TupleList::initialize(unsigned int, unsigned int, unsigned int, unsigned int, unsigned int)'
SpatialLocator.cpp:(.text+0x11c8): undefined reference to `moab::TupleList::enableWriteAccess()'
SpatialLocator.cpp:(.text+0x1225): undefined reference to `moab::TupleList::set_n(unsigned int)'
collect2: ld returned 1 exit status
make[3]: *** [spatial_locator_test] Error 1
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make[2]: *** [check-am] Error 2
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab_serial/ws/test'>
make: *** [check-recursive] Error 1
Build step 'Execute shell' marked build as failure
