[MOAB-dev] commit/MOAB: tautges: Merge branch 'deformed-mesh-remap' of git at bitbucket.org:fathomteam/moab.git
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Tue Jan 7 14:05:17 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/37765e24606e/
Changeset:   37765e24606e
Branch:      master
User:        tautges
Date:        2014-01-07 21:04:26
Summary:     Merge branch 'deformed-mesh-remap' of git at bitbucket.org:fathomteam/moab.git
Affected #:  47 files
diff --git a/.gitignore b/.gitignore
index e824a6b..d842c2b 100644
--- a/.gitignore
+++ b/.gitignore
@@ -165,6 +165,7 @@ test/io/vtk_test
 test/kd_tree_test
 test/kd_tree_time
 test/kd_tree_tool
+test/lloyd_smoother_test
 test/mbcn_test
 test/mbfacet_test
 test/mbground_test
diff --git a/examples/DeformMeshRemap.cpp b/examples/DeformMeshRemap.cpp
new file mode 100644
index 0000000..5442d1d
--- /dev/null
+++ b/examples/DeformMeshRemap.cpp
@@ -0,0 +1,488 @@
+/** @example DeformMeshRemap.cpp
+ * Description: Account for mesh deformation of a solid due to structural mechanics\n
+ * In this example there are two meshes, a "master" and "slave" mesh.  In the master mesh,
+ * the solid material is deformed, to mimic what happens when a solid heats up and deforms.
+ * The fluid mesh is smoothed to account for those deformations, and tags on the fluid are
+ * remapped to those new positions.  Then mesh positions and state variables are transferred
+ * to the slave mesh, mimicing another mesh used by some other physics.
+ * To run: ./DeformMeshRemap [<master_meshfile><slave_meshfile>]\n
+ * (default values can run if users don't specify the mesh files)
+#include "moab/Core.hpp"
+#include "moab/Range.hpp"
+#include "moab/LloydSmoother.hpp"
+#include "moab/ProgOptions.hpp"
+#include "moab/BoundBox.hpp"
+#include "moab/SpatialLocator.hpp"
+#include "MBTagConventions.hpp"
+#include "DataCoupler.hpp"
+#ifdef USE_MPI
+#  include "moab/ParallelComm.hpp"
+#endif
+#include <iostream>
+#include <set>
+#include <sstream>
+#include <assert.h>
+using namespace moab;
+using namespace std;
+#ifndef MESH_DIR
+#define MESH_DIR "."
+#endif
+ErrorCode read_file(string &fname, EntityHandle &seth,
+                    Range &solids, Range &solid_elems, Range &fluids, Range &fluid_elems);
+void deform_func(const BoundBox &bbox, double *xold, double *xnew);
+ErrorCode deform_master(Range &fluid_elems, Range &solid_elems, Tag &xnew);
+ErrorCode smooth_master(int dim, Tag xnew, EntityHandle &master, Range &fluids);
+ErrorCode write_to_coords(Range &elems, Tag tagh);
+const int SOLID_SETNO = 100, FLUID_SETNO = 200;
+Interface *mb;
+#define RR(a) if (MB_SUCCESS != rval) {cout << a << endl; return MB_FAILURE;}
+const bool debug = true;
+class DeformMeshRemap
+public:
+    //! enumerator for solid/fluid, master/slave
+  enum {MASTER=0, SLAVE, SOLID, FLUID};
+    //! constructor
+    //! if master is NULL, the MOAB part is run in serial;
+    //! if slave is NULL but the master isn't, the slave is copied from the master
+    //! Create communicators using moab::ParallelComm::get_pcomm
+  DeformMeshRemap(Interface *impl, ParallelComm *master = NULL, ParallelComm *slave = NULL);
+    //! destructor
+  ~DeformMeshRemap();
+    //! execute the deformed mesh process
+  ErrorCode execute();
+    //! add a set number
+  ErrorCode add_set_no(int fluid_or_solid, int set_no);
+    //! remove a set number
+  ErrorCode remove_set_no(int fluid_or_solid, int set_no);
+    //! get the set numbers
+  ErrorCode get_set_nos(int fluid_or_solid, std::set<int> &set_nos) const;
+    //! get the xNew tag handle
+  inline Tag x_new() const {return xNew;}
+    //! get the tag name
+  std::string x_new_name() const {return xNewName;}
+    //! set the tag name
+  void x_new_name(const std::string &name) {xNewName = name;}
+    //! get/set the file name
+  std::string get_file_name(int m_or_s) const;
+  void set_file_name(int m_or_s, const std::string &name);
+private:
+    //! apply a known deformation to the solid elements, putting the results in the xNew tag; also
+    //! write current coordinates to the xNew tag for fluid elements
+  ErrorCode deform_master(Range &fluid_elems, Range &solid_elems, const char *tag_name = NULL);
+    //! read a file and establish proper ranges
+  ErrorCode read_file(int m_or_s, string &fname, EntityHandle &seth);
+    //! write the input tag to the coordinates for the vertices in the input elems
+  ErrorCode write_to_coords(Range &elems, Tag tagh);
+    //! write the tag to the vertices, then save to the specified file
+  ErrorCode write_and_save(Range &ents, EntityHandle seth, Tag tagh, const char *filename);
+    //! moab interface
+  Interface *mbImpl;
+#ifdef USE_MPI
+    //! ParallelComm for master, slave meshes
+  ParallelComm *pcMaster, *pcSlave;
+#endif
+    //! material set numbers for fluid materials
+  std::set<int> fluidSetNos;
+    //! material set numbers for solid materials
+  std::set<int> solidSetNos;
+    //! sets defining master/slave meshes
+  EntityHandle masterSet, slaveSet;
+    //! sets in master/slave meshes
+  Range fluidSets[2], solidSets[2];
+    //! elements in master/slave meshes
+  Range fluidElems[2], solidElems[2];
+    //! filenames for master/slave meshes
+  std::string masterFileName, slaveFileName;
+    //! tag used for new positions
+  Tag xNew;
+    //! tag name used for new positions
+  std::string xNewName;
+inline ErrorCode DeformMeshRemap::add_set_no(int f_or_s, int set_no)
+  std::set<int> *this_set;
+  switch (f_or_s) {
+    case FLUID:
+        this_set = &fluidSetNos; break;
+    case SOLID:
+        this_set = &solidSetNos; break;
+    default:
+        assert(false && "f_or_s should be FLUID or SOLID.");
+        return MB_FAILURE;
+  this_set->insert(set_no);
+  return MB_SUCCESS;
+inline ErrorCode DeformMeshRemap::remove_set_no(int f_or_s, int set_no)
+  switch (f_or_s) {
+    case FLUID:
+    case SOLID:
+    default:
+  std::set<int>::iterator sit = this_set->find(set_no);
+  if (sit != this_set->end()) {
+    this_set->erase(*sit);
+inline ErrorCode DeformMeshRemap::get_set_nos(int f_or_s, std::set<int> &set_nos) const
+  const std::set<int> *this_set;
+  switch (f_or_s) {
+    case FLUID:
+    case SOLID:
+    default:
+  set_nos = *this_set;
+ErrorCode DeformMeshRemap::execute()
+    // read master/slave files and get fluid/solid material sets
+  ErrorCode rval = read_file(MASTER, masterFileName, masterSet);
+  if (MB_SUCCESS != rval) return rval;
+  rval = read_file(SLAVE, slaveFileName, slaveSet);
+  Range src_elems = solidElems[MASTER];
+  src_elems.merge(fluidElems[MASTER]);
+    // locate slave vertices in master, orig coords; do this with a data coupler, so you can
+    // later interpolate
+  Range tgt_verts, tmp_range = solidElems[SLAVE];
+  tmp_range.merge(fluidElems[SLAVE]);
+  rval = mbImpl->get_adjacencies(tmp_range, 0, false, tgt_verts, Interface::UNION);
+  RR("Failed to get target verts.");
+    // initialize data coupler on source elements
+  DataCoupler dc_master(mbImpl, NULL, src_elems, 0);
+    // locate slave vertices, caching results in dc
+  rval = dc_master.locate_points(tgt_verts); RR("Point location of tgt verts failed.");
+  int num_located = dc_master.spatial_locator()->local_num_located();
+  if (num_located != (int)tgt_verts.size()) {
+    rval = MB_FAILURE;
+    std::cout << "Only " << num_located << " out of " << tgt_verts.size() << " target points successfully located." << std::endl;
+    return rval;
+    // deform the master's solid mesh, put results in a new tag
+  rval = deform_master(fluidElems[MASTER], solidElems[MASTER], "xnew"); RR("");
+  { // to isolate the lloyd smoother & delete when done
+      // smooth the master mesh
+    LloydSmoother ll(mbImpl, NULL, fluidElems[MASTER], xNew);
+    rval = ll.perform_smooth();
+    RR("Failed in lloyd smoothing.");
+    cout << "Lloyd smoothing required " << ll.num_its() << " iterations." << endl;
+    // map new locations to slave
+    // interpolate xNew to slave points
+  rval = dc_master.interpolate((int)DataCoupler::VOLUME, "xnew"); RR("Failed to interpolate target solution.");
+    // transfer xNew to coords, for master and slave
+  rval = write_to_coords(fluidElems[MASTER], xNew); RR("Failed writing tag to master fluid verts.");
+  rval = write_to_coords(tgt_verts, xNew); RR("Failed writing tag to slave verts.");
+  if (debug) {
+    std::string str;
+#ifdef USE_MPI
+    if (pcMaster && pcMaster->size() > 1)
+      str = "PARALLEL=WRITE_PART";
+#endif
+    rval = mbImpl->write_file("smoothed_master.vtk", NULL, str.c_str(), &masterSet, 1);
+#ifdef USE_MPI
+    str.clear();
+    if (pcSlave && pcSlave->size() > 1)
+#endif
+    rval = mbImpl->write_file("slave_interp.vtk", NULL, str.c_str(), &slaveSet, 1);
+std::string DeformMeshRemap::get_file_name(int m_or_s) const
+  switch (m_or_s) {
+    case MASTER:
+        return masterFileName;
+    case SLAVE:
+        return slaveFileName;
+    default:
+        assert(false && "m_or_s should be MASTER or SLAVE.");
+        return std::string();
+void DeformMeshRemap::set_file_name(int m_or_s, const std::string &name)
+  switch (m_or_s) {
+    case MASTER:
+        masterFileName = name; break;
+    case SLAVE:
+        slaveFileName = name; break;
+    default:
+DeformMeshRemap::DeformMeshRemap(Interface *impl, ParallelComm *master, ParallelComm *slave)
+        : mbImpl(impl), pcMaster(master), pcSlave(slave), masterSet(0), slaveSet(0), xNew(0), xNewName("xnew")
+  if (!pcSlave && pcMaster)
+    pcSlave = pcMaster;
+DeformMeshRemap::~DeformMeshRemap()
+    // delete the tag
+  mbImpl->tag_delete(xNew);
+int main(int argc, char **argv) {
+  ErrorCode rval;
+  ProgOptions po("Deformed mesh options");
+  po.addOpt<std::string> ("master,m", "Specify the master meshfile name" );
+  po.addOpt<std::string> ("slave,s", "Specify the slave meshfile name" );
+  po.parseCommandLine(argc, argv);
+  std::string foo;
+  string masterf, slavef;
+  if(!po.getOpt("master", &masterf))
+    masterf = string(MESH_DIR) + string("/rodquad.g");
+  if(!po.getOpt("slave", &slavef))
+    slavef = string(MESH_DIR) + string("/rodtri.g");
+  mb = new Core();
+  DeformMeshRemap *dfr;
+#ifdef USE_MPI
+  ParallelComm *pc = new ParallelComm(mb, MPI_COMM_WORLD);
+  dfr = new DeformMeshRemap(mb, pc);
+#else
+  dfr = new DeformMeshRemap(mb);
+#endif
+  dfr->set_file_name(DeformMeshRemap::MASTER, masterf);
+  dfr->set_file_name(DeformMeshRemap::SLAVE, slavef);
+  rval = dfr->add_set_no(DeformMeshRemap::SOLID, SOLID_SETNO); RR("Failed to add solid set no.");
+  rval = dfr->add_set_no(DeformMeshRemap::FLUID, FLUID_SETNO); RR("Failed to add fluid set no.");
+  rval = dfr->execute();
+  delete dfr;
+  delete mb;
+  return rval;
+ErrorCode DeformMeshRemap::write_and_save(Range &ents, EntityHandle seth, Tag tagh, const char *filename)
+  ErrorCode rval = write_to_coords(ents, tagh); RR("");
+  rval = mbImpl->write_file(filename, NULL, NULL, &seth, 1); RR("");
+  return rval;
+ErrorCode DeformMeshRemap::write_to_coords(Range &elems, Tag tagh)
+    // write the tag to coordinates
+  Range verts;
+  ErrorCode rval = mbImpl->get_adjacencies(elems, 0, false, verts, Interface::UNION);
+  RR("Failed to get adj vertices.");
+  std::vector<double> coords(3*verts.size());
+  rval = mbImpl->tag_get_data(tagh, verts, &coords[0]);
+  RR("Failed to get tag data.");
+  rval = mbImpl->set_coords(verts, &coords[0]);
+  RR("Failed to set coordinates.");
+/*  Deformation function based on max delx and dely at top of rod
+    const double RODWIDTH = 0.2, RODHEIGHT = 0.5;
+    // function: origin is at middle base of rod, and is .5 high
+    // top of rod is (0,.55) on left and (.2,.6) on right
+  double delx = 0.5*RODWIDTH;
+  double xfrac = (xold[0] + .5*RODWIDTH)/RODWIDTH, yfrac = xold[1]/RODHEIGHT;
+  xnew[0] = xold[0] + yfrac * delx;
+  xnew[1] = xold[1] + yfrac * (1.0 + xfrac) * 0.05;
+/* Deformation function based on fraction of bounding box dimension in each direction */
+  double frac = 0.01; // taken from approximate relative deformation from LLNL Diablo of XX09 assys
+  CartVect *xo = reinterpret_cast<CartVect*>(xold), *xn = reinterpret_cast<CartVect*>(xnew);
+  CartVect disp = frac * (*xo - bbox.bMin);
+  *xn = *xo + disp;
+ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems, const char *tag_name)
+    // deform elements with an analytic function
+    // create the tag
+  ErrorCode rval = mbImpl->tag_get_handle((tag_name ? tag_name : ""), 3, MB_TYPE_DOUBLE, xNew, MB_TAG_CREAT|MB_TAG_DENSE);
+  RR("Failed to create xnew tag.");
+    // get all the vertices and coords in the fluid, set xnew to them
+  Range verts;
+  rval = mbImpl->get_adjacencies(fluid_elems, 0, false, verts, Interface::UNION);
+  RR("Failed to get vertices.");
+  std::vector<double> coords(3*verts.size(), 0.0);
+  rval = mbImpl->get_coords(verts, &coords[0]);
+  RR("Failed to get vertex coords.");
+  rval = mbImpl->tag_set_data(xNew, verts, &coords[0]);
+  RR("Failed to set xnew tag on fluid verts.");
+    // get the bounding box of the solid mesh
+  BoundBox bbox;
+  bbox.update(*mbImpl, solid_elems);
+    // get all the vertices and coords in the solid
+  verts.clear();
+  rval = mbImpl->get_adjacencies(solid_elems, 0, false, verts, Interface::UNION);
+  coords.resize(3*verts.size(), 0.0);
+  unsigned int num_verts = verts.size();
+  for (unsigned int i = 0; i < num_verts; i++)
+    deform_func(bbox, &coords[3*i], &coords[3*i]);
+    // set the new tag to those coords
+  RR("Failed to set tag data.");
+ErrorCode DeformMeshRemap::read_file(int m_or_s, string &fname, EntityHandle &seth)
+    // create meshset
+  ErrorCode rval = mbImpl->create_meshset(0, seth);
+  RR("Couldn't create master/slave set.");
+  ostringstream ostr;
+#ifdef USE_MPI
+  ParallelComm *pc = (m_or_s == MASTER ? pcMaster : pcSlave);
+  if (pc && pc->size() > 1) {
+    if (debug) ostr << "DEBUG_IO=1;CPUTIME;";
+    ostr << "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;"
+         << "PARALLEL_GHOSTS=2.0.1;PARALLEL_COMM=" << pc->get_id();
+#endif
+  rval = mbImpl->load_file(fname.c_str(), &seth, ostr.str().c_str());
+  RR("Couldn't load master/slave mesh.");
+    // get material sets for solid/fluid
+  Tag tagh;
+  rval = mbImpl->tag_get_handle(MATERIAL_SET_TAG_NAME, tagh); RR("Couldn't get material set tag name.");
+  for (std::set<int>::iterator sit = solidSetNos.begin(); sit != solidSetNos.end(); sit++) {
+    Range sets;
+    int set_no = *sit;
+    const void *setno_ptr = &set_no;
+    rval = mbImpl->get_entities_by_type_and_tag(seth, MBENTITYSET, &tagh, &setno_ptr, 1, sets);
+    if (sets.empty()) rval = MB_FAILURE;
+    RR("Couldn't get any solid sets.");
+    solidSets[m_or_s].merge(sets);
+    // get solid entities, and dimension
+  Range tmp_range;
+  for (Range::iterator rit = solidSets[m_or_s].begin(); rit != solidSets[m_or_s].end(); rit++) {
+    rval = mbImpl->get_entities_by_handle(*rit, tmp_range, true);
+    RR("Failed to get entities in solid.");
+  int dim = mbImpl->dimension_from_handle(*tmp_range.rbegin());
+  assert(dim > 0 && dim < 4);
+  solidElems[m_or_s] = tmp_range.subset_by_dimension(dim);
+  for (std::set<int>::iterator sit = fluidSetNos.begin(); sit != fluidSetNos.end(); sit++) {
+    Range sets;
+    RR("Couldn't get any fluid sets.");
+    fluidSets[m_or_s].merge(sets);
+    // get fluid entities, and dimension
+  tmp_range.clear();
+  for (Range::iterator rit = fluidSets[m_or_s].begin(); rit != fluidSets[m_or_s].end(); rit++) {
+    RR("Failed to get entities in fluid.");
+  fluidElems[m_or_s] = tmp_range.subset_by_dimension(dim);
diff --git a/examples/LloydRelaxation.cpp b/examples/LloydRelaxation.cpp
index 0cf9d1e..34002cd 100644
--- a/examples/LloydRelaxation.cpp
+++ b/examples/LloydRelaxation.cpp
@@ -14,8 +14,10 @@
  * in the current directory (H5M format must be used since the file is written in parallel).
-#include "moab/ParallelComm.hpp"
-#include "MBParallelConventions.h"
+#ifdef USE_MPI
+#  include "MBParallelConventions.h"
+#endif
 #include "moab/Skinner.hpp"
 #include "moab/CN.hpp"
@@ -30,7 +32,7 @@ string test_file_name = string(MESH_DIR) + string("/surfrandomtris-4part.h5m");
 #define RC if (MB_SUCCESS != rval) return rval
-ErrorCode perform_lloyd_relaxation(ParallelComm *pc, Range &verts, Range &cells, Tag fixed,
+ErrorCode perform_lloyd_relaxation(Interface *mb, Range &verts, Range &cells, Tag fixed,
                                    int num_its, int report_its);
@@ -38,7 +40,9 @@ int main(int argc, char **argv)
   int num_its = 10;
   int report_its = 1;
+#ifdef USE_MPI
   MPI_Init(&argc, &argv);
+#endif
     // need option handling here for input filename
   if (argc > 1){
@@ -49,10 +53,13 @@ int main(int argc, char **argv)
   // get MOAB and ParallelComm instances
   Interface *mb = new Core;
   if (NULL == mb) return 1;
+  int nprocs = 1;
+#ifdef USE_MPI
   // get the ParallelComm instance
-  ParallelComm* pcomm = new ParallelComm(mb, MPI_COMM_WORLD);
-  int nprocs = pcomm->size();
+  ParallelComm *pcomm = new ParallelComm(mb, MPI_COMM_WORLD);
+  nprocs = pcomm->size();
+#endif
   string options;
   if (nprocs > 1) // if reading in parallel, need to tell it how
     options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1;DEBUG_IO=0;DEBUG_PIO=0";
@@ -76,34 +83,45 @@ int main(int argc, char **argv)
     // ok to mark non-owned skin vertices too, I won't move those anyway
     // use MOAB's skinner class to find the skin
   Skinner skinner(mb);
-  rval = skinner.find_skin(faces, true, skin_verts); RC; // 'true' param indicates we want vertices back, not faces
+  rval = skinner.find_skin(0, faces, true, skin_verts); RC; // 'true' param indicates we want vertices back, not faces
   std::vector<int> fix_tag(skin_verts.size(), 1); // initialized to 1 to indicate fixed
   rval = mb->tag_set_data(fixed, skin_verts, &fix_tag[0]); RC;
     // now perform the Lloyd relaxation
-  rval = perform_lloyd_relaxation(pcomm, verts, faces, fixed, num_its, report_its); RC;
+  rval = perform_lloyd_relaxation(mb, verts, faces, fixed, num_its, report_its); RC;
     // delete fixed tag, since we created it here
   rval = mb->tag_delete(fixed); RC;
     // output file, using parallel write
-  rval = mb->write_file("lloydfinal.h5m", NULL, "PARALLEL=WRITE_PART"); RC;
+#ifdef USE_MPI
+  options = "PARALLEL=WRITE_PART";
+#endif
+  rval = mb->write_file("lloydfinal.h5m", NULL, options.c_str()); RC;
     // delete MOAB instance
   delete mb;
+#ifdef USE_MPI
   MPI_Finalize();
+#endif
   return 0;
-ErrorCode perform_lloyd_relaxation(ParallelComm *pcomm, Range &verts, Range &faces, Tag fixed,
+ErrorCode perform_lloyd_relaxation(Interface *mb, Range &verts, Range &faces, Tag fixed,
   ErrorCode rval;
-  Interface *mb = pcomm->get_moab();
+  int nprocs = 1;
+#ifdef USE_MPI
+  ParallelComm *pcomm = ParallelComm::get_pcomm(mb, 0);
+#endif
     // perform Lloyd relaxation:
     // 1. setup: set vertex centroids from vertex coords; filter to owned verts; get fixed tags
@@ -120,8 +138,10 @@ ErrorCode perform_lloyd_relaxation(ParallelComm *pcomm, Range &verts, Range &fac
     // filter verts down to owned ones and get fixed tag for them
   Range owned_verts, shared_owned_verts;
   if (nprocs > 1) {
+#ifdef USE_MPI
     rval = pcomm->filter_pstatus(verts, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned_verts);
     if (rval != MB_SUCCESS) return rval;
+#endif
   else
     owned_verts = verts;
@@ -133,11 +153,13 @@ ErrorCode perform_lloyd_relaxation(ParallelComm *pcomm, Range &verts, Range &fac
   vcentroids.resize(3*owned_verts.size());
   rval = mb->tag_get_data(centroid, owned_verts, &vcentroids[0]); RC;
+#ifdef USE_MPI
     // get shared owned verts, for exchanging tags
   rval = pcomm->get_shared_entities(-1, shared_owned_verts, 0, false, true); RC;
     // workaround: if no shared owned verts, put a non-shared one in the list, to prevent exchanging tags
     // for all shared entities
   if (shared_owned_verts.empty()) shared_owned_verts.insert(*verts.begin());
+#endif
     // some declarations for later iterations
   std::vector<double> fcentroids(3*faces.size()); // fcentroids for face centroids
@@ -195,16 +217,22 @@ ErrorCode perform_lloyd_relaxation(ParallelComm *pcomm, Range &verts, Range &fac
     // 2c. exchange tags on owned verts
     if (nprocs > 1) {
+#ifdef USE_MPI
       rval = pcomm->exchange_tags(centroid, shared_owned_verts); RC;
+#endif
     if (!(nit%report_its)) {
         // global reduce for maximum delta, then report it
       double global_max = mxdelta;
+      int myrank = 0;
+#ifdef USE_MPI
       if (nprocs > 1)
         MPI_Reduce(&mxdelta, &global_max, 1, MPI_DOUBLE, MPI_MAX, 0, pcomm->comm());
-      if (1 == nprocs || !pcomm->rank())
+      myrank = pcomm->rank();
+#endif
+      if (1 == nprocs || !myrank)
         cout << "Max delta = " << global_max << endl;
diff --git a/examples/makefile b/examples/makefile
index 5ae5af0..a6e3d1f 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -4,7 +4,7 @@ include ${MOAB_DIR}/lib/iMesh-Defs.inc
 .SUFFIXES: .o .cpp .F90
-# MESH_DIR is the top-level MOAB source directory, used to locate mesh files that come with MOAB source
+# MESH_DIR is the directory containing mesh files that come with MOAB source
 MESH_DIR="../MeshFiles/unittest"
 EXAMPLES = HelloMOAB GetEntities SetsNTags StructuredMeshSimple DirectAccessWithHoles DirectAccessNoHoles
@@ -14,45 +14,48 @@ EXOIIEXAMPLES = TestExodusII
 default: ${EXAMPLES}
-HelloMOAB : HelloMOAB.o
+HelloMOAB : HelloMOAB.o ${MOAB_LIBDIR}/libMOAB.la
 	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
-GetEntities: GetEntities.o
+GetEntities: GetEntities.o ${MOAB_LIBDIR}/libMOAB.la
-SetsNTags: SetsNTags.o
+SetsNTags: SetsNTags.o ${MOAB_LIBDIR}/libMOAB.la
-LloydRelaxation: LloydRelaxation.o
+LloydRelaxation: LloydRelaxation.o ${MOAB_LIBDIR}/libMOAB.la
-StructuredMeshSimple : StructuredMeshSimple.o
+StructuredMeshSimple : StructuredMeshSimple.o ${MOAB_LIBDIR}/libMOAB.la
-DirectAccessWithHoles: DirectAccessWithHoles.o
+DirectAccessWithHoles: DirectAccessWithHoles.o ${MOAB_LIBDIR}/libMOAB.la
-DirectAccessNoHoles: DirectAccessNoHoles.o
+DirectAccessNoHoles: DirectAccessNoHoles.o ${MOAB_LIBDIR}/libMOAB.la
-DirectAccessNoHolesF90: DirectAccessNoHolesF90.o
+DirectAccessNoHolesF90: DirectAccessNoHolesF90.o ${MOAB_LIBDIR}/libMOAB.la
 	${MOAB_CXX} -o $@ $< ${IMESH_LIBS}
-ReduceExchangeTags : ReduceExchangeTags.o
+ReduceExchangeTags : ReduceExchangeTags.o ${MOAB_LIBDIR}/libMOAB.la
-HelloParMOAB: HelloParMOAB.o
+HelloParMOAB: HelloParMOAB.o ${MOAB_LIBDIR}/libMOAB.la
-TestExodusII: TestExodusII.o
+TestExodusII: TestExodusII.o ${MOAB_LIBDIR}/libMOAB.la
-point_in_elem_search: point_in_elem_search.o
+point_in_elem_search: point_in_elem_search.o ${MOAB_LIBDIR}/libMOAB.la
 PushParMeshIntoMoabF90: PushParMeshIntoMoabF90.o
 	${MOAB_CXX} -o $@ $< ${IMESH_LIBS} -lgfortran -L/usr/lib/openmpi/lib -lmpi_f90 -lmpi_f77 -lmpi -lopen-rte -lopen-pal -ldl
+DeformMeshRemap: DeformMeshRemap.o ${MOAB_LIBDIR}/libMOAB.la
+	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK} -lmbcoupler ${MOAB_LIBS_LINK}
 clean:
 	rm -rf *.o ${EXAMPLES} ${PAREXAMPLES} ${EXOIIEXAMPLES}
diff --git a/src/AdaptiveKDTree.cpp b/src/AdaptiveKDTree.cpp
index f66acbc..1324c30 100644
--- a/src/AdaptiveKDTree.cpp
+++ b/src/AdaptiveKDTree.cpp
@@ -1303,7 +1303,8 @@ namespace moab {
     ErrorCode AdaptiveKDTree::point_search(const double *point,
                                            EntityHandle& leaf_out,
-                                           double tol,
+                                           const double iter_tol,
+                                           const double inside_tol,
                                            bool *multiple_leaves,
                                            EntityHandle *start_node,
                                            CartVect *params)
@@ -1322,7 +1323,7 @@ namespace moab {
       treeStats.nodesVisited++;
       ErrorCode rval = get_bounding_box(box, &node);
-      if (!box.contains_point(point, tol)) return MB_SUCCESS;
+      if (!box.contains_point(point, iter_tol)) return MB_SUCCESS;
       rval = moab()->get_child_meshsets( node, children );
@@ -1346,7 +1347,7 @@ namespace moab {
       treeStats.leavesVisited++;
       if (myEval && params) {
-        rval = myEval->find_containing_entity(node, point, tol,
+        rval = myEval->find_containing_entity(node, point, iter_tol, inside_tol,
                                               leaf_out, params->array(), &treeStats.leafObjectTests);
@@ -1358,7 +1359,8 @@ namespace moab {
                                            AdaptiveKDTreeIter& leaf_it,
-                                           double tol,
+                                           const double /*inside_tol*/,
                                            EntityHandle *start_node)
@@ -1372,7 +1374,7 @@ namespace moab {
       leaf_it.mBox[1] = boundBox.bMax;
         // test that point is inside tree
-      if (!boundBox.contains_point(point, tol)) {
+      if (!boundBox.contains_point(point, iter_tol)) {
         return MB_ENTITY_NOT_FOUND;
@@ -1423,7 +1425,8 @@ namespace moab {
     ErrorCode AdaptiveKDTree::distance_search(const double from_point[3],
                                               const double distance,
                                               std::vector<EntityHandle>& result_list,
-                                              double tol,
                                               std::vector<double> *result_dists,
                                               std::vector<CartVect> *result_params,
                                               EntityHandle *tree_root)
@@ -1445,7 +1448,7 @@ namespace moab {
         // (zero if inside box)
       BoundBox box;
       rval = get_bounding_box(box);
-      if (MB_SUCCESS == rval && !box.contains_point(from_point, tol)) {
+      if (MB_SUCCESS == rval && !box.contains_point(from_point, iter_tol)) {
         return MB_SUCCESS;
@@ -1484,7 +1487,7 @@ namespace moab {
           if (myEval && result_params) {
             EntityHandle ent;
             CartVect params;
-            rval = myEval->find_containing_entity(node.handle, from_point, tol,
+            rval = myEval->find_containing_entity(node.handle, from_point, iter_tol, inside_tol,
                                                   ent, params.array(), &treeStats.leafObjectTests);
             else if (ent) {
@@ -1802,7 +1805,7 @@ namespace moab {
         // the same distance from the input point as the current closest
         // point is.
       CartVect diff = closest_pt - from;
-      rval = distance_search(from_coords, sqrt(diff%diff), leaves, 0.0, NULL, NULL, &tree_root);
+      rval = distance_search(from_coords, sqrt(diff%diff), leaves, 1.0e-10, 1.0e-6, NULL, NULL, &tree_root);
         // Check any close leaves to see if they contain triangles that
@@ -1834,7 +1837,7 @@ namespace moab {
         // get leaves of tree that intersect sphere
       assert(tree_root);
-      rval = distance_search(center, radius, leaves, 0.0, NULL, NULL, &tree_root);
+      rval = distance_search(center, radius, leaves, 1.0e-10, 1.0e-6, NULL, NULL, &tree_root);
         // search each leaf for triangles intersecting sphere
diff --git a/src/BVHTree.cpp b/src/BVHTree.cpp
index 8903070..b65eae4 100644
--- a/src/BVHTree.cpp
+++ b/src/BVHTree.cpp
@@ -435,7 +435,8 @@ namespace moab
     ErrorCode BVHTree::find_point(const std::vector<double> &point,
                                   const unsigned int &index,
-                                  const double tol,
                                   std::pair<EntityHandle, CartVect> &result)
       if (index == 0) treeStats.numTraversals++;
@@ -453,7 +454,7 @@ namespace moab
         for(Range::iterator i = entities.begin(); i != entities.end(); i++) {
           treeStats.leafObjectTests++;
           myEval->set_ent_handle(*i);
-          myEval->reverse_eval(&point[0], tol, params.array(), &is_inside);
+          myEval->reverse_eval(&point[0], iter_tol, inside_tol, params.array(), &is_inside);
           if (is_inside) {
             result.first = *i;
             result.second = params;
@@ -469,11 +470,11 @@ namespace moab
       rval = mbImpl->get_child_meshsets(startSetHandle+index, children);
       if (MB_SUCCESS != rval || children.size() != 2) return rval;
-      if((node.Lmax+tol) < (node.Rmin-tol)){
-        if(point[node.dim] <= (node.Lmax + tol))
-          return find_point(point, children[0]-startSetHandle, tol, result);
-        else if(point[ node.dim] >= (node.Rmin - tol))
-          return find_point(point, children[1]-startSetHandle, tol, result);
+      if((node.Lmax+iter_tol) < (node.Rmin-iter_tol)){
+        if(point[node.dim] <= (node.Lmax + iter_tol))
+          return find_point(point, children[0]-startSetHandle, iter_tol, inside_tol, result);
+        else if(point[ node.dim] >= (node.Rmin - iter_tol))
+          return find_point(point, children[1]-startSetHandle, iter_tol, inside_tol, result);
         result = std::make_pair(0, CartVect(&point[0])); //point lies in empty space.
         return MB_SUCCESS;
@@ -482,11 +483,11 @@ namespace moab
         //left of Rmin, you must be on the left
         //we can't be sure about the boundaries since the boxes overlap
         //this was a typo in the paper which caused pain.
-      if(point[node.dim] < (node.Rmin - tol))
+      if(point[node.dim] < (node.Rmin - iter_tol))
         //if you are on the right Lmax, you must be on the right
-      else if(point[ node.dim] > (node.Lmax+tol))
+      else if(point[ node.dim] > (node.Lmax+iter_tol))
         /* pg5 of paper
          * However, instead of always traversing either subtree
@@ -501,22 +502,22 @@ namespace moab
         //branch predicted..
         //bool dir = (point[ node.dim] - node.Rmin) <=
         //				(node.Lmax - point[ node.dim]);
-      find_point(point, children[0]-startSetHandle, tol, result);
+      find_point(point, children[0]-startSetHandle, iter_tol, inside_tol, result);
       if(result.first == 0){
       return MB_SUCCESS;
-    EntityHandle BVHTree::bruteforce_find(const double *point, const double tol) {
+    EntityHandle BVHTree::bruteforce_find(const double *point, const double iter_tol, const double inside_tol) {
       CartVect params;
       for(unsigned int i = 0; i < myTree.size(); i++) {
-        if(myTree[i].dim != 3 || !myTree[i].box.contains_point(point, tol)) continue;
+        if(myTree[i].dim != 3 || !myTree[i].box.contains_point(point, iter_tol)) continue;
         if (myEval) {
           EntityHandle entity = 0;
-          ErrorCode rval = myEval->find_containing_entity(startSetHandle+i, point, tol,
+          ErrorCode rval = myEval->find_containing_entity(startSetHandle+i, point, iter_tol, inside_tol,
                                                           entity, params.array(), &treeStats.leafObjectTests);
           if (entity) return entity;
           else if (MB_SUCCESS != rval) return 0;
@@ -542,7 +543,8 @@ namespace moab
     ErrorCode BVHTree::point_search(const double *point,
-                                    double tol,
                                     CartVect *params)
@@ -572,7 +574,7 @@ namespace moab
           // test box of this node
         ErrorCode rval = get_bounding_box(box, &this_set);
-        if (!box.contains_point(point, tol)) continue;
+        if (!box.contains_point(point, iter_tol)) continue;
           // else if not a leaf, test children & put on list
         else if (myTree[ind].dim != 3) {
@@ -581,7 +583,7 @@ namespace moab
           continue;
         else if (myTree[ind].dim == 3 && myEval && params) {
-          rval = myEval->find_containing_entity(startSetHandle+ind, point, tol,
+          rval = myEval->find_containing_entity(startSetHandle+ind, point, iter_tol, inside_tol,
           if (leaf_out || MB_SUCCESS != rval) return rval;
@@ -599,7 +601,8 @@ namespace moab
     ErrorCode BVHTree::distance_search(const double from_point[3],
-                                       double params_tol,
@@ -653,7 +656,7 @@ namespace moab
           EntityHandle ent;
           CartVect params;
-          rval = myEval->find_containing_entity(startSetHandle+ind, from_point, params_tol,
+          rval = myEval->find_containing_entity(startSetHandle+ind, from_point, iter_tol, inside_tol,
           else if (ent) {
diff --git a/src/LloydSmoother.cpp b/src/LloydSmoother.cpp
index 0000000..b1614d2
--- /dev/null
+++ b/src/LloydSmoother.cpp
@@ -0,0 +1,232 @@
+#include "moab/Error.hpp"
+#include "moab/Skinner.hpp"
+#include "moab/CN.hpp"
+#include "moab/CartVect.hpp"
+#ifdef USE_MPI
+#include "moab/ParallelComm.hpp"
+#include "MBParallelConventions.h"
+#endif
+#define RR(a) if (MB_SUCCESS != rval) {        \
+    errorHandler->set_last_error(a);                \
+    return rval;}
+namespace moab {
+LloydSmoother::LloydSmoother(Interface *impl, ParallelComm *pc, Range &elms, Tag ctag,
+                             Tag ftag, double at, double rt)
+        : mbImpl(impl), myPcomm(pc), myElems(elms), coordsTag(ctag), fixedTag(ftag), absTol(at), relTol(rt),
+          reportIts(0), numIts(0), iCreatedTag(false)
+  ErrorCode rval = mbImpl->query_interface(errorHandler);
+  if (rval) throw rval;
+LloydSmoother::~LloydSmoother()
+  if (iCreatedTag && fixedTag) {
+    ErrorCode rval = mbImpl->tag_delete(fixedTag);
+ErrorCode LloydSmoother::perform_smooth()
+  ErrorCode rval;
+    // first figure out tolerance to use
+  if (0 > absTol) {
+      // no tolerance set - get one relative to bounding box around elements
+    BoundBox bb;
+    rval = bb.update(*mbImpl, myElems);
+    RR("Failed to compute bounding box around elements.");
+    absTol = relTol * bb.diagonal_length();
+    // initialize if we need to
+  rval = initialize();
+  RR("Failed to initialize.");
+    // get all vertices
+  Range verts;
+  rval = mbImpl->get_adjacencies(myElems, 0, false, verts, Interface::UNION);
+  RR("Failed to get all vertices.");
+    // perform Lloyd relaxation:
+    // 1. setup: set vertex centroids from vertex coords; filter to owned verts; get fixed tags
+    // get all verts coords into tag; don't need to worry about filtering out fixed verts,
+    // we'll just be setting to their fixed coords
+  std::vector<double> vcentroids(3*verts.size());
+  if (!coordsTag) {
+    rval = mbImpl->get_coords(verts, &vcentroids[0]); RR("Failed to get vert coords.");
+  else {
+    rval = mbImpl->tag_get_data(coordsTag, verts, &vcentroids[0]); RR("Failed to get vert coords tag values.");
+  Tag centroid;
+  rval = mbImpl->tag_get_handle("", 3, MB_TYPE_DOUBLE, centroid, MB_TAG_CREAT | MB_TAG_DENSE);
+  RR("Couldn't get tag handle.");
+  rval = mbImpl->tag_set_data(centroid, verts, &vcentroids[0]); RR("Failed setting centroid tag.");
+  Range owned_verts, shared_owned_verts;
+#ifdef USE_MPI
+    // filter verts down to owned ones and get fixed tag for them
+  if (myPcomm && myPcomm->size() > 1) {
+    rval = myPcomm->filter_pstatus(verts, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned_verts);
+    RR("Failed to filter on pstatus.");
+      // get shared owned verts, for exchanging tags
+    rval = myPcomm->filter_pstatus(owned_verts, PSTATUS_SHARED, PSTATUS_AND, -1, &shared_owned_verts);
+    RR("Failed to filter for shared owned.");
+      // workaround: if no shared owned verts, put a non-shared one in the list, to prevent exchanging tags
+      // for all shared entities
+    if (shared_owned_verts.empty()) shared_owned_verts.insert(*verts.begin());
+  else
+    owned_verts = verts;
+#else
+#endif
+  std::vector<unsigned char> fix_tag(owned_verts.size());
+  rval = mbImpl->tag_get_data(fixedTag, owned_verts, &fix_tag[0]); RR("Failed to get fixed tag.");
+    // now fill vcentroids array with positions of just owned vertices, since those are the ones
+    // we're actually computing
+  vcentroids.resize(3*owned_verts.size());
+  rval = mbImpl->tag_get_data(centroid, owned_verts, &vcentroids[0]); RR("Failed to get centroid tag.");
+    // some declarations for later iterations
+  std::vector<double> fcentroids(3*myElems.size()); // fcentroids for element centroids
+  std::vector<double> ctag(3*CN::MAX_NODES_PER_ELEMENT);  // temporary coordinate storage for verts bounding an element
+  const EntityHandle *conn;  // const ptr & size to elem connectivity
+  int nconn;
+  Range::iterator eit, vit;  // for iterating over elems, verts
+  int e, v;  // for indexing into centroid vectors
+  std::vector<EntityHandle> adj_elems;  // used in vertex iteration
+    // 2. while !converged
+  double resid = DBL_MAX;
+  numIts = 0;
+  while (resid > absTol) {
+    numIts++;
+    resid = 0.0;
+    // 2a. foreach elem: centroid = sum(vertex centroids)/num_verts_in_cell
+    for (eit = myElems.begin(), e = 0; eit != myElems.end(); eit++, e++) {
+        // get verts for this elem
+      rval = mbImpl->get_connectivity(*eit, conn, nconn); RR("Failed to get connectivity.");
+        // get centroid tags for those verts
+      rval = mbImpl->tag_get_data(centroid, conn, nconn, &ctag[0]); RR("Failed to get centroid.");
+      fcentroids[3*e+0] = fcentroids[3*e+1] = fcentroids[3*e+2] = 0.0;
+      for (v = 0; v < nconn; v++) {
+        fcentroids[3*e+0] += ctag[3*v+0];
+        fcentroids[3*e+1] += ctag[3*v+1];
+        fcentroids[3*e+2] += ctag[3*v+2];
+      for (v = 0; v < 3; v++) fcentroids[3*e+v] /= nconn;
+    rval = mbImpl->tag_set_data(centroid, myElems, &fcentroids[0]); RR("Failed to set elem centroid.");
+      // 2b. foreach owned vertex:
+    for (vit = owned_verts.begin(), v = 0; vit != owned_verts.end(); vit++, v++) {
+        // if !fixed
+      if (fix_tag[v]) continue;
+        // vertex centroid = sum(cell centroids)/ncells
+      adj_elems.clear();
+      rval = mbImpl->get_adjacencies(&(*vit), 1, 2, false, adj_elems); RR("Failed getting adjs.");
+      rval = mbImpl->tag_get_data(centroid, &adj_elems[0], adj_elems.size(), &fcentroids[0]);
+      RR("Failed to get elem centroid.");
+      double vnew[] = {0.0, 0.0, 0.0};
+      for (e = 0; e < (int)adj_elems.size(); e++) {
+        vnew[0] += fcentroids[3*e+0];
+        vnew[1] += fcentroids[3*e+1];
+        vnew[2] += fcentroids[3*e+2];
+      for (e = 0; e < 3; e++) vnew[e] /= adj_elems.size();
+      double delta = (CartVect(vnew)-CartVect(&vcentroids[3*v])).length();
+      resid = (v ? std::max(resid, delta) : delta);
+      for (e = 0; e < 3; e++) vcentroids[3*v+e] = vnew[e];
+      // set the centroid tag; having them only in vcentroids array isn't enough, as vertex centroids are
+      // accessed randomly in loop over faces
+    rval = mbImpl->tag_set_data(centroid, owned_verts, &vcentroids[0]); RR("Failed to set vertex centroid.");
+#ifdef USE_MPI
+    // 2c. exchange tags on owned verts
+      rval = myPcomm->exchange_tags(centroid, shared_owned_verts); RR("Failed to exchange tags.");
+#endif
+    if (reportIts && !(numIts%reportIts)) {
+      double global_max = resid;
+#ifdef USE_MPI
+        // global reduce for maximum delta, then report it
+        MPI_Reduce(&resid, &global_max, 1, MPI_DOUBLE, MPI_MAX, 0, myPcomm->comm());
+      if (!myPcomm || !myPcomm->rank())
+#endif
+        std::cout << "Max residual = " << global_max << std::endl;
+  } // end while
+    // write the tag back onto vertex coordinates
+  if (!coordsTag) {
+    rval = mbImpl->set_coords(owned_verts, &vcentroids[0]); RR("Failed to set vertex coords.");
+  else {
+    rval = mbImpl->tag_set_data(coordsTag, owned_verts, &vcentroids[0]);
+    RR("Failed to set vert coords tag values.");
+ErrorCode LloydSmoother::initialize()
+  ErrorCode rval = MB_SUCCESS;
+    // first, check for tag; if we don't have it, make one and mark skin as fixed
+  if (!fixedTag) {
+    unsigned char fixed = 0x0;
+    rval = mbImpl->tag_get_handle("", 1, MB_TYPE_OPAQUE, fixedTag, MB_TAG_DENSE|MB_TAG_CREAT, &fixed);
+    RR("Trouble making fixed tag.");
+    iCreatedTag = true;
+      // get the skin; get facets, because we might need to filter on shared entities
+    Skinner skinner(mbImpl);
+    Range skin, skin_verts;
+    rval = skinner.find_skin(0, myElems, false, skin);
+    RR("Unable to find skin.");
+#ifdef USE_MPI
+      // need to do a little extra if we're working in parallel
+    if (myPcomm) {
+        // filter out ghost and interface facets
+      rval = myPcomm->filter_pstatus(skin, PSTATUS_GHOST|PSTATUS_INTERFACE, PSTATUS_NOT);
+      RR("Failed to filter on shared status.");
+#endif
+      // get the vertices from those entities
+    rval = mbImpl->get_adjacencies(skin, 0, false, skin_verts, Interface::UNION);
+    RR("Trouble getting vertices.");
+      // mark them fixed
+    std::vector<unsigned char> marks(skin.size(), 0x1);
+    rval = mbImpl->tag_set_data(fixedTag, skin_verts, &marks[0]);
+    RR("Unable to set tag on skin.");
diff --git a/src/LocalDiscretization/ElemEvaluator.cpp b/src/LocalDiscretization/ElemEvaluator.cpp
index b132da9..4ca3943 100644
--- a/src/LocalDiscretization/ElemEvaluator.cpp
+++ b/src/LocalDiscretization/ElemEvaluator.cpp
@@ -6,6 +6,7 @@
 // need to include eval set types here to support get_eval_set; alternative would be to have some
 // type of registration, but we'd still need static registration for the built-in types
+#include "moab/LinearTri.hpp"
 #include "moab/LinearQuad.hpp"
 #include "moab/LinearTet.hpp"
 #include "moab/LinearHex.hpp"
@@ -16,12 +17,12 @@
 namespace moab {
     ErrorCode EvalSet::evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
                                         const double *posn, const double *verts, const int nverts,
-                                        const int ndim, const double tol, double *work,
-                                        double *params, bool *inside) {
+                                        const int ndim, const double iter_tol, const double inside_tol,
+                                        double *work, double *params, bool *inside) {
         // TODO: should differentiate between epsilons used for
         // Newton Raphson iteration, and epsilons used for curved boundary geometry errors
         // right now, fix the tolerance used for NR
-      const double error_tol_sqr = tol*tol;
+      const double error_tol_sqr = iter_tol*iter_tol;
       CartVect *cvparams = reinterpret_cast<CartVect*>(params);
       const CartVect *cvposn = reinterpret_cast<const CartVect*>(posn);
@@ -30,41 +31,48 @@ namespace moab {
       CartVect new_pos;
         // evaluate that first guess to get a new position
-      ErrorCode rval = (*eval)(cvparams->array(), verts, ndim, ndim, work, new_pos.array());
+      ErrorCode rval = (*eval)(cvparams->array(), verts, ndim,
+                               3, // hardwire to num_tuples to 3 since the field is coords
+                               work, new_pos.array());
         // residual is diff between old and new pos; need to minimize that
       CartVect res = new_pos - *cvposn;
       Matrix3 J;
+      bool dum, *tmp_inside = (inside ? inside : &dum);
       int iters=0;
         // while |res| larger than tol
       while (res % res > error_tol_sqr) {
         if(++iters>10) {
-          if (inside) {
-              // if we haven't converged but we're outside, that's defined as success
-            *inside = (*inside_f)(params, ndim, tol);
-            if (!(*inside)) return MB_SUCCESS;
-          return MB_FAILURE;
+            // if we haven't converged but we're outside, that's defined as success
+          *tmp_inside = (*inside_f)(params, ndim, inside_tol);
+          if (!(*tmp_inside)) return MB_SUCCESS;
+          else return MB_FAILURE;
           // get jacobian at current params
         rval = (*jacob)(cvparams->array(), verts, nverts, ndim, work, J[0]);
         double det = J.determinant();
-        assert(det > std::numeric_limits<double>::epsilon());
+        if (det < std::numeric_limits<double>::epsilon()) {
           // new params tries to eliminate residual
         *cvparams -= J.inverse(1.0/det) * res;
           // get the new forward-evaluated position, and its difference from the target pt
-        rval = (*eval)(params, verts, ndim, ndim, work, new_pos.array());
+        rval = (*eval)(params, verts, ndim,
       if (inside)
+        *inside = (*inside_f)(params, ndim, inside_tol);
       return MB_SUCCESS;
     }// Map::evaluate_reverse()
@@ -85,6 +93,7 @@ namespace moab {
         case MBEDGE:
             break;
         case MBTRI:
+            if (LinearTri::compatible(tp, num_vertices, eval_set)) return MB_SUCCESS;
             break;
         case MBQUAD:
             if (LinearQuad::compatible(tp, num_vertices, eval_set)) return MB_SUCCESS;
@@ -105,9 +114,9 @@ namespace moab {
       return MB_NOT_IMPLEMENTED;
-    ErrorCode ElemEvaluator::find_containing_entity(Range &entities, const double *point, double tol,
-                                                    EntityHandle &containing_ent, double *params,
-                                                    unsigned int *num_evals)
+    ErrorCode ElemEvaluator::find_containing_entity(Range &entities, const double *point, const double iter_tol,
+                                                    const double inside_tol, EntityHandle &containing_ent,
+                                                    double *params, unsigned int *num_evals)
       bool is_inside;
@@ -116,7 +125,7 @@ namespace moab {
       for(i = entities.begin(); i != entities.end(); i++) {
         nevals++;
         set_ent_handle(*i);
-        rval = reverse_eval(point, tol, params, &is_inside);
+        rval = reverse_eval(point, iter_tol, inside_tol, params, &is_inside);
         if (is_inside) break;
diff --git a/src/LocalDiscretization/LinearHex.cpp b/src/LocalDiscretization/LinearHex.cpp
index 14de2d9..5e730af 100644
--- a/src/LocalDiscretization/LinearHex.cpp
+++ b/src/LocalDiscretization/LinearHex.cpp
@@ -96,10 +96,12 @@ namespace moab
     ErrorCode LinearHex::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
                                         const double *posn, const double *verts, const int nverts, const int ndim,
-                                        const double tol, double *work, double *params, bool *is_inside)
+                                        const double iter_tol, const double inside_tol, double *work,
+                                        double *params, bool *is_inside)
       assert(posn && verts);
-      return EvalSet::evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, tol, work, params, is_inside);
+      return EvalSet::evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, iter_tol, inside_tol, work,
+                                       params, is_inside);
     bool LinearHex::insideFcn(const double *params, const int ndim, const double tol)
diff --git a/src/LocalDiscretization/LinearQuad.cpp b/src/LocalDiscretization/LinearQuad.cpp
index ddd4918..63c9959 100644
--- a/src/LocalDiscretization/LinearQuad.cpp
+++ b/src/LocalDiscretization/LinearQuad.cpp
@@ -16,23 +16,23 @@ namespace moab
     const double LinearQuad::gauss[1][2] = { {  2.0,           0.0          } };
-    ErrorCode LinearQuad::jacobianFcn(const double *params, const double *verts, const int /*nverts*/, const int ndim,
+    ErrorCode LinearQuad::jacobianFcn(const double *params, const double *verts, const int /*nverts*/, const int /*ndim*/,
                                       double *, double *result)
       Matrix3 *J = reinterpret_cast<Matrix3*>(result);
       *J = Matrix3(0.0);
       for (unsigned i = 0; i < 4; ++i) {
-        const double   params_p = 1 + params[0]*corner[i][0];
+        const double   xi_p = 1 + params[0]*corner[i][0];
         const double  eta_p = 1 + params[1]*corner[i][1];
-        const double dNi_dparams   = corner[i][0] * eta_p;
-        const double dNi_deta  = corner[i][1] *  params_p;
-        (*J)(0,0) += dNi_dparams   * verts[i*ndim+0];
-        (*J)(1,0) += dNi_dparams   * verts[i*ndim+1];
-        (*J)(0,1) += dNi_deta  * verts[i*ndim+0];
-        (*J)(1,1) += dNi_deta  * verts[i*ndim+1];
+        const double dNi_dxi   = corner[i][0] * eta_p;
+        const double dNi_deta  = corner[i][1] * xi_p;
+        (*J)(0,0) += dNi_dxi   * verts[i*3+0];
+        (*J)(1,0) += dNi_dxi   * verts[i*3+1];
+        (*J)(0,1) += dNi_deta  * verts[i*3+0];
+        (*J)(1,1) += dNi_deta  * verts[i*3+1];
-      (*J)(2,2) = 1.0; /* to make sure the Jacobian determinant is non-zero */
       (*J) *= 0.25;
+      (*J)(2,2) = 1.0; /* to make sure the Jacobian determinant is non-zero */
       return MB_SUCCESS;
     }// LinearQuad::jacobian()
@@ -62,7 +62,7 @@ namespace moab
         for(unsigned int j2 = 0; j2 < LinearQuad::gauss_count; ++j2) {
           x[1] = LinearQuad::gauss[j2][1];
           double w2 = LinearQuad::gauss[j2][0];
-          rval = evalFcn(x.array(),field, ndim, num_tuples, NULL, tmp_result);
+          rval = evalFcn(x.array(), field, ndim, num_tuples, NULL, tmp_result);
           rval = jacobianFcn(x.array(), verts, nverts, ndim, work, J[0]);
@@ -75,9 +75,11 @@ namespace moab
     ErrorCode LinearQuad::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
     bool LinearQuad::insideFcn(const double *params, const int ndim, const double tol)
diff --git a/src/LocalDiscretization/LinearTet.cpp b/src/LocalDiscretization/LinearTet.cpp
index 705dbee..4965cfc 100644
--- a/src/LocalDiscretization/LinearTet.cpp
+++ b/src/LocalDiscretization/LinearTet.cpp
@@ -74,27 +74,29 @@ namespace moab
     ErrorCode LinearTet::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
-      return evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, tol, work, params, is_inside);
+      return evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, iter_tol, inside_tol,
+                              work, params, is_inside);
     bool LinearTet::insideFcn(const double *params, const int , const double tol)
       return (params[0] >= -1.0-tol && params[1] >= -1.0-tol && params[2] >= -1.0-tol &&
-              params[0] + params[1] + params[2] <= -1.0+tol);
+              params[0] + params[1] + params[2] <= 1.0+tol);
     ErrorCode LinearTet::evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
@@ -138,7 +140,7 @@ namespace moab
       if (inside)
       return MB_SUCCESS;
diff --git a/src/LocalDiscretization/LinearTri.cpp b/src/LocalDiscretization/LinearTri.cpp
index 0000000..8fe9d23
--- /dev/null
+++ b/src/LocalDiscretization/LinearTri.cpp
@@ -0,0 +1,145 @@
+#include "moab/Forward.hpp"
+#include <algorithm>
+namespace moab
+    const double LinearTri::corner[3][2] = { {0,0},
+                                             {1,0},
+                                             {0,1}};
+    ErrorCode LinearTri::initFcn(const double *verts, const int /*nverts*/, double *&work) {
+        // allocate work array as:
+        // work[0..8] = T
+        // work[9..17] = Tinv
+        // work[18] = detT
+        // work[19] = detTinv
+      assert(!work && verts);
+      work = new double[20];
+      Matrix3 *T = reinterpret_cast<Matrix3*>(work),
+          *Tinv = reinterpret_cast<Matrix3*>(work+9);
+      double *detT = work+18, *detTinv = work+19;
+      *T = Matrix3(verts[1*3+0]-verts[0*3+0],verts[2*3+0]-verts[0*3+0],0.0,
+                   verts[1*3+1]-verts[0*3+1],verts[2*3+1]-verts[0*3+1],0.0,
+                   verts[1*3+2]-verts[0*3+2],verts[2*3+2]-verts[0*3+2],1.0);
+      *T *= 0.5;
+      (*T)(2,2) = 1.0;
+      *Tinv = T->inverse();
+      *detT = T->determinant();
+      *detTinv = (0.0 == *detT ? HUGE : 1.0 / *detT);
+    ErrorCode LinearTri::evalFcn(const double *params, const double *field, const int /*ndim*/, const int num_tuples,
+                                 double */*work*/, double *result) {
+      assert(params && field && num_tuples > 0);
+        // convert to [0,1]
+      double p1 = 0.5 * (1.0 + params[0]),
+          p2 = 0.5 * (1.0 + params[1]),
+          p0 = 1.0 - p1 - p2;
+      for (int j = 0; j < num_tuples; j++)
+        result[j] = p0 * field[0*num_tuples+j] + p1 * field[1*num_tuples+j] + p2 * field[2*num_tuples+j];
+    ErrorCode LinearTri::integrateFcn(const double *field, const double */*verts*/, const int /*nverts*/, const int /*ndim*/, const int num_tuples,
+                                      double *work, double *result)
+      assert(field && num_tuples > 0);
+      double tmp = work[18];
+      for (int i = 0; i < num_tuples; i++)
+        result[i] = tmp * (field[num_tuples+i] + field[2*num_tuples+i]);
+    ErrorCode LinearTri::jacobianFcn(const double *, const double *, const int, const int ,
+        // jacobian is cached in work array
+      assert(work);
+      std::copy(work, work+9, result);
+    ErrorCode LinearTri::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
+                                        const double *posn, const double *verts, const int nverts, const int ndim,
+      assert(posn && verts);
+      return evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, iter_tol, inside_tol, work,
+    bool LinearTri::insideFcn(const double *params, const int , const double tol)
+      return (params[0] >= -1.0-tol && params[1] >= -1.0-tol &&
+              params[0] + params[1] <= 1.0+tol);
+    ErrorCode LinearTri::evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
+        // TODO: should differentiate between epsilons used for
+        // Newton Raphson iteration, and epsilons used for curved boundary geometry errors
+        // right now, fix the tolerance used for NR
+      CartVect *cvparams = reinterpret_cast<CartVect*>(params);
+      const CartVect *cvposn = reinterpret_cast<const CartVect*>(posn);
+        // find best initial guess to improve convergence
+      CartVect tmp_params[] = {CartVect(-1,-1,-1), CartVect(1,-1,-1), CartVect(-1,1,-1)};
+      double resl = HUGE;
+      CartVect new_pos, tmp_pos;
+      ErrorCode rval;
+      for (unsigned int i = 0; i < 3; i++) {
+        rval = (*eval)(tmp_params[i].array(), verts, ndim, 3, work, tmp_pos.array());
+        double tmp_resl = (tmp_pos-*cvposn).length_squared();
+        if (tmp_resl < resl) {
+          *cvparams = tmp_params[i];
+          new_pos = tmp_pos;
+          resl = tmp_resl;
+        // residual is diff between old and new pos; need to minimize that
+      CartVect res = new_pos - *cvposn;
+      Matrix3 J;
+      rval = (*jacob)(cvparams->array(), verts, nverts, ndim, work, J[0]);
+      double det = J.determinant();
+      assert(det > std::numeric_limits<double>::epsilon());
+      Matrix3 Ji = J.inverse(1.0/det);
+      int iters=0;
+        // while |res| larger than tol
+      while (res % res > error_tol_sqr) {
+        if(++iters>25)
+          // new params tries to eliminate residual
+        *cvparams -= Ji * res;
+          // get the new forward-evaluated position, and its difference from the target pt
+        rval = (*eval)(params, verts, ndim, 3, work, new_pos.array());
+        res = new_pos - *cvposn;
+      if (inside)
+    }// Map::evaluate_reverse()
+} // namespace moab
diff --git a/src/LocalDiscretization/Makefile.am b/src/LocalDiscretization/Makefile.am
index 7309aef..cb34071 100644
--- a/src/LocalDiscretization/Makefile.am
+++ b/src/LocalDiscretization/Makefile.am
@@ -17,6 +17,7 @@ MOAB_LOCALDISCR_SRCS = \
 	LinearHex.cpp \
 	LinearQuad.cpp \
 	LinearTet.cpp \
+	LinearTri.cpp \
 	QuadraticHex.cpp
 MOAB_LOCALDISCR_HDRS = \
@@ -24,6 +25,7 @@ MOAB_LOCALDISCR_HDRS = \
 	moab/LinearHex.hpp \
 	moab/LinearQuad.hpp \
 	moab/LinearTet.hpp \
+	moab/LinearTri.hpp \
 	moab/QuadraticHex.hpp
 # The list of source files, and any header files that do not need to be installed
diff --git a/src/LocalDiscretization/QuadraticHex.cpp b/src/LocalDiscretization/QuadraticHex.cpp
index ca4758b..5c621f6 100644
--- a/src/LocalDiscretization/QuadraticHex.cpp
+++ b/src/LocalDiscretization/QuadraticHex.cpp
@@ -107,10 +107,12 @@ namespace moab
     ErrorCode QuadraticHex::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
     bool QuadraticHex::insideFcn(const double *params, const int ndim, const double tol)
diff --git a/src/LocalDiscretization/SpectralHex.cpp b/src/LocalDiscretization/SpectralHex.cpp
index 0e40eba..31f5391 100644
--- a/src/LocalDiscretization/SpectralHex.cpp
+++ b/src/LocalDiscretization/SpectralHex.cpp
@@ -73,7 +73,8 @@ CartVect SpectralHex::evaluate( const CartVect& params ) const
   return result;
   // replicate the functionality of hex_findpt
-bool SpectralHex::evaluate_reverse(CartVect const & xyz, CartVect &params, double tol, const CartVect &init) const
+    bool SpectralHex::evaluate_reverse(CartVect const & xyz, CartVect &params, double iter_tol, const double inside_tol,
+                                       const CartVect &init) const
   params = init;
@@ -92,7 +93,7 @@ bool SpectralHex::evaluate_reverse(CartVect const & xyz, CartVect &params, doubl
     //copy parametric coords back
   params = r;
-  return is_inside(params, tol);
+  return is_inside(params, inside_tol);
 Matrix3  SpectralHex::jacobian(const CartVect& params) const
diff --git a/src/LocalDiscretization/SpectralQuad.cpp b/src/LocalDiscretization/SpectralQuad.cpp
index cbd1251..5c11d13 100644
--- a/src/LocalDiscretization/SpectralQuad.cpp
+++ b/src/LocalDiscretization/SpectralQuad.cpp
@@ -95,7 +95,8 @@ CartVect SpectralQuad::evalFcn(const double *params, const double *field, const
 bool SpectralQuad::reverseEvalFcn(const double *posn, const double *verts, const int nverts, const int ndim,
   params = init;
@@ -114,7 +115,7 @@ bool SpectralQuad::reverseEvalFcn(const double *posn, const double *verts, const
   params = r;
-  return insideFcn(params, 2, tol);
+  return insideFcn(params, 2, inside_tol);
diff --git a/src/LocalDiscretization/moab/ElemEvaluator.hpp b/src/LocalDiscretization/moab/ElemEvaluator.hpp
index 48d34ac..29d1051 100644
--- a/src/LocalDiscretization/moab/ElemEvaluator.hpp
+++ b/src/LocalDiscretization/moab/ElemEvaluator.hpp
@@ -25,7 +25,8 @@ namespace moab {
     typedef ErrorCode (*ReverseEvalFcn)(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
-                                        const double tol, double *work, double *params, bool *is_inside);
+                                        double *work, double *params, bool *is_inside);
     class EvalSet
@@ -76,8 +77,8 @@ namespace moab {
         /** \brief Common function to do reverse evaluation based on evaluation and jacobian functions */
       static ErrorCode evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
-                                        const int ndim, const double tol, double *work, double *params,
-                                        bool *inside);
+                                        double *work, double *params, bool *inside);
         /** \brief Common function that returns true if params is in [-1,1]^ndims */
       static bool inside_function(const double *params, const int ndims, const double tol);
@@ -119,9 +120,9 @@ namespace moab {
          * \param impl MOAB instance
          * \param ent Entity handle to cache on the evaluator
          * \param tag Tag to cache on the evaluator
-         * \param tag_dim Tag dimension to cache on the evaluator
+         * \param tagged_ent_dim Dimension of entities to be tagged to cache on the evaluator
-      ElemEvaluator(Interface *impl, EntityHandle ent = 0, Tag tag = 0, int tag_dim = -1);
+      ElemEvaluator(Interface *impl, EntityHandle ent = 0, Tag tag = 0, int tagged_ent_dim = -1);
         /** \brief Evaluate cached tag at a given parametric location within the cached entity
          * If evaluating coordinates, call set_tag(0, 0), which indicates coords instead of a tag.
@@ -133,12 +134,14 @@ namespace moab {
         /** \brief Reverse-evaluate the cached entity at a given physical position
          * \param posn Position at which to evaluate parameters
-         * \param tol Tolerance of reverse evaluation, usually 10^-6 or so
+         * \param iter_tol Tolerance of reverse evaluation non-linear iteration, usually 10^-10 or so
+         * \param inside_tol Tolerance of is_inside evaluation, usually 10^-6 or so
          * \param params Result of evaluation
          * \param is_inside If non-NULL, returns true of resulting parameters place the point inside the element
          *                  (in most cases, within [-1]*(dim)
-      ErrorCode reverse_eval(const double *posn, double tol, double *params, bool *is_inside = NULL) const;
+      ErrorCode reverse_eval(const double *posn, double iter_tol, double inside_tol, double *params,
+                             bool *is_inside = NULL) const;
         /** \brief Evaluate the jacobian of the cached entity at a given parametric location
          * \param params Parameters at which to evaluate jacobian
@@ -166,14 +169,16 @@ namespace moab {
          * object is changed.
          * \param entities Entities tested
          * \param point Point tested, must have 3 dimensions, even for edge and face entities
-         * \param tol Tolerance for is_inside test
+         * \param iter_tol Tolerance for non-linear reverse evaluation
+         * \param inside_tol Tolerance for is_inside test
          * \param containing_ent Entity containing the point, returned 0 if no entity
          * \param params Parameters of point in containing entity, unchanged if no containing entity
          * \param num_evals If non-NULL, incremented each time reverse_eval is called
          * \return Returns non-success only if evaulation failed for some reason (point not in element is NOT a
          * reason for failure)
-      ErrorCode find_containing_entity(Range &entities, const double *point, double tol,
+      ErrorCode find_containing_entity(Range &entities, const double *point,
                                        unsigned int *num_evals = NULL);
@@ -186,14 +191,16 @@ namespace moab {
          * \param ent_set Entity set containing the entities to be tested
-      ErrorCode find_containing_entity(EntityHandle ent_set, const double *point, double tol,
+      ErrorCode find_containing_entity(EntityHandle ent_set, const double *point,
@@ -218,8 +225,12 @@ namespace moab {
       inline ErrorCode set_ent_handle(EntityHandle ent);
         /** \brief Get entity handle for this ElemEval */
-      inline EntityHandle get_ent_handle() const {return entHandle;};
+      inline EntityHandle get_ent_handle() const {return entHandle;}
+        /* \brief Get vertex positions cached on this EE
+      inline double *get_vert_pos() {return vertPos[0].array();}
         /* \brief Get the vertex handles cached here */
       inline const EntityHandle *get_vert_handles() const {return vertHandles;}
@@ -233,24 +244,29 @@ namespace moab {
          * To designate that vertex coordinates are the desired tag, pass in a tag handle of 0
          * and a tag dimension of 0.
          * \param tag Tag handle to cache, or 0 to cache vertex positions
-         * \param tag_dim Dimension of entities tagged with this tag
+         * \param tagged_ent_dim Dimension of entities tagged with this tag
-      inline ErrorCode set_tag_handle(Tag tag, int tag_dim = -1);
+      inline ErrorCode set_tag_handle(Tag tag, int tagged_ent_dim = -1);
         /* \brief Set the name of the tag to cache on this evaluator
          * To designate that vertex coordinates are the desired tag, pass in "COORDS" as the name
-         * \param tag Tag handle to cache, or 0 to cache vertex positions
+         * \param tag_name Tag handle to cache, or 0 to cache vertex positions
-      inline ErrorCode set_tag(const char *tag_name, int ent_dim = -1);
+      inline ErrorCode set_tag(const char *tag_name, int tagged_ent_dim = -1);
         /* \brief Get the dimension of the entities on which tag is set */
-      inline int get_tag_dim() const {return tagDim;};
+      inline int get_tagged_ent_dim() const {return taggedEntDim;};
         /* \brief Set the dimension of entities having the tag */
-      inline ErrorCode set_tag_dim(int dim);
+      inline ErrorCode set_tagged_ent_dim(int dim);
+        /* \brief Get work space, sometimes this is useful for evaluating data you don't want to set as tags on entities
+         * Can't be const because most of the functions (evaluate, integrate, etc.) take non-const work space *'s
+      inline double *get_work_space() {return workSpace;}
         /* \brief MOAB interface cached on this evaluator */
       inline Interface *get_moab() {return mbImpl;}
@@ -287,7 +303,7 @@ namespace moab {
       int numTuples;
         /** \brief Dimension of entities from which to grab tag */
-      int tagDim;
+      int taggedEntDim;
         /** \brief Tag space */
       std::vector<unsigned char> tagSpace;
@@ -300,13 +316,13 @@ namespace moab {
     }; // class ElemEvaluator
-    inline ElemEvaluator::ElemEvaluator(Interface *impl, EntityHandle ent, Tag tag, int tag_dim)
+    inline ElemEvaluator::ElemEvaluator(Interface *impl, EntityHandle ent, Tag tag, int tagged_ent_dim)
             : mbImpl(impl), entHandle(0), entType(MBMAXTYPE), entDim(-1), numVerts(0),
               vertHandles(NULL), tagHandle(0), tagCoords(false), numTuples(0),
-              tagDim(0), workSpace(NULL)
+              taggedEntDim(0), workSpace(NULL)
       if (ent) set_ent_handle(ent);
-      if (tag) set_tag_handle(tag, tag_dim);
+      if (tag) set_tag_handle(tag, tagged_ent_dim);
     inline ErrorCode ElemEvaluator::set_ent_handle(EntityHandle ent)
@@ -329,18 +345,17 @@ namespace moab {
         rval = set_tag_handle(tagHandle);
       if (evalSets[entType].initFcn) return (*evalSets[entType].initFcn)(vertPos[0].array(), numVerts, workSpace);
       return MB_SUCCESS;
-    inline ErrorCode ElemEvaluator::set_tag_handle(Tag tag, int tag_dim)
+    inline ErrorCode ElemEvaluator::set_tag_handle(Tag tag, int tagged_ent_dim)
-      if (!tag && !tag_dim) {
+      if (!tag && !tagged_ent_dim) {
         tagCoords = true;
         numTuples = 3;
-        tagDim = 0;
+        taggedEntDim = 0;
         tagHandle = 0;
         return rval;
@@ -355,14 +370,14 @@ namespace moab {
         tagCoords = false;
-      tagDim = (-1 == tag_dim ? 0 : tag_dim);
+      taggedEntDim = (-1 == tagged_ent_dim ? 0 : tagged_ent_dim);
       if (entHandle) {
-        if (0 == tagDim) {
+        if (0 == taggedEntDim) {
           rval = mbImpl->tag_get_data(tagHandle, vertHandles, numVerts, &tagSpace[0]);
-        else if (tagDim == entDim) {
+        else if (taggedEntDim == entDim) {
           rval = mbImpl->tag_get_data(tagHandle, &entHandle, 1, &tagSpace[0]);
@@ -371,14 +386,14 @@ namespace moab {
       return rval;
-    inline ErrorCode ElemEvaluator::set_tag(const char *tag_name, int tag_dim)
+    inline ErrorCode ElemEvaluator::set_tag(const char *tag_name, int tagged_ent_dim)
       if (!tag_name || strlen(tag_name) == 0) return MB_FAILURE;
       Tag tag;
       if (!strcmp(tag_name, "COORDS")) {
         tagCoords = true;
-        tagDim = 0;
+        taggedEntDim = 0;
         numTuples = 3;
         tagHandle = 0;
           // can return here, because vertex coords already cached when entity handle set
@@ -399,15 +414,15 @@ namespace moab {
           tagCoords = false;
-        tagDim = (-1 == tag_dim ? entDim : tag_dim);
+        taggedEntDim = (-1 == tagged_ent_dim ? entDim : tagged_ent_dim);
       if (entHandle) {
@@ -431,16 +446,17 @@ namespace moab {
       assert(entHandle && MBMAXTYPE != entType);
       return (*evalSets[entType].evalFcn)(params,
                                           (tagCoords ? (const double*) vertPos[0].array(): (const double*)&tagSpace[0]),
-                                          entDim, (-1 == num_tuples ? numTuples : num_tuples),
-                                          workSpace, result);
+                                          entDim,
+                                          (-1 == num_tuples ? numTuples : num_tuples), workSpace, result);
-    inline ErrorCode ElemEvaluator::reverse_eval(const double *posn, const double tol, double *params, bool *ins) const
+    inline ErrorCode ElemEvaluator::reverse_eval(const double *posn, const double iter_tol, const double inside_tol,
+                                                 double *params, bool *ins) const
       return (*evalSets[entType].reverseEvalFcn)(evalSets[entType].evalFcn, evalSets[entType].jacobianFcn, evalSets[entType].insideFcn,
-                                                 posn, vertPos[0].array(), numVerts, entDim, tol, workSpace,
-                                                 params, ins);
+                                                 posn, vertPos[0].array(), numVerts,
+                                                 entDim, iter_tol, inside_tol, workSpace, params, ins);
       /** \brief Evaluate the jacobian of the cached entity at a given parametric location */
@@ -456,7 +472,7 @@ namespace moab {
       assert(entHandle && MBMAXTYPE != entType && (tagCoords || tagHandle));
       if (!tagCoords) {
-        if (0 == tagDim) rval = mbImpl->tag_get_data(tagHandle, vertHandles, numVerts, (void*)&tagSpace[0]);
+        if (0 == taggedEntDim) rval = mbImpl->tag_get_data(tagHandle, vertHandles, numVerts, (void*)&tagSpace[0]);
         else rval = mbImpl->tag_get_data(tagHandle, &entHandle, 1, (void*)&tagSpace[0]);
@@ -465,7 +481,8 @@ namespace moab {
                                                workSpace, result);
-    inline ErrorCode ElemEvaluator::find_containing_entity(EntityHandle ent_set, const double *point, double tol,
+    inline ErrorCode ElemEvaluator::find_containing_entity(EntityHandle ent_set, const double *point,
@@ -473,7 +490,7 @@ namespace moab {
       Range entities;
       ErrorCode rval = mbImpl->get_entities_by_handle(ent_set, entities);
-      else return find_containing_entity(entities, point, tol, containing_ent, params, num_evals);
+      else return find_containing_entity(entities, point, iter_tol, inside_tol, containing_ent, params, num_evals);
     inline bool ElemEvaluator::inside(const double *params, const double tol) const
diff --git a/src/LocalDiscretization/moab/LinearHex.hpp b/src/LocalDiscretization/moab/LinearHex.hpp
index e7ca3f4..03ed33f 100644
--- a/src/LocalDiscretization/moab/LinearHex.hpp
+++ b/src/LocalDiscretization/moab/LinearHex.hpp
@@ -17,7 +17,8 @@ public:
     /** \brief Reverse-evaluation of parametric coordinates at physical space position */
   static ErrorCode reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
+                                  double *params, bool *is_inside);
     /** \brief Evaluate the jacobian at a specified parametric position */
   static ErrorCode jacobianFcn(const double *params, const double *verts, const int nverts, const int ndim,
This diff is so big that we needed to truncate the remainder.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
