[MOAB-dev] commit/MOAB: iulian07: missed modified files for	transport example
    commits-noreply at bitbucket.org
    Wed Jan  1 10:38:55 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/8d282cbf3e3a/
Changeset:   8d282cbf3e3a
Branch:      master
User:        iulian07
Date:        2014-01-01 17:32:24
Summary:     missed modified files for transport example
these changes should be part of previous commit 1791bb5
make check did not fail because the new examples are not tests, just execs
the second covering algorithm needs to form the remote_cells tuple to be able
to call later the update  tracer method.
so there are 3 algs implemented; 1st one should be removed
Affected #:  3 files
diff --git a/tools/mbcslam/Intx2Mesh.cpp b/tools/mbcslam/Intx2Mesh.cpp
index 74f65ff..416315e 100644
--- a/tools/mbcslam/Intx2Mesh.cpp
+++ b/tools/mbcslam/Intx2Mesh.cpp
@@ -1164,6 +1164,13 @@ ErrorCode Intx2Mesh::create_departure_mesh_2nd_alg(EntityHandle & euler_set, Ent
   std::string tag_name("DP");
   rval = mb->tag_get_handle(tag_name.c_str(), 3, MB_TYPE_DOUBLE, dpTag, MB_TAG_DENSE);
   ERRORR(rval, "can't get DP tag");
+  EntityHandle dum=0;
+  Tag corrTag;
+  rval = mb->tag_get_handle(CORRTAGNAME,
+                                           1, MB_TYPE_HANDLE, corrTag,
+                                           MB_TAG_DENSE|MB_TAG_CREAT, &dum);
+  ERRORR(rval, "can't get CORR tag");
   // get all local verts
   Range local_verts;
   rval = mb->get_connectivity(localEnts, local_verts);
@@ -1245,7 +1252,7 @@ ErrorCode Intx2Mesh::create_departure_mesh_2nd_alg(EntityHandle & euler_set, Ent
   TLv.enableWriteAccess();
   int sizeTuple = 2+max_edges; // determined earlier
-  TLq.initialize(2+max_edges, 0, 0, 0, numq); // to proc, elem GLOBAL ID, connectivity[10] (global ID v)
+  TLq.initialize(2+max_edges, 0, 1, 0, numq); // to proc, elem GLOBAL ID, connectivity[10] (global ID v), local eh
   TLq.enableWriteAccess();
   std::cout << "from proc " << my_rank << " send " << numv << " vertices and " << numq << " elements\n";
@@ -1295,6 +1302,8 @@ ErrorCode Intx2Mesh::create_departure_mesh_2nd_alg(EntityHandle & euler_set, Ent
         TLq.vi_wr[sizeTuple*n+2+k] = 0; // fill the rest of node ids with 0; we know that the node ids start from 1!
+      TLq.vul_wr[n]=q; // save here the entity handle, it will be communicated back
+      // mabe we should forget about global ID
       TLq.inc_n();
@@ -1372,12 +1381,23 @@ ErrorCode Intx2Mesh::create_departure_mesh_2nd_alg(EntityHandle & euler_set, Ent
     rval=mb->tag_get_data(gid, &q, 1, &gid_el);
     ERRORR(rval, "can't get element global ID ");
     globalID_to_eh[gid_el]=new_element;
+    // is this redundant or not?
+    rval = mb->tag_set_data(corrTag, &new_element, 1, &q);
+    ERRORR(rval, "can't set corr tag on new el");
+    // set the global id on new elem
+    rval = mb->tag_set_data(gid, &new_element, 1, &gid_el);
+    ERRORR(rval, "can't set global id tag on new el");
   // now look at all elements received through; we do not want to duplicate them
   n=TLq.get_n();// number of elements received by this processor
+  // form the remote cells, that will be used to send the tracer info back to the originating proc
+  remote_cells = new TupleList();
+  remote_cells->initialize(2, 0, 1, 1, n);
+  remote_cells->enableWriteAccess();
   for (int i=0; i<n; i++)
     int globalIdEl = TLq.vi_rd[sizeTuple*i+1];
+    int from_proc =  TLq.vi_wr[sizeTuple*i];
     // do we already have a quad with this global ID, represented?
     if (globalID_to_eh.find(globalIdEl)==globalID_to_eh.end())
@@ -1408,6 +1428,16 @@ ErrorCode Intx2Mesh::create_departure_mesh_2nd_alg(EntityHandle & euler_set, Ent
       globalID_to_eh[globalIdEl]=new_element;
       rval = mb->add_entities(covering_lagr_set, &new_element, 1);
       ERRORR(rval, "can't add new element to dep set");
+     /* rval = mb->tag_set_data(corrTag, &new_element, 1, &q);
+      ERRORR(rval, "can't set corr tag on new el");*/
+      remote_cells->vi_wr[2*i]=from_proc;
+      remote_cells->vi_wr[2*i+1]=globalIdEl;
+      remote_cells->vr_wr[i] = 0.; // no contribution yet sent back
+      remote_cells->vul_wr[i]= TLq.vul_rd[i];// this is the corresponding red cell (arrival)
+      remote_cells->inc_n();
+      rval = mb->tag_set_data(gid, &new_element, 1, &globalIdEl);
   return MB_SUCCESS;
diff --git a/tools/mbcslam/Makefile.am b/tools/mbcslam/Makefile.am
index 9138c7a..766c8ab 100644
--- a/tools/mbcslam/Makefile.am
+++ b/tools/mbcslam/Makefile.am
@@ -24,7 +24,7 @@ LDADD = $(top_builddir)/src/libMOAB.la libmbcslam.la
 libmbcslam_la_SOURCES = \
    Intx2Mesh.cpp Intx2Mesh.hpp Intx2MeshOnSphere.cpp Intx2MeshOnSphere.hpp \
-     CslamUtils.cpp CslamUtils.hpp Intx2MeshInPlane.cpp Intx2MeshInPlane.hpp
+     CslamUtils.cpp CslamUtils.hpp Intx2MeshInPlane.cpp Intx2MeshInPlane.hpp wrap_intx.cpp
 # these will be installed
 libmbcslam_la_include_HEADERS =
@@ -39,7 +39,7 @@ cfgdir = $(libdir)
 TESTS = intx_on_sphere_test  intx_in_plane_test spherical_area_test \
          case1_test  intx_mpas
-noinst_PROGRAMS =  cslam_par_test diffusion proj1
+noinst_PROGRAMS =  cslam_par_test diffusion proj1 intx_imesh create_dp advection
 check_PROGRAMS = $(TESTS)
 intx_on_sphere_test_SOURCES = intx_on_sphere_test.cpp
@@ -51,6 +51,9 @@ case1_test_SOURCES = case1_test.cpp
 intx_mpas_SOURCES = intx_mpas.cpp
 cslam_par_test_SOURCES = cslam_par_test.cpp
 proj1_SOURCES = proj1.cpp
+intx_imesh_SOURCES = intx_imesh.cpp
+create_dp_SOURCES = create_dp.cpp
+advection_SOURCES = advection.F90
 EXTRA_DIST  = lagrangeHomme.vtk  \
               eulerHomme.vtk \
diff --git a/tools/mbcslam/wrap_intx.cpp b/tools/mbcslam/wrap_intx.cpp
index fa6bc20..e38c897 100644
--- a/tools/mbcslam/wrap_intx.cpp
+++ b/tools/mbcslam/wrap_intx.cpp
@@ -17,7 +17,7 @@
 using namespace moab;
 double radius = 1.;
 double gtol = 1.e-9;
-bool debug = true;
+bool debug = false;
 #ifdef __cplusplus
 extern "C" {
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
