[MOAB-dev] Neumann boundary condition
Tim Tautges (ANL)
tautges at mcs.anl.gov
Thu Dec 12 16:09:22 CST 2013
And regarding boundary conditions: the NEUMANN_SET tag is of type integer, and is meant to identify and keep separate
the different neumann boundary condition *groupings*. The physical property that constitutes the boundary condition,
e.g. mass flux across a face, would appear as a different tag, probably on that set. That assumes you're accessing the
boundary condition in a loop over faces in that set. If you're looping over hexes and want to get whether a boundary
condition is associated with a face (i.e. you need random access from a face handle) you might be better off storing the
flux value on each face (it's a speed-memory tradeoff, and MOAB usually chooses memory before speed, assuming you can
loop over those groupings without needing random access).
- tim
On 12/11/2013 06:00 PM, Iulian Grindeanu wrote:
> What solver do you use?
> I'm trying to implement MOAB in our CFD code
> Again, I don't understand the question, what do you need?
> Initially i've got only nodes and hexes.
> Every time step i've got loop over cells (hexes). For each cell the scheme demands info from its each face. I can
> get faces with get_adjacencies method. I've read somewhere that after first calling of that method MOAB stores faces
> array internally to speed up future calls. Or i should better store them myself before time-stepping?
> moab, after first adjacency call, will store up-vertex adjacencies (so for each vertex in the mesh, what are the
> entities adjacent to each vertex; it will be a list ordered by handles, it will contain edges, faces, hexas)
> In your case, you should first create all faces with get_adjacency() call, with create = true
> No edges will be created if you do not request it.
> These lists (upvertex adjacencies) will be used for subsequent adjacency calls, to determine the adjacency between a
> face and a hex, for example;
> If you do it many times, it may be better to store those adjacencies yourself, in your arrays/data
> Opposing face to what?
> For each face X i also have to get two faces which are:
> - belong to the cells sharing face X
> - not having common vertices with face X
> That's what i meant by faces lying opposite to face X
> Sorry for not always being clear
> You can use for this:
> ErrorCode MeshTopoUtil::opposite_entity(const EntityHandle parent,
> const EntityHandle child,
> EntityHandle &opposite_element)
> Again, if you do it many times, it may be better to store that info somewhere else.
> be careful about orientation of the face within a hexa; you can use side_number to see how are they oriented
> (so one face between 2 hexas will be oriented positively for one, and negatively for the other one; moab convention is
> positive if its normal points outward)
> Thanks
> Best Regards,
> Iulian
> On Wed, 11 Dec 2013 16:56:35 -0600 (CST), Iulian Grindeanu wrote:
> p { margin: 0; }
> So, as i can understand, any value of NEUMANN_SET tag corresponds to some certain rule implemented in solver
> the value is set by the user, but used by the solver. What solver do you use? for moab, the value is just an
> integer, and should be unique for each set, but it is not mandatory. It is really just a way to group and
> differentiate boundary conditions;
> I've got one more question - having only nodes and hexagonals in .h5m mesh file, what is the best way to
> find and store the opposite face from the neighbouring cell for each hexagonal's face?
> hexagons? I assume you mean hexahedra, because you are asking about "faces". A hexagon is 2d, it has only one
> face, in moab terms.
> a hexahedron has 6 faces.
> a hexahedron can have though 6 neighbors, with which shares a face (unless it is on the boundary).
> from each hexahedron, you get the connected vertices with get_connectivity; you can get adjacent faces with
> A common face between 2 hexagons can be found with get_adjacencies method too, something like this:
> std::vector adjacencies, from_entities = {hex1, hex2};
> // generate common face between these 2 hexas, if it exists
> mb->get_adjacencies( from_entities, 2, 2, true, adjacencies, Interface::INTERSECT);
> // adjacencies.size() should be 1 (or 0, if the hexes for not share a face)
> Iulian
> Thanks
> On Wed, 11 Dec 2013 15:25:00 -0600 (CST), Iulian Grindeanu wrote:
> p { margin: 0; }
> programmatically?
> a neumann set in moab is usually a set of boundary faces (quads in a hexahedral mesh, or triangles in a
> tetrahedral mesh)
> what kind of solver do you have?
> if you know the tag value, you can obtain the set that has that tag value, with something like
> Range neumann_sets;
> Tag neu_tag;
> int value_neumann_tag= 100; // your value, set it accordingly
> mb->tag_get_handle(NEUMANN_SET_TAG_NAME, neu_tag, 1, MB_TYPE_INTEGER);
> mb->get_entities_by_type_and_tag(0, MBENTITYSET, &neu_tag, &value_neumann_tag, 1, neumann_sets);
> neumann_sets[0] should be your set.
> then you can get entities from it with
> Range entities;
> mb->get_entities_by_handle(neumann_sets[0], entities);
> Entities should be your quads or triangles. it is up to the specific solver syntax to set pressure on
> them (or other BCs)
> Maybe I didn't understand your question
> Iulian
> Hello MOAB-dev,
> Can you please explain how can i set a certain Neumann boundary condition
> for selected set of faces via NEUMANN_SET tag?
> For example the normal derivative of pressure
> Thanks
> Anton
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
