[MOAB-dev] commit/MOAB: janehu: Fixed the bug Andy Davis reported for getting graphics for edges, the first tol is angle tolerance, in degree.
Paul Wilson
wilsonp at engr.wisc.edu
Tue Dec 3 11:24:23 CST 2013
Hi Jane
Did this interface change? In CGM? In ACIS?
Since faceting tolerance is the primary parameter we use, it probably needs to be still passed into the get_graphics method, perhaps as well as a default norm_tol.
Paul
Professor, Nuclear Engineering
Faculty Director, Advanced Computing Infrastructure
UW-Madison
wilsonp at engr.wisc.edu, 608.263.0807
Sent from my iPhone
On Dec 3, 2013, at 11:17, commits-noreply at bitbucket.org wrote:
> 1 new commit in MOAB:
> https://bitbucket.org/fathomteam/moab/commits/119198dc4d96/
> Changeset: 119198dc4d96
> Branch: master
> User: janehu
> Date: 2013-12-03 18:15:13
> Summary: Fixed the bug Andy Davis reported for getting graphics for edges, the first tol is angle tolerance, in degree.
> Affected #: 1 file
> diff --git a/src/io/ReadCGM.cpp b/src/io/ReadCGM.cpp
> index 13b64fb..9b6ba09 100644
> --- a/src/io/ReadCGM.cpp
> +++ b/src/io/ReadCGM.cpp
> @@ -474,7 +474,7 @@ ErrorCode ReadCGM::load_file(const char *cgm_file_name,
> RefEdge* edge = dynamic_cast<RefEdge*>(ci->first);
> Curve* curve = edge->get_curve_ptr();
> data.clean_out();
> - edge->get_graphics( data, faceting_tol);
> + edge->get_graphics( data, norm_tol);
> if (CUBIT_SUCCESS != s)
> return MB_FAILURE;
> Repository URL: https://bitbucket.org/fathomteam/moab/
> This is a commit notification from bitbucket.org. You are receiving
> this because you have the service enabled, addressing the recipient of
> this email.
