[MOAB-dev] commit/MOAB: iulian07: remove dependency of mbcslam to mbcoupler
commits-noreply at bitbucket.org
Mon Dec 2 10:26:32 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/3442bdac533f/
Changeset: 3442bdac533f
Branch: master
User: iulian07
Date: 2013-12-02 17:23:01
Summary: remove dependency of mbcslam to mbcoupler
it was used only for spec_visu_test, spectral element defined in
ElemUtil.hpp
imesh dependency will remain, because of fortran
Affected #: 4 files
diff --git a/tools/mbcslam/CslamUtils.cpp b/tools/mbcslam/CslamUtils.cpp
index 90a13e3..6cca02d 100644
--- a/tools/mbcslam/CslamUtils.cpp
+++ b/tools/mbcslam/CslamUtils.cpp
@@ -9,10 +9,10 @@
#include <math.h>
// this is from mbcoupler; maybe it should be moved somewhere in moab src
// right now, add a dependency to mbcoupler
-#include "ElemUtil.hpp"
+// #include "ElemUtil.hpp"
#include "moab/MergeMesh.hpp"
#include "moab/ReadUtilIface.hpp"
+#include <iostream>
// this is for sstream
#include <sstream>
@@ -476,7 +476,8 @@ CartVect spherical_to_cart (SphereCoords & sc)
res[2] = sc.R * sin(sc.lat); // z
return res;
+// remove dependency to coupler now
+#if 0
ErrorCode SpectralVisuMesh(Interface * mb, Range & input, int NP, EntityHandle & outputSet, double tolerance)
ErrorCode rval = MB_SUCCESS;
@@ -557,7 +558,8 @@ ErrorCode SpectralVisuMesh(Interface * mb, Range & input, int NP, EntityHandle &
return rval;
+// remove for the time being dependency on coupler
+#endif
ErrorCode ProjectOnSphere(Interface * mb, EntityHandle set, double R)
Range ents;
diff --git a/tools/mbcslam/CslamUtils.hpp b/tools/mbcslam/CslamUtils.hpp
index bc1223d..05775df 100644
--- a/tools/mbcslam/CslamUtils.hpp
+++ b/tools/mbcslam/CslamUtils.hpp
@@ -89,7 +89,7 @@ CartVect spherical_to_cart (SphereCoords &) ;
* output: a set with refined elements; with proper input, it should be pretty
* similar to a Homme mesh read with ReadNC
-ErrorCode SpectralVisuMesh(Interface * mb, Range & input, int NP, EntityHandle & outputSet, double tolerance);
+//ErrorCode SpectralVisuMesh(Interface * mb, Range & input, int NP, EntityHandle & outputSet, double tolerance);
* given an entity set, get all nodes and project them on a sphere with given radius
diff --git a/tools/mbcslam/Makefile.am b/tools/mbcslam/Makefile.am
index b6b7b9d..9138c7a 100644
--- a/tools/mbcslam/Makefile.am
+++ b/tools/mbcslam/Makefile.am
@@ -18,10 +18,9 @@ AM_CPPFLAGS += -DSRCDIR=$(srcdir) \
-I$(top_srcdir)/test
lib_LTLIBRARIES = libmbcslam.la
-libmbcslam_la_LIBADD = $(top_builddir)/src/libMOAB.la $(top_builddir)/itaps/imesh/libiMesh.la \
- $(top_builddir)/tools/mbcoupler/libmbcoupler.la
+libmbcslam_la_LIBADD = $(top_builddir)/src/libMOAB.la $(top_builddir)/itaps/imesh/libiMesh.la
-LDADD = $(top_builddir)/src/libMOAB.la libmbcslam.la $(top_builddir)/tools/mbcoupler/libmbcoupler.la
+LDADD = $(top_builddir)/src/libMOAB.la libmbcslam.la
libmbcslam_la_SOURCES = \
Intx2Mesh.cpp Intx2Mesh.hpp Intx2MeshOnSphere.cpp Intx2MeshOnSphere.hpp \
@@ -38,7 +37,7 @@ libmbcslam_la_includedir = $(includedir)
# check that only libraries are going in $(libdir)
cfgdir = $(libdir)
-TESTS = intx_on_sphere_test intx_in_plane_test spec_visu_test spherical_area_test \
+TESTS = intx_on_sphere_test intx_in_plane_test spherical_area_test \
case1_test intx_mpas
noinst_PROGRAMS = cslam_par_test diffusion proj1
@@ -46,7 +45,7 @@ check_PROGRAMS = $(TESTS)
intx_on_sphere_test_SOURCES = intx_on_sphere_test.cpp
diffusion_SOURCES = diffusion.cpp
intx_in_plane_test_SOURCES = intx_in_plane_test.cpp
-spec_visu_test_SOURCES = spec_visu_test.cpp
+# spec_visu_test_SOURCES = spec_visu_test.cpp
spherical_area_test_SOURCES = spherical_area_test.cpp
case1_test_SOURCES = case1_test.cpp
intx_mpas_SOURCES = intx_mpas.cpp
diff --git a/tools/mbcslam/spec_visu_test.cpp b/tools/mbcslam/spec_visu_test.cpp
deleted file mode 100644
index 54c7e8f..0000000
--- a/tools/mbcslam/spec_visu_test.cpp
+++ /dev/null
@@ -1,82 +0,0 @@
- * spec_visu_test.cpp
- * Will refine a quad mesh to a spectral visu mesh
- * It may even project on the sphere :)
- * Created on: Oct 21, 2012
-#include <stdio.h>
-#include "moab/Core.hpp"
-#include "moab/Interface.hpp"
-#include "CslamUtils.hpp"
-#define STRINGIFY_(X) #X
-#define STRINGIFY(X) STRINGIFY_(X)
-using namespace moab;
-int main(int argc, char* argv[])
- // check command line arg
- const char *filename_mesh = STRINGIFY(SRCDIR) "/eulerHomme.vtk";
- const char *newFile = "spectral.vtk";
- int NP = 4; // number of nodes in each direction
- double tolerance = 0.0001;
- double R = 6.; // should be input
- if (argc == 6)
- filename_mesh = argv[1];
- NP = atoi(argv[2]);
- newFile = argv[3];
- R = atof(argv[4]);
- tolerance = atof(argv[5]);
- else
- printf("Usage: %s <mesh_filename><NP><newFile><tolerance>\n", argv[0]);
- if (argc != 1)
- return 1;
- printf("run: %s %d %s %f %f\n",
- filename_mesh, NP, newFile, R, tolerance);
- // read input mesh in a set
- ErrorCode rval = MB_SUCCESS;
- Core moab;
- Interface* mb = &moab;// global
- EntityHandle sf;
- rval = mb->create_meshset(MESHSET_SET, sf);
- if (MB_SUCCESS != rval)
- return 1;
- rval=mb->load_file(filename_mesh, &sf);
- return 1;
- Range inputRange;
- // get quads of interest
- rval = mb->get_entities_by_type(sf, MBQUAD, inputRange);
- return 1;
- EntityHandle outputSet;
- rval = mb->create_meshset(MESHSET_SET, outputSet);
- return 1;
- rval = SpectralVisuMesh( mb, inputRange, NP, outputSet, tolerance);
- return 1;
- rval = ProjectOnSphere(mb, outputSet, R);
- return 1;
- rval = mb->write_mesh(newFile, &outputSet, 1);
- return 1;
- return 0;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
