[MOAB-dev] commit/MOAB: iulian07: remove the Push example from	itaps/imesh
    commits-noreply at bitbucket.org
    Wed Nov 27 15:39:36 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/75901a2bee29/
Changeset:   75901a2bee29
Branch:      master
User:        iulian07
Date:        2013-11-27 22:34:56
Summary:     remove the Push example from itaps/imesh
on platforms you cannot figure out the correct compiling/linking
you can try moving it there (from examples) and let autotools fix it for you :)
or look what includes and what libraries are added when you compile
one of the fortran tests in itaps/imesh, using verbose option:
 (like make V=1 FindAdjacencyF90)
Affected #:  3 files
diff --git a/examples/PushParMeshIntoMoabF90.F90 b/examples/PushParMeshIntoMoabF90.F90
index 131d19c..2d5a0f4 100644
--- a/examples/PushParMeshIntoMoabF90.F90
+++ b/examples/PushParMeshIntoMoabF90.F90
@@ -16,6 +16,8 @@ program PushParMeshIntoMoab
   use ISO_C_BINDING
   implicit none
+#include "mpif.h"
 #ifdef USE_MPI
 #  include "iMeshP_f.h"
 #else
@@ -49,7 +51,7 @@ program PushParMeshIntoMoab
 #ifdef USE_MPI
   ! local variables for parallel runs
   iMeshP_PartitionHandle imeshp
-  integer MPI_COMM_WORLD
+!    integer MPI_COMM_WORLD
 #endif
   ! vertex positions, latlon coords, (lat, lon, lev), fortran ordering
diff --git a/itaps/imesh/Makefile.am b/itaps/imesh/Makefile.am
index d8a81eb..647b8c1 100644
--- a/itaps/imesh/Makefile.am
+++ b/itaps/imesh/Makefile.am
@@ -38,9 +38,6 @@ if PARALLEL
 #  check_PROGRAMS += partest iMeshP_unit_tests moabtest
   check_PROGRAMS += partest MOAB_iMeshP_unit_tests
-if ENABLE_FORTRAN
-  check_PROGRAMS += PushParMeshIntoMoabF90
-endif
 #  moabtest_SOURCES = moabtest.F
 #  check_PROGRAMS += ftest
@@ -72,9 +69,6 @@ ScdMeshF77_DEPENDENCIES = $(TESTDEPS)
 FindAdjacencyF90_SOURCES = FindAdjacencyF90.F90
 FindAdjacencyF90_DEPENDENCIES = $(TESTDEPS)
-PushParMeshIntoMoabF90_SOURCES = PushParMeshIntoMoabF90.F90
-PushParMeshIntoMoabF90_DEPENDENCIES = $(TESTDEPS)
 lib_LTLIBRARIES = libiMesh.la
 libiMesh_la_includedir = $(includedir)
diff --git a/itaps/imesh/PushParMeshIntoMoabF90.F90 b/itaps/imesh/PushParMeshIntoMoabF90.F90
deleted file mode 100644
index 46d577a..0000000
--- a/itaps/imesh/PushParMeshIntoMoabF90.F90
+++ /dev/null
@@ -1,283 +0,0 @@
-! PushParMeshIntoMoabF90: push parallel mesh into moab, F90 version
-! This program shows how to push a mesh into MOAB in parallel from Fortran90, with sufficient
-! information to resolve boundary sharing and exchange a layer of ghost information.
-! To successfully link this example, you need to specify FCFLAGS that include:
-!    a) -DUSE_MPI, and
-!    b) flags required to link Fortran90 MPI programs with the C++ compiler; these flags
-!       can often be found on your system by inspecting the output of 'mpif90 -show'
-! For example, using gcc, the link line looks like:
-!   make MOAB_DIR=<moab install dir> FCFLAGS="-DUSE_MPI -I/usr/lib/openmpi/include -pthread -I/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -lmpi_f90 -lmpi_f77 -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl" PushParMeshIntoMoabF90
-! Usage: PushParMeshIntoMoab
-program PushParMeshIntoMoab
-  use ISO_C_BINDING
-  implicit none
-#include "mpif.h"
-#ifdef USE_MPI
-#  include "iMeshP_f.h"
-#else
-#  include "iMesh_f.h"
-#endif
-  ! declarations
-  ! imesh is the instance handle
-  iMesh_Instance imesh
-  ! NUMV, NUME, NVPERE are the hardwired here; these are for the whole mesh,
-  ! local mesh determined later
-  integer NUMV, NUME, NVPERE
-  parameter (NUMV = 8)   ! # vertices in whole mesh
-  parameter (NUME = 6)   ! # elements in whole mesh
-  parameter (NVPERE = 4) ! # vertices per element
-  ! ents, verts will be arrays storing vertex/entity handles
-  iBase_EntityHandle, pointer :: ents, verts
-  iBase_EntitySetHandle root_set
-  TYPE(C_PTR) :: vertsPtr, entsPtr
-  ! storage for vertex positions, element connectivity indices, global vertex ids
-  real*8 coords(0:3*NUMV-1)
-  integer iconn(0:4*NUME-1), gids(0:NUMV-1)
-  ! local variables
-  integer lgids(0:NUMV-1), lconn(0:4*NUME-1)
-  real*8 lcoords(0:3*NUMV-1)
-  integer lnumv, lvids(0:NUMV-1), gvids(0:NUMV-1)
-  integer lvpe, ltp ! lvpe = # vertices per entity, ltp = element type
-  integer ic, ie, iv, istart, iend, ierr, indv, lnume, rank, sz
-#ifdef USE_MPI
-  ! local variables for parallel runs
-  iMeshP_PartitionHandle imeshp
-  ! integer MPI_COMM_WORLD
-#endif
-  ! vertex positions, latlon coords, (lat, lon, lev), fortran ordering
-  ! (first index varying fastest)
-  data coords / &
-       0.0, -45.0,   0.0,  90.0, -45.0,   0.0, 180.0, -45.0,   0.0, 270.0, -45.0,   0.0, &
-       0.0,  45.0,   0.0,  90.0,  45.0,   0.0, 180.0,  45.0,   0.0, 270.0,  45.0,   0.0 /
-  ! quad index numbering, each quad ccw, sides then bottom then top
-  data iconn / &
-       0, 1, 5, 4,  &
-       1, 2, 6, 5,  &
-       2, 3, 7, 6,  &
-       3, 0, 4, 7,  &
-       0, 3, 2, 1,  &
-       4, 5, 6, 7 /
-  data lvpe /4/ ! quads in this example
-  data ltp / iMesh_QUADRILATERAL / ! from iBase_f.h
-  ! initialize global vertex ids
-  do iv = 0, NUMV-1
-     lgids(iv) = iv+1
-  end do
-#ifdef USE_MPI
-  ! init the parallel partition
-  call MPI_INIT(ierr)
-  call MPI_COMM_SIZE(MPI_COMM_WORLD, sz, ierr)
-  call MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierr)
-  ! compute starting/ending element numbers
-  lnume = NUME / sz
-  istart = rank * lnume
-  iend = istart + lnume - 1
-  if (rank .eq. sz-1) then
-     iend = NUME-1
-     lnume = iend - istart + 1
-  endif
-#else
-  ! set the starting/ending element numbers
-  istart = 0
-  iend = NUME-1
-  lnume = NUME
-#endif
-  ! for my elements, figure out which vertices I use and accumulate local indices and coords
-  ! lvids stores the local 0-based index for each vertex; -1 means vertex i isn't used locally
-  ! also build up connectivity indices for local elements, in lconn
-  do iv = 0, NUMV-1
-     lvids(iv) = -1
-  end do
-  lnumv = -1
-  do ie = istart, iend
-     do iv = 0, lvpe-1
-        indv = iconn(lvpe*ie + iv)
-        if (lvids(indv) .eq. -1) then
-           lnumv = lnumv + 1 ! increment local # verts
-           do ic = 0, 2 ! cache local coords
-              lcoords(3*lnumv+ic) = coords(3*indv+ic)
-           end do
-           lvids(indv) = lnumv
-           gvids(lnumv) = 1+indv
-        end if
-        lconn(lvpe*(ie-istart)+iv) = lvids(indv)
-     end do  ! do iv
-  end do  ! do ie
-  lnumv = lnumv + 1
-  ! now create the mesh; this also initializes parallel sharing and ghost exchange
-  imesh = 0
-  imeshp = 0
-  call create_mesh(imesh, imeshp, MPI_COMM_WORLD, lnumv, lnume, gvids, lvpe, ltp, lcoords, lconn, &
-       vertsPtr, entsPtr, ierr)
-  call c_f_pointer(vertsPtr, verts, [lnumv])
-  call c_f_pointer(entsPtr, ents, [lnume])
-  ! get/report number of vertices, elements
-  call iMesh_getRootSet(%VAL(imesh), root_set, ierr)
-  iv = 0
-  ie = 0
-#ifdef USE_MPI
-  call iMeshP_getNumOfTypeAll(%VAL(imesh), %VAL(imeshp), %VAL(root_set), %VAL(iBase_VERTEX), iv, ierr)
-  call iMeshP_getNumOfTypeAll(%VAL(imesh), %VAL(imeshp), %VAL(root_set), %VAL(iBase_FACE), ie, ierr)
-  if (rank .eq. 0) then
-     write(0,*) "Number of vertices = ", iv
-     write(0,*) "Number of entities = ", ie
-  endif
-#else
-  call iMesh_getNumOfTypeAll(%VAL(imesh), %VAL(root_set), %VAL(iBase_VERTEX), iv, ierr)
-  call iMesh_getNumOfTypeAll(%VAL(imesh), %VAL(root_set), %VAL(iBase_FACE), ie, ierr)
-#endif
-  ! from here, can use verts and ents as (1-based) arrays of entity handles for input to other iMesh functions
-  call MPI_FINALIZE(ierr)
-  stop
-end program PushParMeshIntoMoab
-subroutine create_mesh( &
-  !     interfaces
-     imesh, imeshp, &
-  !     input
-     comm, numv, nume, vgids, nvpe, tp, posn, iconn, &
-  !     output
-  ! create a mesh with numv vertices and nume elements, with elements of type tp
-  ! vertices have positions in posn (3 coordinates each, interleaved xyzxyz...), indexed from 0
-  ! elements have nvpe vertices per entity, with connectivity indices stored in iconn, referencing
-  ! vertices using 0-based indices; vertex and entity handles are output in arrays passed in
-  ! if imesh/imeshp are 0, imesh/imeshp are initialized in this subroutine
-  use ISO_C_BINDING
-  implicit none
-#ifdef USE_MPI
-#  include "mpif.h"
-#else
-#endif
-  ! subroutine arguments
-  integer numv, nume, nvpe, vgids(0:*), iconn(0:*), ierr, tp
-  real*8 posn(0:*)
-#ifdef USE_MPI
-  integer comm
-#endif
-  ! local variables
-  integer comm_sz, comm_rank, numa, numo, iv, ie
-  TYPE(C_PTR) :: statsPtr
-  integer, allocatable, target :: stats(:)
-  iBase_TagHandle tagh
-  integer i
-  iBase_EntityHandle, pointer :: verts(:), ents(:)
-  iBase_EntityHandle, allocatable :: conn(:)
-#ifdef USE_MPI
-  IBASE_HANDLE_T mpi_comm_c
-  TYPE(C_PTR) :: partsPtr
-  iMeshP_PartHandle, pointer :: parts(:)
-  iMeshP_PartHandle part
-  integer partsa, partso
-#endif
-  ! create the Mesh instance
-  if (imesh .eq. 0) then
-     call iMesh_newMesh("MOAB", imesh, ierr)
-  end if
-#ifdef USE_MPI
-  if (imeshp .eq. 0) then
-     call iMeshP_getCommunicator(%VAL(imesh), MPI_COMM_WORLD, mpi_comm_c, ierr)
-     call iMeshP_createPartitionAll(%VAL(imesh), %VAL(mpi_comm_c), imeshp, ierr)
-     call iMeshP_createPart(%VAL(imesh), %VAL(imeshp), part, ierr)
-  else
-     partsa = 0
-     call iMeshP_getLocalParts(%VAL(imesh), %VAL(imeshp), partsPtr, partsa, partso, ierr)
-     call c_f_pointer(partsPtr, parts, [partso])
-     part = parts(1)
-  end if
-  call MPI_COMM_RANK(comm, comm_rank, ierr)
-  call MPI_COMM_SIZE(comm, comm_sz, ierr)
-#endif
-  ! create the vertices, all in one call
-  numa = 0
-  call iMesh_createVtxArr(%VAL(imesh), %VAL(numv), %VAL(iBase_INTERLEAVED), posn, %VAL(3*numv), &
-       vertsPtr, numa, numo, ierr)
-  ! fill in the connectivity array, based on indexing from iconn
-  allocate (conn(0:nvpe*nume-1))
-  call c_f_pointer(vertsPtr, verts, [numv])
-  do i = 0, nvpe*nume-1
-     conn(i) = verts(1+iconn(i))
-  end do
-  ! create the elements
-  numa = 0
-  allocate(stats(0:nume-1))
-  statsPtr = C_LOC(stats(0))
-  call iMesh_createEntArr(%VAL(imesh), %VAL(tp), conn, %VAL(nvpe*nume), &
-       entsPtr, numa, numo, statsPtr, numa, numo, ierr)
-  deallocate(stats)
-  deallocate(conn)
-#ifdef USE_MPI
-  ! take care of parallel stuff
-  ! add entities to part, using iMesh
-  call c_f_pointer(entsPtr, ents, [numo])
-  call iMesh_addEntArrToSet(%VAL(imesh), ents, %VAL(numo), %VAL(part), ierr)
-  ! set global ids on vertices, needed for sharing between procs
-  call iMesh_getTagHandle(%VAL(imesh), "GLOBAL_ID", tagh, ierr, %VAL(9))
-  if (iBase_SUCCESS .ne. ierr) then
-     ! didn't get handle, need to create the tag
-     call iMesh_createTag(%VAL(imesh), "GLOBAL_ID", %VAL(iBase_INTEGER), tagh, ierr, %VAL(9))
-  end if
-  call iMesh_setIntArrData(%VAL(imesh), verts, %VAL(numv), %VAL(tagh), vgids, %VAL(numv), ierr)
-  ! now resolve shared verts and exchange ghost cells
-  call iMeshP_syncMeshAll(%VAL(imesh), %VAL(imeshp), ierr)
-  if (comm_rank .eq. 0) then
-     write(0,*) "After syncMeshAll:"
-     write(0,*) "   Number of vertices = ", iv
-     write(0,*) "   Number of entities = ", ie
-  endif
-  call iMeshP_createGhostEntsAll(%VAL(imesh), %VAL(imeshp), %VAL(2), %VAL(1), %VAL(1), %VAL(0), ierr)
-     write(0,*) "After createGhostEntsAll:"
-  endif
-#endif
-  return
-end subroutine create_mesh
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
