[MOAB-dev] AdaptiveKDTree Settings equivalent
Iulian Grindeanu
iulian at mcs.anl.gov
Fri Nov 22 15:16:17 CST 2013
so the idea is that the options are parsed using FileOptions class; pass an option string to the build_tree method
----- Original Message -----
| On 11/22/2013 02:08 PM, Iulian Grindeanu wrote:
| | You can follow these differences maybe, from MeshKit
| | https://trac.mcs.anl.gov/projects/fathom/changeset/4553
| | | Hi all,
| | | New guy here looking for a little aid.
| | | Using a version of code that uses a class, Settings, to
| | | initialize
| | | preferences in the KDTree. It looks as though this structure no
| | | longer
| | | exists in the repo version. Can someone help me understand the
| | | equivalent form of creating preferences for a KDTree in the repo?
| | | Thank you,
| | | Patrick C. Shriwise
| | | Research Assistant
| | | University of Wisconsin - Madison
| | | Engineering Research Building - Rm. 428
| | | 1500 Engineering Drive
| | | Madison, WI 53706
| | | (608) 446-8173
| Thank you!
| Patrick C. Shriwise
| Research Assistant
| Madison, WI 53706
| (608) 446-8173
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131122/e6e2a2fa/attachment.html>
