[MOAB-dev] commit/MOAB: danwu: Test reading HOMME dimension variables, including lev (regular) and ncol (dummy).
commits-noreply at bitbucket.org
Tue Nov 19 13:09:11 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/f255f254828a/
Changeset: f255f254828a
Branch: master
User: danwu
Date: 2013-11-19 20:08:53
Summary: Test reading HOMME dimension variables, including lev (regular) and ncol (dummy).
Affected #: 1 file
diff --git a/test/io/read_ucd_nc.cpp b/test/io/read_ucd_nc.cpp
index 12ca977..50644b8 100644
--- a/test/io/read_ucd_nc.cpp
+++ b/test/io/read_ucd_nc.cpp
@@ -1,6 +1,7 @@
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/ReadUtilIface.hpp"
+#include "TagInfo.hpp"
using namespace moab;
@@ -20,6 +21,7 @@ void test_read_onevar();
void test_read_onetimestep();
void test_read_nomesh();
void test_read_novars();
+void test_read_dim_vars();
ErrorCode get_options(std::string& opts);
@@ -40,6 +42,7 @@ int main(int argc, char* argv[])
result += RUN_TEST(test_read_onetimestep);
result += RUN_TEST(test_read_nomesh);
result += RUN_TEST(test_read_novars);
+ result += RUN_TEST(test_read_dim_vars);
#ifdef USE_MPI
fail = MPI_Finalize();
@@ -75,6 +78,7 @@ void test_read_onevar()
Core moab;
Interface& mb = moab;
std::string opts;
ErrorCode rval = get_options(opts);
CHECK_ERR(rval);
@@ -145,6 +149,7 @@ void test_read_onetimestep()
Core moab;
std::string opts;
CHECK_ERR(rval);
@@ -245,6 +250,59 @@ void test_read_novars()
CHECK_ERR(rval);
+ Core moab;
+ Interface& mb = moab;
+ EntityHandle set;
+ ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
+ CHECK_ERR(rval);
+ std::string orig, opts;
+ rval = get_options(orig);
+ CHECK_ERR(rval);
+ opts = orig + std::string(";NOMESH;VARIABLE=");
+ rval = mb.load_file(example, &set, opts.c_str());
+ CHECK_ERR(rval);
+ std::string tag_name;
+ int var_len;
+ Tag var_tag;
+ const void* var_data;
+ // Check tag for regular dimension variable lev
+ tag_name = "lev";
+ var_len = 0;
+ rval = mb.tag_get_handle(tag_name.c_str(), var_len, MB_TYPE_OPAQUE, var_tag, MB_TAG_SPARSE | MB_TAG_VARLEN);
+ CHECK_ERR(rval);
+ CHECK_EQUAL(true, var_tag->variable_length());
+ CHECK_EQUAL(MB_TYPE_DOUBLE, var_tag->get_data_type());
+ // Check lev tag size and values
+ rval = mb.tag_get_by_ptr(var_tag, &set, 1, &var_data, &var_len);
+ CHECK_EQUAL(26, var_len);
+ double* lev_val = (double*)var_data;
+ const double eps = 1e-10;
+ CHECK_REAL_EQUAL(3.54463800000002, lev_val[0], eps);
+ CHECK_REAL_EQUAL(992.556100000005, lev_val[25], eps);
+ // Check tag for dummy dimension variable ncol
+ tag_name = "ncol";
+ var_len = 0;
+ CHECK_ERR(rval);
+ CHECK_EQUAL(MB_TYPE_INTEGER, var_tag->get_data_type());
+ // Check ncol tag size and values
+ CHECK_EQUAL(1, var_len);
+ int* ncol_val = (int*)var_data;
+ CHECK_EQUAL(3458, ncol_val[0]);
#ifdef USE_MPI
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
