[MOAB-dev] Order of entities returned by iMesh_getEntAdj
Iulian Grindeanu
iulian at mcs.anl.gov
Sun Nov 17 23:39:52 CST 2013
----- Original Message -----
| Hey Moab-Dev,
| Are the adjacent entities returned by iMesh_getEntAdj in any sort of
| order?
from the code, it looks like we are not preserving the order, we are ordering the adjacent entities by their handles (and eliminating the duplicates)
I am not seeing an easy solution if you need a particular order.
Maybe Tim has some suggestions. One solution would be to implement side number method in iMesh;
Or to look at connectivity array and figure out from there the order. I am not sure which one would be easier to do or be more efficient.
Iulian
| For example, consider a mesh of quadrilaterals. Get the edges
| adjacent
| to a given face. If the edges are numbered according the convention
| defined by MOAB
| (http://www.mcs.anl.gov/uploads/cels/papers/P1573A.pdf) I would get
| the array (0,1,2,3) or some shifted version of this. Will
| iMesh_getEntAdj return (0,1,2,3) (or a shifted/flipped version of
| it),
| or could I get something like (1,3,2,0) back (where the edges are not
| ordered with respect to a CW or CCW traverse around the face)?
| Thanks,
| -Chris Eldred
| Chris Eldred
| DOE Computational Science Graduate Fellow
| Graduate Student, Atmospheric Science, Colorado State University
| B.S. Applied Computational Physics, Carnegie Mellon University, 2009
| chris.eldred at gmail.com / celdred at atmos.colostate.edu
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131117/9f192b9a/attachment.html>
