[MOAB-dev] commit/MOAB: tautges: Put some comments in structured3 about what kind of mesh is created.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Fri Nov 15 11:28:22 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/cfbd8c74d184/
Changeset:   cfbd8c74d184
Branch:      tautges/par-owner-fix
User:        tautges
Date:        2013-11-15 18:28:10
Summary:     Put some comments in structured3 about what kind of mesh is created.
Affected #:  1 file
diff --git a/test/parallel/structured3.cpp b/test/parallel/structured3.cpp
index 17ad177..daf065b 100644
--- a/test/parallel/structured3.cpp
+++ b/test/parallel/structured3.cpp
@@ -14,6 +14,12 @@ using namespace moab;
   // Number of cells in each direction:
 int NC;
+/* This mesh creates a box that is NCxNCxNC in global dimension, partitioned among processors
+ * automatically using ScdInterface's SQIJK algorithm.  It checks to make sure there are enough
+ * procs to support this partition method.  After mesh creation, shared vertex resolution is done,
+ * then ghost exchange is done.
 const int ITERS = 50;
 void create_parallel_mesh();
@@ -60,7 +66,7 @@ void create_parallel_mesh()
   times[0] = MPI_Wtime();
   rval = scdi->construct_box(HomCoord(), HomCoord(), NULL, 0, // no vertex positions
                              new_box, NULL, // not locally periodic
-                             &par_data, true, false); // assign global ids & resolve shared verts
+                             &par_data, true, false); // assign global ids, don't resolve shared verts
   CHECK_ERR(rval);
     // get global id tag
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
