[MOAB-dev] Questions about side_number
Iulian Grindeanu iulian at mcs.anl.gov
Wed Nov 13 09:40:55 CST 2013
| | 4) Is there an iMESH function (or MOAB specific extension) that
| | would
| | return similar information to side_number. I need to get access to
| | the
| | information returned by side_number via Fortran 90 and iMESH is
| | what
| | I
| | am currently using to access MOAB via Fortran.
| I don't think there is an imesh extension yet for side_number. If you
| need it, it should be added to the
| iMesh_extensions.h and iMesh_extensions_protos.h files, and
| implemented in the iMesh_MOAB.cpp. It should work for Fortran then
| too.
| Thanks,
| Iulian
Hi Tim,
Do you have any suggestions here? Should we implement it? Is there a better way?
Iulian
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131113/3288f1d0/attachment.html>
