[MOAB-dev] Questions about side_number
Chris Eldred
chris.eldred at gmail.com
Tue Nov 12 20:48:21 CST 2013
Hey Moab-Dev,
I wanted to clarify my understanding of the side_number function for
polygon meshes in 2D. Specifically, given a parent-child element pair;
the function returns three parameters: side number, sense and offset.
For a face-edge pair, these parameters represent:
Side_number =the index of the edge in the array (NOT range) returned
by get_adjacencies(face,1,1,edges_associated_with_face)
Sense = the orientation of the normal of the edge with respect to the
face (ie positive for outward, negative for inward)
For a face-vertex pair, these parameter represent:
Side_number = the index of the vertex in the array (NOT range)
returned by get_adjacencies(face,1,0,vertices_associated_with_face)
Sense = 0
For an edge-vertex pair, these parameters represent:
returned by get_adjacencies(edge,1,0,vertices_associated_with_edge)
Sense = the orientation of the tangent of the edge with respect to the
vertex (ie positive for towards, negative for away)
Questions:
1) Is this understanding correct?
2) What does the offset parameter represent in these cases?
3) Is side_number working for meshes that contain polygons with
repeated vertices (like those used in MPAS)? My preliminary testing
based on the above understanding says no, but I wanted to check. If
not, will it be working soon?
4) Is there an iMESH function (or MOAB specific extension) that would
return similar information to side_number. I need to get access to the
information returned by side_number via Fortran 90 and iMESH is what I
am currently using to access MOAB via Fortran.
Chris Eldred
Chris Eldred
DOE Computational Science Graduate Fellow
Graduate Student, Atmospheric Science, Colorado State University
B.S. Applied Computational Physics, Carnegie Mellon University, 2009
chris.eldred at gmail.com / celdred at atmos.colostate.edu
