[MOAB-dev] commit/MOAB: danwu: For GATHER_SET=<gatherSetRank> read option, allow ParallelComm::gather_data() to specify a root processor to gather data. Also, changed new/delete to malloc/free for the temp buffer.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Thu Nov 7 12:02:27 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/8c3d9712faec/
Changeset:   8c3d9712faec
Branch:      master
User:        danwu
Date:        2013-11-07 19:02:15
Summary:     For GATHER_SET=<gatherSetRank> read option, allow ParallelComm::gather_data() to specify a root processor to gather data. Also, changed new/delete to malloc/free for the temp buffer.
Affected #:  2 files
diff --git a/src/parallel/ParallelComm.cpp b/src/parallel/ParallelComm.cpp
index 7c3f5c7..8efc777 100644
--- a/src/parallel/ParallelComm.cpp
+++ b/src/parallel/ParallelComm.cpp
@@ -8728,7 +8728,7 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
   ErrorCode ParallelComm::gather_data(Range &gather_ents, Tag &tag_handle,
-				      Tag id_tag, EntityHandle gather_set)
+				      Tag id_tag, EntityHandle gather_set, int root_proc_rank)
     int dim = mbImpl->dimension_from_handle(*gather_ents.begin());
     int bytes_per_tag = 0;
@@ -8743,7 +8743,7 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
     ptr_int = (int*)(senddata) + 1 + gather_ents.size();
     rval = mbImpl->tag_get_data(tag_handle, gather_ents, (void*)ptr_int);
     std::vector<int> displs(proc_config().proc_size(), 0);
-    MPI_Gather(&sz_buffer, 1, MPI_INT, &displs[0], 1, MPI_INT, 0, comm());
+    MPI_Gather(&sz_buffer, 1, MPI_INT, &displs[0], 1, MPI_INT, root_proc_rank, comm());
     std::vector<int> recvcnts(proc_config().proc_size(), 0);
     std::copy(displs.begin(), displs.end(), recvcnts.begin());
     std::partial_sum(displs.begin(), displs.end(), displs.begin());
@@ -8752,14 +8752,14 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
     //std::copy_backward(displs.begin(), --displs.end(), displs.end());
     displs[0] = 0;
-    if (rank() != 0)
-      MPI_Gatherv(senddata, sz_buffer, MPI_BYTE, NULL, NULL, NULL, MPI_BYTE, 0, comm());
+    if ((int)rank() != root_proc_rank)
+      MPI_Gatherv(senddata, sz_buffer, MPI_BYTE, NULL, NULL, NULL, MPI_BYTE, root_proc_rank, comm());
     else {
       Range gents;
       mbImpl->get_entities_by_dimension(gather_set, dim, gents);
       int recvbuffsz = gents.size() * (bytes_per_tag + sizeof(int)) + proc_config().proc_size() * sizeof(int);
       void* recvbuf = malloc(recvbuffsz);
-      MPI_Gatherv(senddata, sz_buffer, MPI_BYTE, recvbuf, &recvcnts[0], &displs[0], MPI_BYTE, 0, comm());
+      MPI_Gatherv(senddata, sz_buffer, MPI_BYTE, recvbuf, &recvcnts[0], &displs[0], MPI_BYTE, root_proc_rank, comm());
       void* gvals = NULL;
@@ -8772,13 +8772,15 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
         rval = mbImpl->tag_iterate(tag_handle, gents.begin(), gents.end(), count, gvals);
         assert(NULL != gvals);
         assert(count > 0);
-        if ((size_t)count != gents.size())
+        if ((size_t)count != gents.size()) {
           multiple_sequences = true;
+          gvals = NULL;
       // If gents has multiple sequences, create a temp buffer for gathered values
       if (multiple_sequences) {
-        gvals = new (std::nothrow) char[gents.size() * bytes_per_tag];
+        gvals = malloc(gents.size() * bytes_per_tag);
@@ -8809,8 +8811,8 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
         assert(start_idx == gents.size());
-        // Delete the temp buffer
-        delete[] (char*)gvals;
+        // Free the temp buffer
+        free(gvals);
diff --git a/src/parallel/moab/ParallelComm.hpp b/src/parallel/moab/ParallelComm.hpp
index e02d4b3..e4217ce 100644
--- a/src/parallel/moab/ParallelComm.hpp
+++ b/src/parallel/moab/ParallelComm.hpp
@@ -899,7 +899,7 @@ namespace moab {
     //! get the verbosity level of output from this pcomm
     int get_debug_verbosity();
-    /* \brief Gather tag value from entities down to root proc
+    /* \brief Gather tag value from entities down to a specified root proc
      * This function gathers data from a domain-decomposed mesh onto a global mesh
      * represented on the root processor.  On the root, this gather mesh is distinct from
      * the root's domain-decomposed subdomain.  Entities are matched by global id, or by
@@ -910,9 +910,10 @@ namespace moab {
      * \param tag_handle Tag whose values are being gathered
      * \param id_tag Tag to use for matching entities (global id used by default)
      * \param gather_set On root, set containing global mesh onto which to put data
+     * \param root_proc_rank Rank of the specified root processor (default rank is 0)
     ErrorCode gather_data(Range &gather_ents, Tag &tag_handle,
-			  Tag id_tag = 0, EntityHandle gather_set = 0);
+			  Tag id_tag = 0, EntityHandle gather_set = 0, int root_proc_rank = 0);
     /* \brief communicate extra points positions on boundary
      * This function is called after intersection of 2 meshes, to settle the
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
